![]() Join Date: Nov 2010 Location: Alhambra
Rep Power: 524 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 237
Groaned at 35 Times in 14 Posts
(Thread Starter) | Not Ranked : 0 score (Mods: should this thread be in another forum? we don't have a maintenance one and the general one seemed better than the other specific ones...) |
![]() Join Date: Nov 2010 Location: northwest arkansas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,067
Groans: 103
| Not Ranked : 0 score dude, go download the manual from the vip section. it will tell you how to do it. don't touch the bulb with bare hands if it's hid.
__________________ 2008 ms3 mit: hypertech tune, pg sri, corksport tip, jbr(80 tmm, 88 rmm, 80 pmm), jbarone bushings + heavy shift knob, diy sts, sure ssp, sensen shocks, jbr rsb, ford transfluid, aura 5 channel amp, jbl gt speakers, 6" bazooka sub, diy mudflaps, DDM 3000k HID fog kit, 6000k lows [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to tddvrrn For This Useful Post: | Raider (06-04-2011) |
![]() Join Date: Nov 2009
Rep Power: 155 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score just did this about a week ago. easy money. 1. lower wheel well shields. remove them from bumper work your way up to the halfway point. gives you plenty of room to get in there. i had the car on jackstands as i was going to take the bumper off anyway to check FMIC clamps. 2. theres a grey looking cover with a tab on it. turn it counter clockwise. 3. large silver igniter, turn cc. 4. carefully, pop spring clips off. slide out bulb. pay attention to tab location. 5. with gloves on, grab new bulb and insert it with tabs facing how they were and while holding the bulb with pointer finger, pop the spring clip back on. 6. reverse order the rest. i got some philips 6000k D2S. i run my lights 24/7 and after a few years seemed dull to me. the difference is totally noticeable, much brighter, and they havent even seen the 50hr burn in yet. so im expecting much brighter in the next few weeks...
__________________ 2011.75 BMW E90 M3 El-Superbeast-O |
![]() Join Date: Jan 2011
Rep Power: 0 ![]() ![]() Thanks: 6
| Not Ranked : 0 score ^^ good instructions tons easier once you get familiar with the way the springs and tabs move. Didn't you have a CAI? If so, the stock box should be out along with all that plastic labyrinth mess and there should be lots of space in the drivers side bulb? (which side bulb, btw?) It was a total b8tch for me the first time but I was new and on a time crunch. In retrospect, changing the bulbs (and especially taking off/replacing that clip) is more of a "if it seems like its too much work - you're probably doing it wrong" kinda thing. Once you figure out exactly how to apply pressure to the clip, it moves fairly easily. Oh and there's that rubber gasket thing you'd have to remove to get to the lightbulb housing |
![]() Join Date: Nov 2010 Location: Marion, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 413
Groans: 46
| Not Ranked : 0 score If, by Xenons, you mean the blue colored halogens, then yeah, you should be able to. If you mean the factory HID bulbs, I wouldn't mess with it and take it to the dealership |
i got better things to do with $80/hr labor money and the $300 whatever else they "find" that has to be fixed before i leave...
__________________ 2011.75 BMW E90 M3 El-Superbeast-O | |
| Not Ranked : 0 score whoops! Mine's just a sport - I bought the aftermarket raptors for my hid lights. If you have the GT, bswyatt, disregard my earlier post! |
(Thread Starter) | Not Ranked : 0 score In the daylight I could see in the engine bay better and I changed my bulbs from there. I started to take the fender shield off, but it seemed like it wouldn't be easier that way, so I tried another time to get the retaining clips off (that was the part I wasn't sure about with the visibility I had) and I figured it out. Had to reattach them by feel and it took a bit longer, but wasn't too bad. Thanks for the responses. |
![]() Join Date: Jan 2011 Location: Tampa
Rep Power: 0 ![]() Thanks: 0
Groaned at 19 Times in 1 Post
| Not Ranked : 0 score i did my light about a week ago as well and didnt want to waste the money by bringing it to the dealer. it was simple and all i did was go off the manual and use it step by step Last edited by Jerseyrican88; 01-24-2011 at 01:43 AM. |
![]() Join Date: Feb 2011 Location: Keuka Park, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 119
Groaned at 30 Times in 14 Posts
__________________ mroclimbr AEM CAI, OCC, Turbosmart BPV, CP-e turbo downpipe, JBR rsb, JBR 80 duro rmm, 3" CNT CBE, upgraded hpfp, Guardian Angel, JBR heavy knob, Cobb ap, currently stage two on 93 octane, blose speakers and amps all replaced and upgraded, dash daq, full replacement shifter, new ko4 compliments of Mazda at 48k miles. | |
Groans: 224
| Not Ranked : 0 score Padiddle!
![]() Join Date: Nov 2010 Location: Texas
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score I have an '08 Sport. I'm confused about what is HID or just halogen? My low beams are projector, but not sure what that means in terms of what bulb it is. Also, the high beams look like normal halogen. Can someone help me out with an explanation? |
![]() Join Date: Feb 2011 Location: Edmonton Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score the sports come with halogen and the GT comes with HID
__________________ 2007 CWP mazdaspeed 3 GT, Cobb access port stage 1 sf , Cobb SRI, Cobb turbo inlet, Forge bypass valve V2, One step colder plugs, Sure RMM, Corksport CBE, JBR ssp stage 2, kmd internals version 2 , Spin on oil coversion with sandwich plate, H & R coilovers, 18 x 8 Enkie fujin black, lamin x fog light covers, 35% front 20% rear tint, more to come... |
| The Following User Says Thank You to Nikon187 For This Useful Post: | jesseh627 (06-04-2011) |
![]() Join Date: Apr 2011
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score I just move the fender splash shield out of the way and had enough access to the bulb, took me 10min each side.
__________________ *07 Mazda CX-7 GT AKA The Baby Wagon Baby Stuff *05 Mercedes Benz E500 AKA The Daily Apperance Package, Sport Package, Comfort Package, Lighting Package, Navi, Keyless Go, Airmatic Suspension, AMG Quad Tip Exhaust, *94 Toyota Supra Turbo AKA The Garage Anchor Precision 63 / Auto 3.8k Stall / Methanol Injection / Volk SF Challenge / Recaro Speed / Seibon / Eibach / KYB / Greddy / Bomex / C-West / RMM / Tial / |
Rep Power: 0 ![]() ![]() Thanks: 3
| Not Ranked : 0 score High Intensity Discharge uses a ballest and converts 12 volt to higher voltage which arcs across two points inide the "bulb" not unlike arc welding as opposed to a conventional bulb which ue a filliment. |
| DDM Low Beam/Fog Install? | Speed3eak | 2010 MS3 - How-To's | 2 | 05-01-2010 09:45 PM |
| DDM Low Beam kit swap with factory HIDs MS6 GT>>> | Alpha | MazdaSpeed 3/6 - Appearance | 4 | 03-05-2010 06:59 AM |
| how to change High beam | Dros | MazdaSpeed 6 - How-To's | 4 | 12-29-2009 12:37 PM |
