 Old 11-02-2009, 07:19 PM   #1
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Default I need some parts.
Cosworth YD0212
Cosworth PR8044
Cosworth KK3484
2006 Mazdaspeed 6
 Old 11-02-2009, 07:50 PM   #2
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
What the hell ARE you up too? I get nervous when you, Lex, or whoosh get Ideas.....
Carry on citizens....
10.7 @ 133 auto 1G DSM
06Speed6 (11-02-2009)
 Old 11-02-2009, 07:56 PM   #3
Target:STi's Avatar
Posts: 289   (View Stats)
Target:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the world
edit nvm
Formerly: TG 06 MS6- CAI, TMIC, TBE
Currently: RR 08 Evo X- SRI, UICP, TP, CBE, Tune
Target:STi is offline   Reply With Quote
 Old 11-02-2009, 08:18 PM   #4
phantom3's Avatar
Posts: 1,223   (View Stats)
Groans: 190
A PCV block off plate,
An exhaust manifold flange,
and a balance shaft delete kit?
Are you building a WMD?
seriously though,
For the BSD I tapped the oil hole for a brass plug and sealed it up... .49cents.
As for the other parts, a local machine shop can make them easily if you provide the originals. Unless the exhaust flange has magic properties... lol
EDIT: I'm suprised your not putting this in http://www.cosworthusa.com/store/pc/...&idproduct=306 Oil control/PCV Fix/Oil Cooling all in 1!
EDIT 2: I see why you wan the exhaust flange... no EGR on it.
My mission is to go fast.
Currently Designing:
The golden girdle of the gods
The CF "fuck your face" IM
phantom3 is offline   Reply With Quote
 Old 11-02-2009, 08:53 PM   #5
Speeeeeed
06Speed6's Avatar
I am rebuilding the PCV system, I may not actually use that plate but I have some ideas for it.
Yeah my built head doesnt have a EGR, so if I can buy a flange that deletes it on that end, I am set.
Dry sump... hahah yeah baby!
2006 Mazdaspeed 6
 Old 11-03-2009, 04:08 PM   #6
maperformance's Avatar
Posts: 4,979   (View Stats)
You have a PM sir!!!!!
Modern Automotive Performance
The Following User Says Thank You to maperformance For This Useful Post:
06Speed6 (11-03-2009)
 Old 11-03-2009, 05:53 PM   #7
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
lol wow that dry sump is expensive lol
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
 Old 11-03-2009, 06:55 PM   #8
Speeeeeed
06Speed6's Avatar
For a 3 stage dry sump with the pump? Thats cheap lol.
2006 Mazdaspeed 6
phantom3 (11-03-2009)
 Old 11-03-2009, 07:02 PM   #9
phantom3's Avatar
Groans: 190
That's what I was thinking.... I might do a dry sump before I do an intake!
 Old 11-04-2009, 03:56 PM   #10
QuickSpool's Avatar
Posts: 235   (View Stats)
QuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to behold
Groaned at 9 Times in 5 Posts
All of those bolck parts will work on the DISI block? i.e. water pump, baffle block off, etc.
QuickSpool is offline   Reply With Quote
 Old 11-04-2009, 03:59 PM   #11
phantom3's Avatar
Groans: 190
I believe so... the major difference between the duratec and MZR is in the head, so to speak.
Parts from 1st gen MS3 that fit on 2nd gen MS3 9900rpm 2010 MS3 - Turbo Induction 48 01-07-2014 10:21 PM
Page generated in 0.30905 seconds with 26 queries
