Like Tree24Likes
 Old 07-03-2014, 10:21 PM   #1
King Scumbag's Avatar
Posts: 2,384   (View Stats)
Originally Posted by Cevaes_64 View Post
Edit:
@smoogs12; I have a 3.5 JBR WP (all silicone) , will this fit with it? I don't see how i could use a coupler silicone to silicone....
Also Any news on ETA?
Sent from my SM-N900P using Tapatalk 4
If you have the JBR 3.5 WP all silicone intake with stock size inlet, yes it will work on the beaner. It's a tight fit but does work.
07 BLACK MICA MS3
PATTY/JEFF BUILT MOTOR
STOCK BLOCK
BOSTON STRONG
Cevaes_64 (07-04-2014)
 Old 07-07-2014, 11:27 AM   #2
Cevaes_64's Avatar
Posts: 1,066   (View Stats)
Are you running this setup?
 Old 07-07-2014, 11:28 AM   #3
Negative I am not but know and have heard of people that are.
Tapatalk for what!
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
Cevaes_64 (07-07-2014)
 Old 07-03-2014, 10:04 PM   #4
Any word on these snails? @RPM;
 Old 07-03-2014, 10:10 PM   #5
RPM
RPM's Avatar
Posts: 1,149   (View Stats)
Well, I heard they cleared customs, so BNR was just waiting to receive them. If all goes well, they should start production this coming week and start shipping end of the week or the following week. Once Bryan gives me more info, I'll pass it along.
Mazdazilla6 likes this.
Mazdazilla6 (07-03-2014)
 Old 07-07-2014, 11:34 AM   #6
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
Neutral  +1 score
Its going to be pretty tight and possibly a PITA to get it over the S3 housing.
Stock comp inlet is something like 2.16". S3 is 2.25". So It'll be a stretch, but it can be done.
Edit: 2.25 is actually the previous generation of s3. Current is ~2.5".
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 07-07-2014, 11:35 AM   #7
Cevaes_64's Avatar
Maybe heat the silicone a little bit, on the bright side I won't need a clamp lmao
 Old 07-07-2014, 11:41 AM   #8
smoogs12's Avatar
Groans: 423
Just measured the k04 comp inlet with a caliper and it came out to 2.169". It will be a tight fit for sure.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 07-07-2014, 11:45 AM   #9
Default BNR S3 Turbos @ therpmstore.com
Yes it's a very very tight fit, but it does work.
Get er nice and lubed up and you'll be golden
Tapatalk for what!
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
 Old 07-07-2014, 03:03 PM   #10
I thought the updated comp housing was something like 2.46"
Official BNR S3v2 bonanza thread via OP
The Following 3 Users Say Thank You to Mazdazilla6 For This Useful Post:
Cevaes_64 (07-07-2014), JgamB (07-07-2014), smoogs12 (07-07-2014)
 Old 07-07-2014, 03:13 PM   #11
smoogs12's Avatar
Groans: 423
Yep sorry that was my mistake. I was thinking of the previous version.
In that case I am pretty doubtful that a current s3 will work with an intake designed for the k04.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 07-07-2014, 03:19 PM   #12
RPM
RPM's Avatar
Yes, the new S2 and S3 are 2.46", so none of the silicone TIPs will work. You will need something like the HTP TIP/intake with a 2.5" silicone coupler.
 Old 07-07-2014, 04:10 PM   #13
I stand corrected then!
Tapatalk for what!
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
 Old 07-07-2014, 05:41 PM   #14
JgamB's Avatar
Posts: 2,566   (View Stats)
Not quite. I have the JBR 3" Widepath full silicone shoehorned on the S3 V2. I did remove 1 layer of material inside the intake to give it a slight bevel, but even without doing that we've managed to shove a CS Stg2 onto the new Beener as well.
If my bunghole put up this much of a fight in a prison shower I'd be proud of it, but it can be successfully installed.
The Following 4 Users Say Thank You to JgamB For This Useful Post:
ItsNox (07-08-2014), King Scumbag (07-07-2014), RPM (07-12-2014), spals (07-08-2014)
 Old 07-07-2014, 05:42 PM   #15
I thought I remembered someone that had already successfully attempted it haha.
Tapatalk for what!
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
 Old 07-07-2014, 05:47 PM   #16
JgamB's Avatar
Yessir - and the good news is after a few heat cycles, it's much easier going in and out. And the intake fits better also.
King Scumbag likes this.
 Old 07-12-2014, 01:33 PM   #17
RPM
RPM's Avatar
Perhaps the correct answer is that it depends on the specific TIP, then. The K04 has a 2.16" inlet, so if the TIP is 2.25" (as I think some of them are), then it may be able to be shoehorned on the new 2.46" inlet, albeit with persistence or modification. If it's 2.0", it would obviously require a lot more work, if it works at all.
I suppose it all boils down to how much work you're willing to do.
On a side note, BNR did get the parts he's been waiting for in, so some turbos may start shipping next week to those who ordered months ago if he can get them done. He said all of our current orders should ship out of the current batch, but it still could be a few weeks on some of the orders placed more recently, as it will take some time to work through production on all of the units.
To make a long story short, if you've already ordered, it shouldn't be too much longer. If you haven't, you should get your order in now if you'd like to have your turbo sooner than later, even though it will still take some time.
In the end, we will end up stocking these, but not until after all of our orders and BNR's orders have been fulfilled, which will probably take at least another couple months.
The Following 3 Users Say Thank You to RPM For This Useful Post:
smoogs12 (07-13-2014), specvspeedfreak (07-12-2014), Vansquish (07-12-2014)
 Old 07-07-2014, 09:50 PM   #18
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
Not exactly the same but I have a 3.5 WP and ended up using the coupler that I used on the K04. Fit is much better than a 2.5 inlet. 2.5 coupler was actually too big.
JgamB (07-12-2014)
 Old 07-07-2014, 09:52 PM   #19
Cevaes_64's Avatar
Do you have the silicone version or the metal one?
 Old 07-07-2014, 09:53 PM   #20
He's speaking on behalf of the 3.5 alum wheel peen. I believe it uses a standard coupler.
Tapatalk for what!
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
 Old 07-07-2014, 09:54 PM   #21
Cevaes_64's Avatar
That's what I thought... Can't use a coupler sucessfully on a silicone intake
 Old 07-07-2014, 09:55 PM   #22
Technically you could with an aluminum joiner.
Tapatalk for what!
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
 Old 07-07-2014, 09:57 PM   #23
Cevaes_64's Avatar
Tapatalk for what!
tl
True but I wouldn't use it.. Id rather change intakes
 Old 07-11-2014, 09:14 PM   #24
bunta's Avatar
Posts: 42   (View Stats)
bunta has a spectacular aura aboutbunta has a spectacular aura about
What is the current wait time for the the s3? Also are all the s3 v2 corrected from the issue that it's been having since it came out?
bunta is offline   Reply With Quote
 Old 07-11-2014, 09:29 PM   #25
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
All issues have been resolved with the wastegate actuator.
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
The Following 2 Users Say Thank You to taf0422 For This Useful Post:
bunta (07-11-2014), smoogs12 (07-12-2014)
 Old 07-12-2014, 01:53 PM   #26
This batch will be the from the same initial batch with the wga problem. BNR has personally modified all of them so there wont be anymore seizing flappers. Everyone should see the "in house" welding around the flapper arm hole. Also, all will be 1 port wga. The next batch will come with correct specs and double checked by BNR before shipment.
 Old 07-12-2014, 10:56 PM   #27
spals's Avatar
Posts: 305   (View Stats)
spals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the world
Has he addressed the leaking compressor housing that had been brought up in the other thread?
CP Pistons 88mm, Manley H-Beams, Balanced Crank
BNRS3V2, Cobb Catted DP, ETS TMIC, 3.5" JBR Alum Intake, AT HPFP
GS EBCS, 3 Bar Map, JBR 88 RMM, DM OCC, TIGs, BSD+Baffle
SBC Stage 2 Daily, JBR RSB, Koni Yellow, Konig Miligrams 18x8.5, Nitto NT-05 245/45
Spalsbuilt-Freektuned
spals is offline   Reply With Quote
 Old 07-21-2014, 12:38 PM   #28
RPM
RPM's Avatar
Just FYI, a ton of our orders shipped on Friday and we've still got more in the queue!
BNR has all the parts they need to make the turbos, but they're currently working through backorders. If you're in the market, get your order in now to ensure you get in on the next batch! BNR expects to be caught up in a few weeks, so any orders placed now are expected to ship at that time.
And once again, if you're looking for a better price, please contact us!
Mazdazilla6 (07-22-2014)
 Old 07-22-2014, 12:31 AM   #29
I'm supposed to get mine tomorrow! Thanks again RPM for the awesome deal!
 Old 11-03-2014, 04:11 PM   #30
RPM
RPM's Avatar
We shipped all of our stock, but we're ordering more and we can still get them shipped direct from BNR in 1-2 business days in the mean time!
 Old 11-13-2014, 11:47 AM   #31
RPM
RPM's Avatar
BNR Stage 1 and Stage 3 turbos are now IN STOCK! Any orders placed will ship within 1-2 business days, depending upon the time the order is placed!
 Old 11-17-2014, 05:31 AM   #32
Rich990's Avatar
Posts: 274   (View Stats)
Rich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the world
any chance of Black Friday sale specials coming up on the BNR S3?
2007 Velocity Red MS6
Go... BNR S3v2 / COBB APv3 / Snow Performance WMI + DO7 / nator'd DP / test pipe / HTP 3" SRI & TIP / 3 bar MAP / Autotech HPFP / NGK LTR7 / Stratified 3 port / Custom 3" TMIC / EGR delete / CP-E RMM / Turbine Tech FDM / CP-E RDM / Whiteline RSB / H&R springs / Powerbrake GT rotors / Endless MX72 Brakepads
Parts stockpile... Wiseco 88mm's / Manley H beams
Turbo stockpile... Borg Warner S200SX 7670 / GTX3071 / K04
Ex: 2007 Black Mica MS3 - stage 2 mods - 280 whp, 306 tq (321 whp / 358 tq before "stockout", on BNR S2 + meth)
Ex: 2010 Velocity Red MS3 - Stage 1 mods + Meth... 260 whp, 306 tq, stock exhaust
5500 ft altitude FTL
MSF in South Africa
Rich990 is offline   Reply With Quote
 Old 11-17-2014, 10:20 AM   #33
RPM
RPM's Avatar
Yes, BNR will be included.
hilo07spdGT (11-24-2014), Rich990 (11-20-2014)
 Old 11-20-2014, 10:52 AM   #34
Rich990's Avatar
Excellent. One of them badboys will most certainly be in the shopping basket!
RPM likes this.
MSF in South Africa
The Following User Says Thank You to Rich990 For This Useful Post:
smoogs12 (11-20-2014)
 Old 01-17-2015, 07:12 PM   #35
RPM
RPM's Avatar
All extended backorders have shipped. We have a couple orders from last week that will be going out this week and we will have several turbos in stock as soon as BNR finished them up.
If you've been holding off, now is the time to order! I'm not sure how long these will last.
smoogs12 (01-17-2015)
 Old 02-24-2015, 07:54 PM   #36
TORQUERULES's Avatar
Posts: 283   (View Stats)
The Stage 2 looks like a great upgrade for a DD without having to buy a lot of extra supporting modifications. I wonder how much it would affect an existing tune?
Sent from my Windows Phone
2017 Mazda CX-3 Meteor Gray
 Old 02-24-2015, 07:58 PM   #37
rolanblack's Avatar
Posts: 2,110   (View Stats)
If your going to upgrade your turbo, its best just to retune it rather than running your previous tune. Might run like shit or not to your expectation.
 Old 02-24-2015, 09:18 PM   #38
RPM
RPM's Avatar
This is true. Stage 2 (and Stage 1 for that matter) is a minor upgrade from stock, but it does flow a bit more and the compressor map is different. You definitely shouldn't assume that it will operate exactly the same as your stock turbo.
 Old 02-25-2015, 05:59 AM   #39
Thumbs up
I understand. Just kind of thinking of where to go with all of this. Next year may bring a bigger turbo and different tuning if I can swing it. But to be honest, as much as I love power, I want reliability over the long haul too. So while a S3 BNR would be great, I would rather just give up some power and keep supporting costs down with a S2.
I know there are a lot of Hypertech haters on here, but it does work great for a bolt on car. It is just limited on what you can do to yourself (no ability for custom tunes, etc.). I know it is very rich so I was thinking of how I would go about purchasing the mods. Turbo first, then custom tuning with AP, or the reverse, or all together (which is how I am sure I will go).
Just ignore me, my mind is on a thousand different things right now. It has been a crazy year. Lol.
The Following User Says Thank You to TORQUERULES For This Useful Post:
RPM (02-25-2015)
 Old 02-25-2015, 03:06 PM   #40
smoogs12's Avatar
Groans: 423
If you upgrade your turbo you will need a proper tune to go with it. Its definitely not optional. So I would strongly advise buying them [AP, tune, and turbo] at the same time.
That said, once you buy an AP, you really don't have anything that would keep you from running an S3 if you wanted. All you would need to do is pick up a couple minor things like a 3 bar MAP sensor and a 3 port EBCS. Further more, you might even want to look in to those parts even if you decided to just stick with the S2.
Just a few things to consider.
TORQUERULES likes this.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
For all of those with BNR turbos.. numbnuts22715 MazdaSpeed 3/6 - Turbo Induction 66 01-09-2012 10:37 AM
OBX Turbos manofhonor24 MazdaSpeed 3/6 - Turbo Induction 8 06-07-2009 12:16 PM
Page generated in 0.62896 seconds with 32 queries
