| Modern Automotive Performance Modern Automotive Performance is your source for sport compact performance! You can rely on MAPerformance to provide the best possible customer service and unbeatable prices on a huge selection of performance parts for your Mazdaspeed! |
| Approved MSF Vendor ![]() Join Date: Dec 2008
Rep Power: 280 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
__________________ Feel free to take a look at what our customer say about us, we will not let you down…try ME! WE WILL NOT BE BEATEN ON PRICING, bring us your lowest quote and we will do our best to match or beat it! We added a "Customer Rides" section to our site, if you'd like a chance to show off your ride and win some FREE GEAR submit your ride here! Modern Automotive Performance Email:JElmore@maperformance.com / AIM:JElmoreatMAP Last edited by maperformance; 08-09-2011 at 05:02 PM. |
| Not Ranked : 0 score broken
| Banned ![]() ![]() Join Date: Apr 2011 Location: Lanoka Harbor, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 238
Groans: 68
| Not Ranked : 0 score i no see nothing |
| Not Ranked : 0 score less car, more lovely ladies
![]() Join Date: Mar 2011 Location: Hampton, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28,760
| Not Ranked : 0 score Needs moar MEGAN.
__________________ 2011 MAZDASPEED 3 BNR: 352 hp / 342 ft-lbs K04: 296 hp / 343 ft-lbs BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges |
| The Following 4 Users Say Thank You to skeurton For This Useful Post: |
![]() Join Date: Dec 2010 Location: Muncie, Indiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,066
Groans: 82
| Not Ranked : 0 score Last edited by maperformance; 08-09-2011 at 05:02 PM. |
| The Following User Says Thank You to Fatguy729 For This Useful Post: | Alpha (08-09-2011) |
Groans: 82
| Not Ranked : 0 score btw that vidoe is WIN! @maperformance ... When are you guys gonna build a speed 3/6? |
| Not Ranked : 0 score Lol at professional driver ... no helmets for anyone in a caged car ... |
| The Following 2 Users Say Thank You to Lex For This Useful Post: | Silver Ecstasy (08-09-2011), Tokay444 (09-12-2011) |
![]() Join Date: May 2011 Location: Portage, IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,113
Groans: 83
| Not Ranked : 0 score That things sounded more like a honda then I would have a imagined
__________________ -#1 2007 Mazdaspeed 3 GT Black Mica - BBS RX in Dark Gray, KW V2s, SPC Camber Arms, Cobb AccessPORT w/ JBR mount, Full-Race Prostock Mani, TurboXS FMIC, Grimmspeed EBC, ACT 6 puck & flywheel, TWM STS, PTP Internals, Cobb SRI w/ TIP, Cobb Shift Weight, TurboXS BPV, TurboXS Full TBE, JBR Trilogy, JBR RSB, Cobb FSB...........needs bigger turbo -1970 Chevelle - Needs full resto |
| The Following User Says Thank You to MSFer87 For This Useful Post: | tddvrrn (08-09-2011) |
![]() Join Date: May 2009 Location: Duarte, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 472
| Not Ranked : 0 score more of megan bump...
__________________ -John ![]() | Cobb AP | Cobb SRI/TIP | CXRacing/Godspeed FMIC | AQ Motorsports downpipe | Mazdaspeed CBE | Autotech HPFP internals | Koni Yellows | Eibach Prokit | Progress RSB | Mazdaspeed camber arms | CPE RMM | TWM shortshifter/bushings | Redlinegoods shifter/e-brake boots | Defi Red Racer boost gauge | RPM ventpod | OEM RX8 wheels | Yokohama S-drive 245/40/18 | Volt 4300K HID | Ho-en yellow fogs | Mazda5 rear rotors | Dual Fiamm horns | |
(Thread Starter) | Not Ranked : 0 score hahah Noted
__________________ Feel free to take a look at what our customer say about us, we will not let you down…try ME! WE WILL NOT BE BEATEN ON PRICING, bring us your lowest quote and we will do our best to match or beat it! We added a "Customer Rides" section to our site, if you'd like a chance to show off your ride and win some FREE GEAR submit your ride here! Modern Automotive Performance Email:JElmore@maperformance.com / AIM:JElmoreatMAP |
![]() Join Date: Mar 2010 Location: STL, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,038
Groans: 123
| Not Ranked : 0 score @maperformance Hopefully picking up an Evo Wednesday or later this week! Can't wait to spend my money with you haha
__________________ 2003 Evo VIII BUILD PLANS: LR 2.0/2.4, 6466, 800+whp. Shooting for 9s at full weight. Time is on my side, gonna take forever. Old: 2009 White MS3. Fully bolted and tuned. Sold |
![]() Join Date: Apr 2009 Location: Great White North
Rep Power: 512 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,214
| Not Ranked : 0 score I constantly redefine fast with the ladies too!
__________________ Mod List: ATP 3071R @ 22 psi, Grimspeed in 3-port mode, Steedspeed Manifold, Snow Performance Stage 2 Meth Kit, Cobb AP, CP-E 3" Nano SRI, CP-E Big Inlet TIP, Cobb "Stage 2" Suspension Kit, CP-E FMIC, CP-E DP, CP-E HPFP, CP-E MM, TWM STS, Custom Tuned by Fobio. |
| The Following User Says Thank You to -cj- For This Useful Post: | wolly6973 (09-12-2011) |
![]() Join Date: Nov 2010 Location: Marion, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 413
Groans: 46
| The Following User Says Thank You to bscar For This Useful Post: | -cj- (09-13-2011) |
(Thread Starter) | Not Ranked : 0 score HAHAHAHHA
![]() Join Date: Jul 2008 Location: Imperial MO
Rep Power: 581 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 127
| Not Ranked : 0 score Def more megan!
__________________ 2008 MazdaSpeed 3 AWD big turbo...blah blah blah |
| jbr makes fall-a-parts. ![]() Join Date: Jan 2011 Location: Cambridge Ontario Canada
Rep Power: 13536 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,744
Groans: 793
| Not Ranked : 0 score What quantifies Kyle as a "professional"? He looks scared shitless, and the girls just look lime they're having a blast.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
| Not Ranked : 0 score ummm...clearly the "professional" is enough of of credential to qualify him!
![]() | | #19 | ![]() |
Groans: 224
| Not Ranked : 0 score Dude kept looking over to see if one of their titties popped out
| The Following User Says Thank You to MS3-a(sore)ASS-rex For This Useful Post: | Tokay444 (09-13-2011) |
![]() | | #20 | ![]() |
![]() Join Date: Jan 2009 Location: Western MA
Rep Power: 388 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 96
Groaned at 9 Times in 9 Posts
| Not Ranked : 0 score I dunno..1k+HP EVO, and the girls look mildly amused. Conclusion: They are the professionals.
__________________ Goodbye 06MS6 you were a great car. 2011 STi Limited w/ NAV Plasma Blue Pearl, Escort 9500ix, Invidia Catted TBE 3" Q300 Ti Tip, Cobb CAI + Box, AP Stage 2+ 93, Kartboy SS w/ Bushings, Rally Armor Flaps. 303whp/330lbft Pro-Tuned @ EFI Logics “A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens, and you go faster.” --Mr. Clarkson |
| The Following User Says Thank You to fhaze For This Useful Post: | Tokay444 (09-13-2011) |
![]() | | #21 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 189
Groaned at 249 Times in 46 Posts
| Not Ranked : 0 score You guys can have the mousey looking one. I'll take the curly haired/massive chested one ![]() Evo sounds and looks fast as hell. Nice job all around. |
![]() | | #22 | ![]() |
![]() Join Date: Feb 2011 Location: Seattle
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 136
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score driver needs weight reduction mod... |
| The Following User Says Thank You to MazdaASM For This Useful Post: | Tokay444 (09-13-2011) |
![]() | | #23 | ![]() |
(Thread Starter) | Not Ranked : 0 score yes he does lol
![]() | | #24 | ![]() |
![]() Join Date: Dec 2011 Location: Minneapolis Mn
Rep Power: 0 ![]() ![]() Thanks: 22
| Not Ranked : 0 score @mapperformance what track is that? BIR? |
![]() | | #25 | ![]() |
Groans: 793
| Not Ranked : 0 score The extra p is for pm. As in, "pm him for a great deal."
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score Tokay444 has got it right.
| The Following User Says Thank You to maperformance For This Useful Post: | Tokay444 (08-03-2012) |
| Now That's Fast: UK Ford dealers take 1000 orders for Focus RS | Haltech | Automotive News | 0 | 09-11-2008 05:50 PM |
