 Old 03-01-2014, 09:51 AM   #1
Atomic41's Avatar
Posts: 1,174   (View Stats)
Default Sand my oem wheel
I want to do a paint job on my stocker of my MS3.
I want to use my drill to sand (over by hand) all the surface of my wheel ... which tool do you suggest to me.
I'm not equipped to sandblast ... (I know it's the way)
Which grade of sand paper do I need ... to made the best job possible ... after I will try plastidip + glossifer. It's for my winter wheel ... 2 years in a row I made my paint wheel with (canadian tire primer) + (duplicolor paint). After each winter ... the wheel look like crape so I want to made the best I can. With a sand job + good primer (zinc) + plastidip (5 coats) + glossifer (2 coats)
Thanks for your help
2008 MAZDASPEED3 Black
Stratified Tuned / Stage 2
The Following User Says NO Thank You to Atomic41 For This Un-useful Post:
helmetface (03-01-2014)
 Old 03-01-2014, 11:50 AM   #2
white'swhiteMPS's Avatar
Posts: 639   (View Stats)
white'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the world
Sand job sounds painfull
2012 MS3 CWP- Cobb AP, CS CBE, CS SRI/TIH, UR testpipe, Corksport Downpipe, JBR 88 duro RMM, NGK step colder plugs, Autotech HPFP, ETS TMIC, Koni Yellows, Swift Spec-R Springs, Forge V1, Corksport Hoodscoop (cooler BATs, yo)
Enkei RPF1 (gold) 17x9 +45 w/ Conti procontacts 245/45
Freektuned- E85 4/8gal mix
white'swhiteMPS is offline   Reply With Quote
 Old 03-01-2014, 07:29 PM   #3
SyntheticAtmosphere's Avatar
Posts: 193   (View Stats)
SyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond repute
I have been sanding my OEM rims for a repaint as well. Takes me about 4 hours per rim. I have been using 220 on my air powered orbit sander on about 25% of the wheel. The rest I do by hand with 220 followed by course and medium steel wool.
I have done a lot of refinishing in my time, prep work is the most important. Dont complain, you arent hand sanding the Speed6 15 spoker rims
SyntheticAtmosphere
'06 Speed6 Whitewater Pearl (COBB AP v2, CS s2 SRI/TIP, Autotech HPFP, Cp-e RMM&RDM, Fidanza/LuK, homebrew Testpipe&OCC) next...meth habit
If it feels good, do it...Even if you shouldn't!
SyntheticAtmosphere is offline   Reply With Quote
 Old 03-01-2014, 07:35 PM   #4
GoSpeed3Go's Avatar
Posts: 493   (View Stats)
GoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the world
Groaned at 27 Times in 8 Posts
dude, if youre plastidipping you dont need to sand youre wheels. but i see youve already jacked them up with a rattle can job, for that just get some aircraft stripper. it should make that rattle can shit wipe right off.
https://www.facebook.com/NorCalTintZone
instagram: sharpdetails
GoSpeed3Go is offline   Reply With Quote
 Old 03-02-2014, 09:21 AM   #5
Atomic41's Avatar
Which spray gun ... do you recommend to plastidip my wheel ???
Wargner FLEXiO 570 Sprayer (150$ CAN)
or
Earlex HV5500 (350$ CAN)
 Old 03-02-2014, 09:26 AM   #6
or
if youre willing to pay that much, just have them powdercoated. otherwise just use the plastidip cans. no need for a spray gun unless youre doing the whole car
 Old 03-06-2014, 05:17 PM   #7
Remixaflip's Avatar
Posts: 41   (View Stats)
Remixaflip has a spectacular aura aboutRemixaflip has a spectacular aura aboutRemixaflip has a spectacular aura about
I sanded my wheels by hand when I had a honda. I can tell you that you do not want to be sanding them by hand. The coating that they put on rims are extremely thick and extremely durable. You will have a hard time, sore hands, and a sore back just from properly sanding two wheels. If you are that adimant about painting them yourself, you would be better off paying to have them sandblasted ( or whatever media ) by some local shop. I guarantee itll be worth it both in time and final product. 90% of the finished product is in the prep work.
Running OTS Stage 1+ - CS TMIC, CS SRI/TIP, Autotech Internals, HKS CBE, AP.
Soon to come - Cobb RMM, Cobb DP, WMI, Stratified tune.
Remixaflip is offline   Reply With Quote
The Following 2 Users Say Thank You to Remixaflip For This Useful Post:
Atomic41 (03-06-2014), natieb (03-06-2014)
 Old 03-09-2014, 05:51 PM   #8
plak424's Avatar
Posts: 298   (View Stats)
plak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the world
If you are plasti-dipping then no sanding required.
These pics are just black plasti-dip with no prep work beforehand. The first pic is right after, the second is about a year and a half later with new england winter.
Mods: JBR 3" WP, Cobb AP, JBR SSP, JBR 88d RMM, JBR Rear Sway, JBR Camber Arms, Autotech's, UR DP/TP, CS OCC, DO STG1 soon...
plak424 is offline   Reply With Quote
 Old 03-09-2014, 06:35 PM   #9
Bmdisanto's Avatar
Posts: 220   (View Stats)
Bmdisanto is the leader of the worldBmdisanto is the leader of the worldBmdisanto is the leader of the worldBmdisanto is the leader of the worldBmdisanto is the leader of the worldBmdisanto is the leader of the worldBmdisanto is the leader of the worldBmdisanto is the leader of the worldBmdisanto is the leader of the worldBmdisanto is the leader of the worldBmdisanto is the leader of the world
Yeah just use the cans like stated many times above no need to sand only prep is cleaning, I used soapy water to clean them then used Naptha (basically lighter fluid) to remove any oils or leftover contaminates and it evaporates in a couple seconds then sprayed about a can for each wheel, pull them off the car and use index cars around the lip to stop overspray from getting on the tires
2008 Black mica MS3 - BNR S3 [] JBR RMM/PMM [] Cobb AP [] Autotech Internals [] Stratified 3 port EBCS [] JBR 3" widepath intake [] Catless Fleabay DP [] CX piping TR8 core [] Freektuned []
Bmdisanto is offline   Reply With Quote
 Old 03-09-2014, 06:51 PM   #10
Atomic41's Avatar
Ok but if i got some relief on my wheel i need to sans this part to have an even wheel all around and a nice finish
 Old 03-09-2014, 07:02 PM   #11
Bmdisanto's Avatar
Ok but if i got some relief on my wheel i need to sans this part to have a heaven wheel all around and a Nice finish
Envoyé de mon HTC One X en utilisant Tapatalk
You could sand it down to be even and the plastidip is thick enough to cover the minor imperfections
 Old 03-09-2014, 07:08 PM   #12
Atomic41's Avatar
 Old 03-09-2014, 08:14 PM   #13
jbmazda6's Avatar
Posts: 1,230   (View Stats)
jbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the world
I'm using a ryobi multi-tool with 80 and 120 grit triangle sanding pads to get off the previous layers of paint and get down to the bare metal. I'm going to use metal primer after I get them all sanded down and then use spray paint and a clear coat... first time tackling a painting project like this so I hope it goes well! This is on speed6 wheels so it's taking forever. Also plan on filling in some curb rash with bondo filler.
JBR: Whale Penis, SSP+Weight+Bushings+Knob, Boost Tubes, Bypass Valve Hose, TMM, PMM, RMM, OCC, TIG's, Small Battery Tray
Other: Stratified 3-Port EBCS, Stratified Guardian Angel, Cp-e Catted Downpipe, Cp-e Top Mount Intercooler, Cp-e Rear Diff Mount, Autotech Internals, H&R Coilovers
Sponsored By: JamesBaroneRacing.com
jbmazda6 is offline   Reply With Quote
Video: Sand Flea robot goes where your R/C car can't Haltech Automotive News 0 04-03-2012 06:20 PM
Got Some Sand In My Vag & Dont Know What To Do Wicked White Mazdaspeed3/6 General Discussion 170 02-02-2012 12:15 PM
Looks like sand sallyspeed3 Car Detailing 2 05-12-2011 05:20 AM
Cayman Sand: Nor'Ida claims its latest victim Haltech Automotive News 0 11-18-2009 04:50 PM
CLEAN THE SAND OUT' YOUR GINA RANDY Scatt Nasty Mazdaspeed3/6 General Discussion 203 08-01-2009 07:53 PM
Page generated in 0.34393 seconds with 28 queries
