> CX-7 > General Lounge + New Member Welcome
 Old 01-14-2016, 08:00 PM   #1
Aizen Sosuke's Avatar
Posts: 5   (View Stats)
Aizen Sosuke is an unknown quantity at this point
Default Old Member, first post: P0303
Hi all. I've been lurking this site for over 6 years since I bought my 08 CX-7 in 2010. Thanks to many posts in here I got the AC compressor and VVT done under warranty at around 60k miles. I have maintained this baby since I got it with only 20k miles with synthetic and she's given me zero issues. It's my daily, I have a 370Z but that barely gets driven this days.
Anyways for the past 2 months I have been getting the CEL with P0303, cylinder 3 misfire. I replaced the spark plugs since the originals have nearly 90k miles now anyways and I went with another set of NGK laser iridium with a .028 gap. These are the same as the original Fomoco just rebranded. I also switched the coilpack to cylinder 4 and reset the code. Two days later it came back during a cold start in the morning. It's the same code, same cylinder. I think we can safely rule out spark. I will be taking it to the dealer since I do not have the proper scan tools to determine what is wrong. Car is bone stock and it is actually running quite well. I do not feel any misfire whatsoever. I've searched the boards and everything from bad injector seals, injectors themselves, PCM, HPFP, purge valve and many more have been the cause of these. I'll keep everyone posted of any progress and appreciate any input you may have.
Aizen Sosuke is offline   Reply With Quote
 Old 01-14-2016, 09:42 PM   #2
blackms3_71's Avatar
Posts: 2,250   (View Stats)
Either dirty valves, dirty injector, or injector seals.
Or possibly dirty egr.
Last edited by blackms3_71; 01-14-2016 at 09:42 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-15-2016, 02:04 PM   #3
Dealer says compression test is good but EGR was very dirty. They cleaned valve and code came back. HPFP also checks out ok so injector on cylinder 3 appears to be culprit. They quoted me $750 to replace that injector. It will be done by Monday and hopefully that's the end of this issue. I'll report back in then.
 Old 01-15-2016, 02:12 PM   #4
Injectors aren't that expensive, someone that it would cost around $100-175 for each one.
sent from my Nexus 6P
blackms3_71 (01-15-2016)
 Old 01-15-2016, 02:17 PM   #5
Your price is accurate. I am paying them $220 on parts which includes injector, seals, o-rings and intake manifold gasket plus another $480 in labor. They are also doing a $50 injection cleaning that was due since my 80k service. I'm sure they have a slight mark up on parts but overall I did not see anything outrageous.
 Old 01-20-2016, 06:31 PM   #6
Picked up the car yesterday and so far so good. It is running smoothly and pulling hard with no CEL. Dealer also cleaned the valves as they had a lot of carbon build up. I'll post back if the issue resurfaces.
CEL P0303 stokes620 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 37 11-14-2015 11:53 PM
P0303 561BlackMS3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 09-10-2013 01:17 PM
P0303 BGofMD MazdaSpeed 3/6 - Troubleshoot/Diagnostics 49 01-17-2012 04:51 PM
CEL P0303 75meters MazdaSpeed 3 - Engine, Transmission & Driveline 5 04-05-2011 04:05 PM
Page generated in 0.25651 seconds with 22 queries
