 Old 05-14-2012, 03:17 PM   #1
maperformance's Avatar
Posts: 4,979   (View Stats)
Default New MS products on maperformance.com
Tons of new products have been added to the MAPerformance website.
KSport Kontrol Pro Coilovers Mazdaspeed3 (07-12)
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of damping adjustment allow you to fine tune the ride to your handling and comfort needs. The damping adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Where available, camber canbe adjusted via the Pillow-ball Top Mounts, which means no additional "Camber Kits" are needed.
36 levels of adjustable damping
Made from high quality 6061 aluminum with T6 for increased hardness
Compression/Rebound adjustable
Adjustable spring perch for height adjustment
Adjustable body allowing maximum suspension travel
Pillowball top mount with adjustable camber (not available for some models)
Monotube high pressure design reduces oil leakage
Electroplated body for protection from corrosion and rust
One year limited warranty
The Mazdaspeed 3 specific kit features pillowball top mounts for the front and aluminum top mounts for the rear. Spring rates are as follows:
Front: 12.2 kgf/mm 683 lb/in
Rear: 4.7kgf/mm 263 lb/in
Netting a + 11 HP and + 16 lb. ft. gain, the COBB Tuning SF Intake utilizes our custom CFD design to maintain optimal flow and generate ideal performance. The OEM MazdaSpeed airbox is the most restrictive stock intake we have seen to date. Simply replacing it with the COBB Intake will allow your MazdaSpeed3 safe and consistent power gains!
The custom conical cloth filter feeds filtered air directly to the engine, while maintaining optimal intake velocity and minimizing turbulence found with many aftermarket intake systems.
Please contact us for unbeatable pricing on these products, also keep in mind we will match or beat any competitors pricing on so called "package deals"!
: Send us a PM|||||: DrewAtMAP|||||: 1-888-MAPERFORMANCE x 100|||||: dreget@maperformance.com
Modern Automotive Performance
MAPerformance the number one source for Cobb Products!!!! maperformance Modern Automotive Performance 111 05-22-2012 04:13 PM
MAPerformance is proud to offer Torque Solution Products for the Mazdaspeed!!! maperformance Modern Automotive Performance 42 03-21-2012 01:51 PM
Props to MAPerformance. predapio Modern Automotive Performance 8 09-26-2011 01:45 PM
MAPerformance Behind The Scenes maperformance Modern Automotive Performance 121 07-22-2011 10:55 AM
Page generated in 0.55659 seconds with 26 queries
