| Revolution Performance Motorsports Revolution Performance Manufacturing (RPM) was started by three Mazda 6 enthusiasts in early 2004 under a simple premise: to develop and manufacture new products for the Mazda 6 at an affordable price. We began to realize our purpose with the short throw shifter and gas hood lifter kits for that vehicle. Since then, we have added many new aftermarket products from well-known manufacturers and continue to expand to offer products for other vehicles with the goal of having the best prices and customer service on the 'net. |
| Approved MSF Vendor ![]() Join Date: Nov 2008 Location: Euless, TX
Rep Power: 975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 850
(Thread Starter) | Not Ranked : 0 score ![]() Save money with therpmstore.com! ![]() RPM's plug 'n play Bosch MAP Sensor Adapter Harness will convert the proprietary MAP connector found on the Mazdaspeed 3, 6, and CX-7 wiring harness to a standard Bosch connector for use with Bosch MAP sensors. Only $29.75. Order it with a Bosch 3-bar MAP Sensor and save $5! Yes, you heard that right. Get the Bosch 3-bar MAP Sensor AND plug 'n' play harness for under $60! RPM Bosch MAP Sensor Adapter Harness for Mazdaspeed 3 / 6 / CX-7 Bosch 3 Bar T-MAP MAP Sensor with IAT #0281002845
__________________ Last edited by RPM; 02-17-2018 at 10:16 PM. |
| The Following 12 Users Say Thank You to RPM For This Useful Post: | Amnesiac (09-04-2014), aromig (10-18-2014), Code Monkey (09-05-2014), IamJamen (09-05-2014), LMB77 (09-07-2014), Mauro_Penguin (09-07-2014), Mazdazilla6 (09-15-2014), neganox (09-05-2014), smoogs12 (09-04-2014), speed23 (09-07-2014), TiGraySpeed6 (09-05-2014), XxSmarTz (10-05-2014) |
![]() Join Date: Apr 2008 Location: Barnegat, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20
| Not Ranked : 0 score Woo Hoo!
__________________ 2006 MS6 Velocity Red Mica SP63 built motor - SP63 9.5:1 Pistons - Manley Rods - JBR TRU-3" intake - BNR S3 - ETS 3.25" TMIC - Cobb XLE BPV - SP63 IM Port n' Polish - JBR TB TIG - JBR IM TIG - 3 Bar PnP (RPM) MAP - Autotech HPFP Internals - cp-e SafeSeals - NGK Plugs - Streetlite Flywheel - ACT 6 Puck Clutch - GrimmSpeed EBC - BSD - cp-e Catted Downpipe - Magnaflow CBE - cp-e RDM - cp-e Motor Mount - BC Coilovers - 215/45/18 Kuhmo 4x All-Season - Cobb Accessport V2- Prosport Premium Boost Gauge - Vent Pod - Dashhawk - Audiolink iPod Adapter |
| The Following User Says Thank You to igve2shtz For This Useful Post: | RPM (09-05-2014) |
![]() Join Date: May 2010 Location: SLC, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score Wish I knew about this 2 months ago when I spent ~$100. There's no reason the conector should cost twice what the sensor costs.
| The Following User Says Thank You to shamie For This Useful Post: | RPM (09-05-2014) |
(Thread Starter) | Not Ranked : 0 score Well, unfortunately, it wasn't available 2 months ago. We just got them in this week! We do wish we weren't so late to the game, as I'm sure we could have saved a LOT of people some money! At least some will be able to take advantage, though! |
| The Following User Says Thank You to RPM For This Useful Post: | Mauro_Penguin (09-07-2014) |
![]() Join Date: May 2013 Location: CO
Rep Power: 2407 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,487
| Not Ranked : 0 score Thank you for doing this for anyone currently looking to upgrade. I'm in the same boat as other posters of paying way too much for a pnp harness with the sensor. |
| The Following User Says Thank You to monkey.bones.007 For This Useful Post: | RPM (09-08-2014) |
(Thread Starter) | Not Ranked : 0 score It's our pleasure! |
(Thread Starter) | Not Ranked : 0 score This is an ongoing deal and we still have plenty in stock! No coupon code needed! |
| Not Ranked : 0 score Ordered!
| The Following User Says Thank You to igve2shtz For This Useful Post: | RPM (09-16-2014) |
![]() Join Date: Apr 2011 Location: Tampa, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 88
| Not Ranked : 0 score Glad I saw this, will order soon.
__________________ Engine | GTX3067R | Cobb AP | Autotech Internals | HTP 3.5" Intake | M2 Long Downpipe | | ATP FMIC | Forge V1 | Grimmspeed EBCS | 3 BAR MAP | NGK Iridium IX | | Damond EGR Delete | JBR OCC | E33 Self Tune | DO7 Meth | Handling | Damond RMM | Damond PMM | JBR 88a TMM | JBR Shift Weight & Knob | | JBR Rear Sway Bar | Cobb Springs | |
| The Following User Says Thank You to CHUNKYBOWSER For This Useful Post: | RPM (09-16-2014) |
__________________ Last edited by RPM; 09-21-2014 at 03:15 PM. |
| Not Ranked : 0 score Got the combo yesterday in the mail and installed. Works great and good deal.
| The Following User Says Thank You to CHUNKYBOWSER For This Useful Post: | RPM (09-23-2014) |
![]() Join Date: Apr 2011 Location: Hayward, CA 94544
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 176
| Not Ranked : 0 score ordered. thanks!
__________________ 2010 VRM Mazdaspeed3 |
| The Following User Says Thank You to VRM_MS3 For This Useful Post: | RPM (10-03-2014) |
![]() Join Date: Jul 2012 Location: Ventura County, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 593
| Not Ranked : 0 score Thx RPM, great deal as usual. Just bought the map and harness, well within my budget. |
| Not Ranked : 0 score Thx for fast shipping! Got it in record time. |
| The Following User Says Thank You to Mattyhawk1 For This Useful Post: | RPM (10-20-2014) |
(Thread Starter) | Not Ranked : 0 score This is an ongoing deal and we still have plenty in stock! The best deal on a 3-bar with harness AND it stacks with our ongoing sales! |
