Like Tree19Likes
 Old 09-04-2015, 11:32 AM   #1
I remember Garrett saying that the CHRAs on the GTX turbos were not rebuildable and you had to send them in for service should something happen. Meh to that noise.
 Old 09-07-2015, 09:33 AM   #2
dr_banano's Avatar
Posts: 502   (View Stats)
dr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the world
Groaned at 22 Times in 8 Posts
well my bnr s3 started leaking from the exhaust bracket side no oil its and exhaust leak , havnt checked it good , but this s4 looks tempting ...
Dr_banano
Car: Mazdaspeed3 2010 VRM- BNR S3 Turbo*FreekTuned*363HP 360TQ-DDM 6000k ,tinted 5%,K&N short ram - COBB AP V3 - COBB XLE bpv - JBR SSP stage 2 - JBR billet 80 RMM - JBR heavy shift knob - cp-e fuel pump - COBB inlet -COBB downpipe - COBB CBE - ETS TMIC black- FALKEN AZENIS tires - NGK LTR7IX-11 plugs - Corksports led kit - Corksport fog led kit.-Aeroforce gauges dual with blockhead dual gauge pod- CS boost tube -KNIGHTSPORTS REAR BUMPER - GS EBCS - 3 Bar Map - mgp brake calipers- corksport rear bumper lights - TWM short shifter - JBR TB/IM TI - EGR block - Njspeed pnp IM - K&W V3 coilover - Rear Carbon Fiber Spoiler - corksport hood scoop - WORK wheels 18 x 9.5 + 38 rear and 18 x 8 +38 front
ptp studs/seals pending
mazda 323 2002 hiboost turbo 1.6L-Automatic- Wife's car
dr_banano is offline   Reply With Quote
The Following User Says Thank You to dr_banano For This Useful Post:
SNOW_QN (09-07-2015)
 Old 09-07-2015, 10:20 AM   #3
SNOW_QN's Avatar
Posts: 384   (View Stats)
SNOW_QN is the leader of the worldSNOW_QN is the leader of the worldSNOW_QN is the leader of the worldSNOW_QN is the leader of the worldSNOW_QN is the leader of the worldSNOW_QN is the leader of the worldSNOW_QN is the leader of the worldSNOW_QN is the leader of the worldSNOW_QN is the leader of the worldSNOW_QN is the leader of the worldSNOW_QN is the leader of the world
^^^do it. Then sell me your s3.
Sent from my SCH-I545 using Tapatalk
06 MS6: Stocked out and trying to find her a new family.
SNOW_QN is offline   Reply With Quote
 Old 09-24-2015, 11:12 AM   #4
Jkspeed's Avatar
Posts: 293   (View Stats)
Jkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond repute
Groaned at 6 Times in 4 Posts
This is long awaited great news.
Starting to put my "I didn't buy that last beer at the bar" dollars into a jar for this one.
2008.5 Metro Grey MS3
Performance:
HTP 3.5" Intake | Autotech HPFP Internals | SU TMIC | EBay Catless DP | Stratified Tuned | JBR 88a Dogbone - Short shift plate | Eibach Pro-Kit | 18x8 MB Interline wheels | Conti DW's 235/40R18 | JBR Rear Sway Bar
Other fun:
Dashhawk | Single res delete | Corksport Interior LED light kit - Bypass valve hose | Vent pod boost gage | Custom Heated driver and passenger seats | Leather shift boot
Jkspeed is offline   Reply With Quote
The Following 2 Users Say Thank You to Jkspeed For This Useful Post:
Awal (10-04-2015), RPM (09-24-2015)
 Old 09-29-2015, 10:01 PM   #5
Ziggyboy's Avatar
Posts: 239   (View Stats)
Ziggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the world
Thanks RPM for taking my money. Ordered and now I'm stuck with a stupid smile on my face. It's time to start stacking away parts for a motor and BT build over the winter.
2013 MS3 // Purple Drank Tune // BNR S4 // All the other shit to go along with it
Ziggyboy is offline   Reply With Quote
The Following User Says Thank You to Ziggyboy For This Useful Post:
RPM (09-29-2015)
 Old 10-05-2015, 07:55 PM   #6
jme
jme's Avatar
Posts: 39   (View Stats)
jme is a jewel in the roughjme is a jewel in the roughjme is a jewel in the roughjme is a jewel in the rough
Ordered mine today. Quick question. I already have the bosch 3 bar map sensor. Anyone foresee the need to get a 3.5. Or should the 3 be fine.
BNR stage 4 turbo, Full race exhaust manifold, Mahle 2618 Forged Pistons, Darrell Cox vvt, Manley H-Tuff Rods, Clevite H-Series Main & Rod Bearings, SP63 Custom Age 625+ 10mm Head Studs, ARP main studs, Keyed Crankshaft, Pulley, & Sprockets, pioer stage 2 camshaft
Guardian Angle with 4 bar Corksport 3" TBE, HPFP, 3.5" intake, Corksport FMIC, JMF Intake Manifold, Synapse DV, toyota fuel injector seals, Grimm speed EBC, RMM, Balanced Crank/Clutch/Flywheel, Balance shaft delete, James Barone Oil pan Baffle, South Bend stage 4 Extreme clutch kit, Injecting yummy METH "CM10"!
jme is offline   Reply With Quote
The Following User Says Thank You to jme For This Useful Post:
RPM (10-05-2015)
 Old 10-05-2015, 07:56 PM   #7
RPM
RPM's Avatar
Posts: 1,149   (View Stats)
3-bar will be fine for most people. You'd need the 3.5 if you planned to go over 28 lbs of boost.
 Old 10-05-2015, 07:57 PM   #8
The 3in is fine. But eventually you'll want to upgrade to the 3.5in.
If you can swing for a 3.5in, go for it.
sent from my Nexus 6P
 Old 10-05-2015, 08:50 PM   #9
Awal's Avatar
Posts: 645   (View Stats)
Awal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the world
Map sensors, not intakes Shadow But I still agree.
All Go, No Show
2013 LSM W/ Tech
CORKSPORTFull Race RMM CORKSPORTPMM CORKSPORTTMM CORKSPORTTMIC(temporarily uninstalled for Warranty BS) CORKSPORTECU RELOCATION BATTERY BOX(temporarily uninstalled for Warranty BS) CORKSPORTSSP CORKSPORTSHIFTER BUSHINGS CORKSPORT3.5" POWER SERIES SRI/TIP(temporarily uninstalled for Warranty BS) CORKSPORTBPV(temporarily uninstalled for Warranty BS) CORKSPORTRSB @ Full Stiff CORKSPORTMid Chassis Brace CORKSPORTHood Struts + decals for 20whp CORKSPORTLicense Plate Frames
COBBAP v3 w/ Window Mount
AUTOTECHHPFP INTERNALS
ToBeInstalled:
CORKSPORTFull Catless TBE, Rear Trunk Brace, Adjustable FELs, Cold Air Box (modified for 3.5")
dbaDBA42962S Front and Rear Rotors
StopTechRear Braided SS brake lines
JBROCC & VTA OCC kit, EGR BO, Boost Tubes
Cooling MistWMI kit
StratifiedCustom Tune (as soon as TBE is on)
On Deck
wilwoodFastbrakes DP4front Caliper kit (w/ bp-10 pads and braided SS fr lines)
Hawk PerformanceHB478F.605 or HB478Z.605 rear pads
BilsteinB16s
Awal is offline   Reply With Quote
 Old 10-06-2015, 06:10 AM   #10
well it was late, and didn't see that. In that case, if you are going to get a Guardian Angel, that has a 4bar MAP Sensor already.
Awal (10-07-2015), jme (10-06-2015)
 Old 10-08-2015, 03:11 PM   #11
jme
jme's Avatar
Ordered the Guardian Angle with the 4 bar and the Synapse DV Bov
 Old 10-09-2015, 05:25 PM   #12
Ziggyboy's Avatar
Sure has been cold sleeping next to the mail box all week. Stupid turbo is ruining my life.
ItsNox likes this.
 Old 10-09-2015, 05:27 PM   #13
RPM
RPM's Avatar
We can confirm that some shipped today. Our first 5 pre-orders shipped, but I'm not sure how many total, as I'm sure BNR may have also shipped some direct orders, etc.
Ziggyboy (10-09-2015)
 Old 10-10-2015, 04:36 AM   #14
knocturnal's Avatar
Posts: 266   (View Stats)
Leaving next month on the Harry S Truman. I will be making my purchases when i get back from deployment next year. I figure all the bug, if any, will be all sorted out and good numbers would be posted.
Mods:
Stratified Tuned Stage 2 OTS+
273whp/330wtq
SnailD Tuned on Meth
316whp/359wtq
412whp/373wtq
The Following User Says Thank You to knocturnal For This Useful Post:
Zoom66 (10-10-2015)
 Old 10-10-2015, 03:28 PM   #15
speedfreak44's Avatar
Posts: 1,391   (View Stats)
So do we know if anyone has ran this without aux fueling? Kind of interested to see what this would do on straight 93. Probably the same as a gt30 but for $500 less.
 Old 10-11-2015, 02:13 PM   #16
This won't make much over 375 on just 93. Throw some E in and stock fuel system should be able to carry you a little over 400.
RPM (10-11-2015), Thepedigree13 (10-11-2015)
 Old 10-11-2015, 03:36 PM   #17
knocturnal's Avatar
I hope that i could push it further with meth. 375 is not a bad number but i really want to see 400whp with meth.
Mods:
273whp/330wtq
316whp/359wtq
412whp/373wtq
 Old 10-11-2015, 04:04 PM   #18
That's very doable with a proper meth setup.
 Old 10-11-2015, 04:26 PM   #19
RPM
RPM's Avatar
One of our customers hit 408hp on the S4 with an E85 mix only. Meth added another 30hp.
JgamB (10-13-2015)
 Old 10-10-2015, 07:46 PM   #20
Djohns's Avatar
Posts: 3,944   (View Stats)
I want this turbo bad. But I may just have to hold off for a sweet Christmas/Black Friday sale. No point in going BT in winter I guess....
2010 black mica speed3
Soon:built motor
 Old 10-11-2015, 02:54 PM   #21
I think this is the way to go over a gt series. Does it really matter all that much journal vs ball bearing? $500 is a lot of cash
The line up:
 Old 10-11-2015, 03:06 PM   #22
RPM
RPM's Avatar
When comparing two identical turbos (aside from bearings), the ball-bearing will spool a little quicker. That said, this turbo spools pretty quickly as is, so I don't know that the extra $500 would result in too much real-world difference. Durability is the same if both turbos are well-cared for.
 Old 10-11-2015, 03:26 PM   #23
What RPM said is all true. But just for a bit of clarification though, ball bearings provide better transient response. Off the line the spool difference between the two is suuuper minimal, but in a roll race the ball bearing will spool decently faster. The other main advantage to a ball bearing is they survive surging for a much longer period of time than a journal bearing. Realistically though, you'll be perfectly fine with a journal bearing turbo. My S3 is journal bearing and it barely spools slower than a k04.
RPM (10-11-2015)
 Old 10-11-2015, 05:46 PM   #24
prototype_x9's Avatar
Posts: 174   (View Stats)
prototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the world
Next batch shipping out soon? Or do you still have some in inventory?
07 GT: JBR 3.5 wide path intake, FMIC, 51R small battery, grimmspeed EBCS, Cobb DP
3Bar map sensor, Kozmic primary and secondary EGR deletes, Bilstein PS14, whiteline endlinks,
hawk brake pads, rear camber arms. Speedbakery tuning in the works
prototype_x9 is offline   Reply With Quote
 Old 10-11-2015, 05:47 PM   #25
RPM
RPM's Avatar
Originally Posted by prototype_x9 View Post
Next bath shipping out soon? Or do you still have some in inventory?
First batch hasn't totally shipped out, yet. More going out early next week. Once all pre-orders are filled, we'll still have another 10 or so in stock from the first batch. Not sure how long it will be for the next batch.
 Old 10-11-2015, 06:46 PM   #26
Really excited to see what these end up putting down. My only concern is my clutch and motor if I go this route. Seems like a lot of stock block motors give up around 20-30k after a BT (not blown but rings and shit toast)
The line up:
 Old 10-13-2015, 07:50 AM   #27
skoski17's Avatar
Posts: 1,235   (View Stats)
On that note.... I didn't even make it past the final tune of my S3 before my rings started showing signs of shitting the bed. My car had 40k miles of 99% stock with just an intake. Than I went fully bolted with an S3 plus tune and well.... So that is what led me to my stupid, crazy, I think I have a spending problem, build. Lol I loved how fast that S3 spooled, tires never stood a chance. Can't wait to see more on the S4!!
Too much for you
skoski17 is offline   Reply With Quote
 Old 10-13-2015, 01:08 PM   #28
JgamB's Avatar
Posts: 2,566   (View Stats)
I have 20K of 37K on the S3 and E85, pushing 25.5psi, 17.5° timing, and 7200 RPM redline. Damn thing won't blow up. I have a spare engine sitting here - maybe that is the key.
skoski17 likes this.
Awal (10-14-2015), Mazdazilla6 (10-14-2015), MD1032 (10-30-2015)
 Old 10-12-2015, 11:46 PM   #29
Well, I just ordered this package. I feel this could be a great setup for those of us wanting to push the stock block for a decent DD package. Im hoping for a very fun street friendly speed
The Following User Says Thank You to prototype_x9 For This Useful Post:
RPM (10-13-2015)
 Old 10-13-2015, 12:54 AM   #30
Ziggyboy's Avatar
I was thinking the same thing, as long as you can resist turning things up it should be a good setup.
RPM (10-13-2015)
 Old 10-13-2015, 09:48 AM   #31
ninjasaywhat's Avatar
Posts: 13   (View Stats)
ninjasaywhat is an unknown quantity at this point
Groaned at 9 Times in 3 Posts
How could you think it would fit in my speed 6 06? I have a swapped 2013 speed 3 engine inside with Cobb short ram intake and magna flow cat back exhaust
Sent from my SM-G920T using Tapatalk
ninjasaywhat is offline   Reply With Quote
 Old 10-13-2015, 09:57 AM   #32
spl
spl's Avatar
Posts: 185   (View Stats)
spl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the world
It should fit the same as any other drop in turbo
2010 BM - FREEKTUNED - BNRS3
spl is offline   Reply With Quote
The Following User Says Thank You to spl For This Useful Post:
RPM (10-13-2015)
 Old 10-13-2015, 12:13 PM   #33
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Does it come with diesel gears?
MS3Shadow, spl and SNOW_QN like this.
 Old 10-13-2015, 12:14 PM   #34
SNOW_QN's Avatar
^^I'm interested in this as well.
 Old 10-13-2015, 01:14 PM   #35
skoski17's Avatar
Sounds exactly like my setup but I also ran a dvc-30 just as a fail safe at anything above 17lbs.
Too much for you
The Following User Says Thank You to skoski17 For This Useful Post:
JgamB (10-13-2015)
 Old 10-23-2015, 12:44 AM   #36
Ziggyboy's Avatar
Thanks RPM the turbo finally arrived today. I will be in contact soon to pick up some mounts along with some other goodies.
RPM (10-23-2015)
 Old 11-07-2015, 07:34 AM   #37
knocturnal's Avatar
Any updates on this
Mods:
273whp/330wtq
316whp/359wtq
412whp/373wtq
 Old 11-07-2015, 08:04 AM   #38
Any updates on this
It's already out.
http://www.therpmstore.com/store/p/1...eed-3-/-6.html
Sent from my Nexus 6P
Awal (11-07-2015)
 Old 11-07-2015, 12:41 PM   #39
RPM
RPM's Avatar
Any updates on this
Yeah, BNR made a batch of around 40-50 and they have all sold. The next batch is expected to be ready around January, so any orders placed will be shipped as soon as that batch is ready.
 Old 05-04-2017, 01:28 PM   #40
Grab21's Avatar
Posts: 58   (View Stats)
Grab21 has much to be proud ofGrab21 has much to be proud ofGrab21 has much to be proud ofGrab21 has much to be proud ofGrab21 has much to be proud ofGrab21 has much to be proud ofGrab21 has much to be proud ofGrab21 has much to be proud of
Would anyone like to volunteer some reviews?
2006 speed6 ... bnr s4 soon- on order... when danger to manifold explodes... 8 port
335i day driver
LSA supercharged Caddy CTS-V stealth gray-sold
Porsche Panamera turbo- sold
Bmw m3-sold
Z4m- sold
Grab21 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f408/bnr-s4-turbos-therpmstore-com-192766/
BNR Stage 4 is coming soon! PRE-ORDER TODAY! This thread Refback 12-06-2015 04:59 PM
?????????? - ??????? (??????????, ???????, ??????) This thread Refback 10-06-2015 03:46 PM
New logs, stage 2 autotechs installed today. G26 2010 MS3 - ECU Computer Tuning 31 11-18-2011 07:33 AM
Report: 2012 BMW 3 Series U.S. order guide leaked, M Sport coming late Haltech Automotive News 0 11-10-2011 11:30 AM
Hummer plant coming back online to fill 849-unit order? Haltech Automotive News 0 03-09-2010 09:20 AM
Page generated in 0.61925 seconds with 39 queries
