![]() Join Date: Dec 2018 Location: Oranjestad, Aruba
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score any member here know if there are workshop manuals for this engine I would certainly appreciate it . |
| Not Ranked : 0 score Have you searched more than 2min ? There is a lot of infos here including a very detailed how to vvt. Especially if you get VIP. Some good points is that you need timing tool, new washers and torque to yield bolts and a new VVT actuator. The cx7 turbo engine is the same L3VDT than any speed3 or 6
(Thread Starter) | Not Ranked : 0 score Lol, brother I have searched, for a few minutes but on google so I did not find anything so that is why I came here. thanks for the heads up . |
![]() Join Date: May 2010 Location: SLC, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score There are service manuals and engine rebuild manuals in VIP.
(Thread Starter) | Not Ranked : 0 score Ok, I would think that would be the wisest thing to do as soon I'm ready to dig in the engine...guess i'll be a VIP soon |
| BMW says no more manuals, M cars capped at 600 hp | Haltech | Automotive News | 0 | 07-06-2015 11:40 AM |
| Mazda 6/MPS manuals | MaverickX3 | MazdaSpeed 6 - How-To's | 2 | 01-13-2011 08:48 AM |
