 Old 03-03-2011, 03:56 PM   #41
maperformance's Avatar
Posts: 4,979   (View Stats)
So this is what happens if you get some contamination in your turbo. This unit locked the bearings up and spun them in the center section. The shaft was also found to bent as well, which put the wheels into the housings. The only part salvageable is the turbine housing. Not a cheap day for this fella.
Here at MAPerformance we can handle most turbocharger rebuilds. From your run of the mill TDO4 to an 80mm and beyond, we've got you covered!
Modern Automotive Performance
 Old 03-03-2011, 04:00 PM   #42
wankular's Avatar
Posts: 4,343   (View Stats)
So have you guys ever had any mazdaspeeds in your shop for work to be done?
2009 MS3 sport MGM
The Following 2 Users Say Thank You to wankular For This Useful Post:
djuosnteisn (03-03-2011), SpeedSixxx (03-03-2011)
 Old 03-03-2011, 04:04 PM   #43
Yea quiet a bit actually...mostly tuning or clutch installs, not a ton of "hardcore" performance like we are used to with our Evo / Subaru customers though.
If you want to come by and get something done I will pretend like you're the first if it'll make your day
The Following 4 Users Say Thank You to maperformance For This Useful Post:
Broxer (04-08-2011), jracer (03-08-2011), SpeedSixxx (03-03-2011), wankular (03-04-2011)
 Old 03-03-2011, 04:25 PM   #44
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
What clutch do you guys prefer, and how have they performed? Also, what kind of power have the tuned cars been making? Any big turbo guys in there?
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
BrianZX10R (03-03-2011), SpeedSixxx (03-03-2011)
 Old 03-03-2011, 04:33 PM   #45
We generally run Spec or ACT and have good performance from both
As for tuning the only big turbo cars were all down in Panama where Jordan street tuned them so we do not have any dyno numbers
The Following 2 Users Say Thank You to maperformance For This Useful Post:
 Old 03-03-2011, 04:36 PM   #46
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
Groans: 778
all the BT speeds were down in panama?
I wonder why those south/central americans havnt joined this fourm.
 Old 03-03-2011, 06:04 PM   #47
holeinmypocket's Avatar
Posts: 1,129   (View Stats)
holeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the worldholeinmypocket is the leader of the world
once i get my shit rolling i plan on getting a tune from jordan at map...so it could be their first big turbo tuned ms3 at their shop
holeinmypocket is offline   Reply With Quote
The Following 2 Users Say Thank You to holeinmypocket For This Useful Post:
djuosnteisn (03-04-2011), SpeedSixxx (03-03-2011)
 Old 03-03-2011, 09:16 PM   #48
LOL yes 2 cars with gt3076 or bigger....not sure why they are not on here...check out out blog to see some pictures of his trip!
The Following User Says Thank You to maperformance For This Useful Post:
 Old 03-04-2011, 11:10 AM   #49
i plan on running a gt3582r or pte 6262...hopefully i can ultilize those turbos well enough with our rev limiter
 Old 03-04-2011, 04:06 PM   #50
It's been an exciting yet emotional day around here today! One of our welding machines had a baby!
We certainly hope it can keep up with its much larger counterparts. Welcome to the family little fella!
 Old 03-07-2011, 05:45 PM   #51
These are getting more popular around here... This is a stage 4 4B11T cylinder head on our Serdi valve and guide machine.
This little machine cuts our time required for cutting valve seats in half. Oh how magical it is!
 Old 03-08-2011, 12:46 AM   #52
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
Good stuff !!
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
 Old 03-08-2011, 04:46 PM   #53
So I mentioned some shop shenanigans. So as promised here is Potter showing us his how you ride a quad!
We tuned this little hot rod up for a great customer of ours who was so kind to let us have this photo opportunity.
 Old 03-10-2011, 05:11 PM   #54
So little Jim here is doing a very important task. He's assembling our pressure test equipment for the EVO 8/9 rev 2 & 3 intake manifolds.
The manifolds are pressurized and if any leaks are found, sealed up and tested again till they hold pressure.
 Old 03-11-2011, 04:25 PM   #55
I was in the back shop office and came across these little fellas. Do you think these will fit on a civic?
These bad boys are for our RX7 that will be competing in the King Street class this season.
 Old 03-11-2011, 04:34 PM   #56
JMEngineer's Avatar
Posts: 2,122   (View Stats)
Now I really want to buy another RWD car.
-GTX2867R Coming Soon
 Old 03-14-2011, 05:46 PM   #57
Ok... So can anyone tell me what the heck this thing is?
I want one!
 Old 03-17-2011, 01:05 PM   #58
The RX7 is getting it's new tires mounted. So here she sits all lonesome on the lift.
 Old 03-21-2011, 11:06 AM   #59
Pm me for the best deals!!!
 Old 03-22-2011, 05:25 PM   #60
So how many of you have seen one of these fine decals? Due to the rain we're having... I'm unable to deliver you a full vehicle shot at this time. Stay tuned! :p
Here's something you don't see everyday. But what we have here is Kyle checking valve spring pressure and coil bind.
When assembling an engine with an odd combination of components, it is very important to make sure they are compatible.
Last edited by maperformance; 03-22-2011 at 05:25 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-23-2011, 05:42 PM   #61
Bump!!!
 Old 03-24-2011, 05:17 PM   #62
Nothing too crazy today kids, just Kyle welding up this 4" section of stainless for an exhaust.
Just remember we can handle any fabrication project you may have. No project is too big or too small!
This great customer had to drop by for some quick touch-ups. His stock turbo inlet was leaking so he upgraded to an aftermarket silicone unit.
We highly suggest a re-tune after any engine modification! He was in and out in an hour.
Last edited by maperformance; 03-24-2011 at 05:17 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-25-2011, 04:40 PM   #63
Man, look at all these virgins waiting to be built!
 Old 03-29-2011, 09:01 AM   #64
All of our fabricated manifolds are precision Tig welded and of course back purged as shown here.
djuosnteisn (03-29-2011)
 Old 03-30-2011, 05:14 PM   #65
Now that warm season is coming, I'm sure the daily update will more often than not be something on the dyno. So... on with today!
2005 SRT-4
Garrett 50trim Turbo
FIC Injectors
Walbro 255
Diablosport Predator
FMIC
Short Ram Intake
Jordan tuned
 Old 03-30-2011, 05:16 PM   #66
Captain
How many employees does MAP consist of?
www.permtuning.com
 Old 04-01-2011, 09:23 AM   #67
Currently 32 if I am not mistaken....we just picked up a few new sales people.
djuosnteisn (04-01-2011)
 Old 04-01-2011, 09:33 AM   #68
Captain
Damn, that's a healthy sized operation. Very nice.
www.permtuning.com
 Old 04-05-2011, 08:38 AM   #69
So here's some behind the scenes for ya! The band saw is a key player in the fabrication department!
We cut many of our precise fitting pieces with this handy machine. Not sure we could do it without it!
Today we did a little install on our EVO X. We swapped the stock springs out for the Swift Sport Springs!
They provide a modest drop, very straight forward install, and smooth ride!
Last edited by maperformance; 04-05-2011 at 08:38 AM. Reason: MSF Database - Automerged Doublepost
jracer (04-05-2011)
 Old 04-06-2011, 11:12 AM   #70
More dyno results for you kids!
2004 Subaru WRX
Stock besides the exhuast
Invidia Turbo-Back Exhaust
Invidia Up-Pipe
Jordan Tuned
 Old 04-08-2011, 06:09 PM   #71
Another EVO X in the shop today for a spring install. This one got a set of Eibach Sportlines.
We had this 2007 Mustang GT in the shop this morning for three baseline pulls. It will be getting a few mods then brought back in for tuning later.
Last edited by maperformance; 04-08-2011 at 06:09 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-08-2011, 06:42 PM   #72
Broxer's Avatar
Posts: 875   (View Stats)
Broxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the world
Groans: 90
Nice stuff, keep it up.
2012 Triumph Street Triple
SOLD -- 2010 Velocity Mica Red MS3
ATP GTX3071r - Cobb AP(Freek Permed) - CNT Catted DP - UR CBE - DO Stage 2 WMI(80/20) - cp-e TMIC - cp-e xcelXL - cp-e invicid inlet - Grimmspeed MBC - KMD v2.2 hpfp internals - Bosch 3bar MAP - H&R Springs - DDM 6k Raptor Kit - ITV22's - Forge v2 BPV - 225/40/18 Nitto Neogens - SURE RMM
Broxer is offline   Reply With Quote
 Old 04-13-2011, 01:01 PM   #73
Today we had this really clean FC RX7 come into the shop for a custom downpipe.
 Old 04-15-2011, 08:13 AM   #74
This VERY clean 2003 GTi was on the dyno today. I sure love those wheels!
Some more dyno action. This one has been fighting Jordan. Definitely a software issue, hopefully we can get it sorted out soon! It made over 500whp the last time we tuned it though.
Last edited by maperformance; 04-15-2011 at 08:13 AM. Reason: MSF Database - Automerged Doublepost
 Old 04-19-2011, 08:14 AM   #75
So I'm not sure what we're doing with this camaro, but it's here and I took a picture of it for you folks. I like them, I hope you do to.
Todays adventure consisted of this clean 1999 Acura Integra LS.
Stock B18B1
Crower Cams/Valvesprings/Retainers
Victor X Intake Manifold
1000cc Injectors
255 pump
AEM ems
Omnipower 3bar
MAP T3 Turbo Manifold
MAP 3" DP & Dumptube
PTE 6262
E85
Jordan Tuned
We had a number of components fight us along the way, however after swapping some parts out we were able to finish it up.
Click here to view the dyno graph!
Last edited by maperformance; 04-19-2011 at 08:14 AM. Reason: MSF Database - Automerged Doublepost
 Old 04-19-2011, 11:21 AM   #76
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
Just ordered an AEM replacement Intake filter from Daelen today.
Great price on it.
Thanks a bunch.
What a lovable bunch we are!!
 Old 04-19-2011, 05:38 PM   #77
No problem thank you sir!!!
 Old 04-21-2011, 08:28 AM   #78
Just another Turbo Honda on the dyno machine.
 Old 05-06-2011, 11:22 AM   #79
FridayGt's Avatar
Posts: 695   (View Stats)
FridayGt is the leader of the worldFridayGt is the leader of the worldFridayGt is the leader of the worldFridayGt is the leader of the worldFridayGt is the leader of the worldFridayGt is the leader of the worldFridayGt is the leader of the worldFridayGt is the leader of the worldFridayGt is the leader of the worldFridayGt is the leader of the worldFridayGt is the leader of the world
FYHN.
That is all... lol.
-- 2010 MazdaSpeed3
- Current Mod(s): Ventus V12's, CP-E RMM, CS SRI, CS TIP, JBR Stage 2 SSP, 35% Tint, COBB AP, COBB XLE BPV
- Planned Mod(s): JBR Knob, JBR Rear Sway, PMM, CS HPFP (Please), CS Catback, CS TMIC, Driver Mod, Cawk Mod
Originally Posted by Dre View Post
if you get an sri, kiss your mpg goodbye cuz you're gonna be balls deep in that throttle whenever you get the chance..
FridayGt is offline   Reply With Quote
 Old 05-09-2011, 04:51 PM   #80
PM me for the all time best deals!!!
MAPerformance Ported Intake Manifold subparpunk03 Modern Automotive Performance 153 10-27-2015 07:24 AM
MAPerformance Rev3 Intake Manifold (Mazdaspeed 3/6) maperformance Modern Automotive Performance 37 02-04-2011 11:46 AM
SEMA behind the scenes! John F Mazdaspeed3/6 General Discussion 0 01-21-2011 02:13 PM
Unbeatable pricing on the Fidanza flywheel for MS3 & MS6 from MAPerformance! maperformance Modern Automotive Performance 230 07-06-2009 11:31 AM
Page generated in 0.55872 seconds with 29 queries
