| Modern Automotive Performance Modern Automotive Performance is your source for sport compact performance! You can rely on MAPerformance to provide the best possible customer service and unbeatable prices on a huge selection of performance parts for your Mazdaspeed! |
| Approved MSF Vendor ![]() Join Date: Dec 2008
Rep Power: 280 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Tons of new products have been added to the MAPerformance website. KSport Kontrol Pro Coilovers Mazdaspeed3 (07-12) ![]() Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of damping adjustment allow you to fine tune the ride to your handling and comfort needs. The damping adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Where available, camber canbe adjusted via the Pillow-ball Top Mounts, which means no additional "Camber Kits" are needed. 36 levels of adjustable damping Made from high quality 6061 aluminum with T6 for increased hardness Compression/Rebound adjustable Adjustable spring perch for height adjustment Adjustable body allowing maximum suspension travel Pillowball top mount with adjustable camber (not available for some models) Monotube high pressure design reduces oil leakage Electroplated body for protection from corrosion and rust One year limited warranty The Mazdaspeed 3 specific kit features pillowball top mounts for the front and aluminum top mounts for the rear. Spring rates are as follows: Front: 12.2 kgf/mm 683 lb/in Rear: 4.7kgf/mm 263 lb/in Netting a + 11 HP and + 16 lb. ft. gain, the COBB Tuning SF Intake utilizes our custom CFD design to maintain optimal flow and generate ideal performance. The OEM MazdaSpeed airbox is the most restrictive stock intake we have seen to date. Simply replacing it with the COBB Intake will allow your MazdaSpeed3 safe and consistent power gains! The custom conical cloth filter feeds filtered air directly to the engine, while maintaining optimal intake velocity and minimizing turbulence found with many aftermarket intake systems. Please contact us for unbeatable pricing on these products, also keep in mind we will match or beat any competitors pricing on so called "package deals"!
__________________ Feel free to take a look at what our customer say about us, we will not let you down…try ME! WE WILL NOT BE BEATEN ON PRICING, bring us your lowest quote and we will do our best to match or beat it! We added a "Customer Rides" section to our site, if you'd like a chance to show off your ride and win some FREE GEAR submit your ride here! Modern Automotive Performance Email:JElmore@maperformance.com / AIM:JElmoreatMAP |
| Not Ranked : 0 score Good coilovers for under a grand! Nice! |
![]() Join Date: Nov 2011 Location: Carlisle, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,159
| Not Ranked : 0 score I had K Sports on my Talon. Loved them. Ride was a tad stiff but for the price it was worth it. I would get them again.
__________________ 06 Mazdaspeed 6 GT <*Cobb SRI TIP AP JBR HEAVYKNOB RMM CPe HPFP *> |
![]() Join Date: Mar 2011 Location: St. Boni, MN
Rep Power: 485 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 355
Groans: 34
| Not Ranked : 0 score More parts and within 1 hour driving distance... Awsome!! |
![]() Join Date: May 2009 Location: Clw/ NPR Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,516
Groans: 89
| Not Ranked : 0 score Coilovers for the speed6 ?
__________________ [SIGPIC][/SIGPIC] 2013 EVO X GSR Wicked White w/Areo H&R springs/H&R 15mm spacers MAP modified 3" Magna Flow cat back MAP catless testpipe MAP UICP Grimmspeed 3 port Cosworth filter SSP relay kit TWM Desert Eagle shift knob AEM wideband gauge Prosport boost gauge EvoX piller pod 30%Tint Slowpoke Tuned 339hp/336tq **** SOLD ***** 2006 speed6 " A woman's asshole is like a 9-volt battery..U know its wrong, but sooner or later ur gonna put ur tongue on it !! " |
![]() Join Date: Feb 2009 Location: Dupont wa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,527
| Not Ranked : 0 score yea right!!!! we get no love like always.
__________________ |
![]() Join Date: Oct 2008 Location: Calgary Alberta
Groaned at 114 Times in 37 Posts
| Not Ranked : 0 score My ksports are in transit, and Drew handed over a DIRT CHEAP price. Def worth giving him a call
__________________ 2009 Subaru WRX 265 Sedan || Cobb AP || Cobb SF intake w/ air box || Process West TMIC || Tein Springs || Grimspeed 3 port || Forge BPV || Invidia Catback || UR Downpipe || Kartboy short throw w/ cobb knob and bushings || Cobb Heatshield || DW65c fuel pump || NGK 1 steps In Garage for Spring || HSD Coilovers || Eibach f+r sway bars || Whiteline positraction bushing kit || Kartboy Endlinks || Whitelink endlink reinforcements || GTSpec front + rear sway bars || Stoptech front and rear rotors,pads,lines Sold 2007 MS3 295 whp 350 Torque 2010 Evo X 440AWHP 11.7 @ 113 2009 Ralliart w/ xswap 320AWHP (first in canadia to break 300whp in gen2 RA) 12.4@ 108 2004 srt-4 s2 2006 ms6 2005 srt-4 s3 w/toys 12.16 @ 117 |
![]() | | #19 | ![]() |
![]() | | #20 | ![]() |
![]() | | #21 | ![]() |
![]() | | #22 | ![]() |
![]() | | #23 | ![]() |
![]() | | #24 | ![]() |
![]() | | #25 | ![]() |
![]() | | #26 | ![]() |
![]() | | #27 | ![]() |
![]() | | #28 | ![]() |
![]() | | #29 | ![]() |
![]() | | #30 | ![]() |
![]() | | #31 | ![]() |
![]() | | #32 | ![]() |
![]() | | #33 | ![]() |
![]() | | #34 | ![]() |
![]() | | #35 | ![]() |
![]() | | #36 | ![]() |
![]() | | #37 | ![]() |
| Display Modes | |
| MAPerformance the number one source for Cobb Products!!!! | maperformance | Modern Automotive Performance | 111 | 05-22-2012 04:13 PM |
| MAPerformance is proud to offer Torque Solution Products for the Mazdaspeed!!! | maperformance | Modern Automotive Performance | 42 | 03-21-2012 01:51 PM |
| Props to MAPerformance. | predapio | Modern Automotive Performance | 8 | 09-26-2011 01:45 PM |
| MAPerformance Behind The Scenes | maperformance | Modern Automotive Performance | 121 | 07-22-2011 10:55 AM |
