| Modern Automotive Performance Modern Automotive Performance is your source for sport compact performance! You can rely on MAPerformance to provide the best possible customer service and unbeatable prices on a huge selection of performance parts for your Mazdaspeed! |
| Approved MSF Vendor ![]() Join Date: Dec 2008
Rep Power: 280 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score ![]() It has come to my attention that Fidanza makes a flywheel for the Mazdaspeed 3 & 6 platforms. It just so happens that we are a Fidanza master warehouse distributor Check it out on our website by clicking here, and be sure to let me know if you have seen a better price as we will not be beat on Fidanza products!
__________________ Feel free to take a look at what our customer say about us, we will not let you down…try ME! WE WILL NOT BE BEATEN ON PRICING, bring us your lowest quote and we will do our best to match or beat it! We added a "Customer Rides" section to our site, if you'd like a chance to show off your ride and win some FREE GEAR submit your ride here! Modern Automotive Performance Email:JElmore@maperformance.com / AIM:JElmoreatMAP |
| Not Ranked : 0 score Seriously? Thats $40 cheaper than the GB price that I bought mine for lol
![]() Join Date: Jun 2008 Location: Atlanta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 98
| Not Ranked : 0 score Damn,thats a good price.I to bought mine in the group by,what kind of price can you give on a Spec 3+ clutch?
__________________ I BUSTED SOCKS CHERRY AND IT WAS GOOOOD![]() I'VE BEEN PLAYING DUMB FOR SO LONG ITS NOT A GAME ANYMORE IF IT WAS WORTH THE TIME IT TOOK YOU TO GET EVEN THAN WHY DIDNT YOU TAKE A LITTLE MORE AND GET AHEAD? |
I'll shoot you over a price via PM, should be pretty competitive
__________________ Feel free to take a look at what our customer say about us, we will not let you down…try ME! WE WILL NOT BE BEATEN ON PRICING, bring us your lowest quote and we will do our best to match or beat it! We added a "Customer Rides" section to our site, if you'd like a chance to show off your ride and win some FREE GEAR submit your ride here! Modern Automotive Performance Email:JElmore@maperformance.com / AIM:JElmoreatMAP | |
![]() Join Date: May 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
Groaned at 16 Times in 11 Posts
| Not Ranked : 0 score ![]() ![]() ![]() ![]() ![]() ![]() welcome I'm sure this will make other sponsors step up to there pricing
Groans: 78
| Not Ranked : 0 score goddddd i want i want i want
__________________ [Precision 5557 T4 flanged Journal Bearing Turbo][Race Roots Ceramic Coated T4 Manifold][Race Roots 3" V-Band Catless Downpipe][Race Roots Under-Car FMIC kit][CXracing 18"x31"x3" IC Core][Tial 44mm EWG With 0.9Bar Spring][Cobb AP][Full Str33tunit Mount Set][Madvillain 4" Inlet/Intake][Cp-e xcelXL Maf Housing][Devilsown Meth Injection Kit][HKS Ignition Amplifier][Cp-e Catback Exhaust][HKS bov][PTP IM Spacer][Whoosh EGR Delete][AEM Digital Boost Gauge][Matt Damond OCC Kit][Trunk Mounted Optima Battery with KnuKonceptz Kit][Madvillain ECU box][TWM Short Shifter][BC Coilovers][Cobb Rear Sway Bar][Falken Azenis rt615's][Eibach Pro 25mm Spacers] |
| Not Ranked : 0 score how much is shipping for this item to Canada ? i will assume now that i have FMIC this will fit my MS3 =) GTSPEC Type-D Front Strut Brace for Mazda 3 - Modern Automotive Performance
(Thread Starter) | Not Ranked : 0 score PM sent thanks!
(Thread Starter) | Not Ranked : 0 score Bump.
(Thread Starter) | Not Ranked : 0 score Bump. |
| Not Ranked : 0 score Sweet you guys are local! Any info on weight? I've got a MS6 and I've heard that the super light ones are a pain to drive with the weight of our car and the AWD. |
(Thread Starter) | Not Ranked : 0 score 11.15lbs sir, it is on the lighter side but some of their flywheels get into the 9lb range!
![]() Join Date: Mar 2008 Location: STL, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,984
| Not Ranked : 0 score Yeah, the stocker is in the ballpark of 42lbs. Weather you go with the Fidanza/spec combo or the ACT set up, you'll have a HUGE reduction in weight. |
| RIP May 9th, 2012 ![]() Join Date: Mar 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18
![]() | | #19 | ![]() |
![]() | | #20 | ![]() |
![]() | | #21 | ![]() |
![]() | | #22 | ![]() |
| Not Ranked : 0 score Bump for better pricing on the Spec Stage 3+ !!!! |
![]() | | #23 | ![]() |
(Thread Starter) | Not Ranked : 0 score What prices have you guys been able to buy the Spec Stage 3+ for? I see some advertisements for very low pricing, but Spec assures me that there is a different discount level on the 3+ clutches and those people advertising them for so low must not be aware of it. Anyone that has actually purchased one please let me know what the best price you were able to get was, thanks!
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score Haha yeah I need to work on that, I'll keep you posted!
![]() | | #25 | ![]() |
![]() | | #26 | ![]() |
![]() | | #27 | ![]() |
![]() | | #28 | ![]() |
![]() | | #29 | ![]() |
![]() | | #30 | ![]() |
![]() | | #31 | ![]() |
![]() | | #32 | ![]() |
![]() | | #33 | ![]() |
![]() | | #34 | ![]() |
![]() | | #35 | ![]() |
![]() | | #36 | ![]() |
![]() | | #37 | ![]() |
![]() | | #38 | ![]() |
![]() | | #39 | ![]() |
![]() | | #40 | ![]() |
(Thread Starter) | Not Ranked : 0 score We bump our threads so that they show up in the new posts section of the forum and thus potential customers...
| GB: Fidanza Flywheels for MS3 and MS6 | CaptainKRM | Mazdaspeed3/6 General Discussion | 182 | 03-10-2009 05:13 PM |
| Fidanza Flywheels Now In Stock and Shipping | CaptainKRM | Mazdaspeed3/6 General Discussion | 2 | 11-19-2008 10:26 AM |
| The New Golf BlueMotion: Unbeatable Economy | Haltech | Automotive News | 0 | 10-10-2008 10:10 AM |
