| Revolution Performance Motorsports Revolution Performance Manufacturing (RPM) was started by three Mazda 6 enthusiasts in early 2004 under a simple premise: to develop and manufacture new products for the Mazda 6 at an affordable price. We began to realize our purpose with the short throw shifter and gas hood lifter kits for that vehicle. Since then, we have added many new aftermarket products from well-known manufacturers and continue to expand to offer products for other vehicles with the goal of having the best prices and customer service on the 'net. |
![]() Join Date: Mar 2010 Location: Dunlap, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 134
Groaned at 72 Times in 16 Posts
__________________ "I See...." said the Blind man as he pissed into the wind ![]() ![]() ![]() _________________________________ INSTALLED: Cobb SRI Intake and AP V2, Sure Short Shifter, HKS CatBack Exhaust, CP-E Rear Motor Mount & TowPlate & TMIC, Enganeers Shifter Bushings & Passenger Side Mount Mod, JBR TB TIG & TIP & IM TIG, Matt Damond OCC & Banjo Bolt, Forge V1 BPV, HPS Brake pads, Hotchkis Rear Sway Bar, Bilstein Struts/Shocks, DDM Fog HIDS, GT Spec Four Point Brace, Autotech Internals, Rally Armour MudFlaps, Stratified Tune Stage 2, Swift Springs, Denso ITV22 plugs. WAITING: CPE single guage pod (AEM guage) |
![]() Join Date: May 2010 Location: Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 848
| Not Ranked : 0 score James Barone Racing has 'em for $25 a set shipped... Or you can upgrade to the beefier JBR brackets if you're looking for something that's less likely to fail, though considerably more expensive: |
(Thread Starter) | Not Ranked : 0 score thanks for the help but I must have wrote it wrong. I am looking for the rings/collars that keep the sway bar centered. The busings are ok.
| Not Ranked : 0 score Gotcha. Yeah, I've never seen the locating collars sold individually. I highly doubt RPM sells them outside of a kit. Your best bet is probably to contact Hotchkis directly through their website: Contact Information for Hotchkis Sport Suspension If that doesn't work out, you could try sourcing them through Jamie @ JBR, as his rear sway bars have the same diameter: Contact Us : James Barone Racing, Custom Fabrication |
| The Following User Says Thank You to frothy For This Useful Post: | RPM (07-19-2014) |
![]() Join Date: Nov 2010 Location: Phoenix, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,658
| Not Ranked : 0 score Pick your coating/material.... Black Oxide McMaster-Carr Chrome Plated McMaster-Carr Zinc Plated McMaster-Carr 303 Stainless McMaster-Carr Or the stronger version McMaster-Carr
__________________ 2010 MS3 - Restockified (The former STX Battle Wagon) Progress RSB - Koni Sport - EBC Yellow - MD OCC - CS MonoCBE - Cobb SRI 2004 MSM TiGrey AEM SRI - Turbosmart MBC - FM TBI - eBay DP - Turbosmart BPV - Mishimoto FMIC - Denso 305cc Koni Sport - GC Coilover - Racing Beat 1.25" Front Sway Bar - SS Lines - 15x8 Flatout - 225/45 RS3 |
Awesome!
__________________ "I See...." said the Blind man as he pissed into the wind ![]() ![]() ![]() _________________________________ INSTALLED: Cobb SRI Intake and AP V2, Sure Short Shifter, HKS CatBack Exhaust, CP-E Rear Motor Mount & TowPlate & TMIC, Enganeers Shifter Bushings & Passenger Side Mount Mod, JBR TB TIG & TIP & IM TIG, Matt Damond OCC & Banjo Bolt, Forge V1 BPV, HPS Brake pads, Hotchkis Rear Sway Bar, Bilstein Struts/Shocks, DDM Fog HIDS, GT Spec Four Point Brace, Autotech Internals, Rally Armour MudFlaps, Stratified Tune Stage 2, Swift Springs, Denso ITV22 plugs. WAITING: CPE single guage pod (AEM guage) | |
| Front sway bar bushings | SRTie4k | MazdaSpeed 3/6 - Suspension & Brakes | 323 | 10-05-2016 10:07 AM |
| SURE sway bar bushings? | SC08Speed3 | MazdaSpeed 3/6 - Suspension & Brakes | 70 | 05-07-2015 09:24 PM |
| Front sway bar bushings | MS3johanna | MazdaSpeed 3/6 - Suspension & Brakes | 6 | 01-17-2013 04:12 PM |
