  • 1 Post By skeurton
 Old 08-09-2011, 01:12 PM   #1
maperformance's Avatar
Posts: 4,979   (View Stats)
Default Redefining fast for two lovely ladies in MAP's 1000+whp Evolution
Modern Automotive Performance
 Old 08-09-2011, 01:19 PM   #2
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
broken
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
 Old 08-09-2011, 01:20 PM   #3
Rich-PMS's Avatar
Posts: 1,461   (View Stats)
Rich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the world
Groans: 68
i no see nothing
Rich-PMS is offline   Reply With Quote
 Old 08-09-2011, 01:24 PM   #4
Must Have Teh 10's!
less car, more lovely ladies
 Old 08-09-2011, 01:26 PM   #5
skeurton's Avatar
Posts: 745   (View Stats)
skeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the world
Needs moar MEGAN.
Hoyoman likes this.
2011 MAZDASPEED 3
BNR: 352 hp / 342 ft-lbs
K04: 296 hp / 343 ft-lbs
BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs EGR Delete Rear Sway Bar RMM PSMM TMM HTP 3" TIP Battery Tray SURE Motorsports 3" MAF Shortcut CounterShift Anchors AGS 621g Shift Knob Ultimate Racing Catted Downpipe Test Pipe Cat-Back Exhaust CP-e FMIC SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges
skeurton is offline   Reply With Quote
The Following 4 Users Say Thank You to skeurton For This Useful Post:
Alpha (08-09-2011), DONOTBUGME (09-12-2011), Fatguy729 (08-09-2011), Tokay444 (09-12-2011)
 Old 08-09-2011, 02:29 PM   #6
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
fixed
The Following User Says Thank You to Fatguy729 For This Useful Post:
Alpha (08-09-2011)
 Old 08-09-2011, 03:04 PM   #7
Fatguy729's Avatar
Groans: 82
btw that vidoe is WIN! @maperformance ... When are you guys gonna build a speed 3/6?
 Old 08-09-2011, 03:36 PM   #8
Lol at professional driver ... no helmets for anyone in a caged car ...
Silver Ecstasy (08-09-2011), Tokay444 (09-12-2011)
 Old 08-09-2011, 04:12 PM   #9
MSFer87's Avatar
Posts: 1,162   (View Stats)
Groans: 83
That things sounded more like a honda then I would have a imagined
The Following User Says Thank You to MSFer87 For This Useful Post:
tddvrrn (08-09-2011)
 Old 09-09-2011, 06:59 PM   #10
JohnMS3's Avatar
Posts: 754   (View Stats)
JohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the world
more of megan bump...
-John
| Cobb AP | Cobb SRI/TIP | CXRacing/Godspeed FMIC | AQ Motorsports downpipe | Mazdaspeed CBE | Autotech HPFP internals | Koni Yellows | Eibach Prokit | Progress RSB | Mazdaspeed camber arms | CPE RMM | TWM shortshifter/bushings | Redlinegoods shifter/e-brake boots | Defi Red Racer boost gauge | RPM ventpod | OEM RX8 wheels | Yokohama S-drive 245/40/18 | Volt 4300K HID | Ho-en yellow fogs | Mazda5 rear rotors | Dual Fiamm horns |
JohnMS3 is offline   Reply With Quote
 Old 09-12-2011, 12:40 PM   #11
hahah Noted
 Old 09-12-2011, 12:46 PM   #12
4G63's Avatar
Posts: 1,479   (View Stats)
Groans: 123
@maperformance Hopefully picking up an Evo Wednesday or later this week! Can't wait to spend my money with you haha
2003 Evo VIII
 Old 09-12-2011, 01:17 PM   #13
-cj-'s Avatar
Posts: 649   (View Stats)
-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world
I constantly redefine fast with the ladies too!
Mod List: ATP 3071R @ 22 psi, Grimspeed in 3-port mode, Steedspeed Manifold, Snow Performance Stage 2 Meth Kit, Cobb AP, CP-E 3" Nano SRI, CP-E Big Inlet TIP, Cobb "Stage 2" Suspension Kit, CP-E FMIC, CP-E DP, CP-E HPFP, CP-E MM, TWM STS, Custom Tuned by Fobio.
-cj- is offline   Reply With Quote
The Following User Says Thank You to -cj- For This Useful Post:
wolly6973 (09-12-2011)
 Old 09-12-2011, 01:27 PM   #14
HAHAHAHHA
 Old 09-12-2011, 01:30 PM   #15
Jarods7920's Avatar
Posts: 1,415   (View Stats)
Def more megan!
 Old 09-12-2011, 03:11 PM   #16
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
What quantifies Kyle as a "professional"?
He looks scared shitless, and the girls just look lime they're having a blast.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 09-12-2011, 07:22 PM   #17
Jarods7920's Avatar
ummm...clearly the "professional" is enough of of credential to qualify him!
 Old 09-12-2011, 08:04 PM   #18
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Dude kept looking over to see if one of their titties popped out
NATOR PA
Tokay444 (09-13-2011)
 Old 09-12-2011, 08:18 PM   #19
fhaze's Avatar
Posts: 552   (View Stats)
fhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the world
Groaned at 9 Times in 9 Posts
I dunno..1k+HP EVO, and the girls look mildly amused.
Conclusion: They are the professionals.
Goodbye 06MS6 you were a great car.
2011 STi Limited w/ NAV Plasma Blue Pearl, Escort 9500ix, Invidia Catted TBE 3" Q300 Ti Tip, Cobb CAI + Box, AP Stage 2+ 93, Kartboy SS w/ Bushings, Rally Armor Flaps.
303whp/330lbft Pro-Tuned @ EFI Logics
“A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens, and you go faster.”
--Mr. Clarkson
fhaze is offline   Reply With Quote
The Following User Says Thank You to fhaze For This Useful Post:
 Old 09-12-2011, 11:27 PM   #20
Danish's Avatar
Posts: 595   (View Stats)
Danish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the world
Groaned at 249 Times in 46 Posts
You guys can have the mousey looking one. I'll take the curly haired/massive chested one
Evo sounds and looks fast as hell. Nice job all around.
Danish is offline   Reply With Quote
 Old 09-12-2011, 11:34 PM   #21
MazdaASM's Avatar
Posts: 491   (View Stats)
MazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the world
Groaned at 9 Times in 7 Posts
driver needs weight reduction mod...
MazdaASM is offline   Reply With Quote
The Following User Says Thank You to MazdaASM For This Useful Post:
 Old 09-13-2011, 02:24 PM   #22
yes he does lol
 Old 09-13-2011, 04:31 PM   #23
bscar's Avatar
Posts: 1,846   (View Stats)
bscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the world
Groans: 46
bscar is offline   Reply With Quote
The Following User Says Thank You to bscar For This Useful Post:
-cj- (09-13-2011)
 Old 07-12-2012, 12:13 AM   #24
stogi1knobi's Avatar
Posts: 70   (View Stats)
stogi1knobi will become famous soon enoughstogi1knobi will become famous soon enough
@mapperformance what track is that? BIR?
stogi1knobi is offline   Reply With Quote
 Old 07-12-2012, 03:47 AM   #25
Tokay444's Avatar
Groans: 793
The extra p is for pm.
As in, "pm him for a great deal."
Demodded.
The Seals
 Old 08-03-2012, 04:52 PM   #26
Tokay444 has got it right.
The Following User Says Thank You to maperformance For This Useful Post:
Tokay444 (08-03-2012)
Now That's Fast: UK Ford dealers take 1000 orders for Focus RS Haltech Automotive News 0 09-11-2008 05:50 PM
Page generated in 0.44865 seconds with 37 queries
