Like Tree48Likes
 Old 04-03-2014, 12:12 PM   #41
JgamB's Avatar
Posts: 2,566   (View Stats)
This will not work with Bilsteins. Only stock shocks and Konis.
Might work with the Corksports adjustables as well, last I'd read they were the same dimensions.
 Old 04-03-2014, 12:13 PM   #42
RPM
RPM's Avatar
Posts: 1,149   (View Stats)
That's true. Theoretically, it should work with anything that's the same dimensions and shock travel as stock. The Bilsteins are not, so they won't work, but it's possible that other brands may work. I'm just not sure if they've been tested, or not.
 Old 04-03-2014, 12:38 PM   #43
Adog35's Avatar
Posts: 309   (View Stats)
Adog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the world
Originally Posted by Bap View Post
I am on aggressive ride with 525 front and 550 rear. car handles really well with them I am enjoying them.
How does it ride on the freeway and in real world driving?
2010 MS3
5% REAR 30% FRONT
DDM 5K HID
RMM
CS TIP/SRI
Dizzy Tuned
Autotech Internals
Swift Springs
JBR Rear Sway
Stoptech 309's
First Turbo Car and I love it!
Adog35 is offline   Reply With Quote
 Old 04-03-2014, 01:02 PM   #44
Bap
Bap's Avatar
Posts: 248   (View Stats)
Bap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the worldBap is the leader of the world
It is a firm ride handling is excellent, real ruff roads can be a bit much. but i am happy with my set up.
Bap is offline   Reply With Quote
 Old 04-03-2014, 01:31 PM   #45
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
what are you using for bumpstops?
'08 CWP MS3 w/ T3 3071r
 Old 04-03-2014, 02:12 PM   #46
Bap
Bap's Avatar
ground control
 Old 04-03-2014, 03:57 PM   #47
Raider's Ohio Bottom Bitch
therza2169's Avatar
Posts: 204   (View Stats)
therza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the world
Alright, we have a bit more information which should answer most of the questions that have been posed.
The perches MUST be cut off of the KONI shocks in order to use the GC kit. GC is going to send me instructions on how to do that, so I'll post those once I receive them.
The pricing in the first post was based upon the off-the-shelf KONI shocks with no modifications and no bump stops. I'm currently talking to GC about removing the perches and including bump stops. I don't know if this will add to the cost, or how much, but once they get back to me, I'll follow up and let everyone know.
Any update on them removing the perches, and including bump stops? If they will do that I will most likely be down.
therza2169 is offline   Reply With Quote
 Old 04-03-2014, 04:04 PM   #48
RPM
RPM's Avatar
Still waiting.. Should have an answer later today.. They're Pacific time.
therza2169 (04-03-2014)
 Old 04-03-2014, 04:05 PM   #49
therza2169's Avatar
Ahh makes sense. Thank!
 Old 04-03-2014, 05:23 PM   #50
RPM
RPM's Avatar
Talked to GC. They're still waiting to hear back from KONI regarding the warranty stuff, availability and such. They were hoping to hear back today, but the guy they need to talk to has been out for most of the day. If he does get back with them today, they'll forward the information along to me. If not, we'll try again tomorrow!
I apologize for the delays, but we want to be 100% clear on the warranty, perches, bump stops, etc., before we give an update and get this thing going. The last thing we want to do is mislead anyone. We're VERY pleased with the response, so far, though. I have a feeling that this will be quite a successful GB!
The Following 5 Users Say Thank You to RPM For This Useful Post:
brandonnicholson (04-03-2014), Chimmike (04-04-2014), daafisch (04-03-2014), nybe0010 (04-03-2014), smoogs12 (04-03-2014)
 Old 04-03-2014, 05:27 PM   #51
covelife1016's Avatar
Posts: 151   (View Stats)
covelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond repute
Can we use paypal or bill me later on the group buy?
2010 MS3 non tech
// CS TMIC// CS battery box// JBR short shifter// JBR 88a rmm// JBR boost tubes// JBR solid shifter bushings// JBR coolant bypass and throttle body tig// Kozmic Motorsports primary and secondary egr delete// NGK one step colder plugs// AT fuel pump internals// HTP 3" intake// GFB bov// COBB accessport V2 // GroundControl springs// Koni yellows//
TUNED BY STRATIFIED
covelife1016 is offline   Reply With Quote
 Old 04-03-2014, 06:32 PM   #52
RPM
RPM's Avatar
Absolutely!
Chimmike (04-04-2014), covelife1016 (04-03-2014)
 Old 04-03-2014, 10:14 PM   #53
Jonathanhair07's Avatar
Posts: 1,601   (View Stats)
Jonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the world
Groaned at 8 Times in 4 Posts
GC+konis 100%
2012 Mazdaspeed3
Columbus, Ga
FJ Performance Built Block/GTX3582r
Jonathanhair07 is offline   Reply With Quote
The Following 3 Users Say Thank You to Jonathanhair07 For This Useful Post:
Chimmike (04-04-2014), RPM (04-03-2014), smoogs12 (04-04-2014)
 Old 04-03-2014, 10:47 PM   #54
skiptowncat's Avatar
Posts: 1,592   (View Stats)
I'm at about 50% for konis+GC
Tuned with by
The Following 3 Users Say Thank You to skiptowncat For This Useful Post:
 Old 04-03-2014, 11:18 PM   #55
easy's Avatar
Posts: 539   (View Stats)
easy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the world
Groans: 27
im in 75% GC only .... been waiting for this option to come to the ms3!!
08 MS3
() Arias Pistons & Pauter Rods, P&P Head, Port match IM, DCR VVT, ARP Head Studs, Autotech CDFP internals, F2 BSD & Baffle, Cobb AP, Cobb SRI, PG TIP, CS Test Pipe, FMIC, Tial QR, JBR RMM/TMM, Oil spin-on Conversion, NGK iridiums IX
() Koni Yellows, Roadmagnet springs(6.5k Front, 6.4k Rear), Cobb RSB, TB trunk brace, AWR Rear Endlinks, SPC rear camber arms
() Centric Slotted Rotors/ Posi-Quiet pad
() Fidanza 11lbs. Flywheel, E4P STS, Cobb Shifter Weight, TWM Bushings, Redline MT-90
easy is offline   Reply With Quote
The Following 3 Users Say Thank You to easy For This Useful Post:
 Old 04-04-2014, 12:13 AM   #56
Quick question - can the konis be adjusted whilst still on the car, I'm sure I read somewhere that they couldn't.
Tuned with by
 Old 04-04-2014, 05:34 AM   #57
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
The rears have to be removed. The front can.
skiptowncat (04-04-2014)
 Old 04-04-2014, 07:59 AM   #58
Domino81's Avatar
Posts: 5,081   (View Stats)
Where's the bottom perch adjust rest on the front strut?
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
 Old 04-04-2014, 08:26 AM   #59
Bap
Bap's Avatar
The adjustment threaded body slides over the top of the stock strut body or koni body.
The Following User Says Thank You to Bap For This Useful Post:
 Old 04-04-2014, 08:53 AM   #60
Domino81's Avatar
So this is different than the stock Koni yellows I have?
 Old 04-04-2014, 09:00 AM   #61
Bap
Bap's Avatar
The only difference between your konis and the ones in the picture is that they just have the lower spring seat removed from the strut.
The Following 3 Users Say Thank You to Bap For This Useful Post:
Chimmike (04-04-2014), daafisch (04-04-2014), Domino81 (04-04-2014)
 Old 04-04-2014, 04:47 PM   #62
RPM
RPM's Avatar
Okay, so this is what we have so far.
1) GC can sell us a kit that will work *WITH* the perches. You lose 1/4"-3/8" of possible drop in the front, but otherwise, the kit is exactly the same. This might be a good option for those who already have KONIs and don't want to cut them.
2) If GC cuts the perches, they will honor the warranty. If the user cuts the perches, they should still be covered, but if there was a warranty claim and KONI suspected that there was damage due to the cut, the warranty could be denied.
3) The prices we have quoted thus far do not include cutting or bump stops. We're currently in negotiation with GC for them to provide both the cutting and the bump stops so that this will be a complete kit and so that there will be no questions regarding the warranty. We're not sure how much (if any) this will affect the prices. We're hoping it won't affect them at all.
Unfortunately, we won't have an update on (4) until Monday, but stick with us! Our goal is to provide a complete kit with a full warranty for the best price possible!
daafisch, smoogs12 and [R]usty like this.
The Following 9 Users Say Thank You to RPM For This Useful Post:
brandonnicholson (04-04-2014), Chimmike (04-04-2014), easy (04-04-2014), jtday (04-05-2014), magicka (04-04-2014), nybe0010 (04-04-2014), SLOWHATCH (04-04-2014), smoogs12 (04-04-2014), [R]usty (04-04-2014)
 Old 04-04-2014, 04:56 PM   #63
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Looks like this is a better and better option!
Glad GC finally supported our platform.
07 MS3
The original Genpoo Hater
easy (04-04-2014)
 Old 04-04-2014, 05:03 PM   #64
daafisch's Avatar
Groans: 58
So it sounds like Koni only cares about the inner cartridge and not the perch. Good news.
I also like the news that they could make the collar fit WITH the perch. This would make it easier if and when I have to warranty my shocks again. Gives me the option of doing advance replacement again.
oooooo this is getting sexier and sexier.
 Old 04-04-2014, 05:13 PM   #65
[R]usty's Avatar
Posts: 2,204   (View Stats)
Awesome work @RPM; interested in the kit that will work with the perches intact. I don't mind losing some drop I wasn't planning on dropping much anyway. Any pictures of what those will looks like?
I'll adjust to my wanting level to 95%
edit
found a pic online with what it will most likely look like.
EDIT by RPM: Picture removed to avoid confusion. Actual picture of kit is 6 posts above in a picture posted by Bap.
2010 Mazdaspeed3 w/tech
daafisch (04-04-2014), smoogs12 (04-04-2014)
 Old 04-04-2014, 05:21 PM   #66
Domino81's Avatar
Or we could cut the perches ourselves?
 Old 04-04-2014, 05:36 PM   #67
daafisch's Avatar
Groans: 58
Yea. That's how they were originally released a few months back. It's one of the reasons I haven't bought them yet. I already have 32k on my yellows and they were warrantied once already. Granted the original ones I had before were the MZ3 version since the MS3 version didn't exist.
 Old 04-04-2014, 08:04 PM   #68
Domino81's Avatar
Sorry this seems like déjà Vu to me considering this is EXACTLY what the probe and mx6 guys used to have to do.
 Old 04-05-2014, 12:30 PM   #69
im out. i just ordered sonic tuning coilovers
2012 Mazdaspeed3
Columbus, Ga
 Old 04-05-2014, 12:47 PM   #70
RPM
RPM's Avatar
Thanks for letting us know.
For what it's worth, I looked into those, as well as a few other low cost coilover kits and they offer very little info in terms of what is actually adjustable (rebound/compression) and I can't find any shock dyno charts at all. As such, I am confident that the KONI Sports are a superior damper.
The Following 4 Users Say Thank You to RPM For This Useful Post:
Chimmike (04-06-2014), covelife1016 (04-05-2014), easy (04-06-2014), [R]usty (04-05-2014)
 Old 04-05-2014, 04:23 PM   #71
Dumbguy's Avatar
Posts: 130   (View Stats)
Dumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond reputeDumbguy has a reputation beyond repute
If GC is going to be cutting the Koni's then Im in for both.
GC + Koni's 100%
2012 VRM Mazdaspeed 3 - “Claudia”
Cobb v3 AP | Autotech HPFP Internals | UR Catback | Cp-e TMIC | Cp-e Stage 2 RMM | Cp-e Catted DP | TWM Full Replacement | CS Occ | CS Bpv | CS Hood Struts | JBR EGR delete | JBR Boost tubes and Recirc hose | HTP 3.5” Intake | 1 Step colder plugs | Blox 490 | BC Coilovers | Drag dr-49
Waiting for install
CS Battery box
2008 Black Mica Mazdaspeed 3 - "April" (Totaled, may she rest in piece)
Dumbguy is offline   Reply With Quote
The Following 2 Users Say Thank You to Dumbguy For This Useful Post:
RPM (04-05-2014), smoogs12 (04-05-2014)
 Old 04-07-2014, 05:19 PM   #72
RPM
RPM's Avatar
The update you've all been waiting for!
We had to add $40 to each of the full kits, but they now include:
  • Ground Control bump stops
  • Perches cut by Ground Control
  • KONI shocks rebound pre-set to match springs
  • Full warranty on all parts through Ground Control, including modified KONIs
Technically, we can still honor the old pricing if you don't want any of the above, but we believe that all of the above is easily worth $40. Heck, just the bump stops would cost you nearly that much!
The original post has been updated. We just need 5 more to reach the 20+ pricing and we still have 2 weeks left! Getting to 40+ is probably a bit of a stretch, but I figured I'd go ahead and include it anyways, just in case. It would be a nice surprise!
smoogs12 likes this.
Chimmike (04-08-2014), chomorro (04-07-2014), magicka (04-07-2014), nybe0010 (04-07-2014), smoogs12 (04-07-2014)
 Old 04-07-2014, 05:30 PM   #73
timmcc02's Avatar
Posts: 253   (View Stats)
timmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the world
Groaned at 9 Times in 3 Posts
GC+KONI 1000%, I wish you could ship sooner!
timmcc02 is offline   Reply With Quote
 Old 04-07-2014, 05:39 PM   #74
[R]usty's Avatar
Wow @RPM; seriously great job putting this all together. These prices are great.
For those who don't want to do the math at the current pricing you're saving $108.05 on the shocks and coils alone that doesn't even include bump stops and perch removal.
I'm 100% buying.
 Old 04-07-2014, 05:54 PM   #75
therza2169's Avatar
Great job @RPM!!! GC+KONI 100% here.
The Following User Says Thank You to therza2169 For This Useful Post:
 Old 04-07-2014, 06:00 PM   #76
Bap
Bap's Avatar
GC bump stops $12 each, $7 for the grinding blades, $3 for spray paint, not having the head ache of having to cut off the spring perches for a few dollar savings. Nice job with the group buy that is a good deal.
The Following 2 Users Say Thank You to Bap For This Useful Post:
Chimmike (04-08-2014), smoogs12 (04-07-2014)
 Old 04-07-2014, 06:08 PM   #77
daafisch's Avatar
Groans: 58
@RPM; You had mentioned they could provide just the GC kit that is the correct length so cutting the perches is not needed. Is this still an option?
 Old 04-07-2014, 06:09 PM   #78
RPM
RPM's Avatar
Yes, it is. It would just be a variant of the GC only kit listed in the first post.
daafisch likes this.
Chimmike (04-08-2014), daafisch (04-07-2014)
 Old 04-08-2014, 09:50 AM   #79
- POD -'s Avatar
Posts: 619   (View Stats)
- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world
You guys are seriously killing my wallet....
What would shipping be to Edmonton Alberta?
- POD - is offline   Reply With Quote
 Old 04-08-2014, 09:59 AM   #80
RPM
RPM's Avatar
For just GC? or GC+KONI?
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f408/gb-ground-control-koni-sport-coilovers-mazdaspeed-167667/
Konisport + ground control setup This thread Refback 04-25-2014 12:49 PM
Konisport + ground control setup This thread Refback 04-20-2014 03:35 AM
Ground control and koni yellows Bap 2010 MS3 - Suspension & Brakes 212 10-20-2016 11:43 AM
Koni Yellows martin_nj MazdaSpeed 3/6 - Suspension & Brakes 50 05-09-2012 10:27 AM
Page generated in 0.61947 seconds with 37 queries
