Mazdaspeed Forums
-   Modern Automotive Performance (http://www.mazdaspeedforum.org/forum/forum/f392/)
-   -   New MS products on maperformance.com (http://www.mazdaspeedforum.org/forum/forum/f392/new-ms-products-maperformance-com-113685/)
maperformance 05-14-2012 03:17 PM
http://www.maperformance.com/img/for...eed-header.jpg
http://www.maperformance.com/img/forums/tb-maprace.pnghttp://www.maperformance.com/img/forums/tb-whymap.pnghttp://www.maperformance.com/img/forums/tb-services.pnghttp://www.maperformance.com/img/for...-clearance.pnghttp://www.maperformance.com/img/for...-customers.png
http://www.maperformance.com/img/forums/sep.png
Tons of new products have been added to the MAPerformance website.
KSport Kontrol Pro Coilovers Mazdaspeed3 (07-12)
http://www.edgeautosport.com/product...45955_zoom.jpg
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of damping adjustment allow you to fine tune the ride to your handling and comfort needs. The damping adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Where available, camber canbe adjusted via the Pillow-ball Top Mounts, which means no additional "Camber Kits" are needed.
36 levels of adjustable damping
Made from high quality 6061 aluminum with T6 for increased hardness
Compression/Rebound adjustable
Adjustable spring perch for height adjustment
Adjustable body allowing maximum suspension travel
Pillowball top mount with adjustable camber (not available for some models)
Monotube high pressure design reduces oil leakage
Electroplated body for protection from corrosion and rust
One year limited warranty
The Mazdaspeed 3 specific kit features pillowball top mounts for the front and aluminum top mounts for the rear. Spring rates are as follows:
Front: 12.2 kgf/mm 683 lb/in
Rear: 4.7kgf/mm 263 lb/in
http://www.cobbtuning.com//v/vspfile.../771500-2T.jpg
Netting a + 11 HP and + 16 lb. ft. gain, the COBB Tuning SF Intake utilizes our custom CFD design to maintain optimal flow and generate ideal performance. The OEM MazdaSpeed airbox is the most restrictive stock intake we have seen to date. Simply replacing it with the COBB Intake will allow your MazdaSpeed3 safe and consistent power gains!
The custom conical cloth filter feeds filtered air directly to the engine, while maintaining optimal intake velocity and minimizing turbulence found with many aftermarket intake systems.
http://www.maperformance.com/img/forums/sep2.png
Please contact us for unbeatable pricing on these products, also keep in mind we will match or beat any competitors pricing on so called "package deals"!
http://www.maperformance.com/img/forums/pm.png: Send us a PM|||||http://www.maperformance.com/img/forums/aim.png: DrewAtMAP|||||http://www.maperformance.com/img/forums/phone.png: 1-888-MAPERFORMANCE x 100|||||http://www.maperformance.com/img/forums/email.png: dreget@maperformance.com
http://www.maperformance.com/img/forums/social-bl.png|||||http://www.maperformance.com/img/forums/social-fb.png|||||http://www.maperformance.com/img/forums/social-tw.png|||||http://www.maperformance.com/img/forums/social-yt.png
http://www.maperformance.com/img/forums/footer.png
Raider 05-14-2012 04:51 PM
Good coilovers for under a grand! Nice!
smittyMS6 05-14-2012 04:58 PM
I had K Sports on my Talon. Loved them. Ride was a tad stiff but for the price it was worth it. I would get them again.
speed_freak91 05-14-2012 05:33 PM
More parts and within 1 hour driving distance... Awsome!!
maperformance 05-15-2012 08:54 AM
Check the website for our new MS Products added!
maperformance 05-16-2012 08:57 AM
maperformance 05-18-2012 08:03 AM
maperformance 05-21-2012 02:23 PM
maperformance 05-22-2012 04:13 PM
maperformance 05-24-2012 12:43 PM
maperformance 05-29-2012 09:46 AM
maperformance 05-31-2012 08:26 AM
jracer 06-02-2012 10:33 AM
Coilovers for the speed6 ?
memin 06-02-2012 11:30 AM
yea right!!!! we get no love like always.:hitwithrock:
maperformance 06-04-2012 10:26 AM
maperformance 06-05-2012 04:48 PM
maperformance 06-06-2012 04:47 PM
maperformance 06-07-2012 05:10 PM
maperformance 06-08-2012 05:38 PM
maperformance 06-11-2012 06:01 PM
maperformance 06-14-2012 08:33 AM
maperformance 06-18-2012 08:32 AM
maperformance 06-19-2012 02:37 PM
maperformance 06-20-2012 04:34 PM
maperformance 06-25-2012 07:23 PM
maperformance 06-26-2012 05:00 PM
maperformance 06-27-2012 04:43 PM
maperformance 06-29-2012 10:32 AM
maperformance 07-02-2012 05:33 PM
maperformance 07-03-2012 02:20 PM
maperformance 07-04-2012 02:04 PM
maperformance 07-06-2012 04:09 PM
secondchance 07-09-2012 10:35 PM
My ksports are in transit, and Drew handed over a DIRT CHEAP price.
Def worth giving him a call
maperformance 07-10-2012 04:15 PM
maperformance 07-12-2012 05:01 PM
maperformance 07-13-2012 05:26 PM
maperformance 07-16-2012 05:06 PM
maperformance 07-18-2012 03:39 PM
maperformance 07-19-2012 03:41 PM
maperformance 07-20-2012 05:16 PM
Page generated in 0.22915 seconds with 11 queries
