> CX-7 > General Lounge + New Member Welcome
 Old 11-07-2015, 08:55 PM   #1
MG08CX7's Avatar
Posts: 12   (View Stats)
MG08CX7 has a spectacular aura aboutMG08CX7 has a spectacular aura aboutMG08CX7 has a spectacular aura about
Default New, just got a 08 cx7
Hey ladies and gents I just purchased an 08 cx7 awd touring with 73000k and a timing issue for a steal of a deal and I'm here to just say hello and introduce my self . The truck is at the shop and I may be getting it back sometime this week. Glad to see that there is a community out there for these trucks
MG08CX7 is offline   Reply With Quote
The Following User Says Thank You to MG08CX7 For This Useful Post:
Micha (11-07-2015)
 Old 11-08-2015, 07:21 AM   #2
r3d
r3d's Avatar
Posts: 182   (View Stats)
r3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond repute
Welcome, didnt know cx7 was a truck!
Building it from ground up:
r3d is offline   Reply With Quote
The Following 2 Users Say Thank You to r3d For This Useful Post:
Easter Bunny (12-29-2015), robbspeed (11-08-2015)
 Old 11-08-2015, 08:02 AM   #3
MG08CX7's Avatar
Well it sure isn't a car lol
 Old 11-08-2015, 09:11 AM   #4
A truck is a F-150.
You have a SUV...
Sent from my Nexus 6P
 Old 11-08-2015, 09:18 AM   #5
robbspeed's Avatar
Posts: 1,074   (View Stats)
robbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the world
Groans: 50
You need body on frame before I call it a truck. Your driving a jacked up hatchback. Same as all crossovers. Just with an awesome engine.
2011 Mazdaspeed3 w/ tech package
Totaled/ R.I.P.
robbspeed is offline   Reply With Quote
 Old 11-09-2015, 10:33 AM   #6
torquemaniac's Avatar
Posts: 733   (View Stats)
Can I call mine a truck if I have a Dodge Ram Cummins turbo in there...LOL
2011 CX-7 AWD 2.3 turbo
 Old 11-09-2015, 11:13 AM   #7
robbspeed's Avatar
Groans: 50
Lol. Negative
That is awesome tho
Totaled/ R.I.P.
Last edited by robbspeed; 11-09-2015 at 11:13 AM. Reason: MSF Database - Automerged Doublepost
 Old 11-09-2015, 12:15 PM   #8
MG08CX7's Avatar
On any note .. The shop said it would need a whole new engine .. I don't thing they are too knowledgeable about the vvt timing issue so it's off for a second opinion
 Old 11-09-2015, 12:28 PM   #9
robbspeed's Avatar
Groans: 50
New motor lol. Huh? Dealership might be best for that issue. As long as they dont touch anything else.
Totaled/ R.I.P.
 Old 11-09-2015, 12:39 PM   #10
alan1592's Avatar
Posts: 110   (View Stats)
alan1592 has a brilliant futurealan1592 has a brilliant futurealan1592 has a brilliant futurealan1592 has a brilliant futurealan1592 has a brilliant futurealan1592 has a brilliant futurealan1592 has a brilliant futurealan1592 has a brilliant futurealan1592 has a brilliant futurealan1592 has a brilliant futurealan1592 has a brilliant future
Just do it yourself, VVT took me two days.
2006 Mazdaspeed 6, AccessPORT V2, CP-E CAI, Catless DP, and Solid MM's.
alan1592 is offline   Reply With Quote
 Old 11-10-2015, 11:30 AM   #11
bzwyatt's Avatar
Posts: 543   (View Stats)
bzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the world
Groaned at 35 Times in 14 Posts
Welcome and good luck with the new car.
Mine has 101k miles, got a new AC compressor, new turbo, new valve cover, new timing chain, all under TSB before 60k warranty. I have a cool dealer and I get along with them and I've never had a problem getting service, and my car has never let me down. Hopefully stays that way.
Good luck.
bzwyatt is offline   Reply With Quote
 Old 11-10-2015, 12:37 PM   #12
robbspeed's Avatar
Groans: 50
Good luck.
Damn man. People like you are few and far between.
Totaled/ R.I.P.
 Old 11-13-2015, 11:03 AM   #13
MG08CX7's Avatar
Not looking too good. Seems like not only was it a timing issue but the #2 cylinder was either loose or wore down the Bering enough that it seems to be loose "crossing fingers" there is no damage to the crankshaft journal
 Old 11-13-2015, 01:23 PM   #14
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
What the fuck is a loose cylinder?
Not really possible on these engines.
Does have the engine have low compression on cyl 2?
is there some kind of pinging noise that would indicated a bad con rod bearing?
 Old 11-14-2015, 09:44 AM   #15
MG08CX7's Avatar
Apparently you were able to shake the connecting rod while still attached the the crank journal. Like I said I hope there is only damage to the Bering and not to the journal itself. As far as noise I was not able to tell if the cylinder was making any noise over the noise of the timing chain
 Old 11-15-2015, 04:10 AM   #16
Ozynigma's Avatar
Posts: 743   (View Stats)
Welcome and I glad you got it cheap.
Now get on down to SpeedPerformance and buy yourself a built motor, then all you need is a bigger turbo and a...... etc etc etc.
 Old 11-17-2015, 04:20 PM   #17
MG08CX7's Avatar
Well, there was no Bering for cylinder #2 and this was the one for cylinder #3
 Old 11-17-2015, 04:27 PM   #18
robbspeed's Avatar
Groans: 50
Attachment 216618
Good lord. What do you mean there was no #2 bearing?
Totaled/ R.I.P.
 Old 11-17-2015, 05:03 PM   #19
MG08CX7's Avatar
It was sitting in the bottom of the oil pan in shards
 Old 11-17-2015, 05:10 PM   #20
robbspeed's Avatar
Groans: 50
Totaled/ R.I.P.
 Old 11-17-2015, 06:52 PM   #21
MG08CX7's Avatar
Well since a new crankshaft is in order.. Does anyone know where one is obtainable without spending the $1000 wanted from Mazda ? I tried eBay and I hunted one down but I'm just weighing my options
 Old 11-17-2015, 06:57 PM   #22
Ozynigma's Avatar
I just checked my usual aftermarket dealers and they are the same price, around $1100US. There is only OEM for this motor afaik.
You shouldn't pay more than $4-500 for a used one.
 Old 11-19-2015, 08:06 AM   #23
Bob Ross Fanclub
Tomas's Avatar
I have a used crankshaft I could sell you. PM me if interested.
You should also get aftermarket rods while you are at it. For pistons I would use OEM mazdaspeed gen2. Don't use aftermarket.
Still don't understand what you mean by a loose cylinder. Do you mean a loose piston as in a piston scoured the cylinder liner? You need to check the liners to see if they can be honed. If not, then you will need a new block and then you might as well get a new short block from mazda.
 Old 11-19-2015, 08:47 AM   #24
robbspeed's Avatar
Groans: 50
What is it about the oem gen 2 pistons that you like?
Totaled/ R.I.P.
 Old 11-19-2015, 11:06 AM   #25
MG08CX7's Avatar
The connecting rod for cyl 2 was loose on the crankshaft because the Bering was sitting in shards in the oil pan
 Old 11-20-2015, 04:50 AM   #26
Ozynigma's Avatar
Sorry for the thread hijack but that pretty much means using Gen2 Pistons and Carrillo rods. All the other rods I could find had non stock wrist pins and no taper.
I agree with new aftermarket rods (and Pistons) if you can afford it while your motor is apart. The rods are the weakest internal engine component (usually weaker than bearings).
Also unless you know the timing chain and VVT actuator have been replaced recently it's best to renew all the worn timing components when you reassemble. Also make sure that you use a new crank bolt and new friction washers.
Also one way or another clean the inlet valves while the head is off.
Last edited by Ozynigma; 11-20-2015 at 04:50 AM. Reason: MSF Database - Automerged Doublepost
 Old 12-08-2015, 08:31 AM   #27
clivingston's Avatar
Posts: 23   (View Stats)
clivingston is an unknown quantity at this point
How did the VVT replacement go? Where did you get your parts?
clivingston is offline   Reply With Quote
 Old 12-08-2015, 08:34 AM   #28
MG08CX7's Avatar
Didn't replace the vvt yet, pulling the motor out this weekend to work on the lower end (crankshaft, connecting rod bearings, etc.) and after that while the motor is out we will assess the vvt damage and repair that
 Old 12-29-2015, 07:15 AM   #29
MG08CX7's Avatar
Well it seems that the oil pump seized up .. Seems as if the owner before me didn't like changing oil .. We took the pump apart cleaned it up and it's free flowing again .. Just ordered the vvt new tensioners and chains, They should be arriving next week.
robbspeed (12-29-2015)
 Old 12-29-2015, 10:12 AM   #30
Aja1732's Avatar
Posts: 33   (View Stats)
Aja1732 will become famous soon enoughAja1732 will become famous soon enough
Wow, I'm sorry to hear that. As someone who just picked up a CX-7 used, that's one of my biggest fears. The people who had it before did not take care of it. I know already that brake pads and/or rotors are coming up in the spring and a CV or ball joint replacement on the front. But so far the engine has been smooth and all TSB were already done. Good luck getting everything taken care of. It's a fun vehicle that marks all the check boxes for me.
Aja1732 is offline   Reply With Quote
 Old 12-29-2015, 10:36 AM   #31
I would just get a new oil pump. Not worth the risk.
 Old 12-29-2015, 10:37 AM   #32
Police
InkedInspector's Avatar
Groans: 312
Love the avatar. Rick and Morty ftw
Both of you should have done your homework on these CX-7s before buying them. Same engine as a speed, but most were bought by soccer moms trying to avoid mini vans. They have a nasty reputation for reliability that is largely the fault of their owners. OP here clearly didn't do many checks prior to purchase given that his motor was toast. Have you done a compression and leak down test on yours, or you just bought it as is? Best of luck to both of you.
 Old 12-29-2015, 11:35 AM   #33
Aja1732's Avatar
I took mine to a Mazda dealership to check timing, oil leak test(worked at a Subaru Dealership for a while, so I'm familiar. Haha) I'm pretty handy with most things and if I've never done I will give it a shot before taking it to a dealer. Just was on a timeline to get a new car before insurance took the rental away. I read a little about them before I bought mine, mainly the issues, but I can fix most stuff if need be. I refuse to take it to a shop after my Jeeps caliper bolts were stripped and they put the bolt in there with silicon holding it in ....
Edit: and yes R n M is an awesome show. "Hey, I'm Mr Meseeks! Look at me!"
The Following User Says Thank You to Aja1732 For This Useful Post:
InkedInspector (12-29-2015)
 Old 12-29-2015, 11:38 AM   #34
MG08CX7's Avatar
Well I actually got it way below book value with the knowledge of an engine "noise" and it had decently low milage so after all is said and done with me doing majority of the labor. The end cost with 2 new front tires is still going to be lower then book value of the vehicle
The Following 2 Users Say Thank You to MG08CX7 For This Useful Post:
Easter Bunny (12-29-2015), InkedInspector (12-29-2015)
 Old 12-29-2015, 11:41 AM   #35
Aja1732's Avatar
And you know what you did vs taking it to a third party and having them do it and not knowing exactly what they have done or will do.
 Old 12-29-2015, 11:51 AM   #36
Police
Groans: 312
I actually have been looking into buying a blown motor Cx7 as a DD just because of how cheap they are, and I know the reliability claims are bogus so it's good if you can take advantage of people that think they are lemons.
Page generated in 0.51920 seconds with 32 queries
