 Old 02-05-2011, 02:27 PM   #1
maperformance's Avatar
Posts: 4,979   (View Stats)
Default MA Performance Product and Info Thread Rev 3 Intake Manifold
MAP is proud to introduce our Rev3 version of the Mazda 3/6 intake manifolds! This is unlike any other portwork offered for the platform. We start off removing the shutter valves and bar are removed for improved airflow capabilities, and as our dyno testing showed, it suffered no loss in the low and mid range! We then fully port both the runners and plenum, cut open the plenum and reshape for improved airflow, then weld everything back up.
We always test our manifolds before and after porting to ensure we are focused in the right areas. As it turns out, this manifold yielded some of the most impressive gains out of any of the manifolds we have done. The flow results show an improvement of 103CFM flow capacity, and an overall imbalance improvement from over 25% variance down to only 5.8%! See the flow chart for the data.
Why Choose MAP Porting & Polishing Services?
Our porting guru Bob Schreiber has worked on everything from NA applications to boosted nitrous applications, and from single cylinder recreational vehicles all the way to high performance super cars like the Dodge Viper SRT-10, and everything in between. Pulling from his education in fluid dynamics, airflow theory, physics, thermal dynamics, and his real world testing, he is able to bring us nothing less than the best porting and polishing solutions. Over the years he has developed custom tooling (unlike the competition) that allows him to port 'line of sight' and be able to get everything in a manifold even if it is a Viper intake plenum that is ~26" long!
If you are after the most from your setup, and need nothing less than the best porting solutions, look no further than your performance specialists at Modern Automotive Performance.
Contact me today with any questions, I am more than happy to show you what MAPerformance can do for your car!
Please contact us for unbeatable pricing on these products, also keep in mind we will match or beat any competitors pricing on so called "package deals"!
: Send us a PM|||||: BurdAtMAP|||||: 1-888-MAPERFORMANCE x 100|||||: Burd@maperformance.com
: The MAP blog - Get the inside track on what we're doing!|||||: Check us out on Facebook|||||: Follow us on Twitter
The Following 3 Users Say Thank You to maperformance For This Useful Post:
jracer (03-08-2011), rfinkle2 (03-30-2011), Speed3eak (04-18-2011)
DashDAQ Info thread liquoredonlife 2010 MS3 - ECU Computer Tuning 17 05-16-2011 09:29 PM
Bentley to shorten product cycles, focus on performance Haltech Automotive News 0 06-28-2010 06:50 AM
The Official Product Inquiry Thread! flz33 Mazdaspeed3/6 General Discussion 3 04-24-2010 01:48 PM
very valuable info in my engine knocking under load thread allmotor95pgt MazdaSpeed 3 - Engine, Transmission & Driveline 5 11-12-2008 07:35 AM
MS6 Boost Controller - Info Thread jhershorin MazdaSpeed 6 - Engine, Transmission & Driveline 15 09-01-2008 06:17 AM
Page generated in 0.66013 seconds with 26 queries
