| Modern Automotive Performance Modern Automotive Performance is your source for sport compact performance! You can rely on MAPerformance to provide the best possible customer service and unbeatable prices on a huge selection of performance parts for your Mazdaspeed! |
![]() | | #41 | ![]() |
![]() Join Date: Apr 2011 Location: Decatur, Illinois
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 129
Groaned at 8 Times in 7 Posts
| Not Ranked : 0 score
__________________ 2007-Mazdaspeed 6 BNRSIII~all supportings Zoom Zoom Boom part out. |
![]() | | #42 | ![]() |
![]() Join Date: Nov 2010 Location: Breckenridge CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 69
| Not Ranked : 0 score COILS for both the ms3 and 6, since ppl streching the stock ones is nuts, and the HKS twinpower is just too damn expensive or a bigger Throttle body? oh and of course any sort of body kit for a ms6 would be amazing
__________________ Fresh to High Rockies Colorado from VA DC area MS6 07 TiGray! Cpe: FMIC, CAI, TIP, HPFP, bone engine mount Cobb AP, Test pipe, turbosmart BPV, whitlenine swaybar Turbine Tech: Extra front motor mount, both diff mounts +bushings EGR Delete, mini 0803 Dash cam, Prosport Boost guage. Dash Hawk, AWR: Trans mount with 88 duro bushings, End links front/rear(removed due to them being total garbage and got some moog stock ones for all around on rockauto. 17x7 Kosei K1 TS 15lb rims, goodyear 225/50r17 all season performance tires and RPM springs Waiting to install: SPC Ball Joints, SS clutch line, lower engine mount bracket local car shop damaged during clutch install and thermal TB gasket and coolant inline plumbing line that can be turned on and off on demand |
| The Following User Says Thank You to leo766 For This Useful Post: | Alpha (10-04-2011) |
![]() | | #43 | ![]() |
![]() Join Date: Aug 2011 Location: Charlotte, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 36
| Not Ranked : 0 score This would be sweet. A relatively simple bolt on awd system, that you could install with a couple buddies and a relatively well stocked garage in a weekend. If it was less than 3k or so, I think people would be interested. The only downside to this awesome platform is the fwd. I think people will eventually get to 600+ whp, but it's useless with fwd. I plan to keep my car ten years at least, and awd would keep me from jumping to a sti or evo earlier. Sent from my DROIDX using Tapatalk
__________________ 2010 MS3 - Liquid Silver - tech package, Nav, Bose - Cobb AP - HPFP from HPFPUpgrades - JBR Cro-Mo Dogbone RMM - JBR SSP and solid bushings - tinted windows - Ultragauge - CS SRI/TIP - Super duper tranny fluid - Denso ITV22 plugs. wish list - Catted DP, EGR block off, intake and throttle thermal gaskets, OCC, throttle coolant bypass maybe list - BSD, top or front IC, cat back exhaust 2010 CX-7 Grand Touring - Silver - Fiance's car (owned by me though). |
![]() | | #44 | ![]() |
| Not Ranked : 0 score for 3k ud be lucky if the AWD they made could handle 100hp much less 600, its not as simple as you clearly think it is.. you would need a new tranny which would cost you 3k, then a custom driveshaft, 2k more, than a diff and axels with mounts that somehow latch on to anchor points that a ms3 simply doesnt have... another 1k so your looking at 6k and another 6k in labor, so 12k and thats if your lucky you might as well ask for a mystery box that adds 100hp for $1000 it would be much more feasable sorry for being such a troll, but cmon man, 3k to make a car awd, even a mazda 6 cant be converted to a MS6 for anywhere close to that if at all, and not to mention if you do the math, the parts in the ms6 that make it an AWD car, actually cost about 10k all together, but they are also mass produced but ye MAP needs to make a Intake manifold with real velocity stacks, or maybe even laminova water to air cores in it for that extra coolness super-sex
| The Following 2 Users Say NO Thank You to leo766 For This Un-useful Post: | Easter Bunny (10-05-2011), Fatguy729 (10-05-2011) |
![]() | | #45 | ![]() |
![]() Join Date: Dec 2010 Location: Muncie, Indiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,066
Groans: 82
Nothing pisses me off more than someone who posts a load of bullshit about something they clearly know nothing about. you are a fucking toolbag and have absolutely no clue what you're talking about... Please do not spread misinformation on this forum about things you don't know your ass from a hole in the ground. Considering I have personally spoke to the person building PT 5857 + AWD , who said he has LESS THAN 2k in the AWD portion of his build... kinda fucks with your whole post... granted, no company would sell it for 3k... but most of the things you mentioned would be cake work with someone who can weld... the hardest part is relocating the fuel tank. oh, AND PLEASE tell me why the fuck you would need a new transmission? ...
__________________ ... TRADED : 07 MS3 GT Silver... fully bolted w/K04 CURRENT : 06 MS6 GT Silver.... KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6 Last edited by Fatguy729; 10-05-2011 at 01:28 AM. | |
| The Following 3 Users Say Thank You to Fatguy729 For This Useful Post: |
![]() | | #46 | ![]() |
| Not Ranked : 0 score You actually don't need to relocate the fuel tank. The guy with the blog bought one made for a volvo, since they share a platform. Basically bolted on. But yeah, you need to be able to weld. I can kinda weld, but not well enough I'd trust my car to it. I've got plenty of time to learn though, before even considering this swap. Sent from my DROIDX using Tapatalk
![]() | | #47 | ![]() |
| Approved MSF Vendor ![]() Join Date: Dec 2008
Rep Power: 280 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Pm me for a great deal!!!
__________________ Feel free to take a look at what our customer say about us, we will not let you down…try ME! WE WILL NOT BE BEATEN ON PRICING, bring us your lowest quote and we will do our best to match or beat it! We added a "Customer Rides" section to our site, if you'd like a chance to show off your ride and win some FREE GEAR submit your ride here! Modern Automotive Performance Email:JElmore@maperformance.com / AIM:JElmoreatMAP |
![]() | | #48 | ![]() |
![]() Join Date: May 2009 Location: Chicago, IL
Rep Power: 10249 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,116
Groans: 136
| Not Ranked : 0 score Condoms. That way I'll rest assured they won't break. Tapadatass
__________________ |
![]() | | #49 | ![]() |
| jbr makes fall-a-parts. ![]() Join Date: Jan 2011 Location: Cambridge Ontario Canada
Rep Power: 13536 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,744
Groans: 793
| Not Ranked : 0 score Lol. Volk ce28n's $3000 Awd conversion kit. $3000. Riiiiiight.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals Last edited by Tokay444; 10-13-2011 at 03:52 AM. |
![]() | | #50 | ![]() |
![]() Join Date: Jun 2011 Location: Wilmington, Delaware
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 612
Groaned at 25 Times in 10 Posts
| Not Ranked : 0 score Intake manifold, cams and injectors
__________________ If your not first your last. ![]() 03 Speed Protege.. SOLD 10 Speed3 BT and getting my DRANK on!!! |
| The Following User Says Thank You to vrspeed10 For This Useful Post: | Alpha (11-28-2011) |
![]() | | #51 | ![]() |
![]() Join Date: Jan 2010 Location: Ladera Ranch, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 91
| Not Ranked : 0 score 3" vband dp, intake manifold, 3" tip Tapadatass
__________________ 2008 MAZDASPEED 3 GT | Cobb SRI | Cobb XLE BPV | SURE TIP | SURE RMM | Resonators Deleted | TurboXs Catless DP | | Cobb AP Stage 2+ | PG/Godspeed FMIC | BC Coilovers | Evo X Wheels | 245/40/18 Hankook RS3 | | Cquence Drilled/Slotted Rotors | Hawk HPS Pads | TWM STS | Glowshift Boost Gauge | Sti V Limited Front Lip | |
![]() | | #52 | ![]() |
Groans: 82
| Not Ranked : 0 score IMO the injectors... Even finding a way to simply improve the oem would be the highest selling, most needed mod for this platform. There are already IM solutions, atp makes a 3 inch dp with v band adapter. Cams would be cool but unnecessary ATM IMO... Every high power speed owner will tell you the main issue is fueling.
__________________ ... TRADED : 07 MS3 GT Silver... fully bolted w/K04 CURRENT : 06 MS6 GT Silver.... KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6 |
![]() | | #53 | ![]() |
The 3" dp with vband is for the ms6 not the ms3. But yes I agree with injectors. Tapadatass
__________________ 2008 MAZDASPEED 3 GT | Cobb SRI | Cobb XLE BPV | SURE TIP | SURE RMM | Resonators Deleted | TurboXs Catless DP | | Cobb AP Stage 2+ | PG/Godspeed FMIC | BC Coilovers | Evo X Wheels | 245/40/18 Hankook RS3 | | Cquence Drilled/Slotted Rotors | Hawk HPS Pads | TWM STS | Glowshift Boost Gauge | Sti V Limited Front Lip | | |
![]() | | #54 | ![]() |
![]() Join Date: May 2010 Location: Goldsboro NC
| Not Ranked : 0 score anything for the speed6 lol. We need all the options we can get. |
![]() | | #55 | ![]() |
![]() ![]() Join Date: May 2011 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 336
Groaned at 33 Times in 10 Posts
| Not Ranked : 0 score a FMIC for genpu that's less than $600
__________________ 2012 Toyota Tacoma |
![]() | | #56 | ![]() |
![]() Join Date: Dec 2009 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,256
| Not Ranked : 0 score As stated by many... Injectors and a proper Intake Manfiold would sell like crazy!
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() |
![]() | | #57 | ![]() |
![]() Join Date: Jul 2008 Location: Imperial MO
Rep Power: 581 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 127
__________________ 2008 MazdaSpeed 3 AWD big turbo...blah blah blah | |
| The Following User Says Thank You to Jarods7920 For This Useful Post: | Tokay444 (11-28-2011) |
![]() | | #58 | ![]() |
| Banned ![]() Join Date: Sep 2009 Location: La Crosse, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 309
| Not Ranked : 0 score i would have thought that map would have made something by now....but this thread seems pointless |
| The Following User Says Thank You to holeinmypocket For This Useful Post: | thehead (11-29-2011) |
![]() | | #59 | ![]() |
(Thread Starter) | Not Ranked : 0 score There really has not been anything very realistic unfortunately. We offer a ported intake manifold as it is. As for a sheet metal there are not many people willing to comit to one.
| The Following User Says NO Thank You to maperformance For This Un-useful Post: | holeinmypocket (01-02-2012) |
![]() | | #60 | ![]() |
![]() Join Date: Sep 2011 Location: Santa Ana,CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 274
| Not Ranked : 0 score A grill for genpu that would sell
__________________ Performance CobbAPCobbSRI/TIPAutotechInternalsDensoITV22 PlugsForgeBPVJBRDog Bone MountSpeed DaddyCatless DownpipeGreddyOCC Appearance DDM5000k Headlights/3000k FogsCobbShift KnobCorksportLED Bumper LightsDepoLED Tails E85 |
| MAPerformance Ported Intake Manifold | subparpunk03 | Modern Automotive Performance | 153 | 10-27-2015 07:24 AM |
| Props to MAPerformance. | predapio | Modern Automotive Performance | 8 | 09-26-2011 01:45 PM |
| MAPerformance Behind The Scenes | maperformance | Modern Automotive Performance | 121 | 07-22-2011 10:55 AM |
| Latest Fab @ MAPerformance | maperformance | Modern Automotive Performance | 23 | 05-06-2011 01:54 PM |
