 Old 05-14-2012, 03:17 PM   #1
maperformance's Avatar
Posts: 4,979   (View Stats)
Default New MS products on maperformance.com
Tons of new products have been added to the MAPerformance website.
KSport Kontrol Pro Coilovers Mazdaspeed3 (07-12)
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of damping adjustment allow you to fine tune the ride to your handling and comfort needs. The damping adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Where available, camber canbe adjusted via the Pillow-ball Top Mounts, which means no additional "Camber Kits" are needed.
36 levels of adjustable damping
Made from high quality 6061 aluminum with T6 for increased hardness
Compression/Rebound adjustable
Adjustable spring perch for height adjustment
Adjustable body allowing maximum suspension travel
Pillowball top mount with adjustable camber (not available for some models)
Monotube high pressure design reduces oil leakage
Electroplated body for protection from corrosion and rust
One year limited warranty
The Mazdaspeed 3 specific kit features pillowball top mounts for the front and aluminum top mounts for the rear. Spring rates are as follows:
Front: 12.2 kgf/mm 683 lb/in
Rear: 4.7kgf/mm 263 lb/in
Netting a + 11 HP and + 16 lb. ft. gain, the COBB Tuning SF Intake utilizes our custom CFD design to maintain optimal flow and generate ideal performance. The OEM MazdaSpeed airbox is the most restrictive stock intake we have seen to date. Simply replacing it with the COBB Intake will allow your MazdaSpeed3 safe and consistent power gains!
The custom conical cloth filter feeds filtered air directly to the engine, while maintaining optimal intake velocity and minimizing turbulence found with many aftermarket intake systems.
Please contact us for unbeatable pricing on these products, also keep in mind we will match or beat any competitors pricing on so called "package deals"!
: Send us a PM|||||: DrewAtMAP|||||: 1-888-MAPERFORMANCE x 100|||||: dreget@maperformance.com
Modern Automotive Performance
 Old 05-14-2012, 04:51 PM   #2
Good coilovers for under a grand! Nice!
 Old 05-14-2012, 04:58 PM   #3
smittyMS6's Avatar
Posts: 474   (View Stats)
smittyMS6 is the leader of the worldsmittyMS6 is the leader of the worldsmittyMS6 is the leader of the worldsmittyMS6 is the leader of the worldsmittyMS6 is the leader of the worldsmittyMS6 is the leader of the worldsmittyMS6 is the leader of the worldsmittyMS6 is the leader of the worldsmittyMS6 is the leader of the worldsmittyMS6 is the leader of the worldsmittyMS6 is the leader of the world
I had K Sports on my Talon. Loved them. Ride was a tad stiff but for the price it was worth it. I would get them again.
06 Mazdaspeed 6 GT <*Cobb SRI TIP AP JBR HEAVYKNOB RMM CPe HPFP *>
smittyMS6 is offline   Reply With Quote
 Old 05-14-2012, 05:33 PM   #4
speed_freak91's Avatar
Posts: 1,189   (View Stats)
Groans: 34
More parts and within 1 hour driving distance... Awsome!!
speed_freak91 is offline   Reply With Quote
 Old 05-15-2012, 08:54 AM   #5
Check the website for our new MS Products added!
 Old 05-16-2012, 08:57 AM   #6
 Old 05-18-2012, 08:03 AM   #7
 Old 05-21-2012, 02:23 PM   #8
 Old 06-02-2012, 10:33 AM   #9
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
Coilovers for the speed6 ?
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
 Old 06-02-2012, 11:30 AM   #10
memin's Avatar
Posts: 994   (View Stats)
yea right!!!! we get no love like always.
 Old 06-04-2012, 10:26 AM   #11
 Old 06-05-2012, 04:48 PM   #12
 Old 06-06-2012, 04:47 PM   #13
 Old 06-07-2012, 05:10 PM   #14
 Old 07-09-2012, 10:35 PM   #15
secondchance's Avatar
Posts: 421   (View Stats)
secondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the world
Groaned at 114 Times in 37 Posts
My ksports are in transit, and Drew handed over a DIRT CHEAP price.
Def worth giving him a call
2009 Subaru WRX 265 Sedan || Cobb AP || Cobb SF intake w/ air box || Process West TMIC || Tein Springs || Grimspeed 3 port || Forge BPV || Invidia Catback || UR Downpipe || Kartboy short throw w/ cobb knob and bushings || Cobb Heatshield || DW65c fuel pump || NGK 1 steps
In Garage for Spring || HSD Coilovers || Eibach f+r sway bars || Whiteline positraction bushing kit || Kartboy Endlinks || Whitelink endlink reinforcements || GTSpec front + rear sway bars || Stoptech front and rear rotors,pads,lines
Sold
2007 MS3 295 whp 350 Torque
2010 Evo X 440AWHP 11.7 @ 113
2009 Ralliart w/ xswap 320AWHP (first in canadia to break 300whp in gen2 RA) 12.4@ 108
2004 srt-4 s2
2006 ms6
2005 srt-4 s3 w/toys 12.16 @ 117
secondchance is offline   Reply With Quote
 Old 07-10-2012, 04:15 PM   #16
 Old 07-12-2012, 05:01 PM   #17
 Old 07-13-2012, 05:26 PM   #18
 Old 07-16-2012, 05:06 PM   #19
 Old 07-18-2012, 03:39 PM   #20
 Old 07-19-2012, 03:41 PM   #21
 Old 07-20-2012, 05:16 PM   #22
 Old 07-23-2012, 04:45 PM   #23
 Old 07-24-2012, 04:52 PM   #24
 Old 07-25-2012, 03:50 PM   #25
 Old 07-26-2012, 04:59 PM   #26
 Old 07-27-2012, 04:58 PM   #27
 Old 07-30-2012, 04:54 PM   #28
 Old 07-31-2012, 04:40 PM   #29
 Old 08-01-2012, 05:15 PM   #30
 Old 08-02-2012, 05:10 PM   #31
 Old 08-03-2012, 04:33 PM   #32
 Old 08-06-2012, 03:31 PM   #33
 Old 08-07-2012, 04:55 PM   #34
 Old 08-08-2012, 05:20 PM   #35
 Old 08-09-2012, 03:29 PM   #36
 Old 08-10-2012, 05:15 PM   #37
MAPerformance the number one source for Cobb Products!!!! maperformance Modern Automotive Performance 111 05-22-2012 04:13 PM
MAPerformance is proud to offer Torque Solution Products for the Mazdaspeed!!! maperformance Modern Automotive Performance 42 03-21-2012 01:51 PM
Props to MAPerformance. predapio Modern Automotive Performance 8 09-26-2011 01:45 PM
MAPerformance Behind The Scenes maperformance Modern Automotive Performance 121 07-22-2011 10:55 AM
Page generated in 0.54121 seconds with 26 queries
