| Revolution Performance Motorsports Revolution Performance Manufacturing (RPM) was started by three Mazda 6 enthusiasts in early 2004 under a simple premise: to develop and manufacture new products for the Mazda 6 at an affordable price. We began to realize our purpose with the short throw shifter and gas hood lifter kits for that vehicle. Since then, we have added many new aftermarket products from well-known manufacturers and continue to expand to offer products for other vehicles with the goal of having the best prices and customer service on the 'net. |
![]() | | #121 | ![]() |
![]() Join Date: Apr 2014 Location: Ripley, WV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 78
| Not Ranked : 0 score Sent from my Windows Phone
__________________ (SOLD) 2013 Crystal White MS3--JBR 3.5" intake, very minor PNP intake manifold, CS TMIC, CS HPFP internals, CS BPV, JBR EGR delete and block-off, CFM RMM, CS TM insert, Cobb AP V3 with Stratified Stage 3 tunes (93 and E85 mix), VTCS delete, coolant bypass, 1 step colder plugs, CS shifter bushings, CS short shifter, Damond OCC, Ultra Gauge, Progress RSB, Koni dampers, Eibach Pro-Kit springs, JBR rear spacers, 235/40/18 Nitto Motivo tires, Drag DR-49 18x8" wheels, CNT cat-less DP, CNT cat-back, DDM HIDs, etc. 2017 Mazda CX-3 Meteor Gray |
![]() | | #122 | ![]() |
![]() Join Date: Apr 2012 Location: irving,tx
| Not Ranked : 0 score If your going to upgrade your turbo, its best just to retune it rather than running your previous tune. Might run like shit or not to your expectation. |
![]() | | #123 | ![]() |
| Approved MSF Vendor ![]() Join Date: Nov 2008 Location: Euless, TX
Rep Power: 975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 850
| Not Ranked : 0 score This is true. Stage 2 (and Stage 1 for that matter) is a minor upgrade from stock, but it does flow a bit more and the compressor map is different. You definitely shouldn't assume that it will operate exactly the same as your stock turbo. |
![]() | | #124 | ![]() |
I understand. Just kind of thinking of where to go with all of this. Next year may bring a bigger turbo and different tuning if I can swing it. But to be honest, as much as I love power, I want reliability over the long haul too. So while a S3 BNR would be great, I would rather just give up some power and keep supporting costs down with a S2. I know there are a lot of Hypertech haters on here, but it does work great for a bolt on car. It is just limited on what you can do to yourself (no ability for custom tunes, etc.). I know it is very rich so I was thinking of how I would go about purchasing the mods. Turbo first, then custom tuning with AP, or the reverse, or all together (which is how I am sure I will go). Just ignore me, my mind is on a thousand different things right now. It has been a crazy year. Lol.
__________________ (SOLD) 2013 Crystal White MS3--JBR 3.5" intake, very minor PNP intake manifold, CS TMIC, CS HPFP internals, CS BPV, JBR EGR delete and block-off, CFM RMM, CS TM insert, Cobb AP V3 with Stratified Stage 3 tunes (93 and E85 mix), VTCS delete, coolant bypass, 1 step colder plugs, CS shifter bushings, CS short shifter, Damond OCC, Ultra Gauge, Progress RSB, Koni dampers, Eibach Pro-Kit springs, JBR rear spacers, 235/40/18 Nitto Motivo tires, Drag DR-49 18x8" wheels, CNT cat-less DP, CNT cat-back, DDM HIDs, etc. 2017 Mazda CX-3 Meteor Gray | |
| The Following User Says Thank You to TORQUERULES For This Useful Post: | RPM (02-25-2015) |
![]() | | #125 | ![]() |
![]() Join Date: Feb 2011 Location: Waterford,CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,169
Groans: 423
That said, once you buy an AP, you really don't have anything that would keep you from running an S3 if you wanted. All you would need to do is pick up a couple minor things like a 3 bar MAP sensor and a 3 port EBCS. Further more, you might even want to look in to those parts even if you decided to just stick with the S2. Just a few things to consider.
__________________ -Pat 2008 True Red MS3 GT3071R 'n Stuff SOLD 1999 Jeep XJ 6.5" Lift | Armor | 33" Tires | Bumpers 1996 Jeep XJ 3.5" Lift | 31" GY Duratracs | Bumpers 1994 Miata 15x8's w/NT05's | KYB AGX | Hardog Roll Bar | 70D Engine Mounts | |
![]() | | #126 | ![]() |
![]() Join Date: Jan 2011 Location: Vancouver BC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 130
In theory, reflash to stock, replace turbo, reflash tune, and done. That's my brownie logic again. Are you able to source turbo gaskets, or they included?
__________________ 2006 Moist Metallica Silver Speed6 GT #6557 @ 267,000km Leakdown results was 50% or more across all four. slow rebuild in progress Corksport: Turb.IM.DP.OCC.3.5MAP.IC.RMM.TIP.FSB.Tubes.Strut Tower. JBR: 70a Sides.SSP.51r SURE: Full3Aeros.Dreadnaught.Juggernaught.Anchors.FlowM6 .Rad Hoses. Stratified Custome Tune/APv3.Turbosmart DS BOV.Cobb EBCS.AT HPFP.Deatchsworks.CPe SafeSeals.H&R Coils.Moog Camber Arms. SPC Ball Joints.Whiteline Adj RSB. SU Rear Interior Brace.StopTech Perf Pads.Centric X-D Rotors.TechnaFit Braided Clutch-Brake Lines.Damond PS Cooler.EGR. PeRM PCV Plate. Michelin Pilot Sport AS3+ 235/40/18.Drag DR-38 +47. Gloss Black Blue Undercut. Pirelli Sottozero s2 240 215/45/18. MS6 OEMs. To order: Fullrace Exhaust Mani. FMIC. Damond side mounts. New built motor. Still thinking about Flowmasters | |
![]() | | #127 | ![]() |
| Sanctioned MSF Peddler ![]() Join Date: Nov 2014
Rep Power: 146 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 224
I cant say I have ever heard of anyone using a HT tuner with an S1. However I do know that you can use a Cobb OTS map to get you started, so I imagine HT would lead to similar results. I'd still probably look for a custom tune at some point though. As far as the gaskets go, we can get you whatever you need. We are still working on getting the Mazda OEM stuff listed on the site, but we can work with you directly if you need something before that stuff gets listed. Just shoot us a PM
__________________ --- www.theRPMstore.com --- ![]() Need a COBB AccessPort and/or Autotech internals? We offer the best pricing on these parts! Shoot us a PM! NEED FINANCING? We've got you covered with TWO unique options! Click for details! Turbo upgrade bundles now available for BNR AND ATP turbos. Save up to $225! Email Pat@therpmstore.com | |
![]() | | #128 | ![]() |
Pretty sure all will be will.... **knocks on wood**
![]() | | #129 | ![]() |
| Not Ranked : 0 score Still havent ordered it but I did get an email back from Hypertech when I emailed them with the bnr s1 tech info and asked if it'd work. Got a succinct, 'yep'. Not sure if thats a good thing tho (lol?).
![]() | | #130 | ![]() |
| Not Ranked : 0 score Just a quick bump since this remains our most popular selling turbo! |
| Display Modes | |
| Fastbrakes Wilwood Brake Caliper Upgrade Kits @ therpmstore.com | Chimmike | Revolution Performance Motorsports | 46 | 02-11-2015 10:08 PM |
| For all of those with BNR turbos.. | numbnuts22715 | MazdaSpeed 3/6 - Turbo Induction | 66 | 01-09-2012 10:37 AM |
| OBX Turbos | manofhonor24 | MazdaSpeed 3/6 - Turbo Induction | 8 | 06-07-2009 12:16 PM |
