Like Tree48Likes
 Old 07-08-2014, 03:35 PM   #721
Helrich's Avatar
Posts: 306   (View Stats)
I've decided to wait on those cups, but damn am I getting antsy...
2016 MX-5 Club
2012 MS3 -- RIP in peace
 Old 07-08-2014, 05:54 PM   #722
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
Originally Posted by 461_SS View Post
Buy 'em! unless the GC will allow you to adjust caster as well. You already know what I think though haha.
I probably will. Then I can get the car adjusted pretty good.
 Old 07-09-2014, 03:45 PM   #723
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Excellent! Looking forward to getting those spring cups.
So frustrated with this front end clunking that I'm [] that close to fucking yanking my front sway bar. The E36 endlinks didn't work.
07 MS3
The original Genpoo Hater
 Old 07-09-2014, 07:25 PM   #724
daafisch's Avatar
Groans: 58
If it makes you feel better I'm also getting clunking.
But I had it before the spring install. I replaced both front and rear bushings, endlinks are next.
 Old 07-09-2014, 08:27 PM   #725
Dimenus's Avatar
Posts: 2,825   (View Stats)
Groans: 33
No clunk here but I had a nasty interior vibe that turned out to be my right front knuckle loosening up after an AutoX run.
How can you tell how firm or stiff the rears are with them off the car? They don't have defined adjustment points like the fronts
2012 Velocity Red Mica
 Old 07-09-2014, 09:52 PM   #726
Jdraps13's Avatar
Posts: 703   (View Stats)
Jdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the world
Groaned at 18 Times in 5 Posts
Got er all buttoned up tonight super happy with the fitment 1 finger gap no roll no rubbing 18x8 +42 235 28
Jdraps13 is offline   Reply With Quote
The Following User Says Thank You to Jdraps13 For This Useful Post:
thepatient77 (07-10-2014)
 Old 07-10-2014, 05:33 AM   #727
daafisch's Avatar
Groans: 58
If you're adjusting them correctly there are stops for full soft and full stiff. Make sure the piston is compressed completely before spinning the body of the shock.
Dimenus (07-10-2014)
 Old 07-10-2014, 09:03 AM   #728
thepatient77's Avatar
Posts: 162   (View Stats)
thepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond repute
looks good man. I'll have to snap a photo of mine. As for any problems with this suspension, I've had none. I've had them on for about a month meow and so far so good. I just need to dial in the rear.... maybe a little stiffer and i should be good.
thepatient77 is offline   Reply With Quote
 Old 07-10-2014, 10:20 AM   #729
Ewind's Avatar
Posts: 235   (View Stats)
Ewind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond repute
Groaned at 6 Times in 4 Posts
I ended up with 525F and 600R
Ran with GC settings for a couple of days and didn't like it
played with the adjustments in F and R.
Front shocks go almost 2.5 revolutions from full soft. More like 2.25.
Rears shocks max is 2 revolutions from foll soft
I have my F set at 1.25 revolutions from full soft.
I have my R set at 1.25 revolutions from full soft.
Won't be changing it for street anymore. I like it exactly where it is.
Ewind is offline   Reply With Quote
 Old 07-10-2014, 12:06 PM   #730
Will fuck up ur day
Chimmike's Avatar
Groans: 433
yah I saw my sway bar was contacting the frame so I ground/cut away some parts and will see if that helps. Otherwise, I can't figure out where the normal clunking is coming from to save my life. I'm gonna have to check my side motor mounts.....but that doesn't make any sense or I'd get clunks during shifts and engine loading.
07 MS3
 Old 07-10-2014, 06:42 PM   #731
JDMJOSH's Avatar
Posts: 642   (View Stats)
JDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the world
Groaned at 8 Times in 5 Posts
Don't be and just install it. This kit is perfectly safe even without the spring cups at stock height. Just make sure the springs are seated properly when you lower the car and your golden
JBR 3.0" WP // CS Racepipe // UR CBE // CS TMIC // CS SS Plate + Bushings // Autotechs // NGK's // Damond Oil Restrictor Bolt // Forge v2 // JBR RMM 88 // JBR .250 RSB // CS Springs/Struts // SPC Camber Arms //
JDMJOSH is offline   Reply With Quote
The Following 2 Users Say Thank You to JDMJOSH For This Useful Post:
daafisch (07-10-2014), Jdraps13 (07-10-2014)
 Old 07-13-2014, 08:24 AM   #732
Dimenus's Avatar
Groans: 33
I have the same Springs and ended up around the same adjustment wise. The rear end behaves much much better after stiffening it up.
 Old 07-14-2014, 11:38 AM   #733
Ewind's Avatar
Agreed. The OTS settings we pretty close in the front and bouncy in the rear.
quarter turn made a huge difference.
 Old 07-14-2014, 04:36 PM   #734
JDMJOSH's Avatar
Just installed my kit yesterday, same springs as you; 525F 600R. I'm finding its a little "bouncy" for my liking. Going to give everything a week or so to settle and then try your settings and see what happens.
The Following User Says Thank You to JDMJOSH For This Useful Post:
nybe0010 (08-04-2014)
 Old 07-14-2014, 04:47 PM   #735
- POD -'s Avatar
Posts: 619   (View Stats)
- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world- POD - is the leader of the world
Im in the same boat as well. At city speeds it's fine. Dips in the highway are too bouncy.
2012 MS3 SOLD, living in the world of Right Wheel Drive now
Ol' BMO had: Autotech Internals, CS SRI+TIP, CS Short Shift Plate, CS BPV, CS TMIC, UR Catback, CP-e Stage 2 RMM, COBB AP v3.0, UR Test Pipe, JBR Weighted Shift Knob, DM OCC Kit, Koni Yellows+GC springs
- POD - is offline   Reply With Quote
 Old 07-19-2014, 04:28 PM   #736
Helrich's Avatar
So I'm installing mine, fronts are in, but for the rears, it says to re-use the stock bolt and washer to fasten the collar that goes on top of the rear spring. Well that bolt and washer doesn't fit through the collar. Did I perhaps get the wrong rears? I don't mind drilling that hole in the collar out but wanted to make sure I'm approaching this correctly.
2016 MX-5 Club
 Old 07-20-2014, 08:40 AM   #737
Jdraps13's Avatar
I just drilled mine had the same thing super quick to drill em out
 Old 07-20-2014, 08:42 AM   #738
Helrich's Avatar
Alright. Just weird I guess that you have to do that for a kit ordered for a specific car. I'm gonna have to grind the washers down a bit too to get them to fit inside.
2016 MX-5 Club
 Old 07-20-2014, 12:07 PM   #739
- POD -'s Avatar
For what it's worth. The rears on mine did not require any drilling or grinding.
 Old 07-20-2014, 01:59 PM   #740
timmcc02's Avatar
Posts: 253   (View Stats)
timmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the world
Groaned at 9 Times in 3 Posts
I didn't have any issues with mine either
timmcc02 is offline   Reply With Quote
 Old 07-20-2014, 04:36 PM   #741
Helrich's Avatar
Hrm. Well then maybe I'll give GC a call tomorrow when they're open. I also noticed one of the silicone/rubber rings that go on the bottom of the rear springs has a hole in it, so the spring could touch the bottom steel ring when compressed. Not too worried about that though. Put the stock rears back on for now.
2016 MX-5 Club
 Old 07-20-2014, 10:56 PM   #742
JDMJOSH's Avatar
Seems like there was more than a few QC issues with this kit. My fronts were missing the nuts that hold the top hat on but that was no biggie.
 Old 07-21-2014, 12:52 PM   #743
Helrich's Avatar
I called GC, the guy I talked to said there were two or three kits out of a 200 kit batch that didn't have large enough holes. Not sure why they sent them out anyway but oh well! He said he thinks a 12mm drill bit out to bore that hole out enough, but mine are half an inch ID (12.7mm) and obviously isn't enough so perhaps 14mm. I also noted earlier about the bottom rubber gasket being malformed, looks like they scraped it away on purpose to sit flush with the welds on the steel ring. I do still have full-fledged holes in mine but I doubt it will cause any issues. Of course now that I've said that...
2016 MX-5 Club
The Following User Says Thank You to Helrich For This Useful Post:
Jdraps13 (07-21-2014)
 Old 07-21-2014, 03:30 PM   #744
justinsane87's Avatar
Posts: 877   (View Stats)
justinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the world
@RPM; updates on those cups?
2013 Mazdaspeed 3 - GTX3076R EWG
Autotechs - FreekBuilt 3.5" - UR Catless Turbo-back - AP V3 - ETS TMIC
JBR 80D Trilogy/SSP/Bushings/Heavy Knob/TIGs/0.250 RSB - GFB BOV
FreekTune'd - DO DVC-30 - Ground Control w/Koni Yellows - DM OCC
Enkei RPF1 17x9 w/ PSS 235/45/17 - Full Race Exhaust Mani
justinsane87 is offline   Reply With Quote
 Old 07-21-2014, 03:31 PM   #745
Helrich's Avatar
1/2" drill bit worked. Also looking forward to the cups. Had to poke a spring into the sleeve when lowering the car off the jack.
2016 MX-5 Club
 Old 07-22-2014, 05:38 PM   #746
RPM
RPM's Avatar
Posts: 1,149   (View Stats)
They just told me they expect them to ship later this week or early next week.
The Following 3 Users Say Thank You to RPM For This Useful Post:
covelife1016 (07-22-2014), justinsane87 (07-22-2014), thepatient77 (07-22-2014)
 Old 07-29-2014, 11:23 AM   #747
Jdraps13's Avatar
As for adjusting the front shocks do you need to lift the front or can it be done while on the ground?
 Old 07-29-2014, 11:38 AM   #748
RPM
RPM's Avatar
To adjust the damping, you can do it on the ground. You have to lift it to adjust the height, though.
 Old 07-29-2014, 11:45 AM   #749
Raider's Ohio Bottom Bitch
therza2169's Avatar
Posts: 204   (View Stats)
therza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the world
@RPM any word on if the new spring cups shipped?
therza2169 is offline   Reply With Quote
 Old 07-29-2014, 11:55 AM   #750
RPM
RPM's Avatar
Not, yet. Last time I asked they told me another week.
 Old 07-29-2014, 12:11 PM   #751
Jdraps13's Avatar
we'll yeah to adjust the height was just wondering on dampening thanks
 Old 07-29-2014, 12:34 PM   #752
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
I know gc said they would be automatically shipping the cups out, but i purchased mine outside of the group buy. Will it be a situation that anyone with a Mazda who's ordered these will get the cups automatically? I figure that's probably the case but I'd like to confirm.
 Old 07-29-2014, 12:36 PM   #753
RPM
RPM's Avatar
Just got this from GC:
"I was just informed that the Speed 3 spring cones are going to be delayed because of a design change. I'm trying to get the new ETA now and I will contact you shortly as soon as I get the information. I apologize for the delay."
Also, they've said that they will be sending them to all customers.
monkey.bones.007 (07-29-2014)
 Old 07-29-2014, 05:23 PM   #754
Will fuck up ur day
Chimmike's Avatar
Groans: 433
maybe they can work on giving us some good settings to minimize the bounce?
07 MS3
 Old 07-29-2014, 05:57 PM   #755
JDMJOSH's Avatar
I'm talking to Donovan at GC right now about this. With 525F 600R springs, it does an OK (not great) job dampening some of the small to medium bumps but the car seems to come quite unsettled on anything more.
He did say the Konis were on the soft side for my springs (strange, I thought they were supposed to be matched) and suggested I go with 3/4 turn from full stiff front and 1 turn from stiff rear.
I checked my front struts and at 1 1/8" drop, they look as though there is not a lot of travel left in them which I think is the source of the issue myself and others are having. I'm thinking if the car is raised a bit or the GC bumpstop is trimmed slightly it might mitigate the issue somewhat.
In the meantime I'll try his settings and see how it works.
 Old 07-30-2014, 08:03 AM   #756
- POD -'s Avatar
Let us know how this setting work out for you. If it helps I'll be following suit.
 Old 07-30-2014, 03:54 PM   #757
Will fuck up ur day
Chimmike's Avatar
Groans: 433
I'm not so sure adjusting rebound that much is going to help. I'm almost wondering if any drop at all on these is just too much for the konis to handle.
I know with my old civic, there was a clear feel on how much you could drop before it became a bouncing mess. if you raised it off that, ride was fantastic again. And that was with Tokico blues, which are not adjustable.
07 MS3
 Old 07-30-2014, 04:20 PM   #758
[R]usty's Avatar
Posts: 2,204   (View Stats)
I could just be talking out of my ass here but...
A lot of speeds run lowing springs and Koni yellows without issue. I think the problem maybe that the spring rates are too high for OTS Koni yellow valving. After seeing some of the reviews saying the rears were too bouncy, I traded in my 600 springs for 440 and shifted the 525's to the rear. I still don't have these installed but when I do I'll update this thread with my findings.
If the 525's are still causing problems in the rears I'll shift the 440's in the rear and purchase a set of 375's for the fronts. There's not much information on ideal spring rates for OTS yellow's but I think (based on a lot of research) that 550 should be the max that you run without re-valving the shocks.
2010 Mazdaspeed3 w/tech
 Old 07-30-2014, 04:24 PM   #759
RPM
RPM's Avatar
Thanks for sharing your findings. GC has mentioned to me in the past that they will swap out springs is people aren't happy with what they received. I don't know if there is a time limit on this (since purchased or since installed) or what the exact process is, but it may be worth inquiring about if anyone wants to swap.
 Old 07-30-2014, 04:29 PM   #760
[R]usty's Avatar
I had no issues exchanging my springs since they were untouched. Donovon told me as long as they're still new you can exchange without issue.
People can also buy spare sets of springs if they want a second set for daily driving. They're only $64 a set and range from 300 in lbs all the way to 800 I believe.
covelife1016 (07-30-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f408/gb-ground-control-koni-sport-coilovers-mazdaspeed-167667/
Konisport + ground control setup This thread Refback 04-25-2014 12:49 PM
Konisport + ground control setup This thread Refback 04-20-2014 03:35 AM
Ground control and koni yellows Bap 2010 MS3 - Suspension & Brakes 212 10-20-2016 11:43 AM
Koni Yellows martin_nj MazdaSpeed 3/6 - Suspension & Brakes 50 05-09-2012 10:27 AM
Page generated in 0.58573 seconds with 35 queries
