> Mazdaspeed Forums User Reviews
Mazdaspeed Forums User Reviews These are reviews done by our community members.
 Old 12-06-2008, 03:38 AM   #1
Jackal
Breakdown81's Avatar
Posts: 869   (View Stats)
Breakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the world
Groans: 56
Default CP-E Rear Engine Mount: Review
Table of Contents
1 - CP-E Rear Engine Mount: Review
2 - Tools & Box Contents
3 - Installation
4 - Something Drastic or Drastic Improvement...
5 - Almost Done!
6 - Critiques, Impressions & Conclusion
Thats right kids! It's time for another performance part review and handy dandy installation guide! If you're not excited by now, you probably should go to another thread because it's really not going to get any better. Now, on with the extravaganza.
As many of you all know one of the earliest sources of frustration with the mazdaspeed3 was that many people experienced a failure of the stock rear engine mount. Though the possible causes for the failure were many, the inescapable conclusion was that engine mounts should not be prone to failure. Also if this one reason was not enough, the design of the stock rear mount allowed for a large amount of engine play under load. Which translates directly into a certain amount of power not making it to the wheels, which would make many a performance hound chew their fingertips off. Thus, sensing the opportunity to make a few dollars off of enthusiasts everywhere; several companies began to develop replacement options for the rear mounts. Which brings us to CP-E.
A small group of performance nuts dedicated to making your driving experience better through technology. CP-E or Custom Performance Engineering, designed, prototyped and developed a new and improved rear engine mount.
As lifted from their website:
"Mazda SPEED3 Engine Mount
Custom Performance Engineering is very proud to release the first aftermarket EPDM (ethylene propylene diene monomer) rubber engine mount for the MazdaSPEED3! CNC machined from a single piece of billet 6061-series aluminum; this mount is not only totally indestructible, but it also transmits far less NVH (noise, vibration and harshness) into the cabin than comparable mounts.
Our mount is unique compared to our competitors mounts both in form and in function. We use rubber for the bushing as opposed to urethane simply because it is better suited for this application. Rubber withstands engine heat much better then urethane, and it will not deform or crack over time the way urethane can. We were also able to incorporate a unique method of holding the mount in the vehicle. Instead of placing all of the force on the center bushing pin, the load is distributed throughout the bushing. This increases the effective stiffness of the bushing under engine loads, and the 50-durometer bushing absorbs annoying vibrations. Now you can combine the stiffness of a race mount with the comfort of a stock unit!"
It was a triumphant moment, it was new, it was hefty, it was......BOFFO.
Problems arose concerning the rubber pour as it was found that achieving the specified 50 durometer stiffness rating was not being done consistently. At this point CP-E stopped selling the mount and sent it back to be re-developed. Now, in the waning months of 2008 the mount is back, with a higher 60 durometer rating. It can be purchased through select vendors on the web, however stock may be short as many people have been on waiting lists for many months to get this mount. But enough of that.
1 2 3 4 5 6 Next»
Last edited by Breakdown81; 06-02-2009 at 08:20 PM. Reason: adding updates since product design has changed
Breakdown81 is offline   Reply With Quote
The Following 63 Users Say Thank You to Breakdown81 For This Useful Post:
3mazdaspeed (11-29-2010), akabickle (07-23-2010), AmillieMS6 (01-27-2010), AZSPEED3 (07-30-2010), badams118 (02-06-2009), bmfms3 (07-08-2010), burntRice (05-06-2010), byau (04-11-2010), clowncar (12-19-2010), cookieheadjenkins (03-15-2010), Crossbow (04-05-2009), Dash08 (12-09-2008), dead-zone (09-09-2013), DingoDave (11-20-2010), Docnox (12-10-2008), doubleflusher (02-11-2009), FCmaniac (12-15-2008), fred114 (12-23-2008), fyrecrotch (12-23-2008), gerlitzkib6 (04-25-2012), i3pimpin4life (05-05-2009), indianaryan (05-12-2010), Jetech (06-30-2011), JS + MS3 (02-13-2010), kgb (04-14-2010), kingpin748 (12-13-2008), kpsoerensen (03-22-2010), Lee123 (01-02-2009), liquoredonlife (04-16-2010), lolwrx (12-29-2013), MattJackson86 (12-14-2008), miguelbates (01-27-2009), Mooseknuckler (06-28-2015), mouse0330 (12-06-2008), Mr. Bean (03-10-2009), MS33SM (06-04-2010), MS3_Brett (12-12-2008), ms_3 (06-14-2010), Night Wolf (03-03-2010), obijack (09-20-2011), paradigme (03-29-2010), pebenito (06-02-2010), phailerider (12-13-2008), phantom3 (12-08-2008), rossisboss07 (04-10-2010), SJP0tato (11-14-2010), skeeter149 (12-06-2008), skubidoobie (12-07-2008), Smokehouse (03-04-2009), Snap Off (08-02-2012), steven88 (07-13-2009), surebOOst (02-24-2011), TheMachinist (12-09-2008), the_caruch (03-23-2010), ToledoSpeed3 (07-11-2009), writhen (05-27-2010), xandrake (07-11-2009), xcoldricex (02-05-2009), xdm88 (12-31-2010), xSP33Dx3x (04-29-2009), Zeya (12-08-2008), ZoomMe (01-09-2011), zumanback (03-13-2010)
 Old 04-10-2009, 03:01 AM   #2
yang_jackson's Avatar
Posts: 432   (View Stats)
yang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the world
Groaned at 56 Times in 24 Posts
excellent instuctions. best i have seen for this product so far. how are you liking the rear mount now? was there a settling in period? have you been able to compare the feel w/any other after market rear mounts? thanks for your time.
yang_jackson is offline   Reply With Quote
 Old 07-11-2009, 11:39 AM   #3
ToledoSpeed3's Avatar
Posts: 244   (View Stats)
ToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the world
Thanks again for the good write-up. I used the rhino ramps and all went well. It would have been nice to do it on a lift for better clearance...probably would have made this a 25 minute job instead of a 45 minute job. Rhino ramps don't give much room to move around under there. I groaned and bitched a little bit while trying to get into position to pry and get the aluminum engine bracket bolts lined up.
First impressions are good with the 60 duro mount. The car feels much more solid without the engine moving around so much. Now it doesn't feel like it's going to break under hard acceleration. Shifting performance has been improved, even when just cruising around. As you reported, vibrations are minimal even without break-in and are most noticeable at startup and with the A/C on.
I agree, CP-E did a nice job with this mount!
ToledoSpeed3
09 MazdaSpeed3 GT, True Red
ToledoSpeed3 is offline   Reply With Quote
 Old 07-11-2009, 12:30 PM   #4
xandrake's Avatar
Posts: 575   (View Stats)
xandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the worldxandrake is the leader of the world
I installed mine today as well. A breaker bar is necessary in my case (over one year old car in cold weather area) to get the bolts out. After I got the breaker bar the total time of the install was about 25 mins. Easy as cake.
Also, I got a small block of wood and a 2 ton jack to support the tranny during the install. It made the holes line back up perfectly during install of the CP-e part.
xandrake is offline   Reply With Quote
 Old 07-11-2009, 01:37 PM   #5
Nice. How do you like it? Did you get the 60 duro or 75? I am curious to how much different the vibes are. I am happy that I chose the 60 at this point as I wouldn't want any more vibes that I have right now with the A/C on. Noticeable, but not annoying. We'll wait and see how it is after a bit of driving.
I used my 1/2" drive breaker bar out of habit, but probaboy wound't of needed it. I also used a jack to support the tranny like the CP-E instructions suggested. I adjusted the jack to help with the line up of those 3 holes and it did help, but I still had to pry it in 2mm or so like in the OP instructions to get the bolts started right. The up and down of the jack didn't get me there all the way.
ToledoSpeed3
 Old 07-12-2009, 09:14 AM   #6
paradigmshift's Avatar
Posts: 78   (View Stats)
paradigmshift is just really niceparadigmshift is just really niceparadigmshift is just really niceparadigmshift is just really nice
Thanks!
So just one bolt should have locktite applied to it? how about the bolt that comes with the cp-e mount?
2008.5 Mazdaspeed3 CWP
paradigmshift is offline   Reply With Quote
 Old 07-12-2009, 03:44 PM   #7
Originally Posted by paradigmshift View Post
Thanks!
I used it on 4 of the 5 bolts (1 inverted one mentioned by the OP + 3 that hold the aluminum mount on the engine). The bolt that cp-e ships comes with a lock washer. It's also good to go back after a little while and check to make sure that any of 5 bolts aren't vibrating loose like it mentions in the cp-e instructions.
ToledoSpeed3
 Old 01-27-2010, 10:22 PM   #8
kyoo's Avatar
Posts: 253   (View Stats)
kyoo has a brilliant futurekyoo has a brilliant futurekyoo has a brilliant futurekyoo has a brilliant futurekyoo has a brilliant futurekyoo has a brilliant futurekyoo has a brilliant futurekyoo has a brilliant futurekyoo has a brilliant futurekyoo has a brilliant futurekyoo has a brilliant future
will this stop the engine from falling out?
what?
Last edited by kyoo; 01-28-2010 at 02:08 PM. Reason: MSF Database - Automerged Doublepost
kyoo is offline   Reply With Quote
The Following 4 Users Say NO Thank You to kyoo For This Un-useful Post:
 Old 02-19-2010, 09:43 AM   #9
MPS83's Avatar
Posts: 15   (View Stats)
MPS83 is an unknown quantity at this point
Very good mount
MPS83 is offline   Reply With Quote
 Old 03-03-2010, 11:10 PM   #10
Night Wolf's Avatar
Posts: 894   (View Stats)
Night Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the world
Groans: 38
Great write up. I'm planning to get this one for my Speed 3. I have a question tho, what is the difference between 60 and 75 duro?
2008 Mazdaspeed 3GT
Wiseco pistons || K1 rods || GT3076 at 21 PSI (for now) || Built by Pablo and tuned by Dustin || Steedspeed exhaust mani || TIAL 38mm EWG || Custom dump tube || Grimmspeed EBCS
CP-e safe seals || CP-e 4" TIP || CP-e big maf || CP-e catless DP || CP-e HPFP || CP-e gauge pod with Prosport gauges || COBB FMIC || COBB XLE BPV || COBB STS || COBB AP
Matt Damond OCC || CNT exhaust || BSD || EGR del || DENSO ITV22 || TRZ RMM || TRZ TMM || JBR PMM || JBR shift knob || Stoptech slotted rotors || KONI FSD || ROTA GRID 18 x 8.5
NATOR NJ FTW
Night Wolf is offline   Reply With Quote
 Old 03-07-2010, 11:15 PM   #11
mtxandy's Avatar
Posts: 53   (View Stats)
mtxandy has a brilliant futuremtxandy has a brilliant futuremtxandy has a brilliant futuremtxandy has a brilliant futuremtxandy has a brilliant futuremtxandy has a brilliant futuremtxandy has a brilliant futuremtxandy has a brilliant futuremtxandy has a brilliant futuremtxandy has a brilliant futuremtxandy has a brilliant future
60 is the softer of the two. Less vibes with the 60 but more motor movement than with the 75.
mtxandy is offline   Reply With Quote
 Old 03-07-2010, 11:21 PM   #12
Night Wolf's Avatar
Groans: 38
Thanks for the clarification.
2008 Mazdaspeed 3GT
NATOR NJ FTW
 Old 04-05-2010, 06:41 PM   #13
Vinnie's Avatar
Posts: 714   (View Stats)
Vinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the world
Groans: 76
does anyone know how this compares to the su one piece mount?
'12 speed 3 CWP w/tech: DIZZY Tuned by Phate!,cobb AP,Autotech internals, cp-e nano, cp-e TIP, JBR 88 dogbone, JBR SSP/bushings, JBR rear sway bar, UR test pipe
RIP '08 speed 3 silver cp-e 75 duro RMM, cp-e intake, cp-e TIP, Jbarone SSP and bushings.
Vinnie is offline   Reply With Quote
 Old 04-05-2010, 06:44 PM   #14
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
sat in breakdowns car and man i almost forgot he has a rmm. good job cp-e on making a mount that does its job but doesnt shake the shite out of you like a yahoo.
 Old 04-11-2010, 01:20 PM   #15
byau's Avatar
Posts: 288   (View Stats)
byau has a reputation beyond reputebyau has a reputation beyond reputebyau has a reputation beyond reputebyau has a reputation beyond reputebyau has a reputation beyond reputebyau has a reputation beyond reputebyau has a reputation beyond reputebyau has a reputation beyond reputebyau has a reputation beyond reputebyau has a reputation beyond reputebyau has a reputation beyond repute
Groaned at 4 Times in 1 Post
i just used this guide today and its AWESOME. parts of the cp-e instructions were unclear so this made it a smooth install. thanks!!
byau is offline   Reply With Quote
 Old 04-14-2010, 11:02 PM   #16
prspect's Avatar
Posts: 22   (View Stats)
prspect will become famous soon enoughprspect will become famous soon enough
Walkthrough helped with a painless install
prspect is offline   Reply With Quote
 Old 05-16-2010, 10:46 AM   #17
JS + MS3's Avatar
Posts: 1,794   (View Stats)
JS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the world
Groaned at 72 Times in 51 Posts
So, I'm going to install this CPE RMM on my car right now.
But I don't have any jackstands or anything that could be put under the transmission.. I only have 1 regular jack in the back of the trunk..
Can I use the jacks in my parents cars? Then, I will have total 3 scissors jacks.
Let me know asap guys! Thanks!
2010 Mazdaspeed3
Cobb AP - CP-E SRI - Ultimate Racing TP - CP-E RMM 75D - JBR RSB - JBR SSP - Autotech HPFP Internal - Denso ITV22 - Advan RZ 18x8 (Conti ExtremeContact DW 235/40/18)
JS + MS3 is offline   Reply With Quote
 Old 05-16-2010, 02:14 PM   #18
speed_freak's Avatar
Posts: 187   (View Stats)
speed_freak has a reputation beyond reputespeed_freak has a reputation beyond reputespeed_freak has a reputation beyond reputespeed_freak has a reputation beyond reputespeed_freak has a reputation beyond reputespeed_freak has a reputation beyond reputespeed_freak has a reputation beyond reputespeed_freak has a reputation beyond reputespeed_freak has a reputation beyond reputespeed_freak has a reputation beyond reputespeed_freak has a reputation beyond repute
dude with ur next set of planned mods just go get a good floor jack and stands... makes like so much easier not to mention safer
cp-e cai, trz rmm and jbarone ssp
speed_freak is offline   Reply With Quote
 Old 05-16-2010, 03:17 PM   #19
JS + MS3's Avatar
^ Yeah, that's my plan.
Anyway, I tried to install the mount just now. Everything's fully done except for this one bolt out of three on the right side. its the left top one, which would not go in more.. right now 3/4 of it is tightened in, but no more.. I tried everything but it's just not going in anymore. Everything else is set and done..
I tried to take off everything and tried to screw in the bolt just to see if it screws in fully, but surprisingly it didn't go in after 3/4. What does that mean?? before i did this, i thought it was the off lining that's stopping the bolt from going in fully, but i guess not..
Any advice please?
2010 Mazdaspeed3
 Old 11-18-2010, 07:28 PM   #20
G Sp33dy's Avatar
Posts: 337   (View Stats)
G Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the world
Groaned at 7 Times in 3 Posts
thanks so much for the how to. Just installed the RMM dogbone from Protege garage.com and it was an easy install. Love the new feel of the car. FYI i got the "race" option, and the vibes are not bad at all after about 2 days of driving. Wheel hop still exists a little but majorly reduced.
G Sp33dy is offline   Reply With Quote
 Old 02-22-2011, 11:58 PM   #21
CheezIt's Avatar
Posts: 39   (View Stats)
CheezIt is just really niceCheezIt is just really niceCheezIt is just really niceCheezIt is just really niceCheezIt is just really nice
sucks about the price raise on these..
CheezIt is offline   Reply With Quote
 Old 02-24-2011, 02:59 PM   #22
mroclimbr's Avatar
Posts: 245   (View Stats)
mroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond reputemroclimbr has a reputation beyond repute
Groaned at 30 Times in 14 Posts
Don't worry about the price increase. Our friend JBarone is making a rmm that will be out this spring. I'm sure his price will be more inline with reality and his quality is never compromised.
I might even throw away my cpe rmm and put the JBarone one in out of spite.
mroclimbr AEM CAI, OCC, Turbosmart BPV, CP-e turbo downpipe, JBR rsb, JBR 80 duro rmm, 3" CNT CBE, upgraded hpfp, Guardian Angel, JBR heavy knob, Cobb ap, currently stage two on 93 octane, blose speakers and amps all replaced and upgraded, dash daq, full replacement shifter, new ko4 compliments of Mazda at 48k miles.
Last edited by mroclimbr; 02-24-2011 at 02:59 PM. Reason: MSF Database - Automerged Doublepost
mroclimbr is offline   Reply With Quote
The Following User Says Thank You to mroclimbr For This Useful Post:
JBR (02-25-2011)
 Old 02-25-2011, 06:11 AM   #23
mroclimbr,
Your statement is very accurate accept it will be out before spring!
Thanks,
Jamie
 Old 02-25-2011, 11:55 AM   #24
I'm a caveman
gtlaw's Avatar
Posts: 758   (View Stats)
gtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the world
Groans: 68
Groaned at 22 Times in 16 Posts
mroclimbr,
Thanks,
Jamie
I would like to see a full set of 3 at a price a little lower than $600
2015 MUSTANG GTPP
gtlaw is offline   Reply With Quote
 Old 03-17-2011, 09:30 PM   #25
TRRR80's Avatar
Posts: 45   (View Stats)
TRRR80 is a jewel in the roughTRRR80 is a jewel in the roughTRRR80 is a jewel in the roughTRRR80 is a jewel in the rough
just installed my 75 duro today and wow i should have done this as my first mod like everyone else has mentioned. there's some vibes yes but i like it and they aren't bad at all. it makes the car feel real sporty and launching the car is like a rocket from a stand still. if you're gonna get a motor mount i'd highly recommend the 75! go big or go home!
TRRR80 is offline   Reply With Quote
 Old 03-19-2011, 05:37 AM   #26
Amazon's Avatar
Posts: 2,679   (View Stats)
Amazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the world
Groans: 214
Groaned at 114 Times in 83 Posts
My CP-E rmm is alright, but I think I'll go back to TRZ. I'd get the CP-E tranny mount, but I think I can get a rmm, tranny mount, AND passenger mount for the price of one CP-E mount
Amazon is offline   Reply With Quote
 Old 11-23-2011, 09:24 AM   #27
Ponypetro's Avatar
Posts: 59   (View Stats)
Ponypetro is a splendid one to beholdPonypetro is a splendid one to beholdPonypetro is a splendid one to beholdPonypetro is a splendid one to beholdPonypetro is a splendid one to beholdPonypetro is a splendid one to beholdPonypetro is a splendid one to behold
Groaned at 3 Times in 1 Post
hi guys!
just mounted the 60 duro rmm to the car.
i am some confused cause i´ve read in this howto to tighten all bolts by a torque of 70 ft/lbs. i´ve done 90 ft/lbs as written in the cp-e installation manual. why did u write 70 ft/lbs here.???!
at idle feel as good as no added vibration to the car. only in lower rpm´s (below 1500) i can feel some vibration. will this disappear within some time after a few miles?
kindly regards
- 3" TURBOBACK - 3.25" ETS TMIC - 3" CP-E TURBO INLET & CAI - CP-E HPFP - GFB BPV - CP-E RMM - DENSO ITV22 - GRIMSPEED EBCS -
- MAZDAEDIT ECU REFLASH - JBR SHORT SHIFT KIT - PROSPORT BOOST GAUGE - MSD DASHHAWK -
Ponypetro is offline   Reply With Quote
 Old 11-23-2011, 09:28 AM   #28
Grumpyjap's Avatar
Posts: 1,839   (View Stats)
It will get less, but not completely go away
 Old 11-23-2011, 09:40 AM   #29
Ponypetro's Avatar
thank u and what about the torque???!!!!
 Old 11-23-2011, 10:33 AM   #30
Crarrs's Avatar
Posts: 1,662   (View Stats)
Go by what's in their instructions. This review is three years old. New info>old info.
2004 MSM TiGrey
 Old 11-27-2011, 08:22 PM   #31
zpele's Avatar
Posts: 1,654   (View Stats)
zpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the world
Groans: 354
Groaned at 213 Times in 109 Posts
I'm retarded. Below is a family guy clip for your enjoyment:
2012 Shelby GT500 - Roush Axleback ~ JLT Oil Separator ~ JLT 123mm intake ~ Ngauge ~ Lund Tuned ~ smaller pulley ~ xpipe (loud as fuck now)
2007 Mazdaspeed6 (SOLD) - COBB SRI ~ Gutted Stock Midpipe ~ HKS BPV ~ JBR RMM ~ AWR PMM ~ AWR TMM ~ Juggernaught Rear Diff Mount ~ Dreadnaught Rear Diff Mount ~ ACT Stage 2 Clutch ~ ITV22s ~ AP(self fucking tuned in a week fuckers) ~ Autotech Internals ~ eBay Downpipe ~ Poke Sub thingy
zpele is offline   Reply With Quote
The Following User Says Thank You to zpele For This Useful Post:
Raider (11-27-2011)
 Old 04-22-2012, 09:57 PM   #32
Fi2ost's Avatar
Posts: 65   (View Stats)
Fi2ost is a splendid one to beholdFi2ost is a splendid one to beholdFi2ost is a splendid one to beholdFi2ost is a splendid one to beholdFi2ost is a splendid one to beholdFi2ost is a splendid one to beholdFi2ost is a splendid one to behold
Just did this install awesome guide much thanks!
Fi2ost is offline   Reply With Quote
 Old 10-17-2012, 06:31 AM   #33
tdjach's Avatar
Posts: 7   (View Stats)
tdjach will become famous soon enough
great walk-through, cant wait to get back to the states and install
tdjach is offline   Reply With Quote
 Old 05-21-2013, 07:48 PM   #34
MaikuMS3's Avatar
Posts: 47   (View Stats)
MaikuMS3 has a spectacular aura aboutMaikuMS3 has a spectacular aura aboutMaikuMS3 has a spectacular aura about
i have jbr chromely and ill use this guide to install mine.
MaikuMS3 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f387/cp-e-rear-engine-mount-review-16713/
Corksport inserts or replace whole motor mount? - 2010-13 Mazda 3/Mazdaspeed 3 Forums This thread Refback 02-27-2013 06:30 PM
CP-E Discount Offering - 2012 Mazda 3/Mazdaspeed 3 Forums This thread Refback 12-19-2012 05:39 AM
Corksport inserts or replace whole motor mount? - 2012 Mazda 3/Mazdaspeed 3 Forums This thread Refback 10-30-2012 06:12 PM
Rear Motor Mounts | ZoomSquared This thread Refback 04-20-2011 07:30 AM
bruit sous le capot. - Mazda 3 Quebec This thread Refback 04-18-2011 08:31 PM
cp-e 75 duro rear motor mount | Flickr - Photo Sharing! This thread Refback 04-12-2011 04:34 PM
Picked up my MS3 last night - Page 2 - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Refback 12-02-2010 09:14 AM
cp-e 75 duro rear motor mount on Flickr - Photo Sharing! This thread Refback 04-22-2010 12:33 AM
CR Havoc rear engine mount Review! tagkat MazdaSpeed 3 - Engine, Transmission & Driveline 4 10-29-2008 12:21 AM
my review - TRZ "Dog Bone" Rear Motor Mount melan47 MazdaSpeed 3 - Engine, Transmission & Driveline 3 10-24-2008 09:29 AM
Page generated in 0.56637 seconds with 48 queries
