Like Tree48Likes
 Old 06-21-2014, 02:35 PM   #641
Dimenus's Avatar
Posts: 2,825   (View Stats)
Groans: 33
How does the top mount fit back together? I can't see how the ball bearings would be reused.
Tappin'
2012 Velocity Red Mica
 Old 06-21-2014, 03:49 PM   #642
bennyzoom's Avatar
Posts: 20   (View Stats)
bennyzoom is a glorious beacon of lightbennyzoom is a glorious beacon of lightbennyzoom is a glorious beacon of lightbennyzoom is a glorious beacon of lightbennyzoom is a glorious beacon of lightbennyzoom is a glorious beacon of light
So I got my ground control + Koni's installed at a shop, the height was set to relatively stock height. I got on the highway on my way back home and one of my rear springs totally unseated itself and popped off the seat in the middle of the road. The other rear spring was also slightly off position as well.
Called the shop and had it towed back, they actually found the spring on the side of the highway.
After further examination, it appears that when the suspension is fully stretched, there is no tension on the springs to hold it in place. The roads are really shitty around the area, tons of bumps and dips, which probably caused it to unseat itself.
Did I get the wrong springs? How long are they supposed to be? Mine was about 6 inches.
Even if lowered some more, I still feel that the spring can also pop off.
What height settings do you guys have it at?
So at this point, I really don't know what to do. I am not too thrilled with the ground controls so far, it just feels really unstable.
bennyzoom is offline   Reply With Quote
The Following 6 Users Say Thank You to bennyzoom For This Useful Post:
jack_hammer (06-21-2014), JDMJOSH (06-21-2014), justinsane87 (06-21-2014), Mattyhawk1 (06-21-2014), yourname2221 (06-21-2014), [R]usty (06-21-2014)
 Old 06-21-2014, 05:02 PM   #643
justinsane87's Avatar
Posts: 877   (View Stats)
justinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the world
That makes me nervous now, I wasn't planning on lowering that much and the roads are terrible here too in Edmonton.
2013 Mazdaspeed 3 - GTX3076R EWG
Autotechs - FreekBuilt 3.5" - UR Catless Turbo-back - AP V3 - ETS TMIC
JBR 80D Trilogy/SSP/Bushings/Heavy Knob/TIGs/0.250 RSB - GFB BOV
FreekTune'd - DO DVC-30 - Ground Control w/Koni Yellows - DM OCC
Enkei RPF1 17x9 w/ PSS 235/45/17 - Full Race Exhaust Mani
justinsane87 is offline   Reply With Quote
 Old 06-21-2014, 07:52 PM   #644
JDMJOSH's Avatar
Posts: 642   (View Stats)
JDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the world
Groaned at 8 Times in 5 Posts
@bennyzoom The position of the collars in your pictures suggests they were lowered almost as far as they can go, not stock height which makes it even more puzzling as to why they came loose. This is worrisome, I was all set to install the kit this weekend but I am going to hold off for a while untill we know what the hell is going on.
Using limit straps to hold everything in place is bullshit, this is supposed to be a complete kit, not "requiring modification"
JBR 3.0" WP // CS Racepipe // UR CBE // CS TMIC // CS SS Plate + Bushings // Autotechs // NGK's // Damond Oil Restrictor Bolt // Forge v2 // JBR RMM 88 // JBR .250 RSB // CS Springs/Struts // SPC Camber Arms //
JDMJOSH is offline   Reply With Quote
The Following 2 Users Say Thank You to JDMJOSH For This Useful Post:
bennyzoom (06-22-2014), justinsane87 (06-21-2014)
 Old 06-21-2014, 07:59 PM   #645
Helrich's Avatar
Posts: 306   (View Stats)
This was brought up earlier in the thread, you can get/make straps to keep the springs from falling out (just like a real rase kar™!)
2016 MX-5 Club
2012 MS3 -- RIP in peace
 Old 06-21-2014, 08:04 PM   #646
- POD -'s Avatar
Posts: 619   (View Stats)
- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world
I'm not thrilled about this as well. I understand that I/we can make limiting straps (and it looks like we may have to), but I thought it was (or was hoping it was) a direct bolt in.
I suppose I could lobby my MLA to fix our hellish roads...
Sent from my SGH-I747M using Tapatalk
2012 MS3 SOLD, living in the world of Right Wheel Drive now
Ol' BMO had: Autotech Internals, CS SRI+TIP, CS Short Shift Plate, CS BPV, CS TMIC, UR Catback, CP-e Stage 2 RMM, COBB AP v3.0, UR Test Pipe, JBR Weighted Shift Knob, DM OCC Kit, Koni Yellows+GC springs
- POD - is offline   Reply With Quote
The Following User Says Thank You to - POD - For This Useful Post:
 Old 06-21-2014, 08:10 PM   #647
Mattyhawk1's Avatar
Posts: 739   (View Stats)
@bennyzoom;
That is so wrong, the rear springs appear to be totally wrong for this platform. I know we can use limiting straps, but that is not mentioned anywhere in the GC website or other documentation before buying.
Mattyhawk1 is offline   Reply With Quote
The Following 5 Users Say Thank You to Mattyhawk1 For This Useful Post:
- POD - (06-21-2014), bennyzoom (06-22-2014), bstover17 (06-21-2014), justinsane87 (06-21-2014), [R]usty (06-21-2014)
 Old 06-21-2014, 08:32 PM   #648
461_SS's Avatar
Posts: 1,160   (View Stats)
461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world461_SS is the leader of the world
I have not gotten my kit yet, but why don't you just strap a small chain that loops around the spring/suspension to keep the spring tied in the pocket? Honestly though in my mind GC should have a tube that comes down over the spring to keep it in place while still having access to the adjuster.
What are the size of the springs that other companies are running in the rear?
461_SS is offline   Reply With Quote
 Old 06-21-2014, 10:34 PM   #649
timmcc02's Avatar
Posts: 253   (View Stats)
timmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the world
Groaned at 9 Times in 3 Posts
He's actually adjusted at max height. He needs to lower it half an inch and should be fine.
timmcc02 is offline   Reply With Quote
The Following User Says Thank You to timmcc02 For This Useful Post:
 Old 06-21-2014, 10:45 PM   #650
PoweredByDeez's Avatar
Posts: 42   (View Stats)
PoweredByDeez is a splendid one to beholdPoweredByDeez is a splendid one to beholdPoweredByDeez is a splendid one to beholdPoweredByDeez is a splendid one to beholdPoweredByDeez is a splendid one to beholdPoweredByDeez is a splendid one to beholdPoweredByDeez is a splendid one to behold
Groaned at 3 Times in 1 Post
People in Auto X swear by this setup.
2008 Mazdaspeed 3 GT Metropolitan Grey Mica
RPF-1 17x9 +45 rear +37 front 245/45/17 BF Goodrich, CP-E 3.25 Intake and TIP, 3" HKS Exhaust with Catless 3" DP, AutoTech HPFP, TR8 FMIC w/ JBR Underside piping, GT3071 w/ Tial 44mm EWG and XS Exhaust Manifold, Overspeed Built engine, AEM Meth kit, JBR ECBS, JBR EGR DEL, Damond OCC, JBR TMM & PMM w/ CP-E Stage 2 RMM, AP V3, HKS VTA,
2008 Mazdaspeed 3 GT Metropolitan Grey Mica Total Loss
2006 Mazdaspeed 6 GT- Total Loss.
PoweredByDeez is offline   Reply With Quote
 Old 06-21-2014, 10:58 PM   #651
yourname2221's Avatar
Posts: 224   (View Stats)
yourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the world
and I quote.
Originally Posted by Chimmike View Post
The springs definitely aren't coming unseated with that much weight from these cars.
Originally Posted by 461_SS View Post
Too many people worry on this forum.
Installed: JBR SSP/RMM/RSB
Cobb APv3/EBCS
AT Internals
Bilstein Coilovers
SPC arms
UR
TP/DP
BNR S4, JBR Undermount w/TR8, 3.5" intake
OBX CBE
For dat racecar: Gold Caliper Paint
yourname2221 is offline   Reply With Quote
The Following User Says Thank You to yourname2221 For This Useful Post:
461_SS (06-22-2014)
 Old 06-21-2014, 11:17 PM   #652
JDMJOSH's Avatar
Your absolutely right, my mistake. Still, if adjusting a half inch will solve his problem what happens to those of us in the winter who need to adjust back to stock height? Do we need to worry about the rear spring flying out of the car again? My confidence level in this setup is not where it needs to be...
- POD - (06-22-2014), nybe0010 (06-22-2014)
 Old 06-22-2014, 07:25 AM   #653
timmcc02's Avatar
What is the reason for being at stock height during winter? This GC kit is not like your slamming your car
 Old 06-22-2014, 09:14 AM   #654
Jdraps13's Avatar
Posts: 703   (View Stats)
Jdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the world
Groaned at 18 Times in 5 Posts
Did anyone end up getting a measurement for limiting straps
Jdraps13 is offline   Reply With Quote
 Old 06-22-2014, 09:33 AM   #655
JDMJOSH's Avatar
We don't live in Southern California, with all the snow, ice and God knows what else (not to mention our roads are shit in the first place) . Trust me, every little bit counts.
My whole reason for going with coil overs was to be able to adjust height/stiffness as I please . Not just for aesthetic reasons, but functionality as well. If I just wanted to drop it a few inches I'd have gone with some lowering springs and called it a day
The Following 4 Users Say Thank You to JDMJOSH For This Useful Post:
- POD - (06-22-2014), bennyzoom (06-22-2014), justinsane87 (06-22-2014), nybe0010 (06-22-2014)
 Old 06-22-2014, 10:11 AM   #656
bennyzoom's Avatar
My point exactly, I wanted to be able to adjust the height at will. Now it seems that you must lower it a considerable amount so that the chances of the spring popping off is less likely to happen.
 Old 06-22-2014, 10:18 AM   #657
timmcc02's Avatar
The car sits pretty high to being with, half an inch Lower than stock is not a huge deal. I would say our roads are some of the worst known to mankind
 Old 06-22-2014, 10:25 AM   #658
- POD -'s Avatar
Hazards like this are not uncommon in Edmonton. While the GC kit would not have faired any better than the stock suspension, the option to be at stock height is a real benefit. At stock height I plow snow as it is. There are also driveways that I drag the front valance on trying to get up.
There are 4 of us (to my knowledge) from Edmonton that purchased this kit. I can't speak for all of us, but I know myself personally I was looking for a bolt in kit that would improve handling and reduce suspension bounce while maintaining stock height or while dropping the height just a little (0.5 to 1 inch). This kit appeared to be exactly the ticket.
Now however, it sounds like there are some issues that need to be sorted out before the install. I'm not against trouble shooting or making limiting straps to let this kit work, I just need to know exactly what needs to be done to let this kit work in an area where the roads are very, VERY, bad and where I will probably run a 0.5 to 1 inch drop in the summer and run at stock height in the winter.
The Following 3 Users Say Thank You to - POD - For This Useful Post:
JDMJOSH (06-22-2014), justinsane87 (06-22-2014), nybe0010 (06-22-2014)
 Old 06-22-2014, 10:34 AM   #659
JDMJOSH's Avatar
I've done a fair bit of driving in SoCal. Trust me, your roads ain't that bad.
The Following User Says Thank You to JDMJOSH For This Useful Post:
bstover17 (06-22-2014)
 Old 06-22-2014, 11:00 AM   #660
timmcc02's Avatar
Some areas yes but anywhere near LA is fucking terrible. I wish I could live back in Florida again just for the roads
 Old 06-22-2014, 11:06 AM   #661
Jdraps13's Avatar
Can someone that has these installed jack up their car until the spring is just about to unseat and pull a measurement for limiting straps please that's the solution here
The Following 2 Users Say Thank You to Jdraps13 For This Useful Post:
- POD - (06-22-2014), justinsane87 (06-22-2014)
 Old 06-22-2014, 05:28 PM   #662
RPM
RPM's Avatar
Posts: 1,149   (View Stats)
FYI, I'm out of town, but I have an email in to GC about this.
The Following 3 Users Say Thank You to RPM For This Useful Post:
bennyzoom (06-22-2014), JDMJOSH (06-22-2014), Jdraps13 (06-22-2014)
 Old 06-22-2014, 06:09 PM   #663
moonrider_99's Avatar
Posts: 185   (View Stats)
moonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond repute
Groaned at 46 Times in 14 Posts
People who live in the south of US have NO IDEA how bad roads are in Canada. I spent half of my life there and I guarantee you that between the harsh winters and heavy semis (much higher weight limits than in US) the roads are terrible. The worst piece of road in LA is considered average for a Canadian. And, in the winter, every inch of clearance counts when you driving through 1+ feet of snow....
2017 Ford Focus RS - Stock
2004 MSM
- AEM Intake - BEGI - FM Turboback - Turbosmart BPV - Hallman Boost Controller - ...
"I'm a Turbo addict, I know."
SCCA Philadelphia: (http://www.phillyscca.com/solo/)
2012 MS3 Silver w/ Tech Package - sold in '17
2009 WRX Stage 2- sold in '12
moonrider_99 is offline   Reply With Quote
The Following 2 Users Say Thank You to moonrider_99 For This Useful Post:
justinsane87 (06-22-2014), speed23 (06-22-2014)
 Old 06-22-2014, 06:18 PM   #664
I was thinking of purchasing the GC kit, not anymore.
If the kit is designed to work between 0-2.x inches of drop, there should be no reason for a spring to literally fly off the car at any height... Even if you drop your car by an inch, I guarantee that there's plenty of times when rear suspension will extend enough to allow for the spring to move out of position during driving, I don't even want to imagine what could happen on a track with some level changes, etc.
This is frankly a serious safety hazard. In a society when we are warned that coffee from McDonalds is hot, I have difficulty understanding how it is acceptable to design and sell a product with such a major safety flaw.
2004 MSM
The Following User Says Thank You to moonrider_99 For This Useful Post:
 Old 06-22-2014, 07:36 PM   #665
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
Doubt this will help ease any of your "fears" but I finally got to run mine at autox today. The lot that we ran on was extremely bumpy to which one spot was kind of a small jump for lighter cars. There were numerous times that I went slightly off line and had trouble breaking because the lot was so uneven. With that said I didn't have 1 issue with my suspension and rear was definitely close to fully extended a few times.
I've also been driving all over CT and NY (including the awful roads in NYC) and I've had no issues (I drive at least 100 miles per day). To enter my driveway I have 1 wheel come off the ground every time. The only way I can see anything possibly happening like this is if both wheels came completely off the ground. From what I remember when installing them even with the back of the car in the air the spring was still not completely free to just fall out. I have my height set the same as the images posted above.
I know some of you are looking into limiting straps but couldn't it also be possible to either install a longer spring or even use helper springs?
 Old 06-22-2014, 08:16 PM   #666
Jdraps13's Avatar
Doubt this will help ease any of your "fears" but I finally got to run mine at autox today. The lot that we ran on was extremely bumpy to which one spot was kind of a small jump for lighter cars. There were numerous times that I went slightly off line and had trouble breaking because the lot was so uneven. With that said I didn't have 1 issue with my suspension and rear was definitely close to fully extended a few times. I've also been driving all over CT and NY (including the awful roads in NYC) and I've had no issues (I drive at least 100 miles per day). To enter my driveway I have 1 wheel come off the ground every time. The only way I can see anything possibly happening like this is if both wheels came completely off the ground. From what I remember when installing them even with the back of the car in the air the spring was still not completely free to just fall out. I have my height set the same as the images posted above. I know some of you are looking into limiting straps but couldn't it also be possible to either install a longer spring or even use helper springs?
Would helper springs really work tho without a damper to keep it in place, just spring on spring doesn't seem like it would work
 Old 06-22-2014, 10:35 PM   #667
jeffdevo's Avatar
Posts: 395   (View Stats)
jeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond repute
I just want a little drop and slightly stiffer set up. this is a huge concern for me, think I may switch to a different spring combo that has been proven and reliable so far.
-Low Beam/ Fog HIDS - Lamin-X Yellow Tint on Fog Lights - TSW Mallory Wheels - Thule Bike Rack with 598 Criterium Bike Mount - GX-65 with Blendmount - Corksport RMM - Corksport Mudflaps - Corksport SRI - Corksport Rear Sway Bar - GX-65 radar laser detector - TRS Angel Eyes - Rear bumper LED Light - H&R Springs - Koni Yellow Struts - JBR Camber Arms - AP v2 -Autotech internals - Tork Motorsports Tuned - Halos - Strips - D2 Xenon Lights - SST brake lines - Stoptech Sport brake and rotors w/ sst Brake lines
[/I][/SIZE][/FONT]
jeffdevo is offline   Reply With Quote
 Old 06-23-2014, 07:05 AM   #668
Dimenus's Avatar
Groans: 33
@bennyzoom;. I have no idea how you have so much clearance with the LCA still attached. I was able to pull the spring out when it was completely unloaded but It took some maneuvering.
For what it's worth, I'm quite happy with mine so far. Seems to absorb small bumps much better than stock even with the 525/600 springs.
I'm going to need to adjust my shocks though. It's very bouncy over dips in the road and speed bumps. I didn't fiddle with them out of the kit.
The Following User Says Thank You to Dimenus For This Useful Post:
Jdraps13 (06-23-2014)
 Old 06-23-2014, 08:30 AM   #669
Mattyhawk1's Avatar
Anyone coming from another spring setup, like Eibach, Cobb or Swift? If so, How does it feel in comparison?
Are the spring rates shown on GC spec springs comparable to the spring rates from other companies?
 Old 06-23-2014, 08:41 AM   #670
jeffdevo's Avatar
I'm a car noob, but I just convinced the wife to let me buy this car and that even a baby seat will fit... Thanks Dimenus but at this rate of two cars of having springs pop off, (10% +) I can't put this on my car....
[/I][/SIZE][/FONT]
 Old 06-23-2014, 08:50 AM   #671
timmcc02's Avatar
It was only one car and he probably has his control arm bolts loose. my spring doesnt fall out when lifted. so unless he dukes of hazards his car on a rally course i cant see how this is possible. He should call GC and find out what they recommend.
daafisch (06-23-2014)
 Old 06-23-2014, 09:04 AM   #672
justint5387's Avatar
Posts: 608   (View Stats)
justint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the worldjustint5387 is the leader of the world
Just put in 7 inch springs if you are going to run the car that high.
justint5387 is offline   Reply With Quote
The Following 2 Users Say Thank You to justint5387 For This Useful Post:
Crarrs (06-23-2014), daafisch (06-23-2014)
 Old 06-23-2014, 09:13 AM   #673
Ewind's Avatar
Posts: 235   (View Stats)
Ewind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond repute
Groaned at 6 Times in 4 Posts
I think you got the wrong rear springs.
I don't see them in this list (based on what you have stamped on the spring):
Ground Control Suspension Systems - GC Spec Springs
Plus the other person a page back asking what spring rate was in the rear had 8" springs.
edit: it looks like other gen 2 cars got 6" springs as well?
The guy who got 8" springs was a gen 1
Ewind is offline   Reply With Quote
 Old 06-23-2014, 09:27 AM   #674
Crarrs's Avatar
Posts: 1,662   (View Stats)
To the people having these pop-out issues: What driving type did you spec when you ordered? I'm only going to assume that some people picked "Aggressive" and are trying to make their cars work as uncompromised street cars.
That list is only the "custom" GC spring application list. Eibach makes a shitload of other springs that aren't on that list.
2004 MSM TiGrey
Last edited by Crarrs; 06-23-2014 at 09:27 AM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to Crarrs For This Useful Post:
Ewind (06-23-2014)
 Old 06-23-2014, 09:44 AM   #675
Ewind's Avatar
That would be good information to know.
FYI I chose occasional autocross with touring feel.
Haven't received my kit yet.
Yeah, that is why I edited my post to acknowledge that other gen 2's got that spring.
 Old 06-23-2014, 09:45 AM   #676
I asked for dd touring, I'm not at home to measure them though
 Old 06-23-2014, 09:48 AM   #677
- POD -'s Avatar
I'll measure my springs in an hour or so. I selected Daily Driver Aggressive when I ordered.
When I looked at our kits the springs were identical (from what I could tell).
Last edited by - POD -; 06-23-2014 at 09:48 AM. Reason: MSF Database - Automerged Doublepost
justinsane87 (06-23-2014)
 Old 06-23-2014, 10:12 AM   #678
- POD -'s Avatar
6" springs on the rear.
 Old 06-23-2014, 05:01 PM   #679
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
if you are running a rear sway bar, these are not going to come out driving on the street, OR the track. I just don't see it happening now.
07 MS3
The original Genpoo Hater
 Old 06-23-2014, 05:11 PM   #680
Guess I'm buying a rsb now lol, was planning on it eventually anyways
The Following User Says Thank You to justinsane87 For This Useful Post:
Mattyhawk1 (10-10-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f408/gb-ground-control-koni-sport-coilovers-mazdaspeed-167667/
Konisport + ground control setup This thread Refback 04-25-2014 12:49 PM
Konisport + ground control setup This thread Refback 04-20-2014 03:35 AM
Ground control and koni yellows Bap 2010 MS3 - Suspension & Brakes 212 10-20-2016 11:43 AM
Koni Yellows martin_nj MazdaSpeed 3/6 - Suspension & Brakes 50 05-09-2012 10:27 AM
Page generated in 0.60439 seconds with 40 queries
