Like Tree3Likes
 Old 03-24-2014, 06:05 PM   #1
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Default Fastbrakes Wilwood Brake Caliper Upgrade Kits @ therpmstore.com
Fastbrakes Wilwood Caliper Upgrade and Big Brake Kits are now available through RPM!
Both 4-piston and 6-piston kits are available!
I have the 4-piston upgrade on my car. It uses OEM-sized rotors, comes with adapters, pads, lines, and Wilwood forged calipers.
Initial impression is a much more progressive pedal feel, nicely firm, and should have NO fade!
Great street setup for upgraded power! You should ALWAYS upgrade brakes when going big turbo, people!
Fastbrakes Wilwood 4-Piston Front Brake Caliper Kit for Mazdaspeed 3 : $585
Fastbrakes Wilwood 4-Piston Rear Brake Caliper Kit for Mazdaspeed 3 : $795
Fastbrakes Wilwood 6-Piston Front Brake Caliper Kit for Mazdaspeed 3 : $950
Fastbrakes Wilwood 6-Piston 13" Front Big Brake Kit for Mazdaspeed 3 : $1995
Fastbrakes Wilwood 4-Piston Front Brake Caliper Kit for Mazdaspeed 6 : $695
Remember, Tax return sale is 5% off 'til April 15th!
PM Me for pricing or
- Click here to order! -
Mauro_Penguin and Awal like this.
07 MS3
The original Genpoo Hater
The Following 6 Users Say Thank You to Chimmike For This Useful Post:
Awal (10-01-2015), Mauro_Penguin (03-25-2014), MazdaMOFO84 (03-29-2014), Mazdazilla6 (04-09-2014), smoogs12 (03-24-2014), spdtrux (03-29-2014)
 Old 03-24-2014, 06:20 PM   #2
RPM
RPM's Avatar
Posts: 1,149   (View Stats)
Just FYI, these aren't on the site just yet, but I'll have them up by the end of the night!
Chimmike (03-24-2014), smoogs12 (03-24-2014)
 Old 03-24-2014, 06:41 PM   #3
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Wasn't there an issue with these not grabbing the full brake surface of the rotor or something? Or was that addressed already?
MINI H1 6.0 - CAR LED TAILS
 Old 03-24-2014, 06:47 PM   #4
Will fuck up ur day
Chimmike's Avatar
Groans: 433
It does not grab the full surface of the stock rotor. That does not diminish from the grabbing power of these brakes. It is more or less a cosmetic thing. These grab hard. Trust me.
07 MS3
 Old 03-25-2014, 01:27 AM   #5
RPM
RPM's Avatar
Added to site and updated first post with links, etc.
 Old 03-25-2014, 01:51 AM   #6
RPM
RPM's Avatar
These kits do use smaller pads than the stock calipers. However, a smaller pad of the same compound in the same location as a larger pad will not affect stopping distances. The amount of pressure applied, the pad friction coefficient, and the diameter of the rotor at which that pressure is applied, determine the torque reaction, or stopping force. As such, an upgrade to a 4-piston caliper will improve braking due to the increased amount of more evenly-distributed pressure, despite the smaller pad.
Chimmike (03-25-2014), Mauro_Penguin (03-25-2014)
 Old 03-25-2014, 07:07 AM   #7
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Not only the fact that you're reducing unsprung weight from the heavy stockers to these billet forged aluminum pieces.
07 MS3
RPM (03-25-2014)
 Old 03-27-2014, 03:32 PM   #8
SparkySparks's Avatar
Posts: 1,314   (View Stats)
Plus it is an excuse to run a 2 piece rotor and fix the cosmetic issue right? At least that is what I remember seeing in pictures that someone posted.
On Order:
Coming Soon:
DIY Projects:
 Old 03-27-2014, 03:51 PM   #9
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
whats the size difference of the 4 pistons to the stockers?
860whp/677wtq
2.7 V6 Ecoboost
 Old 03-27-2014, 06:09 PM   #10
RPM
RPM's Avatar
Here's a comparison. The odd shaped one is stock and the more rectangular shaped one is the Wilwood pad.
 Old 03-27-2014, 06:20 PM   #11
PapaSmurf's Avatar
Sorry, I meant the caliper size. I know our stocks are fairly large.
Sent from your girlfriends tapabedroom
860whp/677wtq
2.7 V6 Ecoboost
 Old 03-27-2014, 06:24 PM   #12
RPM
RPM's Avatar
Ah.. lol.. I'll see what I can find!
PapaSmurf (03-27-2014)
 Old 03-27-2014, 07:15 PM   #13
Sixxer's Avatar
Posts: 103   (View Stats)
Sixxer has a brilliant futureSixxer has a brilliant futureSixxer has a brilliant futureSixxer has a brilliant futureSixxer has a brilliant futureSixxer has a brilliant futureSixxer has a brilliant futureSixxer has a brilliant futureSixxer has a brilliant futureSixxer has a brilliant futureSixxer has a brilliant future
What about ms6 love?
Sixxer is offline   Reply With Quote
 Old 03-27-2014, 07:22 PM   #14
RPM
RPM's Avatar
Well, Fastbrakes currently doesn't offer a kit for the Mazdspeed 6, but they may be able to make one if someone in the Phoenix area is willing to work with them on it.
 Old 03-28-2014, 06:50 AM   #15
Will fuck up ur day
Chimmike's Avatar
Groans: 433
I don't have a side by side comparison pic but the 4 piston calipers are definitely smaller than stock. I have 'em on 17" wheels with plenty of clearance. More so than stockers.
I'll try to get a comparison pic next weekend.
07 MS3
 Old 03-28-2014, 08:03 AM   #16
PapaSmurf's Avatar
I was just interested to know if we could fit 15's over them. They really wouldn't need to be that much smaller to do so.
860whp/677wtq
2.7 V6 Ecoboost
 Old 03-28-2014, 08:18 AM   #17
Will fuck up ur day
Chimmike's Avatar
Groans: 433
I guess it would totally depend on the rims. Only thing I can do is tell you what wheels I have and measure the clearance to the spokes and rim. If the 15 is thin, it might be possible?
07 MS3
PapaSmurf (03-28-2014)
 Old 03-28-2014, 11:01 AM   #18
Sixxer's Avatar
ok just buying the calipers is a better price then a full wilwood kit for the ms6 i've found about half. So hopefully they will get someone local so they can make a adapter
 Old 03-28-2014, 11:17 AM   #19
RPM
RPM's Avatar
I take that back. I just called and they will have a caliper kit available for the MS6 in about 2 weeks. I'll get it added to the site. It will be $695 and uses the Wilwood 4-piston Superlite calipers.
The Following 3 Users Say Thank You to RPM For This Useful Post:
Easter Bunny (03-30-2014), Sixxer (03-28-2014), smoogs12 (03-28-2014)
 Old 03-28-2014, 04:51 PM   #20
RPM
RPM's Avatar
Mazdaspeed 6 kit is now on the site and has been added to the OP! Order now and it ships in 2 weeks or less!
Fastbrakes Wilwood 4-Piston Front Brake Caliper Kit for Mazdaspeed 6 #MS6-SL4 - Revolution Performance Motorsports!
The Following 5 Users Say Thank You to RPM For This Useful Post:
maddocx240 (03-29-2014), MazdaMOFO84 (03-29-2014), Poohster (03-30-2014), Sixxer (03-28-2014), smoogs12 (03-28-2014)
 Old 03-28-2014, 10:23 PM   #21
Sixxer's Avatar
good news
 Old 03-29-2014, 09:43 PM   #22
MazdaMOFO84's Avatar
Posts: 158   (View Stats)
MazdaMOFO84 has a reputation beyond reputeMazdaMOFO84 has a reputation beyond reputeMazdaMOFO84 has a reputation beyond reputeMazdaMOFO84 has a reputation beyond reputeMazdaMOFO84 has a reputation beyond reputeMazdaMOFO84 has a reputation beyond reputeMazdaMOFO84 has a reputation beyond reputeMazdaMOFO84 has a reputation beyond reputeMazdaMOFO84 has a reputation beyond reputeMazdaMOFO84 has a reputation beyond reputeMazdaMOFO84 has a reputation beyond repute
I waaaant!
~CORKSPORT STAGE 1 SRI/TIP~JBR 70 TMM~AWR 88 RMM~H & R SPRINGS~SHOPMADE TEST PIPE~GFB BPV~DDM 3000K HID FOGS~CAR_LED TAIL LIGHTS~TSW MAX 18X8.5 +40~HANKOOK VENTUS V12 235X40X18~DUAL BABY CAR SEATS~ROTORPRO'S ZINC PLATED ROTORS AND POSI QUIET PADS~
MazdaMOFO84 is offline   Reply With Quote
 Old 03-29-2014, 09:55 PM   #23
SIXual Panda's Avatar
Posts: 2,363   (View Stats)
Groans: 56
yeah, anyone know the difference in size between these and the stock calipers for an MS6?
also, how would one go about re-ordering pads for these wilwoods?
and are there different pads to choose from?
I envy your ass raping.
 Old 03-30-2014, 03:15 AM   #24
Post 10 answers the size comparison
 Old 03-30-2014, 09:33 AM   #25
Groans: 56
OK... Fail?
1. That's the brake pad.. I'm talking about the caliper size.
2. That's for MS3..Im talking about the MS6.
The ms6 has a bigger front caliper than the 3.
 Old 03-30-2014, 09:45 AM   #26
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
No it doesn't.
"Exclusivity" - CP-enis
Demodded.
The Seals
The Following User Says NO Thank You to Tokay444 For This Un-useful Post:
SIXual Panda (03-30-2014)
 Old 03-30-2014, 10:29 AM   #27
Woops. Maybe Fastbrakes can provide a template to show caliper size difference.
 Old 03-30-2014, 10:33 AM   #28
starscream's Avatar
Posts: 630   (View Stats)
Groans: 44
I saw these...and wanted to know difference in pad size as I was just curious, although it doesnt make a difference as reasons were stated above...but if anyone was interested my crude photochop using their inches scale to bring them to their realistic sizes over eachother.
The Following 2 Users Say Thank You to starscream For This Useful Post:
Easter Bunny (03-30-2014), Tokay444 (03-30-2014)
 Old 03-30-2014, 11:28 AM   #29
Groans: 56
No it doesn't.
no what doesn't?
 Old 03-30-2014, 11:57 AM   #30
Tokay444's Avatar
Groans: 793
The 6 does not have a bigger caliper than the 3.
Demodded.
The Seals
phate (03-30-2014)
 Old 03-30-2014, 12:12 PM   #31
Groans: 56
then explain to me why a 17x9 rpf1 clears a speed3 caliper, but not on my speed6? (without grinding down on the caliper)
 Old 03-30-2014, 12:15 PM   #32
Tokay444's Avatar
Groans: 793
I guess it all depends on your definition of "bigger".
Especially when the most important part of a caliper is piston size.
Demodded.
The Seals
 Old 03-30-2014, 12:19 PM   #33
Groans: 56
im talking "bigger" as in.. you put the two side by side, and look at them. actual size of the caliper. not the piston that's in it.
I never once mentioned the piston size.
in this case. the most important part is the physical size of the caliper, because if needs to clear the wheels.
 Old 03-30-2014, 03:11 PM   #34
Tokay444's Avatar
Groans: 793
In that case, there are dimensions of the 3 caliper which are bigger also.
Demodded.
The Seals
 Old 03-30-2014, 03:27 PM   #35
Tokay444's Avatar
Groans: 793
I suppose the only ones that matter are the ones that interfere with your wheels.
Demodded.
The Seals
 Old 03-30-2014, 03:33 PM   #36
Groans: 56
that's why I was wondering what the caliper size was for these wilwoods compared to the stock speed6 calipers.
also... for reference.
Gold RPF1's 17x9 +45 with 255/40/17
 Old 03-30-2014, 04:37 PM   #37
Will fuck up ur day
Chimmike's Avatar
Groans: 433
these wilwoods are more compact than the stock speed3 calipers, which means they're surely smaller than the speed 6 calipers. There's at least an inch clearance, or more, between my caliper and my 17x9 TRM C3's.
These wheels did fit on my buddy's ms6 as a test fit.
07 MS3
MazdaMOFO84 (03-30-2014), SIXual Panda (03-30-2014)
 Old 03-30-2014, 04:52 PM   #38
Groans: 56
Thanks for the input!
 Old 03-30-2014, 07:07 PM   #39
revin-it02's Avatar
Posts: 58   (View Stats)
revin-it02 is just really nicerevin-it02 is just really nicerevin-it02 is just really nicerevin-it02 is just really nicerevin-it02 is just really nice
That Photoshop concerns me. I don't care how much more pressure these calipers exert, having a smaller contact area with the rotor will promote fading and heat spots. Not to mention the more likelihood of pad deposit on the rotor surface and warping for people DDing their cars. There is a reason for massive pad size and that's heat dissipation.
Has anyone used these in track applications? This just looks like a cosmetic upgrade.
I'm not trying to hate, I'm just looking at the real world application of this.
SIXual Panda likes this.
revin-it02 is offline   Reply With Quote
The Following 3 Users Say Thank You to revin-it02 For This Useful Post:
dale_gribble (03-31-2014), phate (03-30-2014), SIXual Panda (03-30-2014)
 Old 04-04-2014, 11:04 AM   #40
PapaSmurf's Avatar
Do you have the part number for the actual caliper used? so I can get measurements off their website.
thanks
860whp/677wtq
2.7 V6 Ecoboost
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f408/fastbrakes-wilwood-brake-caliper-upgrade-kits-therpmstore-167127/
Corksport Calipers ? Mazda MPS Owners Club This thread Refback 07-11-2015 11:10 AM
Corksport Calipers This thread Refback 06-19-2014 08:03 AM
4 Piston Brake Kits for a 2010 MS3 (and what happens when you push the stock brakes as far as they will go) Reedy 2010 MS3 - Suspension & Brakes 264 01-03-2020 03:07 AM
$5 Off $20 In-Store Coupon Walgreens at Online Store Haltech Hot Deals Section 0 04-11-2008 07:11 AM
Page generated in 0.65784 seconds with 31 queries
