> CX-7 > General Lounge + New Member Welcome
Like Tree4Likes
  • 1 Post By Raider
  • 1 Post By Raider
  • 2 Post By torquemaniac
 Old 12-14-2010, 11:59 AM   #1
Default CX-7 FAQ Thread
Does the CX-7 need 91 octane or higher?
Yes, for 2007 models only. For 08 models and up, 91 is not a requirement but it is recommended for the best performance. Got Turbo? Please use 91+ no matter what year. It will run better.
I'm having an issue with my CX-7, what should I do?
First, before posting a thread search on the issue and see if you can find an answer for your problem or if other members here have experienced the problem you're having or if there is a TSB (Technical Service Bulletin) that outlines the problem and offers a fix.
Issues and Troubleshooting Forum
My tires have worn out, should Mazda replace them or will I have to replace them myself?
Now, this question has been asked more than enough times. The best thing to do is come out of pocket and get some tires that will last much longer than the OE tires, because chances are you will just get another set of those that will wear out in the same amount of time. ORM tires suck. Period.
Tires, Wheels, and Brakes Section
My brakes are down to the metal, can I upgrade? Should I get just get OE pads? Rotors?
Brake pad and Rotor replacement megalist
I want to change the oil myself.
How to: Change your CX-7's oil
Where is/How do I change my cabin air filter?
You can order a replacement from the dealer or online for $20 or less.
How To: Replace Cabin Air Filter
I want to change out my stock sound system, what are the speaker sizes? BOSE?
First, the base 4 speaker sound system has 4 6x8/5x7 speakers. BOSE however has 2 9" Bass drivers in the front door, 5 3 1/2" Mid/High range drivers in the dash and D-Pillar, and 2 6 1/2" mid-range drivers in the rear doors. In order to replace the headunit on BOSE models you need the MAZATO from PAC. The BOSE amplifier is located behind the 2nd row of seats in between it and the spare tire.
How do I remove the door panels?
How To: Remove door panel
Need OEM Replacement parts? New bumper? Interior trim?
ClassicMazdaParts.Net
CX-7 Owners Manuals and Maintenance Schedules .PDF
-CX-7 Owner's Manual
-2007
-2008 With NAV Manual!!!
-2009
-CX-7 Maintenance Schedule
-2007
-2008
-2009
I'll be updating this as I go along.. throw out any suggestions and links.
CX-7 Crash Test Scores
-IIHS Crash test ratings
Frontal / Good
Side
/ Good
Rear
/ Marginal
IIHS-HLDI: Mazda CX-7
-NCAP Crash test ratings
Frontal / Five Stars
Side / Five Stars
Rollover / Four Stars
http://www.safercar.gov/
MCX-7 Abbreviations
BPV | ByPass Valve
BOV | Blow Off Valve
CEL | Check Engine Light
CAI | Cold Air Intake
SRI | Short Ram Intake
TMIC | Top Mount InterCooler
FMIC | Front Mount InterCooler
DSC |Directional Stability Control
TCS | Traction Control System
EBD | Electronic Brakeforce Distribution
CX-7 Quick Facts
-Performance Numbers
0-60 | 7.7 sec to 8.5
60-0 | 112.9ft
Slalom | 64.3mph
Bulbs: yoinked from the Sylvanna website
OSRAM SYLVANIA - Replacement Guide - Start
2007 MAZDA CX-7 (With HID (high intensity discharge) headlamps)
Low beam headlamp
HID-D2S
High beam headlamp
9005
9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9005EB EcoBright - Your Environmental Choice
9005XV XtraVision Halogen - The Brighter Light
9005CB Cool Blue Halogen - The Whiter Light
Parking light
1157A
1157AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
1157ALL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
1157A
Rear turn signal
992 (7440A)
Tail light
7443
Stop light
7443
High mount stop light
LED
Fog/Driving light
H11
H11ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H11XV XtraVision Halogen - The Brighter Light
License plate
2825
2825LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
7440
7440ST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
7440LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
2825
Rear sidemarker
2825
Map light
2825
Dome light
DE3175
DE3175LL Long Life Upgrade: Up to twice the life of the standard lamp
7443LL Long Life Upgrade: Up to twice the life of the standard lamp
Trunk/Cargo area
DE3175
-OE tire size
235/60/R18
-Optional tire size
255/55/18
-Recommended Oil
Full synthetic 5W-30 Rotella T
Turbo differences with CX-7 and MS3/MS6
K04 Differences: K0422-582 vs. K0422-881 / K0422-882
bigmike_878 (07-12-2011), Black(M) (01-14-2011), czbo (10-29-2015), ecrim (03-23-2011), mikomi (12-31-2010), nmdonahoe (09-01-2013)
 Old 12-14-2010, 12:09 PM   #2
Feel free to post anything that may need to be added.
 Old 12-14-2010, 12:17 PM   #3
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
good shit
wat ever happened to Mazoom?
 Old 12-14-2010, 12:19 PM   #4
He is on here now as a different user. Not sure what it is, the thread vaporized when the forum crashed. I just wanted to make sure he got credit for the info.
Alpha Wolf likes this.
 Old 12-17-2010, 08:41 AM   #5
Zdraveca's Avatar
Posts: 3,888   (View Stats)
Groans: 145
Tranny fluid is to be changed every 40k miles and you MUST do the flush not only the drain and fill up because there is about 1gallon of old crappy fluid that's left if you don't do the flush.
2011 MS3"Princess GRU"
GT2876r
E85 FREEKTUNE
The Following 2 Users Say Thank You to Zdraveca For This Useful Post:
mikomi (12-30-2010), Raider (12-17-2010)
 Old 03-23-2011, 09:29 AM   #6
ecrim's Avatar
Posts: 3   (View Stats)
ecrim is an unknown quantity at this point
I read the frequently asked question point above about replacing the Bose stereo. It was suggested that you need the Mazato by pac. I went to the site and all that comes up are interfaces for Ipod, smart phones, and mp3 players. I'm not sure I understand how that helps with stereo replacement. I've got a 2010 cx-7. I was wondering what would be the repercussions of just replacing the 9 inch woofer with something tighter sounding. I could just cut off the speaker harness interface and connect the wires to the new woofers. That's the first question. The second question is if you pull the bose system out entirely, do you lose the rear view camera that is installed as well as the navigation that is installed or are they separate systems?
EJCJ
ecrim is offline   Reply With Quote
 Old 03-23-2011, 09:34 AM   #7
If you have questions, start a new thread in the interior section and you will get more responses.
 Old 01-01-2012, 02:13 PM   #8
ryandlor's Avatar
Posts: 126   (View Stats)
ryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant future
Any possibility of getting a sticky on the type of AWD system the 7 uses?
2009 CX-7
Platinum Silver Metallic
AWD
ryandlor is offline   Reply With Quote
 Old 01-01-2012, 02:17 PM   #9
Got a thread link?
lvdukerider likes this.
 Old 01-01-2012, 09:20 PM   #10
ryandlor's Avatar
Nope, was looking for one...
2009 CX-7
AWD
 Old 06-24-2014, 06:48 PM   #11
Ozynigma's Avatar
Posts: 743   (View Stats)
@Raider
How about adding this thread to the CX7 faqs.
 Old 06-25-2014, 11:27 AM   #12
Originally Posted by Ozynigma View Post
@Raider
added~
 Old 08-06-2014, 08:08 PM   #13
torquemaniac's Avatar
Posts: 733   (View Stats)
My contribution...
Jeff19342 and epicjin like this.
2011 CX-7 AWD 2.3 turbo
The Following 4 Users Say Thank You to torquemaniac For This Useful Post:
AboveAverageJoe (07-29-2017), jaguar_mike (02-06-2016), Ozynigma (08-06-2014), Raider (08-07-2014)
 Old 11-23-2015, 04:19 PM   #14
Ozynigma's Avatar
Here is the engine workshop manual also courtesy of torquemaniac
The Following User Says Thank You to Ozynigma For This Useful Post:
 Old 02-06-2016, 02:35 PM   #15
jaguar_mike's Avatar
Posts: 18   (View Stats)
jaguar_mike has a little shameless behaviour in the past
Hi,
Great resource manual, you just save me so much time. Now I don't have to wait for one to come and see if it has what I need.
Thanks agan,
M<e
jaguar_mike is offline   Reply With Quote
 Old 02-06-2016, 02:47 PM   #16
Hi,
I am going to be able and need both of these manuals. I pulled the engine and transmission from mine, both needed repaired and fixed. I bought the car at the auction and the description said that it needed "mechanical" I guessed that it needed a head, I could only spin the crank to see if it had thrown a rod, it spun ok so no block. But I got the car home got it running sounded good but did have smoke off and on. I think from turbo or just need to be run from sitting. The engine would tack evenly at 5K. So I took it for a ride up the road. The transmission would no shift in normal and only changed shifts using the slap manual mode, hate that system. Is it possible for the transmission to act up and seem like the car has no power at all making you think that the engine is bad?
 Old 02-10-2016, 04:13 AM   #17
Ozynigma's Avatar
It's possible but unlikely. Maybe the ECU is in limp home mode due to transmission problem. Could be a Comms failure between the ECU and TCU.
You need to get it checked out by Mazda.
jaguar_mike (02-10-2016)
Page generated in 0.40707 seconds with 28 queries
