| Revolution Performance Motorsports Revolution Performance Manufacturing (RPM) was started by three Mazda 6 enthusiasts in early 2004 under a simple premise: to develop and manufacture new products for the Mazda 6 at an affordable price. We began to realize our purpose with the short throw shifter and gas hood lifter kits for that vehicle. Since then, we have added many new aftermarket products from well-known manufacturers and continue to expand to offer products for other vehicles with the goal of having the best prices and customer service on the 'net. |
| Approved MSF Vendor ![]() Join Date: Nov 2008 Location: Euless, TX
Rep Power: 975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 850
(Thread Starter) | Not Ranked : 0 score ![]() BNR STAGE 4 IS HERE! ![]() ![]() ![]() ![]() ![]() Following the amazing success of the BNR Stage 3, which has been chosen by many as the best, most cost-effective way to maximize the stock block, BNR has taken things a step further with the Stage 4! The Stage 4 turbo steps into true big-turbo territory, featuring a custom T04E 50 trim compressor wheel with 76mm exducer and a GT30 turbine wheel, putting this turbo in the same ballpark as the popular Garrett GT3076. BNR Stage 4 Turbocharger for Mazdaspeed 3 / 6 #BNR-MZ4 ^^ ORDER TODAY! ^^ NEED FINANCING? We've got you covered! We offer two different financing methods. Read more about them here: FINANCING OPTIONS @ therpmstore.com
__________________ Last edited by RPM; 02-17-2018 at 10:05 PM. |
| The Following 24 Users Say Thank You to RPM For This Useful Post: | aviator79 (09-02-2015), Awal (09-02-2015), Bolted6 (09-02-2015), Code Monkey (09-01-2015), Dralphy (09-01-2015), ItsNox (09-01-2015), Jackis (10-06-2015), jack_hammer (09-06-2015), JgamB (09-01-2015), Mazdazilla6 (09-03-2015), MD1032 (09-01-2015), MS3Shadow (09-01-2015), mxlplx71 (09-02-2015), neganox (09-02-2015), smileyspeed3 (09-02-2015), SNOW_QN (09-01-2015), SpeedRebirth (09-01-2015), tegxsi (09-01-2015), The Nut (09-03-2015), Thepedigree13 (09-01-2015), Tomas (10-13-2015), WAMBUSHHHH! (09-07-2015), Zoom66 (09-01-2015), [R]usty (09-01-2015) |
Groans: 438
| Not Ranked : 0 score And I just installed my s3 a couple weeks ago......
(Thread Starter) | Not Ranked : 0 score Well, the S3 seems like a good fit for what you have listed. Unless you build your motor, you wouldn't be able to take full advantage of what the S4 will offer. |
| The Following 3 Users Say Thank You to RPM For This Useful Post: |
| Not Ranked : 0 score I'd like to see how responsive this turbo is. If spool characteristics are good, it could be the logical upgrade to ensure you never need more boost unless going full R-tard.
| The Following 7 Users Say Thank You to JgamB For This Useful Post: | Awal (09-02-2015), dale_gribble (09-01-2015), ItsNox (09-01-2015), MD1032 (09-01-2015), MS3Shadow (09-01-2015), Thepedigree13 (09-01-2015), WAMBUSHHHH! (09-07-2015) |
They do plan on releasing dyno charts. They're just waiting until the car is ready, so they can release the best chart first. | |
| The Following 5 Users Say Thank You to RPM For This Useful Post: | ItsNox (09-01-2015), JgamB (09-01-2015), MD1032 (09-01-2015), MS3Shadow (09-01-2015), SpeedRebirth (09-01-2015) |
Groans: 438
This should be a great seller, just like the s3 was.
__________________ All good things must come to an end... | |
| Not Ranked : 0 score My BNR S3 hit 20 psi at ~3600 (before I adjusted WG spring pressure preload and got it to 3,300). That's not bad for a larger turbo. I think the MS3 can benefit from a slightly later spool anyways since big gains in the 2,500-3,500 pretty much translates to wheelspin. That's great that it drops into the stock location and doesn't need a massive whale penis intake. This could probably pass a roadside visual and smog visual inspection in Cali, and since it mates to stock intake size, it makes it that much easier. That also means guys could swap in the turbo and then upgrade to large intake later. Knowing Bryan, I'm sure the turbo is balanced flow wise, so probably no boost control problems (i.e. spikes) either.
| The Following 11 Users Say Thank You to dale_gribble For This Useful Post: | ItsNox (09-01-2015), Jackis (10-06-2015), JgamB (09-01-2015), Justin@Freektune (09-02-2015), MD1032 (09-01-2015), MS3Shadow (09-01-2015), mxlplx71 (09-02-2015), SpeedRebirth (09-01-2015), The Nut (09-03-2015), Thepedigree13 (09-01-2015), WAMBUSHHHH! (09-07-2015) |
(Thread Starter) | Not Ranked : 0 score Well, it does have a 3-inch inlet, so it will need a larger intake, or at least a larger coupler if you already have one. I'm not sure what size starts to constitute "whale penis" size.. haha |
| The Following 2 Users Say Thank You to RPM For This Useful Post: | ItsNox (09-01-2015), Justin@Freektune (09-02-2015) |
![]() Join Date: Feb 2014 Location: TEXAS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,527
Groans: 64
| Not Ranked : 0 score As a guy that swore I was going to stay stock until the car was paid off, I think this turbo would be good for me. I swear now I don't want to do an engine build, but I would probably buy an S3 or CS turbo and eventually get bored and/or want more. This S4 may be the right turbo for guys like me. Could be fun on stock block, but has potential to take you further. And that bundle price is crazy, very tempting.
__________________ ~2013 BLACK MS3~ COBB: (APV3//Exhaust Hangers) CS: (TMIC//RP//Leather Knob//Battery Box//Interior LEDs) JBR: (3" SRI//80 Threesome//SSP//SSB//TB TIG//Coolant Bypass//Rice Flaps, EGR delete, OCC) Magnaflow CBE//GFB BOV//FREEKY DEEKY OTS+ 》》》SUPPORT YOUR MSF VENDORS《《《 |
| The Following User Says Thank You to Thepedigree13 For This Useful Post: | RPM (09-01-2015) |
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) | |
(Thread Starter) | Not Ranked : 0 score Yes, it does have a JMF intake manifold. |
| Not Ranked : 0 score Is it possible for Bryan to put a thicker bead closer to the edge or on the edge of the turbo outlet? I used a shorter coupler on my BNR S3 and the t-bolt clamp was above the thick bead and I blew the coupler off after 4 road racing sessions running only 21 psi of boost.
| Not Ranked : 0 score ^ Yeah, but they hit the boost a few times for a short period of time and call it quits, try doing it 4 times a day, 30 minutes each time.... Just saying, it would not cost him much time or effort, and it would make the turbo better for those who run a fmic. Guys who run a tmic do not have this problem as the coupler is jammed between the turbo outlet and the intercooler inlet.
| The Following 2 Users Say Thank You to Code Monkey For This Useful Post: | Easter Bunny (09-04-2015), Jackis (10-06-2015) |
![]() Join Date: Feb 2013 Location: Montgomery, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 204
Groaned at 49 Times in 12 Posts
| Not Ranked : 0 score If you're just wanting a thicker bead on the outlet, that seems like something that would take a few minutes of welding - I can't see a shop charging you more than $20 for something like that.
__________________ 2007 Mazdaspeed 6 - Black Mica - ZZB RIP 2016! BNR S3, JBR 3" wp intake, JBR rmm, JBR heavy shift knob, JBR shifter bushings, JBR SSP, South Bend Stage 3 Endurance clutch, Juggernaught/Dreadnaught, Autotech HPFP, 3 bar map sensor, Stratified Boost Dial, Streetunit TMIC, Forge V2 BPV, ebay DP/TP, 3 inch custom single exit cat-back, magnaflow muffler, H&R springs, Cobb AP, JL Audio 12" W3 w/ 500w Alpine amp, 6000k HIDs, LED fogs, dipped and tinted - Stratified 369awhp/383awtq vdyno on 4 gallons of corn |
![]() Join Date: Aug 2015 Location: Virginia Beach, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
| Not Ranked : 0 score I hate this forum. Every time I get on here I buy something, or plan to buy something that I never intended on purchasing. I'm going to be broke in no time. On that note, anybody upgrading from an s3 to an s4 need to get rid of their s3 in order to get an s4? 😁 I might be putting up a WTB thread soon. Lol Edit: that's a hell of a deal on the s4 package btw
__________________ 06 MS6: Stocked out and trying to find her a new family. |
| The Following User Says Thank You to SNOW_QN For This Useful Post: | Easter Bunny (09-04-2015) |
| Very good deal on the combo. Might look into this compared to the CS Turbo. Sent from my HTC M9
(Thread Starter) | Not Ranked : 0 score Thanks! This turbo isn't really comparable to the CS turbo, though. The CS would compare closer to the S3. If you're planning on building your motor at some point, this is the way to go. |
![]() | | #19 | ![]() |
![]() Join Date: Oct 2011 Location: brooklyn, ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 240
| Not Ranked : 0 score My motor is getting built as we speak. But as much as I an tempted to get this, bnr turbos have a rep for having issues at first production. I will stick with my s3 for the time being. If I hear of no issues by next summer, then I will get one. |
![]() | | #20 | ![]() |
![]() Join Date: Nov 2014 Location: La Porte, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 56
| Not Ranked : 0 score Cant wait to get more info on this thing. |
![]() | | #21 | ![]() |
![]() Join Date: Aug 2013 Location: Bartlesville, OK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 195
| Not Ranked : 0 score Hmmm.... this looks interesting. Do I get this one or a GTX3076 to replace my GTX2867 on my freshly built motor??? Decisions, Decisions....
__________________ 2013 MS3 Velocity Red - FLOW Tuned 25% E85 Mods - GTX2867R Turbo, Snow Meth Kit, Forged Manley Platinum pistons and Rods, Matt Dammond Balance Shaft Delete, Southbend Stage 3 Clutch, SPerformance Aux Fan Controller, 4" HTP Intake, Greddy FV BOV, Stratified Guardian Angel V2, Cobb AP V3, Tanabe Strut Tower Brace, Magna-flow CBE, HPFP Autotech Internals, CorkSport Shifter Bushings, CorkSport short throw shifter, CP-e Stage 2 RMM, CP-e Catless Downpipe, QTP Electric Exhaust Cutoff, NGK one step colder plugs, Cobb 3-port EBCS, Whiteline FSB, EBC 3GD Slotted Rotors, Hawk HPS Brake Pads, Goodridge Stainless Steel Brake Lines, HTP Small Battery Box, 51R Optima Yellow, SPC adjustable Rear Camber Arms, KW Variant 3 Coilover setup, Matt Dammond Passenger and Transmission mounts, Falken Azenis tires (street use), Defi Boost Gauge, AEM UEGO Wideband Gauge, AEM Water Temperature Gauge, AEM Oil pressure gauge, Corksport Short Shifter, Apexi Turbo Timer, Corksport Skid Plate, Threadstone TR8 core and crash bar, DOCRACE exhaust manifold, Reletnless Customs Ported IM, JBR 250 Competition Rear Sway Bar, Kuhmo V710 on RX8 wheels (track use), Matt Dammond OCC (VC and intake), Speed Performance Vented Oil Cap, Rice - 20% tint, Morimoto HID kit, Retrofit High Beams, Morimoto projector clear lenses, Corksport Hood Strut Kit, Corksport eyelids color matched, Ebay rear spoiler extension, Morimoto RGB Halos, LED Red Evil Eye, VG Shark Fin Antenna, Coil Cover, Blue Vacuum Hoses, Morimoto LED low beams, Cover King custom Seat Covers |
![]() | | #22 | ![]() |
![]() Join Date: Sep 2013 Location: Vancouver, BC
Rep Power: 303 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,298
| Not Ranked : 0 score Nice unit, package, and price point. Definitely tempting for someone who can resist turning up the boost until they build their motor. I'll wait for test results before I decide whether this will be the route I go, I'm always a little wary of first runs on new products that move at 1 million RPMs ![]() I hope it goes well for anyone who tries this turbo.
__________________ All Go, No Show 2013 LSM W/ Tech CORKSPORTFull Race RMM CORKSPORTPMM CORKSPORTTMM CORKSPORTTMIC(temporarily uninstalled for Warranty BS) CORKSPORTECU RELOCATION BATTERY BOX(temporarily uninstalled for Warranty BS) CORKSPORTSSP CORKSPORTSHIFTER BUSHINGS CORKSPORT3.5" POWER SERIES SRI/TIP(temporarily uninstalled for Warranty BS) CORKSPORTBPV(temporarily uninstalled for Warranty BS) CORKSPORTRSB @ Full Stiff CORKSPORTMid Chassis Brace CORKSPORTHood Struts + decals for 20whp CORKSPORTLicense Plate Frames COBBAP v3 w/ Window Mount AUTOTECHHPFP INTERNALS ToBeInstalled: CORKSPORTFull Catless TBE, Rear Trunk Brace, Adjustable FELs, Cold Air Box (modified for 3.5") dbaDBA42962S Front and Rear Rotors StopTechRear Braided SS brake lines JBROCC & VTA OCC kit, EGR BO, Boost Tubes Cooling MistWMI kit StratifiedCustom Tune (as soon as TBE is on) On Deck wilwoodFastbrakes DP4front Caliper kit (w/ bp-10 pads and braided SS fr lines) Hawk PerformanceHB478F.605 or HB478Z.605 rear pads BilsteinB16s |
![]() | | #23 | ![]() |
![]() Join Date: Jan 2009 Location: Andover, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,936
Groans: 192
Not like its his 1st ever turbo
__________________ precision gen2 5862 coming soon [SIZE="1"]07 MS3 GT.. Engine:Cobb V3,GTX3076r EWG,Wiseco Pistons/Manley Rods, L19's,JMF, Bosch 3.5bar MAP,CS cat-back,M2 DP, full race manifold,FP internals,FREEK 4",CP-E flange HKS,DO Stage II ss lines,Cobb piping,TR8L,MD RMM&TMM,JBR RSB & FSB,JBR SST,JBR knob,ACT 6puck,JBR EGR delete,CPE Seals,Grimmspeed EBC,JBR BSD,MD Catch Can.Looks:yellow lamin-x fogs,chrome turn signals,side moldings removed,20% tint,CS wheelSuspension/Wheels:Enkei RPF1 17x9,Eibach 5mm spaces H&R springs,koni yellows. GTX3076r --- 479/412 S4-460/400 Highest HP BNR S3 BNR-S3 424/397 | |
| The Following 3 Users Say Thank You to taf0422 For This Useful Post: |
![]() | | #24 | ![]() |
| Not Ranked : 0 score Obviously not, by no means did I imply it was. But even 1st run Honda Civics have their fair share of issues. edit: I'm fully pulling for this to be a fantastic product, just like the others, more great products for our platforms/engines is all one can ask for as a performance enthusiast.
![]() | | #25 | ![]() |
![]() | | #26 | ![]() |
Groans: 192
Also because no one ran the turbo prior to the release. It was just released without testing. V3 wastegate issue due to bryan making own housing instead of reusing k04's. This turbo has been on my car since June 19th with 2500 plus miles on it. Only issue was wastegate port being too large which has been remedied ![]() Just as an fyi
| The Following 4 Users Say Thank You to taf0422 For This Useful Post: |
![]() | | #27 | ![]() |
![]() Join Date: Sep 2013 Location: Heflin, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 803
| Not Ranked : 0 score Well, I went to BNR to visit with Bryan for a bit yesterday. Lots of stuff going on at the shop. Plenty of turbos being built. If you want an s4 you better go ahead and preorder. Killer turbo. The knowledge Bryan has with turbos and how well they will perform always blows my mind. Basically, Just get the turbo is what I'm trying to say. And Thanks RPM. the 4k$ I spent earlier this is finally about to be put to good use as my build is almost complete. I love it when awesome people team up to offer the community greatness.
| V2 Pre-amp | | |
| The Following User Says Thank You to BLKSTIG For This Useful Post: | RPM (09-03-2015) |
![]() | | #28 | ![]() |
| Not Ranked : 0 score I don't doubt bryans knowledge of turbos, I do run the s3 now. Just the kinks it had initially. But if testing them and they are good then that's great. |
| The Following User Says Thank You to maddocx240 For This Useful Post: | RPM (09-03-2015) |
![]() | | #29 | ![]() |
| Not Ranked : 0 score funny you mention that. I brought that up yesterday when we were talking. It's painful to see things like this happen with any vendor, but they were handled professionally and quickly. He realizes that while his company can suffer when things like this happen his main concern is the consumer and making sure that we are happy. That means a lot to me. These units won't see any problems at all with boost control....
| V2 Pre-amp | | |
![]() | | #30 | ![]() |
@nindoja; and I figured out the initial IWG issue with the S3 V2, Bryan had it fixed within the week, and recalled the whole lot that had been shipped. He takes care of his customers, and some other people haven't been as fortunate with their large turbo manufacturer's followup.
| The Following 10 Users Say Thank You to JgamB For This Useful Post: | Awal (09-03-2015), Easter Bunny (09-04-2015), Justin@Freektune (09-03-2015), MD1032 (09-03-2015), mxlplx71 (09-03-2015), RPM (09-03-2015), smileyspeed3 (09-03-2015), taf0422 (09-03-2015), The Nut (09-03-2015), Thepedigree13 (09-03-2015) |
![]() | | #31 | ![]() |
![]() | | #32 | ![]() |
Groans: 143
| Not Ranked : 0 score The ATP kit for that turbo retails for $1849. Please explain to me why this decision is so difficult for you.
| The Following User Says Thank You to MD1032 For This Useful Post: | Awal (09-03-2015) |
![]() | | #33 | ![]() |
| Not Ranked : 0 score Mmmm definitely might have to upgrade after my engine is built. This price is crazy stupid good. Will the price remain the same after it officially launches @RPM;?
![]() | | #34 | ![]() |
| The Following User Says Thank You to RPM For This Useful Post: | Mazdazilla6 (09-03-2015) |
![]() | | #35 | ![]() |
![]() Join Date: Oct 2008 Location: Carson, CA
Rep Power: 977 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 168
| Not Ranked : 0 score As I am on the shitter; i can vouch that bryan will take care of you if something does happen. 》coming from the (2nd) guy with documented S3 v2 issues... That being said, i really dont have worries that the S4 will be a great turbo for most... stock or built
__________________ *COBB: AP, shifter weight *BITWISE: Harness, 3bar BNR: S3v2 *CP-e: Stage 2 RMM ,TMIC *JBR: RSB, EGR delete, WP *GRIMMSPEED: EBCS *TWM: Full Shifter *KDM: HPFP internals *DENSO:ITV22 *FORD: syn trans fluid *OBX: TBE *BILSTEIN: B8 Sport *SWIFT: Spec-R springs *GTSPEC: 4point ladder brace, rear subframe brace *NITTO: NT-05 * Whiteline: BSK *MOOG: F/R endlinks* SPC: Adj. camber arms *MORIMOTO: 5K HID elite |
| The Following User Says Thank You to specvspeedfreak For This Useful Post: | RPM (09-03-2015) |
![]() | | #36 | ![]() |
| Not Ranked : 0 score I definitely didn't mean to imply anything bad about Brian's turbos or BNR, sorry to have tilted the thread into that direction. Just thinking out loud, I've been bitten by bad luck a few times on brand new products. The price is truly insane for a turbo of this magnitude, I wish it great success.
![]() | | #37 | ![]() |
| Not Ranked : 0 score For one I have aftermarket Kozmic oil feed and drain lines on the my GTX and there is always the decision of bearing type in the CHRA.
![]() | | #38 | ![]() |
| Feline Führer ![]() Join Date: Feb 2013 Location: Jacksonville, FL
Rep Power: 2280 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,422
| Not Ranked : 0 score I remember Garrett saying that the CHRAs on the GTX turbos were not rebuildable and you had to send them in for service should something happen. Meh to that noise.
__________________ Official CatDickRacing Sales Rep - All products backordered. |
![]() | | #39 | ![]() |
![]() Join Date: Oct 2009
Rep Power: 269 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 173
Groaned at 22 Times in 8 Posts
| Not Ranked : 0 score well my bnr s3 started leaking from the exhaust bracket side no oil its and exhaust leak , havnt checked it good , but this s4 looks tempting ...
__________________ Dr_banano Car: Mazdaspeed3 2010 VRM- BNR S3 Turbo*FreekTuned*363HP 360TQ-DDM 6000k ,tinted 5%,K&N short ram - COBB AP V3 - COBB XLE bpv - JBR SSP stage 2 - JBR billet 80 RMM - JBR heavy shift knob - cp-e fuel pump - COBB inlet -COBB downpipe - COBB CBE - ETS TMIC black- FALKEN AZENIS tires - NGK LTR7IX-11 plugs - Corksports led kit - Corksport fog led kit.-Aeroforce gauges dual with blockhead dual gauge pod- CS boost tube -KNIGHTSPORTS REAR BUMPER - GS EBCS - 3 Bar Map - mgp brake calipers- corksport rear bumper lights - TWM short shifter - JBR TB/IM TI - EGR block - Njspeed pnp IM - K&W V3 coilover - Rear Carbon Fiber Spoiler - corksport hood scoop - WORK wheels 18 x 9.5 + 38 rear and 18 x 8 +38 front ptp studs/seals pending mazda 323 2002 hiboost turbo 1.6L-Automatic- Wife's car |
| The Following User Says Thank You to dr_banano For This Useful Post: | SNOW_QN (09-07-2015) |
![]() | | #40 | ![]() |
| Not Ranked : 0 score will it come with the studs and the crush rings and drain gasket?
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f408/bnr-s4-turbos-therpmstore-com-192766/ | ||||
| BNR Stage 4 is coming soon! PRE-ORDER TODAY! | This thread | Refback | 12-06-2015 04:59 PM | |
| ?????????? - ??????? (??????????, ???????, ??????) | This thread | Refback | 10-06-2015 03:46 PM | |
| New logs, stage 2 autotechs installed today. | G26 | 2010 MS3 - ECU Computer Tuning | 31 | 11-18-2011 07:33 AM |
| Report: 2012 BMW 3 Series U.S. order guide leaked, M Sport coming late | Haltech | Automotive News | 0 | 11-10-2011 11:30 AM |
| Hummer plant coming back online to fill 849-unit order? | Haltech | Automotive News | 0 | 03-09-2010 09:20 AM |
