Like Tree24Likes
 Old 04-02-2014, 07:20 PM   #41
bunta's Avatar
Posts: 42   (View Stats)
bunta has a spectacular aura aboutbunta has a spectacular aura about
Ordered mine yesterday. NEED THIS SNAIL ASAP!!! my k04 is smoking
bunta is offline   Reply With Quote
 Old 04-03-2014, 12:20 PM   #42
RPM
RPM's Avatar
Posts: 1,149   (View Stats)
For those of you getting the S2/S3 that have silicone turbo inlet pipes, you'll need to replace it since you can't just buy a new coupler for the turbo side like those with hard inlet pipes. The best solution we've found so far is the HTP 2.5" or 3.0" TIP with a 2.5" coupler, which would be a direct replacement, allowing you to keep whatever intake you're using.
Or, you could go with a full 3.0" (or larger) HTP intake system with a 2.5" coupler, but, since the BNR pushes the intake to the right a bit, you would need to either relocate your ECU (if you keep the stock battery tray), or go with the HTP+tray combo.
We're hosting a GB (ends in less than a week) for the HTP intakes and combos, so you might consider jumping on that if this is your plan!
GB: HTP BIG Intake + Small Battery Tray + Stratified S-OTS PLUS Tune!
 Old 04-03-2014, 02:36 PM   #43
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
To the right? Does that mean pushes it out... Do you know by how much? I wonder if my 3.5 will be able to fit with stock tray. I was thinking maybe shortening the intake (the end that goes to the turbo) and creating a slot in the battery try to give me just enough room for the intake. Now I am not sure if that will even work.
 Old 04-03-2014, 02:44 PM   #44
RPM
RPM's Avatar
Yeah, it pushes it out by like 3/8". Apparently there were issues with the 3.0", so it would be even worse with the 3.5". If you made some modifications, it might work, but it's tough to speculate.
 Old 04-03-2014, 03:31 PM   #45
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
Ecu relocation required my 3" barely fits now
 Old 04-03-2014, 03:34 PM   #46
alextheguineapig's Avatar
Posts: 827   (View Stats)
With or without a small box? What car?
Current
SOLD!
2008 Sunlight Silver MS3:
BNR: S3 V2
Cobb: V3 AccessPort
Damond Motorsports: RMM
Eibach: Prokit
JBR: Rear Sway Bar
Koni: Yellows
MAC: 3-Port EBCS
 Old 04-03-2014, 04:08 PM   #47
My ms3 with the stock box and stock ecu location.
 Old 04-03-2014, 04:45 PM   #48
bunta's Avatar
I'm on the corksport hardpip TIP. I believe it is 2.25. Looks like i'll have to get a 2.5 to 2.25 coupler to get it to fit. The only thing that sucks is that the tip at 2.25 was already hard enough to squeeze past the ecu and all the other junk. I wonder how it'll look now with the BNR moving it even closer. smh.
 Old 04-04-2014, 11:12 AM   #49
Okay, purchased the coupler. Before the install I will try to see what I can do with the battery box. I really don't want to get one lol
 Old 04-04-2014, 12:02 PM   #50
JgamB's Avatar
Posts: 2,566   (View Stats)
It's not really that bad - it's more of a pivoting on the axis kind of thing, with the fulcrum being just past the typical mounting stud toward the front of the vehicle. Unless you've got some oversized BPV, there should be room for the assembly to pivot the filter end a few degrees inboard and not lose much at all near the ECU harness.
bunta (04-04-2014)
 Old 04-04-2014, 12:03 PM   #51
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
Battery trays are great. Idk why you dont want one. Stock tray is such a piece of shit.
Wish I got mine sooner.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 04-04-2014, 12:28 PM   #52
Dimenus's Avatar
Posts: 2,825   (View Stats)
Groans: 33
With a full sized battery? Our winter was cold as shit this last year. Idk if I'd want to go without a full sized battery.
Tappin'
2012 Velocity Red Mica
 Old 04-04-2014, 01:46 PM   #53
smoogs12's Avatar
Groans: 423
I, as well as other people, have had 51r batteries start cars in 0-10* weather. Never an issue.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 04-04-2014, 05:44 PM   #54
Scare Dem's Avatar
Posts: 1,505   (View Stats)
What if we have an AMP for subwoofers?
2008 Mazdaspeed3 GT
GTX2867r
 Old 04-06-2014, 04:27 PM   #55
Yeah, made some modifications and it opened up very lil space then fell back into original spot lol. Not sure if I should get the CS battery box (it might not even work but if it does I get to use the stock battery), or HTP/JBR tray.
Can you PM a price I can't refuse on a JBR or HTP tray?lol
Also any word on the BNR and my order? order #136347
 Old 04-06-2014, 05:02 PM   #56
blackms3_71's Avatar
Posts: 2,250   (View Stats)
When i get my s3 i may just cut a little off my htp 3" to make it work
 Old 04-08-2014, 04:50 PM   #57
bunta's Avatar
any updates?
 Old 04-08-2014, 04:53 PM   #58
smoogs12's Avatar
Groans: 423
I just talked to Donny today and he said that some will begin to ship out next week, and the rest the week after.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
Vansquish (04-15-2014)
 Old 04-10-2014, 11:44 PM   #59
SnowWhiteMs3's Avatar
Posts: 28   (View Stats)
SnowWhiteMs3 is on a distinguished road
Might have to get one of.these for my ms3 I'm picking up tomorrow! 3rd mazdaspeed of mine
SnowWhiteMs3 is offline   Reply With Quote
 Old 04-15-2014, 11:02 AM   #60
starscream's Avatar
Posts: 630   (View Stats)
Groans: 44
BNR BNR BNR BNR BNR... lol
But note for Smoogs being a great guy to deal with.
The Following User Says Thank You to starscream For This Useful Post:
smoogs12 (04-15-2014)
 Old 04-15-2014, 11:03 AM   #61
I'll keep it in mind!!
 Old 04-15-2014, 11:46 AM   #62
I hope this doesn't turn into a "2 weeks" dilemma @smoogs12;
 Old 04-15-2014, 11:59 AM   #63
smoogs12's Avatar
Groans: 423
I can tell you where you stand on the list if anyone who is curious would like to pm myself or @RPM; with your order number.
I was told first five should go out this week and the second five the week after that.
The delay is on BNR's end. We are as anxious as you guys are.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
RPM (04-15-2014)
 Old 04-15-2014, 12:21 PM   #64
I know it's not on you guys. I am just busting your balls.
 Old 04-18-2014, 07:36 AM   #65
MazdaBoy2.3's Avatar
Posts: 5,797   (View Stats)
Groans: 51
Sub.
Keeping an eye on potential ship date before I send all my money!
 Old 04-18-2014, 08:06 AM   #66
Let me know when you receive yours I might order ome
 Old 04-18-2014, 11:47 AM   #67
RPM
RPM's Avatar
First orders are starting to ship! BNR isn't giving me a good estimate for the remaining orders, though. Apparently some items they need are stuck in customs, so I won't know more until that is resolved. We were hoping the remaining orders would ship next week, but it's looking like that may not happen.
smoogs12 (04-18-2014)
 Old 04-18-2014, 12:55 PM   #68
Cool. I got an email update.
This means you guys still need to receive the turbo then re-ship it to me?
 Old 04-18-2014, 02:46 PM   #69
RPM
RPM's Avatar
No, it's shipping direct from BNR.
smoogs12 (04-18-2014), specvspeedfreak (04-18-2014)
 Old 04-22-2014, 02:57 PM   #70
Scare Dem's Avatar
Mine just made it through the front door.
Thanks @smoogs12; & @RPM;
2008 Mazdaspeed3 GT
GTX2867r
RPM (04-22-2014)
 Old 04-26-2014, 06:08 AM   #71
Fuxxx's Avatar
Posts: 1   (View Stats)
Fuxxx is an unknown quantity at this point
@RPM
do you have at the moment a BNR in stock?
Fuxxx is offline   Reply With Quote
 Old 04-26-2014, 03:51 PM   #72
RPM
RPM's Avatar
No, we are still waiting on the S3. I think BNR might have a Stage 1 available.
Sent from my Galaxy Nexus using Tapatalk
dockinstation (10-20-2014)
 Old 04-26-2014, 05:23 PM   #73
smoogs12's Avatar
Groans: 423
Originally Posted by Fuxxx View Post
@RPM
In case you didnt see it yet, I sent a reply to your email.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
RPM (04-26-2014)
 Old 04-26-2014, 05:44 PM   #74
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
My next upgrade, how i long for your s3 goodness in my engine bay...
tapatalk, it sucks for free.
 Old 04-27-2014, 08:27 AM   #75
starscream's Avatar
Groans: 44
BNRs3v2 received as well as the HTP 3inch.
Thanks @smoogs12; and @RPM;!
smoogs12 likes this.
The Following 3 Users Say Thank You to starscream For This Useful Post:
bstover17 (04-27-2014), RPM (04-27-2014), smoogs12 (04-27-2014)
 Old 04-28-2014, 04:06 PM   #76
smoogs12's Avatar
Groans: 423
So I just want to make sure that everyone is aware of the WGA issues that these turbos are experiencing at the moment.
I saw a few of you that ordered from us had posted in the thread that I am about to link. But for those of you that are not aware I urge you to give it a read.
New BNRS3 Housing
monkey.bones.007 likes this.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
The Following 7 Users Say Thank You to smoogs12 For This Useful Post:
223Patriot (04-29-2014), monkey.bones.007 (04-28-2014), nindoja (05-01-2014), RPM (04-28-2014), Scare Dem (04-28-2014), shadesofgray19 (04-28-2014), WetzMS3 (04-28-2014)
 Old 06-16-2014, 01:53 AM   #77
Ordered mine a few days ago! Thanks @smoogs12; for the awesome deal and thanks @RPM; for stepping up your game in the Speed community!
Like an hour after I placed my order I got a call from them to tell me my turbo would take probably a few weeks to be made, while I had already figured as much it was very appreciated to see them reach out to the customer like that. Definitely going to order through RPM in the future.
The Following 3 Users Say Thank You to Mazdazilla6 For This Useful Post:
RPM (06-16-2014), smoogs12 (06-16-2014), Vansquish (06-24-2014)
 Old 06-24-2014, 02:40 PM   #78
bigspender's Avatar
Posts: 854   (View Stats)
bigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the world
Groaned at 46 Times in 21 Posts
@smoogs12, @RPM
When do you think you will have the turbos back in stock?
bigspender is offline   Reply With Quote
 Old 06-24-2014, 08:43 PM   #79
RPM
RPM's Avatar
Originally Posted by bigspender View Post
@smoogs12, @RPM
Still waiting for word from BNR, but it could be as soon as next week.
 Old 06-26-2014, 11:45 PM   #80
Don't get my hopes up like that lol. It's like telling a kid that Christmas is coming a week early.
For all of those with BNR turbos.. numbnuts22715 MazdaSpeed 3/6 - Turbo Induction 66 01-09-2012 10:37 AM
OBX Turbos manofhonor24 MazdaSpeed 3/6 - Turbo Induction 8 06-07-2009 12:16 PM
Page generated in 0.56674 seconds with 36 queries
