 Old 09-15-2011, 08:26 PM   #1
High on PSI's Avatar
Posts: 58   (View Stats)
High on PSI has a spectacular aura aboutHigh on PSI has a spectacular aura about
Groaned at 13 Times in 5 Posts
Default MS6 - 18 x 8.5 +38?
Hey guys, I'm sure there is a thread around but I needed an answer asap so I can go out and buy the new wheels!
I have my rear guards rolled on my 06 MS6, will the 18 x 8.5 +38 with 235/40/18 fit my car?
If it makes any difference... my car is from Australia
If anyone can source a thread link for me I'm more then happy to read through it.
Originally I was going with a +44 offset and I know that it's sure to fit but I'm wanting something more "hellaflush"
Thanks in advance!
High on PSI is offline   Reply With Quote
 Old 09-15-2011, 11:15 PM   #2
bump..
 Old 09-15-2011, 11:44 PM   #3
m4tic's Avatar
Posts: 4,928   (View Stats)
EvoX wheels? Sure go for it.
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
 Old 09-16-2011, 12:26 AM   #4
Nah, Rota G-Force.
Are Evo X wheels the same size?
 Old 09-16-2011, 11:53 AM   #5
m4tic's Avatar
yep... make sure you get a good fender roll
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 09-16-2011, 07:03 PM   #6
I can't find any examples of Evo X wheels on MS6's. Could you link me? Would greatly appreciate it!
Do alot of people have Evo X wheels on their MS6's?
 Old 09-17-2011, 11:03 AM   #7
m4tic's Avatar
a couple... they are around, most likely in the aggressive fitment thread
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 09-20-2011, 08:27 PM   #8
So I got the Rota G-Forces 18x8.5 +38, 235/40/18 tires.
There's no scrubbing with a driver and a passenger, but when theres 2 people in the back it scrubs quite abit... I tore some of my edge / corner / sidewall off last night, does it ruin how the tire performs now?
I will definitely be getting my guards rolled before I install the Eibach springs
 Old 09-20-2011, 09:53 PM   #9
Modelcsr08@yahoo.com's Avatar
Posts: 243   (View Stats)
Modelcsr08@yahoo.com has a reputation beyond reputeModelcsr08@yahoo.com has a reputation beyond reputeModelcsr08@yahoo.com has a reputation beyond reputeModelcsr08@yahoo.com has a reputation beyond reputeModelcsr08@yahoo.com has a reputation beyond reputeModelcsr08@yahoo.com has a reputation beyond reputeModelcsr08@yahoo.com has a reputation beyond reputeModelcsr08@yahoo.com has a reputation beyond reputeModelcsr08@yahoo.com has a reputation beyond reputeModelcsr08@yahoo.com has a reputation beyond reputeModelcsr08@yahoo.com has a reputation beyond repute
Im running a 18x8 with 37mm offset with 235/40/18s on my car, I had to roll mine and im running a stock suspension, I took a baseball bat and rolled the hell out of them and it did the job. I learn my lesson after going over some rail road tracks and took a little piece of meat out of my tire, you might as well roll them just for insurance purposes and if your going to lower it.
Cobb AP: Stage2+SUR+TIH+IC 93|SURE: Aeros|Sidewinder|Charge Tubes|Return|ShortCut|CounterShift|M6 RacePipe|TorqR6 RMM|TurboSmart Dual Port BOV|CP-E TMIC|MagnaFlow CB 2.5'|StopTech D&S|HAWK HPS|AutoTech Internals|Denso ITV22|
Modelcsr08@yahoo.com is offline   Reply With Quote
 Old 09-20-2011, 10:20 PM   #10
Hmm that's odd cause with only me in the car, it's near impossible to get it to scrub.
My tire is worn all around, on the corner of the sidewall.. it seems to have ripped some of the tread pattern off, do you think its going to affect my cornering and hard turning?
 Old 09-20-2011, 10:31 PM   #11
m4tic's Avatar
Make sure you roll the fenders at the section that is directly behind the doors... On suspension compression the rear wheels arc toward the front side of the fenders, not straight up and down.. Because of the trailing arm
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 09-20-2011, 10:30 PM   #12
It depends how bad it is, I couldn't tell you to be honest if you had a picture I could tell you, Im just about the only person who rides in my car and it still happened, I would go ahead and roll them fenders good cause otherwise in the near future when you get new tires they are going to get tore up because of that reason, and if you have insurance on the tires it wont get coved cause of that reason. Just rent a fender roller it will get the job done, you can rent one from streetunit, or you can use a baseball bat if your looking to not spend no money, also besure to have a heat gun so you dont crack your paint!
 Old 09-21-2011, 01:10 AM   #13
I'll be getting the full fender rolled, I can't rent from SU because I'm in Australia
The grooves circled in red have been torn off, and it has happened to about 3/4 of the tire.
 Old 09-21-2011, 02:54 AM   #14
To be exact, I took a photo.
 Old 09-21-2011, 03:15 AM   #15
Brian MP5T's Avatar
Posts: 1,101   (View Stats)
That isn't that bad, but I bet it tore the shit out of the fender as well...
To run silly big tires you need to have a suspension that can adjust camber, or control links that can be adjusted in and suspension that can adjust camber.
You see how the tire is tucked in? The top of the rear tire fits because it is tilted (Camber) in
Last edited by Brian MP5T; 09-21-2011 at 04:50 AM. Reason: FINE!!! FUCKING WIDE BODY PICTURES ARE UNWELCOMED!!! I GET IT!!! FUUUUCCKKK!!!
 Old 09-21-2011, 03:56 AM   #16
I don't have a silly big tire though, and nah it didn't tear the fender. Hopefully it doesn't happen anymore with my guards rolled
 Old 09-21-2011, 04:40 AM   #17
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
horrible example brian, thats a widebody kit haha
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
 Old 09-21-2011, 04:49 AM   #18
Brian MP5T's Avatar
True, but it gave me the chance to post up an awesome picture..
The Kit is only rated for a 235 wide tire... so in actuality the fact that he is running a wide wide tire... it's a bit the same as the OPs situation.
 Old 09-23-2011, 04:23 AM   #19
Just wondering if I need the front guards rolled? I'm getting the rear tomorrow and if I need to front done might aswell do it on the spot
 Old 09-24-2011, 08:41 PM   #20
m4tic's Avatar
with proper negative camber up front (need adj balljoints) you'll be fine
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 09-28-2011, 04:31 AM   #21
This is it, lowered on Eibach springs.
One thing that is bothering me, when I was on stock height the front seemed to stick out more than the rear, now that it's lowered the front still stick out more than the rear. Is this a natural thing with our car?
 Old 09-28-2011, 01:07 PM   #22
m4tic's Avatar
i think its an illusion from the uneven fender layout
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 09-29-2011, 12:57 AM   #23
It's not an illusion as I can actually see that it's poked out more at the front, it's noticeable.. BUT I think that it's slowly going away due to springs settling it?
 Old 10-04-2011, 07:07 AM   #24
exftw's Avatar
Posts: 168   (View Stats)
exftw has a reputation beyond reputeexftw has a reputation beyond reputeexftw has a reputation beyond reputeexftw has a reputation beyond reputeexftw has a reputation beyond reputeexftw has a reputation beyond reputeexftw has a reputation beyond reputeexftw has a reputation beyond reputeexftw has a reputation beyond reputeexftw has a reputation beyond reputeexftw has a reputation beyond repute
hmmm i have those same exact rims with 235/40 tires... and my fenders are ROLLLLLLED saves lives wen ur slammed.... cant wait to install my coilovers lol.
-2006 Mazdaspeed6-
Engine: CPE FMIC, Sure Aeros, Sure Sidewinder, ATP DP, GHL CBE, TurboSmart BOV, Cobb AP, AT HPFP internals, DNP Mani, OCC
Drivetrain: SURE Dread & Jugg, CPE RMM, TT FMM, Spec Clutch, TWM SS (s2)
Suspension/Brakes: BC Coils, EBC Ultimax Rotors, Hawk HPS Pads
Exterior: NEXTMod Lip Kit, VG Sharkfin, APR Splitter Rods, Rota GForce 18x8.5 with 225/40/18 Hankook Ventus V12
Upcoming: GT3071R ...
exftw is offline   Reply With Quote
 Old 10-10-2011, 12:14 AM   #25
Settled in now, cant be any more happy!
http://i53.tinypic.com/9q9r8j.jpg
The Following User Says Thank You to High on PSI For This Useful Post:
Docnox (10-10-2011)
 Old 10-10-2011, 05:06 PM   #26
Docnox's Avatar
Posts: 1,435   (View Stats)
Docnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the world
Groans: 35
I think those wheels look awesome, aggressive as hell.
'06 Speed 6
Black Mica
Mazdaspeed SRI, Medieval inlet, Eibach Springs, Magnaflow cbe,
3 ebay catless dp, SU rmm, HKS ssqv, JBR stage 2 ssp
Altered Customs fmic, Autotech fp internals
Cobb AP, Stage 2+ 93 tweaked
Centric blanks, EBC red pads
Lotek center gauge pod: AEM wideband, Autometer boost and volts
Tints, blacked emblems, spec-v front lip, Shark fin
Redline MT-90, ITV-22s, Matt Damond OCC
13.66@102 Lebanon Valley 4/10/11 (sri, tp, rmm, ap)
DO Meth kit waiting on install
Docnox is offline   Reply With Quote
 Old 11-25-2013, 09:39 PM   #27
yldcrd's Avatar
Posts: 23   (View Stats)
yldcrd has a spectacular aura aboutyldcrd has a spectacular aura aboutyldcrd has a spectacular aura about
Sorry to bring up an old thread.
Have you got more pics of these wheel/car combo? I cant find anything on the net with 18 x 8.5 +38 offset.
yldcrd is offline   Reply With Quote
Page generated in 0.43134 seconds with 26 queries
