> Mazdaspeed Forums User Reviews
Mazdaspeed Forums User Reviews These are reviews done by our community members.
 Old 08-23-2009, 09:02 PM   #1
pewpew
Sacrilicious's Avatar
Posts: 2,452   (View Stats)
Groaned at 9 Times in 9 Posts
Default Forge BPV version 2: Review
Ok, guys. I know you've all been waiting a long time for this, and I apologize for keeping you waiting for so long, but I didn't want to let anything slip before Forge made its official announcement about this valve's release. For reference, here is the official product link for this new valve from Forge Motorsport: Forge Motorsport | Alloy Fabrication The new valve retails for $185, which is $15 more than the old valve ($170). Hopefully, this will mean that the usual retailers will drop this down to something even more reasonable like the old v1 valve (at ~$155).
What is this "version 2" release, you ask? Well, Forge has long been aware of the main complaint that has plagued its MS3/MS6/CX7 BPV: what IS that pinging sound??? Other than this sole complaint, the Forge BPV has probably been the single most functional (and affordable) valve out there for our cars. It fits like stock, doesn't cause fueling issues (reference this thread for more info: http://www.mazdaspeedforum.org/forum/foru...ect-ltfts.html), is tunable, is more responsive, and is way sturdier than stock. In an effort to fix this "problem" (and this really is a subjective preference here), Forge has been working on a redesign for their popular MS3/MS6/CX7 BPV to take away the "ping" for quite some time now. Unfortunately, I am not fit to comment on why it took so long to bring this product to market, but let's all rejoice that it's finally here!
To start, let's show a few overhead shots of this valve in a car with a stock intercooler:
...and a Cobb FMIC:
This new valve has definitely completely taken away the "ping" from before! The things that I like most about it are:
1. It sounds like a more aggressive version of the stock valve under heavy release (think more gutsy "pssh") and about like stock under light release.
2. Like the old valve, there is absolutely no fluttering upon release. One clean release is all you get when the valve fires off.
3. It is still every bit as tunable as the old version, meaning you can adjust your valve to make sure it does not screw with your fuel trims.
There is one thing to look out for is that fitment is definitely tighter. Since Forge had to change the direction the piston fires, it caused the valve to grow large, which brought it a lot closer to the stock intercooler cover. Here's a shot of what I mean:
As you can see, the top of the valve is slightly pressing against the TMIC cover. This means that if you are using this with a stock TMIC, you may have to play some games with how you angle the valve and the recirculation hose that connects it back to the turbo inlet. This is not a terribly big deal, though, since the Forge valve is adjustable in what angle the valve faces. All you have to do is loosen the plate holding valve base in place by inserting the points of needle nose pliers into the marked holes and twisting:
For FMIC users, this is obviously not a problem. I would recommend using a new recirc hose bought from SU or something just for easy of fitment, since the stock one is pretty rigid. If you want to orient the valve as you see in the stock TMIC pictures above, here's some pictures that show the angle that you need to turn your valve:
Overall, I am absolutely loving this valve. As I said, it fixes the only thing that annoyed me about the Forge BPV (the ping), and left me with all the things that I loved about it. Yes, the fitment is tighter, but it's really not that big of a deal compared to some of the other valves out there, so I definitely don't sweat it. Before anyone asks, I have found that like the v1 valve, the blue spring and two shims seem to work very well for me on both stock and up to 21 psi tunes. As far as longevity goes, I've been running this valve since December 2008, and it's never given me any trouble at all. I definitely give it a two thumbs up and recommend it without reservations! If you've been looking really hard at the Forge BPV, but just couldn't stand the sound it made, here's your chance to have your cake and eat it!
Sorry, I will have sound clips up in the next day or two, so stay tuned...=d
Sacrilicious is offline   Reply With Quote
The Following 37 Users Say Thank You to Sacrilicious For This Useful Post:
2008MS3H (04-14-2012), 802MS3 (08-23-2009), AmillieMS6 (08-28-2009), Anklh (12-15-2009), atenza_freak (10-13-2009), bioevolve (09-29-2009), Breakdown81 (08-23-2009), burntRice (03-14-2011), Chief_Wiggum (10-02-2009), cookieheadjenkins (03-15-2010), DaleNixon (12-02-2009), Darksun280 (10-08-2009), Decepticon (09-29-2009), dread (12-02-2009), evidence (08-23-2009), FreeFlyFreak (08-23-2009), GLORIFIEDBOZO (09-01-2011), gsrtype1 (08-28-2009), Haltech (08-23-2009), hashboogie (09-05-2009), JBR (12-04-2009), JmkC (08-23-2009), jon619 (10-11-2009), jscass2000 (04-12-2014), kpsoerensen (08-01-2010), Lama (08-23-2009), madvillain (10-09-2009), MATT DAMOND (08-23-2009), Mistersix (10-05-2009), ms3077 (12-08-2009), ponny135 (12-08-2009), popecruz (08-23-2009), RayRayBauder (08-23-2009), tunersteve (09-30-2009), usmc_adams (04-27-2010), Zeya (08-25-2009), _Toxic_ (12-15-2009)
 Old 08-23-2009, 09:19 PM   #2
I have candy in my van
MATT DAMOND's Avatar
Posts: 1,931   (View Stats)
Groans: 70
I just heard about the V2 like 2 days ago, (I've been living under a rock) but I am very excited about it.
I honestly hate the swords clashing every time I shift, it gets annoying fast, since my MS6 is my DD.
Current Fail:
 Old 08-23-2009, 10:45 PM   #3
speedtown's Avatar
Posts: 533   (View Stats)
speedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the worldspeedtown is the leader of the world
i don't even notice the ping any more, but when I do hear it I still love it. Though I wouldn't mind having the new version either. It's nice there are choices for people now though. I'm sure there will be plenty of V1 going up for sale soon.
speedtown is offline   Reply With Quote
 Old 08-28-2009, 01:05 PM   #4
manelscout4life's Avatar
Posts: 1,781   (View Stats)
Groans: 661
what ever happen to the sound clip?
 Old 08-28-2009, 01:25 PM   #5
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
Nice!
 Old 08-28-2009, 01:30 PM   #6
AmillieMS6's Avatar
Posts: 1,700   (View Stats)
AmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the world
Groans: 365
Groaned at 594 Times in 575 Posts
lol no vids?
Mazdaspeed
AmillieMS6 is offline   Reply With Quote
The Following User Says Thank You to AmillieMS6 For This Useful Post:
HammerChile11 (11-23-2013)
The Following User Says NO Thank You to AmillieMS6 For This Un-useful Post:
 Old 09-29-2009, 07:54 AM   #7
TongMan's Avatar
Posts: 444   (View Stats)
TongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond reputeTongMan has a reputation beyond repute
Which spring and how many shims should I run with Mazdaspeed CAI and Cobb Turbo Inlet for the best results?
2009 Crystal White Pearl Mazdaspeed3 Sport **SOLD**
2010 Monterey Blue Nissan 370z Base w/ Sport Package 6MT
TongMan is offline   Reply With Quote
 Old 09-29-2009, 08:44 AM   #8
clos561's Avatar
Posts: 1,172   (View Stats)
clos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the world
Originally Posted by AmillieMS6 View Post
lol no vids?
get you get vids sac? in car and some drive by shifts?
7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance
clos561 is offline   Reply With Quote
 Old 09-30-2009, 08:55 AM   #9
tunersteve's Avatar
Posts: 869   (View Stats)
tunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the world
I wish they'd do a trade-in program for all of the V1 owners out there. Good review.
2011 Mustang GT
tunersteve is offline   Reply With Quote
 Old 09-30-2009, 04:00 PM   #10
AmillieMS6's Avatar
Groans: 365
soo video ???
Mazdaspeed
 Old 09-30-2009, 05:03 PM   #11
Lama's Avatar
Posts: 339   (View Stats)
Lama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond reputeLama has a reputation beyond repute
Where is the video?
Mazdaspeed 6 2007 GT : Cobb AccessPORT, Cobb Stage 2+SF TIH 91 BT map, Cobb SF SRI, Cobb Turbo Inlet, Cobb shifter weight, Cobb XLE BPV, Cp-e TMIC, SAMCO Xtraflex recirc hose, AutoEXE Boost tubes, CP-e Rear Motor Mount, Cp-e diff mount, SURE juggernaut, Magnaflow Catback , SU Test pipe, TWM Short Shifter Stage 2 & Bushings, DashHawk, Denso ITV-22, RPM sport springs, whiteline RSB, freins Rotora, TSW nurburgring wheels
Lama is offline   Reply With Quote
 Old 10-05-2009, 08:28 PM   #12
Mistersix's Avatar
Posts: 2,585   (View Stats)
i got rid of my forge because the ping wasnt doin it for me. but the V1 works great, so this is good news.
lookin forward to them clips.
 Old 10-08-2009, 12:17 AM   #13
romeox929's Avatar
Posts: 207   (View Stats)
romeox929 has much to be proud ofromeox929 has much to be proud ofromeox929 has much to be proud ofromeox929 has much to be proud ofromeox929 has much to be proud ofromeox929 has much to be proud ofromeox929 has much to be proud ofromeox929 has much to be proud ofromeox929 has much to be proud ofromeox929 has much to be proud of
so, about them clips..
romeox929 is offline   Reply With Quote
 Old 10-12-2009, 07:12 PM   #14
Mistersix's Avatar
eh, clips never really do any justice anyways. unless you have an external mic for a camera its gonna sound like butt!
 Old 10-13-2009, 12:04 AM   #15
atenza_freak's Avatar
Posts: 613   (View Stats)
atenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the world
Sick
2010 ford focus
andy
atenza_freak is offline   Reply With Quote
 Old 10-16-2009, 07:42 AM   #16
wcm250f's Avatar
Posts: 174   (View Stats)
wcm250f has much to be proud ofwcm250f has much to be proud ofwcm250f has much to be proud ofwcm250f has much to be proud ofwcm250f has much to be proud ofwcm250f has much to be proud ofwcm250f has much to be proud ofwcm250f has much to be proud ofwcm250f has much to be proud of
how about that video. i am very interested to hear how it sounds
wcm250f is offline   Reply With Quote
 Old 10-16-2009, 08:08 AM   #17
RayRayBauder's Avatar
Posts: 1,999   (View Stats)
RayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the world
Groans: 234
Groaned at 154 Times in 122 Posts
^ nice avatar? where you live?
'08 MazdaSpeed3 - sold
RayRayBauder is offline   Reply With Quote
The Following User Says Thank You to RayRayBauder For This Useful Post:
evidence (10-16-2009)
 Old 10-16-2009, 04:00 PM   #18
evidence's Avatar
Posts: 1,033   (View Stats)
In a forum with 99.5% dudes, there is only one reason why you would have that as your avatar. Looks like RayRay hit the jackpot this time..
sound clip/video++ .. does anyone have this installed yet?
Some things.
The Following User Says Thank You to evidence For This Useful Post:
FreeFlyFreak (10-16-2009)
 Old 12-02-2009, 02:14 PM   #19
dread's Avatar
Posts: 1,223   (View Stats)
dread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the world
is this available yet
[SIGPIC]http://i163.photobucket.com/albums/t318/dreadedhero/DSCN2058-2.jpg[/SIGPIC]
2007 ms3 sport black mica completely stock
dread is offline   Reply With Quote
 Old 12-02-2009, 02:24 PM   #20
KeysMS3's Avatar
Posts: 341   (View Stats)
KeysMS3 is the leader of the worldKeysMS3 is the leader of the worldKeysMS3 is the leader of the worldKeysMS3 is the leader of the worldKeysMS3 is the leader of the worldKeysMS3 is the leader of the worldKeysMS3 is the leader of the worldKeysMS3 is the leader of the worldKeysMS3 is the leader of the worldKeysMS3 is the leader of the worldKeysMS3 is the leader of the world
Groaned at 8 Times in 3 Posts
yup
Mazda3Online :: ProtegeGarage :: MazdaRX8Online - Your Source for Mazda Performance
KeysMS3 is offline   Reply With Quote
 Old 12-02-2009, 05:34 PM   #21
DSIT995's Avatar
Posts: 1,768   (View Stats)
Mine should be arriving tomorrow Ill try and post a sound clip
99 Miata NB - Stock for now
 Old 12-02-2009, 06:08 PM   #22
flyrevs2's Avatar
Posts: 1,235   (View Stats)
need sound clips bad - santa wants to hear before he loads up the sleigh
2013 Mazdaspeed3 Gen2
flyrevs2 is offline   Reply With Quote
 Old 12-02-2009, 06:19 PM   #23
syoo6's Avatar
Posts: 103   (View Stats)
syoo6 is a jewel in the roughsyoo6 is a jewel in the roughsyoo6 is a jewel in the rough
^ +1
syoo6 is offline   Reply With Quote
 Old 12-02-2009, 06:37 PM   #24
dimaxxxl's Avatar
Posts: 397   (View Stats)
dimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the world
Default Re: Forge BPV version 2: Review
+2
2010 Mazdaspeed3 with Tech package
Mazdaspeed Intake in SRI
DDM 6000K HID's
Turbosmart Dual Port BOV
dimaxxxl is offline   Reply With Quote
 Old 12-03-2009, 12:29 PM   #25
pewpew
sorry, guys...i've been out of touch and my camera is dead, so i still need to get a new one before i can make the vid...=/
 Old 12-07-2009, 07:24 PM   #26
Got one today. Sounds nice, looks nice, built nice. Blue no shims for now. I will try other combinations tomorrow.
Jamie
 Old 12-07-2009, 08:29 PM   #27
evidence's Avatar
Jamie
The spring will break in over the first couple of drive cycles. Prob good to run it that way an reevaluate in a week or two. Might need to drop a shim in later.
Sound clips or vids?
Some things.
 Old 12-08-2009, 04:20 AM   #28
ponny135's Avatar
Posts: 20   (View Stats)
ponny135 is a jewel in the roughponny135 is a jewel in the roughponny135 is a jewel in the rough
How the hell you open the valve to change the springs?? I am twisting it with all I got... no luck
ponny135 is offline   Reply With Quote
 Old 12-08-2009, 11:11 AM   #29
evidence's Avatar
If it's off the car compress the piston a few times to make sure nothings wedged.. then grab some gloves. Just the top 1/2 inch comes off, the piece with the small nipple.
Some things.
 Old 12-08-2009, 11:17 AM   #30
You are referring to the new V2 valve correct? If so the end that comes off, is the end that the bypass tube connects to. Not the end with the vacuum connection.
Jamie
 Old 12-09-2009, 01:25 AM   #31
ponny135's Avatar
thank you guys for pointing me to the right end lol! got no gloves thou, so I said f**** it and I used the wise grip on it wt a towel to not scrach it.
This valve is sturdy. I mean the outlet and all is thick, I was not afraid of bending it at all. Here is a pic of what I found. cheers.
The Following 2 Users Say Thank You to ponny135 For This Useful Post:
kpsoerensen (08-01-2010), Sacrilicious (12-09-2009)
 Old 12-09-2009, 11:23 AM   #32
pewpew
i have to say that the black valve looks niiice...
 Old 12-09-2009, 12:20 PM   #33
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
So Moderator..... approve the attached photos so we can all see them ;-p
Suspension:
 Old 12-09-2009, 12:23 PM   #34
pewpew
haha...whoops, i didn't even notice they were still pending...
The Following User Says Thank You to Sacrilicious For This Useful Post:
FreeFlyFreak (12-09-2009)
 Old 12-15-2009, 06:22 AM   #35
I really hear no significant difference in it compared to the stock BPV. So my opinion is it's a job well done.
Jamie
 Old 01-11-2010, 02:01 AM   #36
OMGWTFHAX's Avatar
Posts: 445   (View Stats)
OMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the world
Groaned at 26 Times in 25 Posts
Any clips or vids of this yet?
Flickr
Originally Posted by Andrew85 View Post
Wow kid... how about LOL @ you for being a piece of garbage without a purpose in life. For one thing, im not really bragging, just sharing an experience. Another thing is that you like men and your opinions dont count cause you take it up the poop shute.
OMGWTFHAX is offline   Reply With Quote
 Old 01-11-2010, 02:24 AM   #37
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
by far the worst looking valve ever , b=neck and neck with omgthanx crushed dsm one
hope it performs well
The Following 2 Users Say Thank You to rodrigo For This Useful Post:
FreeFlyFreak (01-11-2010), OMGWTFHAX (01-11-2010)
 Old 01-15-2010, 01:28 PM   #38
cletusb's Avatar
Posts: 488   (View Stats)
Agreed, for a somewhere "rice" mod it is quite ugly
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f387/forge-boost-bypass-valve-version-2-review-36265/
?????? ??????? Forge version 2 This thread Refback 04-03-2012 12:15 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
COBB AP Version 2?!?!?! bioevolve MazdaSpeed 3/6 - ECU Computer Tuning 9 06-29-2009 02:05 PM
Opel to get its own version of Volt Haltech Automotive News 0 10-04-2008 07:10 AM
Next VW GTI puts out 210 hp, R version gets AWD and 270 hp Haltech Automotive News 0 09-22-2008 11:40 AM
Now hear this! There will be no M version of the BMW X5 Haltech Automotive News 0 04-11-2008 12:50 PM
Page generated in 0.54160 seconds with 48 queries
