> CX-7 > General Lounge + New Member Welcome
  • 1 Post By Vansquish
 Old 02-06-2016, 10:34 AM   #1
jaguar_mike's Avatar
Posts: 18   (View Stats)
jaguar_mike has a little shameless behaviour in the past
Default Torque Specs.
Hi,
Just wanted to say hi to the site. It looks impressive and helpful.
I am rebuilding a 2.3 turbo.
I have the crappy version of All Data because I work at home.
It doesn't have all of the torque measurement's.
Could someone please let me know the bolt torque sepcs. for the balance unit?
I took the engine and transmission out and noticed that someone has been here.
I wanted to check out the crankshaft while the head was getting done.
But I found connecting rod torque but nothing for the Balancer.
I got the head back and will start measuring the cam clearance to see what cups I need to order. But need to sock up the bottom to get ready for the head, new chains and guides, VVt.
Thanks again,
M<e
jaguar_mike is offline   Reply With Quote
 Old 02-06-2016, 10:54 AM   #2
ALPINEST4RS's Avatar
Posts: 905   (View Stats)
Groaned at 8 Times in 3 Posts
Are you building the motor or are you using OEM rods and pistons?
If you're building the motor stout, go with a balance shaft delete. Its way easier than installing the balancer. You must shim it properly and make sure you have proper backlash or you'll be pretty pissed.
Torque specs are 19ft lbs first pass +32.5-33.9ft lbs final pass.
The Following User Says Thank You to ALPINEST4RS For This Useful Post:
jaguar_mike (02-06-2016)
 Old 02-06-2016, 11:53 AM   #3
Hi,
Its just OEM, I trying to keep it stock because the car is for resale. Not going to keep this one. I just want to make everything as good as I can for the ne
 Old 02-06-2016, 12:36 PM   #4
Police - Grammarhead
Vansquish's Avatar
Originally Posted by jaguar_mike View Post
Hi,
Shop manual is available online, including on MSF in the VIP section.
jaguar_mike likes this.
ms6mil (02-06-2016)
 Old 02-06-2016, 12:54 PM   #5
Hi,
how do I get to it? Is it on this forum?
Thanks,
M<e
 Old 02-06-2016, 12:58 PM   #6
Vansquish's Avatar
You have to get a VIP membership to MSF to access that specific portion of the forum.
Edit:
A 2-minute google search resulted in this:
CX-7 FAQ Thread
 Old 02-06-2016, 03:59 PM   #7
Edit:
CX-7 FAQ Thread
Hi,
I have a silly question. I took off in sequence the cylinder head bolts and placed them on the bench. I dropped off the head and picked it up yesterday. When I picked it up my guy said that there still were head bolt washers in the head and gave me what was left. The head bolts that I took out look like the washer is part of the head of the bolt, all one piece. Are there suppose to be head bolts and washers or just the head bolts? I know someone else has done work on this engine, maybe the washers are OEM and they used aftermarket bolts?
Thanks,
M<e
 Old 02-06-2016, 04:29 PM   #8
Hi,
I have a silly question. I took off in sequence the cylinder head bolts and placed them on the bench. I dropped off the head and picked it up yesterday. When I picked it up my guy said that there still were head bolt washers in the head and gave me what was left. The head bolts that I took out look like the washer is part of the head of the bolt, pretty beefy all one piece. Are there suppose to be head bolts and washers or just the head bolts? I know someone else has done work on this engine, maybe the washers are OEM and they used aftermarket bolts?
Thanks,
M<e
Lug nut torque specs? forbidden doughnut 2010 MS3 - Torque Specs & information 78 11-23-2016 08:51 AM
RMM Torque Specs mhebert2001 Gen2 MS3 General Discussion 7 04-21-2014 08:44 PM
Need some torque specs zdrpewter01 MazdaSpeed 3 - Engine, Transmission & Driveline 3 07-21-2011 06:29 PM
Torque specs DV8 MazdaSpeed 3/6 - Wheels & Tires 7 04-14-2010 12:29 AM
Page generated in 0.29587 seconds with 22 queries
