Like Tree48Likes
 Old 04-15-2014, 07:42 AM   #121
Dimenus's Avatar
Posts: 2,825   (View Stats)
Groans: 33
Debating between Cobb Springs (or stockers) & Yellows vs these. Hmmmm.
Put me at 50% for the set.
2012 Velocity Red Mica
 Old 04-15-2014, 09:53 AM   #122
Hal
Hal's Avatar
Posts: 233   (View Stats)
Hal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the world
Sorry guys, found better deal for another set up. I am now 0%.
www.emeraldtuning.com
twittter: @emeraldtuning
YouTube: https://www.youtube.com/user/EmeraldTuning
2013 CWP w/ Tech
JBR Shortie
JBR TIP
JBR Boost Tubes
JRB RMM
JBR RSB
JBR 5mm Spacers
JBR Heavy Shift Knob
JBR Flaps
Buddy Club Custom 3" Exhaust
Koni Yellows
Corksport 4-Piston Brake Upgrade
Corksport Springs
Corksport Adjustable End Links
Stoptech Slotted
Stoptech Sport Pads
Stoptech SS Lines
Hal is offline   Reply With Quote
 Old 04-15-2014, 10:56 AM   #123
RPM
RPM's Avatar
Posts: 1,149   (View Stats)
Originally Posted by Hal View Post
So how do we order? I have money burning a hole in my credit card.
I'll have the links up shortly. Now that we're over 20, I'll just set the discount at that level and then if we manage to make 40, I'll adjust the orders and give refunds or whatever is necessary at that time.
The Following 3 Users Say Thank You to RPM For This Useful Post:
Chimmike (04-15-2014), covelife1016 (04-15-2014), easy (04-15-2014)
 Old 04-15-2014, 04:09 PM   #124
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
excellent. How soon would these ship? Will order as soon as the links are ready!
07 MS3
The original Genpoo Hater
 Old 04-15-2014, 04:15 PM   #125
[R]usty's Avatar
Posts: 2,204   (View Stats)
^ Me too!
2010 Mazdaspeed3 w/tech
 Old 04-15-2014, 04:19 PM   #126
RPM
RPM's Avatar
They still won't ship until the end of the GB unless I can work something out with GC. It also depends on how quickly the solid orders come in. Our goal is to have them to you as quickly as possible, but we have to work within the limitations we're given in order to be able to offer this price. I'm working on the link/code right now. Give me another hour or so.
Chimmike (04-15-2014), daafisch (04-15-2014), easy (04-15-2014)
 Old 04-15-2014, 05:10 PM   #127
timmcc02's Avatar
Posts: 253   (View Stats)
timmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the world
Groaned at 9 Times in 3 Posts
I'm ready to order asap, especially if they are going to ship soon
timmcc02 is offline   Reply With Quote
 Old 04-15-2014, 05:14 PM   #128
Shorty_Meeks's Avatar
Posts: 64   (View Stats)
Shorty_Meeks is infamous around these partsShorty_Meeks is infamous around these partsShorty_Meeks is infamous around these partsShorty_Meeks is infamous around these partsShorty_Meeks is infamous around these partsShorty_Meeks is infamous around these partsShorty_Meeks is infamous around these partsShorty_Meeks is infamous around these partsShorty_Meeks is infamous around these partsShorty_Meeks is infamous around these partsShorty_Meeks is infamous around these parts
Groaned at 116 Times in 29 Posts
Yo do these come with upper camber plates if so I'm down.
Shorty_Meeks is offline   Reply With Quote
 Old 04-15-2014, 05:37 PM   #129
RPM
RPM's Avatar
Ordering details are now in the first post! They do not come with camber plates.
Chimmike (04-15-2014), smoogs12 (04-15-2014)
 Old 04-15-2014, 06:05 PM   #130
[R]usty's Avatar
What setup you guys getting? I have 2 in mind but have no idea what the differences are.
Daily Driver/Aggressive
Occasional Autocross/Aggressive
 Old 04-15-2014, 06:15 PM   #131
RPM
RPM's Avatar
They're probably going to be very similar. GC doesn't give out details on the exact spring rates they use, which is why we ask the questions. An occasional autocross setup might have slightly stiffer springs (maybe 25-50 lbs heavier) and may be pre-set with a little stiffer rebound, but that's always adjustable.
smoogs12 (04-15-2014), [R]usty (04-15-2014)
 Old 04-15-2014, 06:21 PM   #132
covelife1016's Avatar
Posts: 151   (View Stats)
covelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond repute
Just put my order in.
smoogs12 likes this.
2010 MS3 non tech
// CS TMIC// CS battery box// JBR short shifter// JBR 88a rmm// JBR boost tubes// JBR solid shifter bushings// JBR coolant bypass and throttle body tig// Kozmic Motorsports primary and secondary egr delete// NGK one step colder plugs// AT fuel pump internals// HTP 3" intake// GFB bov// COBB accessport V2 // GroundControl springs// Koni yellows//
TUNED BY STRATIFIED
covelife1016 is offline   Reply With Quote
The Following 2 Users Say Thank You to covelife1016 For This Useful Post:
RPM (04-15-2014), smoogs12 (04-15-2014)
 Old 04-15-2014, 07:08 PM   #133
timmcc02's Avatar
Payment sent!
The Following 2 Users Say Thank You to timmcc02 For This Useful Post:
 Old 04-15-2014, 08:14 PM   #134
justinsane87's Avatar
Posts: 877   (View Stats)
justinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the world
100% gc/koni
Sent from the flux capacitor
2013 Mazdaspeed 3 - GTX3076R EWG
Autotechs - FreekBuilt 3.5" - UR Catless Turbo-back - AP V3 - ETS TMIC
JBR 80D Trilogy/SSP/Bushings/Heavy Knob/TIGs/0.250 RSB - GFB BOV
FreekTune'd - DO DVC-30 - Ground Control w/Koni Yellows - DM OCC
Enkei RPF1 17x9 w/ PSS 235/45/17 - Full Race Exhaust Mani
justinsane87 is offline   Reply With Quote
 Old 04-15-2014, 08:16 PM   #135
RPM
RPM's Avatar
Originally Posted by justinsane87 View Post
100% gc/koni
No more need to post interest! Just place your order! Instructions in the first post!
justinsane87 (04-15-2014)
 Old 04-15-2014, 08:17 PM   #136
gmoney542's Avatar
Posts: 236   (View Stats)
gmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the world
YES! Ordering mine tomorrow. I can't wait to get these!
2009 CWP Mazdaspeed3
- COBB AP V3 - Richtune - 50/50 E85 - Autotech HPFP Internals - CNT Catless Downpipe - HTP 3" Intake - NGK One Step Colder Plugs -
- Kozmic Motorsports EGR Deletes - JBR 88 RMM/TMM/PMM - JBR Shifter Bushings - JBR TIG + Coolant Bypass - JBR OCC -
- JBR RSB - GroundControl Coilovers - CorkSport Camber Plates - CorkSport Rear Camber Arms - CorkSport Rear Toe Arms -
- WhiteLine Front Endlinks - WhiteLine Bumpsteer Kit - WhiteLine Poly LCA Bushings - AWR Rear Endlinks -
- 18x8 Mazdaspeed MS-01S - Nitto NT05 245/40/18 -
gmoney542 is offline   Reply With Quote
The Following User Says Thank You to gmoney542 For This Useful Post:
RPM (04-15-2014)
 Old 04-15-2014, 11:27 PM   #137
Raider's Ohio Bottom Bitch
therza2169's Avatar
Posts: 204   (View Stats)
therza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the worldtherza2169 is the leader of the world
Hey @RPM I'm trying to place my order and the coupon code isn't updating the total. Help?
therza2169 is offline   Reply With Quote
 Old 04-15-2014, 11:36 PM   #138
RPM
RPM's Avatar
There was a little issue, but I just fixed it. Try again.
 Old 04-16-2014, 12:21 AM   #139
therza2169's Avatar
Thank you, just ordered.
The Following User Says Thank You to therza2169 For This Useful Post:
smoogs12 (04-16-2014)
 Old 04-16-2014, 06:37 AM   #140
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
Ordered. Sorry for all the order comments.
 Old 04-16-2014, 08:18 AM   #141
Will fuck up ur day
Chimmike's Avatar
Groans: 433
One final question: any info as to whether or not these can be shipped early?
Also. I'm deliberating. I DD, but there's always a chance i'll hop on a road course. Don't know if I wanna choose DD/aggressive, or occasional road course/aggressive. Don't want my ride to be shat on the 80+ mile daily commute.
07 MS3
Dimenus (04-16-2014), [R]usty (04-16-2014)
 Old 04-16-2014, 08:34 AM   #142
daafisch's Avatar
Groans: 58
I'm in the same boat. I commute 100+ miles a day but will attend atleast 13-15 autox events and the occasional road course (if I have the money). I wrote a lengthy description in the order comments. I'm hoping GC can sort it out..lol
Chimmike (04-16-2014)
 Old 04-16-2014, 12:00 PM   #143
RPM
RPM's Avatar
We can't ship early. In order to get the lower pricing, we have to order everything in bulk. If all 20 orders came in we MIGHT could ship early, but right now we only have about 5 of them. And I'd hate to get 20 and ship early if it looks like we might be able to make 40+.
As I mentioned before, those two options are probably going to be very similar. An occasional autocross/road course setup might have slightly stiffer springs (maybe 25-50 lbs heavier) and may be pre-set with a little stiffer rebound, but that's always adjustable. It will be a stiffer ride, but it will also be well-controlled by the dampers, so it shouldn't be uncomfortable. Personally, I prefer the Aggressive feel over the Touring feel.
 Old 04-16-2014, 12:26 PM   #144
timmcc02's Avatar
Id be willing to pay the price for 20 orders even if you do hit 40 if I could get them earlier
 Old 04-16-2014, 12:50 PM   #145
RPM
RPM's Avatar
Haha, well, everyone else would have to agree with you. Even so, we still need to get at least the 20 people who already said they were interested to pay. Just double-checked... We have received only 4 orders, so far.
 Old 04-16-2014, 12:57 PM   #146
RPM
RPM's Avatar
Let's try this...
@gingermike, @smoogs12, @Mpettograsso, @nybe0010, @rustysurfsa, @mrshoulders, @covelife1016, @Mike@Stratified, @IMASA, @skiptowncat, @easy, @Dumbguy, @Elvisrosales88, @Adog35, @gmoney542, @Hal, @Canuck
Ordering instructions are in the first post! We can't even consider beginning to ship until we get the orders in!
Chimmike (04-16-2014), smoogs12 (04-16-2014)
 Old 04-16-2014, 01:00 PM   #147
[R]usty's Avatar
Ordering mine today. Just reading about ground controls as much as possible to get an idea of what I should order.
 Old 04-16-2014, 01:10 PM   #148
daafisch's Avatar
Groans: 58
@Optimus prime; you order yours?
 Old 04-16-2014, 01:26 PM   #149
gmoney542's Avatar
Ordering today. Just trying to figure out how I should order them. I'm undecided whether I should choose Occasional Autocross/Aggressive, Occasional Autocross/Race, or custom rates, maybe 500/625. It would be a lot easier if we knew what spring rates GC chose for each option.
 Old 04-16-2014, 01:59 PM   #150
skiptowncat's Avatar
Posts: 1,592   (View Stats)
Can't be bothered with taking the rears off to adjust, I'm going to save up for something else @RPM;
Tuned with by
 Old 04-16-2014, 02:04 PM   #151
RPM
RPM's Avatar
I agree. I tried to get this information out of them, but they just kept saying, "We base it on the individual customer's needs". I finally asked them what information they needed to best design a kit and they told me intended use, ride feel, and weight. The exact wording of the options I made up myself. The most I could get out of them is that the range is 450-650 lb/in in the front and 500-800 lb/in in the rear. With that in mind, at least we know that Daily Driver, Touring is at the low end and Dedicated, Race is at the top.
Fair enough. Although I would like to add that they shouldn't need to be adjusted once they are set properly. I've had adjustable coilovers on 2 different cars and once I got them set up, I never touched them after that.
Last edited by RPM; 04-16-2014 at 02:04 PM. Reason: MSF Database - Automerged Doublepost
Chimmike (04-16-2014), daafisch (04-16-2014), jtday (04-16-2014)
 Old 04-16-2014, 02:14 PM   #152
[R]usty's Avatar
Ordered. I went for Occasional Road Course/Aggressive with minor weight reduction. I also wrote out a note to Ground Control to let them know exactly what my car will be used for, I hope this gives me the best setup for my requests.
 Old 04-16-2014, 02:19 PM   #153
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Sounds like what I'll do.
Will order tonight. Who wants to rub me off while I order?
07 MS3
RPM (04-16-2014), smoogs12 (04-16-2014)
 Old 04-16-2014, 02:36 PM   #154
I put my order in last night. For dedicated road course with light weight reduction and aggressive spring rates.
2010 MS3 non tech
TUNED BY STRATIFIED
 Old 04-16-2014, 02:57 PM   #155
RPM
RPM's Avatar
5 orders in now
 Old 04-16-2014, 07:32 PM   #156
Steezyms3's Avatar
Posts: 202   (View Stats)
Steezyms3 has a brilliant futureSteezyms3 has a brilliant futureSteezyms3 has a brilliant futureSteezyms3 has a brilliant futureSteezyms3 has a brilliant futureSteezyms3 has a brilliant futureSteezyms3 has a brilliant futureSteezyms3 has a brilliant futureSteezyms3 has a brilliant futureSteezyms3 has a brilliant futureSteezyms3 has a brilliant future
Groaned at 6 Times in 4 Posts
Does anybody know how low these will go? It says 0-1.6 inch I believe but I feel like that's almost nothing.
Steezyms3 is offline   Reply With Quote
 Old 04-16-2014, 07:56 PM   #157
RPM
RPM's Avatar
The numbers are accurate, and the drop is more than sufficient for a performance-oriented setup.
daafisch (04-16-2014), gmoney542 (04-17-2014)
 Old 04-17-2014, 02:01 AM   #158
It's the setting up part though, I don't have time to mess around taking them off and on.
Tuned with by
 Old 04-17-2014, 02:16 AM   #159
gmoney542's Avatar
Ground Control is presetting them to match the spring rates so there shouldn't really be any need to adjust them once you put them on.
The Following 3 Users Say Thank You to gmoney542 For This Useful Post:
daafisch (04-17-2014), skiptowncat (04-17-2014), smoogs12 (04-17-2014)
 Old 04-17-2014, 06:08 AM   #160
Will fuck up ur day
Chimmike's Avatar
Groans: 433
this isn't really a kit you'll want to "slam". there's a pretty obvious point where the ride becomes terrible and bouncy, and that's the suspension's way of saying "raise it back up, junior". Happened with GC's on my old b18 civic. Once I brought it back up a little bit, the ride was awesome and the handling was fantastic.
07 MS3
yourname2221 (04-19-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f408/gb-ground-control-koni-sport-coilovers-mazdaspeed-167667/
Konisport + ground control setup This thread Refback 04-25-2014 12:49 PM
Konisport + ground control setup This thread Refback 04-20-2014 03:35 AM
Ground control and koni yellows Bap 2010 MS3 - Suspension & Brakes 212 10-20-2016 11:43 AM
Koni Yellows martin_nj MazdaSpeed 3/6 - Suspension & Brakes 50 05-09-2012 10:27 AM
Page generated in 0.58980 seconds with 34 queries
