| Revolution Performance Motorsports Revolution Performance Manufacturing (RPM) was started by three Mazda 6 enthusiasts in early 2004 under a simple premise: to develop and manufacture new products for the Mazda 6 at an affordable price. We began to realize our purpose with the short throw shifter and gas hood lifter kits for that vehicle. Since then, we have added many new aftermarket products from well-known manufacturers and continue to expand to offer products for other vehicles with the goal of having the best prices and customer service on the 'net. |
![]() | | #41 | ![]() |
![]() Join Date: Aug 2015 Location: Virginia Beach, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
| Not Ranked : 0 score Sent from my SCH-I545 using Tapatalk
__________________ 06 MS6: Stocked out and trying to find her a new family. |
![]() | | #42 | ![]() |
| Approved MSF Vendor ![]() Join Date: Nov 2008 Location: Euless, TX
Rep Power: 975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 850
(Thread Starter) | Not Ranked : 0 score Yes, it will. |
![]() | | #43 | ![]() |
![]() | | #44 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah. It basically comes with all of the same stuff as the S3. |
| The Following User Says Thank You to RPM For This Useful Post: | Mazdazilla6 (09-13-2015) |
![]() | | #45 | ![]() |
![]() Join Date: Sep 2012 Location: West Hartford, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 68
Groaned at 6 Times in 4 Posts
| Not Ranked : 0 score This is long awaited great news. Starting to put my "I didn't buy that last beer at the bar" dollars into a jar for this one.
__________________ 2008.5 Metro Grey MS3 Performance:HTP 3.5" Intake | Autotech HPFP Internals | SU TMIC | EBay Catless DP | Stratified Tuned | JBR 88a Dogbone - Short shift plate | Eibach Pro-Kit | 18x8 MB Interline wheels | Conti DW's 235/40R18 | JBR Rear Sway Bar Other fun: Dashhawk | Single res delete | Corksport Interior LED light kit - Bypass valve hose | Vent pod boost gage | Custom Heated driver and passenger seats | Leather shift boot |
![]() | | #46 | ![]() |
![]() Join Date: Jun 2015 Location: Salt Lake City, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 59
| Not Ranked : 0 score Thanks RPM for taking my money. Ordered and now I'm stuck with a stupid smile on my face. It's time to start stacking away parts for a motor and BT build over the winter.
__________________ 2013 MS3 // Purple Drank Tune // BNR S4 // All the other shit to go along with it Last edited by Ziggyboy; 09-29-2015 at 10:21 PM. |
| The Following User Says Thank You to Ziggyboy For This Useful Post: | RPM (09-29-2015) |
![]() | | #47 | ![]() |
![]() Join Date: Jul 2014 Location: Saskatoon, SK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 83
| Not Ranked : 0 score If it comes with the same oil drain line gasket as the s3, I would suggest reusing the OEM one or buying a new OEM one. I installed my s3 and used the supplied gasket and after 2 months the return line was spraying oil onto the back of my block. I totally wish the BNRs4 was out when I was shopping for a turbo... Might have to upgrade next year
__________________ 2010 BM - FREEKTUNED - BNRS3 |
![]() | | #48 | ![]() |
![]() Join Date: Dec 2013 Location: MA
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 3
| Not Ranked : 0 score Ordered mine today. Quick question. I already have the bosch 3 bar map sensor. Anyone foresee the need to get a 3.5. Or should the 3 be fine.
__________________ BNR stage 4 turbo, Full race exhaust manifold, Mahle 2618 Forged Pistons, Darrell Cox vvt, Manley H-Tuff Rods, Clevite H-Series Main & Rod Bearings, SP63 Custom Age 625+ 10mm Head Studs, ARP main studs, Keyed Crankshaft, Pulley, & Sprockets, pioer stage 2 camshaft Guardian Angle with 4 bar Corksport 3" TBE, HPFP, 3.5" intake, Corksport FMIC, JMF Intake Manifold, Synapse DV, toyota fuel injector seals, Grimm speed EBC, RMM, Balanced Crank/Clutch/Flywheel, Balance shaft delete, James Barone Oil pan Baffle, South Bend stage 4 Extreme clutch kit, Injecting yummy METH "CM10"! |
| The Following User Says Thank You to jme For This Useful Post: | RPM (10-05-2015) |
![]() | | #49 | ![]() |
(Thread Starter) | Not Ranked : 0 score 3-bar will be fine for most people. You'd need the 3.5 if you planned to go over 28 lbs of boost. |
![]() | | #50 | ![]() |
| The 3in is fine. But eventually you'll want to upgrade to the 3.5in. If you can swing for a 3.5in, go for it. sent from my Nexus 6P
![]() | | #51 | ![]() |
![]() Join Date: Sep 2013 Location: Vancouver, BC
Rep Power: 303 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,298
But I still agree.
__________________ All Go, No Show 2013 LSM W/ Tech CORKSPORTFull Race RMM CORKSPORTPMM CORKSPORTTMM CORKSPORTTMIC(temporarily uninstalled for Warranty BS) CORKSPORTECU RELOCATION BATTERY BOX(temporarily uninstalled for Warranty BS) CORKSPORTSSP CORKSPORTSHIFTER BUSHINGS CORKSPORT3.5" POWER SERIES SRI/TIP(temporarily uninstalled for Warranty BS) CORKSPORTBPV(temporarily uninstalled for Warranty BS) CORKSPORTRSB @ Full Stiff CORKSPORTMid Chassis Brace CORKSPORTHood Struts + decals for 20whp CORKSPORTLicense Plate Frames COBBAP v3 w/ Window Mount AUTOTECHHPFP INTERNALS ToBeInstalled: CORKSPORTFull Catless TBE, Rear Trunk Brace, Adjustable FELs, Cold Air Box (modified for 3.5") dbaDBA42962S Front and Rear Rotors StopTechRear Braided SS brake lines JBROCC & VTA OCC kit, EGR BO, Boost Tubes Cooling MistWMI kit StratifiedCustom Tune (as soon as TBE is on) On Deck wilwoodFastbrakes DP4front Caliper kit (w/ bp-10 pads and braided SS fr lines) Hawk PerformanceHB478F.605 or HB478Z.605 rear pads BilsteinB16s | |
![]() | | #52 | ![]() |
| well it was late, and didn't see that. In that case, if you are going to get a Guardian Angel, that has a 4bar MAP Sensor already.
![]() | | #53 | ![]() |
| Not Ranked : 0 score Ordered the Guardian Angle with the 4 bar and the Synapse DV Bov
![]() | | #54 | ![]() |
| Not Ranked : 0 score Sure has been cold sleeping next to the mail box all week. Stupid turbo is ruining my life.
__________________ 2013 MS3 // Purple Drank Tune // BNR S4 // All the other shit to go along with it |
![]() | | #55 | ![]() |
(Thread Starter) | Not Ranked : 0 score We can confirm that some shipped today. Our first 5 pre-orders shipped, but I'm not sure how many total, as I'm sure BNR may have also shipped some direct orders, etc. |
| The Following User Says Thank You to RPM For This Useful Post: | Ziggyboy (10-09-2015) |
![]() | | #56 | ![]() |
![]() Join Date: May 2012 Location: Virginia Beach, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 101
| Not Ranked : 0 score Leaving next month on the Harry S Truman. I will be making my purchases when i get back from deployment next year. I figure all the bug, if any, will be all sorted out and good numbers would be posted.
__________________ 2012 Crystal White Pearl MazdaSpeed 3 Mods: BNR S4 V2 // XS Power Manifold V3 // JBR Tru-3.0" Aluminum Intake // Devils Own WMI D10 NOZZLE// JBR DISI Bypass Valve Hose // JBR 70duro RMM // JBR SSB // JBR SSP // JBR Coolant Bypass Kit // DM EGR Full Delete Kit // DM TMM // DM PMM // COBB AP V2 // CNT Racing Catless Downpipe // CP-E TMIC // CP-E Injector Seals // SP63 Valve Cover Breather // Custom 3" Magnaflow exhaust //One Step Colder NGK Plugs // Bosch 3bar Map sensor // Grimmspeed EBCS // MD OCC // MD PCV Plate // Stop Tech Braided Lines // Autotech Internals // Forge BPV V1 // Corksport V2 RSB // Eibach PRO-kit Stratified Tuned Stage 2 OTS+ 273whp/330wtq SnailD Tuned on Meth 316whp/359wtq Purple Drank Tuned BNR S4 V2 and 100%Meth 412whp/373wtq Last edited by knocturnal; 10-10-2015 at 04:41 AM. Reason: missing info |
| The Following User Says Thank You to knocturnal For This Useful Post: | Zoom66 (10-10-2015) |
![]() | | #57 | ![]() |
![]() Join Date: Dec 2013 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 462
| Not Ranked : 0 score So do we know if anyone has ran this without aux fueling? Kind of interested to see what this would do on straight 93. Probably the same as a gt30 but for $500 less. |
![]() | | #58 | ![]() |
| Not Ranked : 0 score I want this turbo bad. But I may just have to hold off for a sweet Christmas/Black Friday sale. No point in going BT in winter I guess....
![]() | | #59 | ![]() |
| Not Ranked : 0 score This won't make much over 375 on just 93. Throw some E in and stock fuel system should be able to carry you a little over 400.
| The Following 2 Users Say Thank You to Mazdazilla6 For This Useful Post: | RPM (10-11-2015), Thepedigree13 (10-11-2015) |
![]() | | #60 | ![]() |
| Not Ranked : 0 score I think this is the way to go over a gt series. Does it really matter all that much journal vs ball bearing? $500 is a lot of cash
__________________ The line up: 2013 G37 loaded...not stock for long 2013 MS3...stock to midturbo back to stock (traded) 2009 Nissan Frontier LE loaded...big stereo system (traded) 2009 Cadillac CTS sport package...stock (blown and traded piece of shit) 1994 Integra RS built all motor (sold) 1990 Civic EF nitrous turbo motor swapped beast (sold) 1987 Dodge pick up...jacked up (sold) |
![]() | | #61 | ![]() |
(Thread Starter) | Not Ranked : 0 score When comparing two identical turbos (aside from bearings), the ball-bearing will spool a little quicker. That said, this turbo spools pretty quickly as is, so I don't know that the extra $500 would result in too much real-world difference. Durability is the same if both turbos are well-cared for. |
![]() | | #62 | ![]() |
__________________ Built 5862: Shootin For The Stars 2006 Mazdaspeed6 GT Crystal White Pearl #07141 Damond Motorsports = PS Cooler - RMM - PMM - OCC VersaTuner = Versatune Clutchmasters = 850 Street Twindisk Corksport = RDM - CBE - RSB - TMM Insert Turbine Tech = Forward Diff Mount - FMM CP-e = Exhaust Manifold - Injector Seals PTE = JB 5862 JMF = Intake Manifold w/Custom PI Kozmic = Downpipe - 6th Port - EGR Delete Forge = V2 BPV Tial = 44mm WG Autotech = HPFP Internals HTP = 4" Intake - Battery Tray Bilstein = B6 Shocks w/Eibach springs Grimmspeed = EBCS Technafit = SS Brake Lines - SS Clutch Line Enkei = EVOX GSR 18x8.5 +38 - NT03+M 17x9.5 +38 Custom = FMIC w/TR1035 - Shifter Cables - Shifter Bushings | ||
| The Following User Says Thank You to Mazdazilla6 For This Useful Post: | RPM (10-11-2015) |
![]() | | #63 | ![]() |
| Not Ranked : 0 score I hope that i could push it further with meth. 375 is not a bad number but i really want to see 400whp with meth.
__________________ 2012 Crystal White Pearl MazdaSpeed 3 Mods: BNR S4 V2 // XS Power Manifold V3 // JBR Tru-3.0" Aluminum Intake // Devils Own WMI D10 NOZZLE// JBR DISI Bypass Valve Hose // JBR 70duro RMM // JBR SSB // JBR SSP // JBR Coolant Bypass Kit // DM EGR Full Delete Kit // DM TMM // DM PMM // COBB AP V2 // CNT Racing Catless Downpipe // CP-E TMIC // CP-E Injector Seals // SP63 Valve Cover Breather // Custom 3" Magnaflow exhaust //One Step Colder NGK Plugs // Bosch 3bar Map sensor // Grimmspeed EBCS // MD OCC // MD PCV Plate // Stop Tech Braided Lines // Autotech Internals // Forge BPV V1 // Corksport V2 RSB // Eibach PRO-kit Stratified Tuned Stage 2 OTS+ 273whp/330wtq SnailD Tuned on Meth 316whp/359wtq Purple Drank Tuned BNR S4 V2 and 100%Meth 412whp/373wtq |
![]() | | #64 | ![]() |
| Not Ranked : 0 score That's very doable with a proper meth setup.
![]() | | #65 | ![]() |
(Thread Starter) | Not Ranked : 0 score One of our customers hit 408hp on the S4 with an E85 mix only. Meth added another 30hp. |
| The Following User Says Thank You to RPM For This Useful Post: | JgamB (10-13-2015) |
![]() | | #66 | ![]() |
![]() Join Date: Mar 2008 Location: South Beach Miami
| Not Ranked : 0 score Next batch shipping out soon? Or do you still have some in inventory?
__________________ 07 GT: JBR 3.5 wide path intake, FMIC, 51R small battery, grimmspeed EBCS, Cobb DP 3Bar map sensor, Kozmic primary and secondary EGR deletes, Bilstein PS14, whiteline endlinks, hawk brake pads, rear camber arms. Speedbakery tuning in the works |
![]() | | #67 | ![]() |
(Thread Starter) | Not Ranked : 0 score First batch hasn't totally shipped out, yet. More going out early next week. Once all pre-orders are filled, we'll still have another 10 or so in stock from the first batch. Not sure how long it will be for the next batch. |
![]() | | #68 | ![]() |
| Not Ranked : 0 score Really excited to see what these end up putting down. My only concern is my clutch and motor if I go this route. Seems like a lot of stock block motors give up around 20-30k after a BT (not blown but rings and shit toast)
![]() | | #69 | ![]() |
| Not Ranked : 0 score Well, I just ordered this package. I feel this could be a great setup for those of us wanting to push the stock block for a decent DD package. Im hoping for a very fun street friendly speed
| The Following User Says Thank You to prototype_x9 For This Useful Post: | RPM (10-13-2015) |
![]() | | #70 | ![]() |
| Not Ranked : 0 score I was thinking the same thing, as long as you can resist turning things up it should be a good setup.
| The Following User Says Thank You to Ziggyboy For This Useful Post: | RPM (10-13-2015) |
![]() | | #71 | ![]() |
![]() Join Date: Aug 2012 Location: Tracy CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 89
| Not Ranked : 0 score On that note.... I didn't even make it past the final tune of my S3 before my rings started showing signs of shitting the bed. My car had 40k miles of 99% stock with just an intake. Than I went fully bolted with an S3 plus tune and well.... So that is what led me to my stupid, crazy, I think I have a spending problem, build. Lol I loved how fast that S3 spooled, tires never stood a chance. Can't wait to see more on the S4!!
__________________ Too much for you |
![]() | | #72 | ![]() |
![]() Join Date: Oct 2015
Rep Power: 0 ![]() Thanks: 0
Groaned at 9 Times in 3 Posts
| Not Ranked : 0 score How could you think it would fit in my speed 6 06? I have a swapped 2013 speed 3 engine inside with Cobb short ram intake and magna flow cat back exhaust Sent from my SM-G920T using Tapatalk |
![]() | | #73 | ![]() |
| Not Ranked : 0 score It should fit the same as any other drop in turbo
| The Following User Says Thank You to spl For This Useful Post: | RPM (10-13-2015) |
![]() | | #74 | ![]() |
| Bob Ross Fanclub ![]() Join Date: Jan 2009 Location: SEFL
Rep Power: 4333 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,534
| Not Ranked : 0 score Does it come with diesel gears?
__________________ |
![]() | | #75 | ![]() |
| Not Ranked : 0 score ^^I'm interested in this as well. Sent from my SCH-I545 using Tapatalk
![]() | | #76 | ![]() |
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) | |
| The Following 3 Users Say Thank You to JgamB For This Useful Post: |
![]() | | #77 | ![]() |
| Not Ranked : 0 score Sounds exactly like my setup but I also ran a dvc-30 just as a fail safe at anything above 17lbs.
| The Following User Says Thank You to skoski17 For This Useful Post: | JgamB (10-13-2015) |
![]() | | #78 | ![]() |
| Not Ranked : 0 score Thanks RPM the turbo finally arrived today. I will be in contact soon to pick up some mounts along with some other goodies.
| The Following User Says Thank You to Ziggyboy For This Useful Post: | RPM (10-23-2015) |
![]() | | #79 | ![]() |
| Not Ranked : 0 score Any updates on this
![]() | | #80 | ![]() |
| The Following User Says Thank You to MS3Shadow For This Useful Post: | Awal (11-07-2015) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f408/bnr-s4-turbos-therpmstore-com-192766/ | ||||
| BNR Stage 4 is coming soon! PRE-ORDER TODAY! | This thread | Refback | 12-06-2015 04:59 PM | |
| ?????????? - ??????? (??????????, ???????, ??????) | This thread | Refback | 10-06-2015 03:46 PM | |
| New logs, stage 2 autotechs installed today. | G26 | 2010 MS3 - ECU Computer Tuning | 31 | 11-18-2011 07:33 AM |
| Report: 2012 BMW 3 Series U.S. order guide leaked, M Sport coming late | Haltech | Automotive News | 0 | 11-10-2011 11:30 AM |
| Hummer plant coming back online to fill 849-unit order? | Haltech | Automotive News | 0 | 03-09-2010 09:20 AM |
