> MazdaSpeed 3/6 - Wheels & Tires > Wheels & Tires - METRO GREY
Wheels & Tires - METRO GREY Wheels & Tires on metro grey cars.
 Old 12-21-2014, 01:38 AM   #29
silkyms3's Avatar
Posts: 66   (View Stats)
silkyms3 has a brilliant futuresilkyms3 has a brilliant futuresilkyms3 has a brilliant futuresilkyms3 has a brilliant futuresilkyms3 has a brilliant futuresilkyms3 has a brilliant futuresilkyms3 has a brilliant futuresilkyms3 has a brilliant futuresilkyms3 has a brilliant futuresilkyms3 has a brilliant futuresilkyms3 has a brilliant future
Might be too late as I just saw this... but it depends a lot on tire size and brand. If you go with 225/40 non-extreme tires you should be ok with stock height. Otherwise you'll likely have to roll. And rolling is not bad at all. I'm running Direzza ZII in same 235/40 now, which is bit narrower than star specs, so zero rubbing with mild roll in rear. Rocking KW v2 coils now.
silkyms3 is offline   Reply With Quote
G-Force Chips? crtguns MazdaSpeed 3/6 - ECU Computer Tuning 17 09-19-2011 10:22 PM
cp-e™ Ω-force™ goodfella16 2010 MS3 - Engine, Transmission & Driveline 15 04-05-2011 04:35 AM
Help with Rota G-Force Boostedrice Wheels & Tires - METRO GREY 0 03-18-2011 11:03 PM
g-Force T/A™ KDW brandonms3 MazdaSpeed 3/6 - Wheels & Tires 13 12-30-2010 01:40 PM
JIC J-force 05 wheels ms3boost Wheels & Tires - RED 7 08-26-2009 03:01 PM
Page generated in 0.47537 seconds with 40 queries
