| Revolution Performance Motorsports Revolution Performance Manufacturing (RPM) was started by three Mazda 6 enthusiasts in early 2004 under a simple premise: to develop and manufacture new products for the Mazda 6 at an affordable price. We began to realize our purpose with the short throw shifter and gas hood lifter kits for that vehicle. Since then, we have added many new aftermarket products from well-known manufacturers and continue to expand to offer products for other vehicles with the goal of having the best prices and customer service on the 'net. |
![]() | | #161 | ![]() |
![]() Join Date: Nov 2010 Location: SoCal
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 35
Groaned at 9 Times in 3 Posts
| The Following User Says Thank You to timmcc02 For This Useful Post: | Chimmike (04-17-2014) |
![]() | | #162 | ![]() |
![]() Join Date: Nov 2013 Location: Delaware
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 228
Groaned at 79 Times in 52 Posts
| Not Ranked : 0 score One very good point on this kit, vs some others including Bilsteins, is that they appear to come with a visable compression bump cushion inside the spring, and on the shock rod. This provides a stiffer net spring as you experience high compression of the spring. This "soft" stop is better than going into coil-bind "hard impact" stop as some have experienced with the Bilstein PSS kits. They may actually be designed for the lighter Mazda3, and have an internal bump stop, but it has not prevented coil bind up front in a few applications. Note that the GC/Koni bump cushion is designed for a specific range of drop. This part may require modification, depending on drop used. .
__________________ From Delaware Current Fleet: 04 Mazda6, 93 Rx7 TT, 76 Triumph 750 Trident Tracked Cars: 68 Triumph GT6 (~full race prep'd), 81 Porsche 924 Turbo, 93 Rx7 twin turbo Last edited by KevinK2; 04-18-2014 at 01:09 PM. Reason: added bump stop info for Bilstein |
![]() | | #163 | ![]() |
| Banned ![]() Join Date: Apr 2014 Location: Gainesville FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 43
Groaned at 6 Times in 4 Posts
![]() | | #164 | ![]() |
![]() Join Date: Nov 2010 Location: Manchester, England
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,709
| Not Ranked : 0 score Ok, last question...how much to ship to the uk? I may be able to get a few more onboard
__________________ Tuned with by ![]() K1 Rods//Wiseco Pistons//CX Racing FMIC//JBR Widepath Intake//Custom 3" TBE//Grimmspeed EBCS//Forge BPV//JBR SSP//JBR RSB//JBR Side Mounts//ISC-N! coilovers//JBR BSD and Baffle//Sure TIG Set//Sure R3 RMM//KMD Internals//XS Power Exhaust Manifold//P&P Intake Manifold//Fidanza Flywheel//EM Organic Compound Clutch//GTX3071//DVC30 Meth Kit//3 Gauge Pod.....415WHP....so far!! |
| The Following User Says Thank You to skiptowncat For This Useful Post: | Chimmike (04-18-2014) |
![]() | | #165 | ![]() |
| Approved MSF Vendor ![]() Join Date: Nov 2008 Location: Euless, TX
Rep Power: 975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 850
| The Following 3 Users Say Thank You to RPM For This Useful Post: |
![]() | | #166 | ![]() |
![]() Join Date: Oct 2013 Location: Edmonton, AB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 814
__________________ 2013 Mazdaspeed 3 - GTX3076R EWG Autotechs - FreekBuilt 3.5" - UR Catless Turbo-back - AP V3 - ETS TMIC JBR 80D Trilogy/SSP/Bushings/Heavy Knob/TIGs/0.250 RSB - GFB BOV FreekTune'd - DO DVC-30 - Ground Control w/Koni Yellows - DM OCC Enkei RPF1 17x9 w/ PSS 235/45/17 - Full Race Exhaust Mani | |
![]() | | #167 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah.. They have some pretty insane pricing through TNT.. Sometimes we can get close by calling FedEx for special rates, but we need the postal code to get a quote. |
![]() | | #168 | ![]() |
__________________ Tuned with by ![]() K1 Rods//Wiseco Pistons//CX Racing FMIC//JBR Widepath Intake//Custom 3" TBE//Grimmspeed EBCS//Forge BPV//JBR SSP//JBR RSB//JBR Side Mounts//ISC-N! coilovers//JBR BSD and Baffle//Sure TIG Set//Sure R3 RMM//KMD Internals//XS Power Exhaust Manifold//P&P Intake Manifold//Fidanza Flywheel//EM Organic Compound Clutch//GTX3071//DVC30 Meth Kit//3 Gauge Pod.....415WHP....so far!! Last edited by skiptowncat; 04-20-2014 at 03:25 AM. | |
![]() | | #169 | ![]() |
Groans: 433
| Not Ranked : 0 score seems like $220 would be some sort of express shipping? That seems INSANELY high for ground shipping
![]() | | #170 | ![]() |
That was the cheapest option on their site, kind of redonkulous Sent from the flux capacitor
![]() | | #171 | ![]() |
![]() Join Date: Mar 2012 Location: Beaufort, SC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 195
| Not Ranked : 0 score 11 days left. I can't wait to get these on the car.
__________________ 2010 MS3 non tech // CS TMIC// CS battery box// JBR short shifter// JBR 88a rmm// JBR boost tubes// JBR solid shifter bushings// JBR coolant bypass and throttle body tig// Kozmic Motorsports primary and secondary egr delete// NGK one step colder plugs// AT fuel pump internals// HTP 3" intake// GFB bov// COBB accessport V2 // GroundControl springs// Koni yellows// ![]() TUNED BY STRATIFIED![]() |
![]() | | #172 | ![]() |
![]() Join Date: Jul 2012 Location: Ventura County, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 593
You shouldn't be worried about too much negative camber with this setup. If anything, most worry about not enough. | |
![]() | | #173 | ![]() |
Out of curiousity, you have an option for using stock shocks for the coilovers only, right? You state in the first post that they are 15% stiffer, is that stiffer than stock? Your response earlier suggests the only option is 450 / 500 as the softest. That will definitely be too much spring for stock shocks. Is this 450/500 meant to apply to the stock shock coilover only option? I have to caveat all my suspension mod decisions with "Wife Approved". 450/500 will be husband abused... | |
![]() | | #174 | ![]() |
![]() Join Date: May 2013 Location: Summerville, SC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 184
I doubt the springs for the stock shock option will be anywhere near as stiff.
__________________ 2009 CWP Mazdaspeed3 - COBB AP V3 - Richtune - 50/50 E85 - Autotech HPFP Internals - CNT Catless Downpipe - HTP 3" Intake - NGK One Step Colder Plugs - - Kozmic Motorsports EGR Deletes - JBR 88 RMM/TMM/PMM - JBR Shifter Bushings - JBR TIG + Coolant Bypass - JBR OCC - - JBR RSB - GroundControl Coilovers - CorkSport Camber Plates - CorkSport Rear Camber Arms - CorkSport Rear Toe Arms - - WhiteLine Front Endlinks - WhiteLine Bumpsteer Kit - WhiteLine Poly LCA Bushings - AWR Rear Endlinks - - 18x8 Mazdaspeed MS-01S - Nitto NT05 245/40/18 - | |
| The Following User Says Thank You to gmoney542 For This Useful Post: | Mattyhawk1 (04-18-2014) |
![]() | | #175 | ![]() |
| Not Ranked : 0 score I think you are right, but I want to hear it from RPM's lips before I order. |
![]() | | #176 | ![]() |
| The Following 4 Users Say Thank You to RPM For This Useful Post: |
![]() | | #177 | ![]() |
It's somewhat similar to just adding drop springs and being instructed to cut one ring off the OEM bump cushions. The lower the drop, the sooner the bump cushion will be engaged. With the front m-struts, the motion ratio is high, so you are seeing close to that drop at the shock. .
__________________ From Delaware Current Fleet: 04 Mazda6, 93 Rx7 TT, 76 Triumph 750 Trident Tracked Cars: 68 Triumph GT6 (~full race prep'd), 81 Porsche 924 Turbo, 93 Rx7 twin turbo | |
![]() | | #178 | ![]() |
| The Following User Says Thank You to RPM For This Useful Post: | Chimmike (04-18-2014) |
![]() | | #179 | ![]() |
![]() | | #180 | ![]() |
Groans: 433
__________________ 07 MS3 The original Genpoo Hater PTE 5862cea ball bearing, plus some built stuff. Turismo Vids - Store your car vids and pics here! Blog your builds too! Click here for great deals at The RPM Store! PM me for pricing! I hear that honkey at Protégé Garage is pretty decent too. | |
![]() | | #181 | ![]() |
I agree with rpm's reply that the koni and stiff spring combo should not be an issue. But with just the 15% stiffer springs, IMHO they should be verified to contribute when running little drop. .
| The Following User Says Thank You to KevinK2 For This Useful Post: | Nliiitend1 (04-19-2014) |
![]() | | #182 | ![]() |
![]() Join Date: Sep 2012
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 1
| The Following User Says Thank You to Canuck For This Useful Post: | covelife1016 (04-19-2014) |
![]() | | #183 | ![]() |
![]() | | #184 | ![]() |
| The Following User Says Thank You to RPM For This Useful Post: | Chimmike (04-19-2014) |
![]() | | #185 | ![]() |
![]() Join Date: May 2010 Location: Los Angeles, CA
Rep Power: 195 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26
| Not Ranked : 0 score Placing order today. Need to talk to you about spring rates.
__________________ 2010 MS3 5% REAR 30% FRONT DDM 5K HID RMM CS TIP/SRI Dizzy Tuned Autotech Internals Swift Springs JBR Rear Sway Stoptech 309's First Turbo Car and I love it! |
| The Following User Says Thank You to Adog35 For This Useful Post: | [R]usty (04-19-2014) |
![]() | | #186 | ![]() |
I am not condeming this combination of high quality components. Just suggesting that you may quickly verify they can do what's advertised to do. Your company is certainly qualified to do a verification, when you have had great designs: RPM-Street-Lowering-Springs-for-Mazdaspeed .
__________________ From Delaware Current Fleet: 04 Mazda6, 93 Rx7 TT, 76 Triumph 750 Trident Tracked Cars: 68 Triumph GT6 (~full race prep'd), 81 Porsche 924 Turbo, 93 Rx7 twin turbo | ||
![]() | | #187 | ![]() |
I'll have to get back to you on Monday. Lots of family time this weekend due to Easter.
__________________ Last edited by RPM; 04-19-2014 at 09:53 PM. Reason: MSF Database - Automerged Doublepost | |
| The Following User Says Thank You to RPM For This Useful Post: | KevinK2 (04-20-2014) |
![]() | | #188 | ![]() |
| Not Ranked : 0 score Will Ground Control let us know what spring rates they send us? I answered the questions on the site when checking out since I am not a huge guru on spring rates. It would be helpful for in the future if I decide to change the spring rates up.
![]() | | #189 | ![]() |
Sent from my Galaxy Nexus using Tapatalk | |
![]() | | #190 | ![]() |
(Thread Starter) | Not Ranked : 0 score Up to 7 orders! Just over a week left! |
![]() | | #191 | ![]() |
Groans: 433
| Not Ranked : 0 score Putting in my order today. The sooner I can get these things the better!
![]() | | #192 | ![]() |
Groans: 433
| Not Ranked : 0 score Come on guys! Put in your orders! the sooner, the faster they'll ship!
![]() | | #193 | ![]() |
(Thread Starter) | Not Ranked : 0 score We're up to 10 now! |
![]() | | #194 | ![]() |
![]() Join Date: May 2013 Location: Chesapeake, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 166
| Not Ranked : 0 score Yes sir @gingermike sir. Just put in the order. Now to order camber arms and a skid plate :3 amped...
__________________ 2012 VRM Mazdaspeed 3 - “Claudia” Cobb v3 AP | Autotech HPFP Internals | UR Catback | Cp-e TMIC | Cp-e Stage 2 RMM | Cp-e Catted DP | TWM Full Replacement | CS Occ | CS Bpv | CS Hood Struts | JBR EGR delete | JBR Boost tubes and Recirc hose | HTP 3.5” Intake | 1 Step colder plugs | Blox 490 | BC Coilovers | Drag dr-49 Waiting for install CS Battery box 2008 Black Mica Mazdaspeed 3 - "April" (Totaled, may she rest in piece) |
| The Following User Says Thank You to Dumbguy For This Useful Post: | Chimmike (04-22-2014) |
![]() | | #195 | ![]() |
| Not Ranked : 0 score I put my order in last night. Can't wait to get these!
| The Following User Says Thank You to gmoney542 For This Useful Post: | smoogs12 (04-22-2014) |
![]() | | #196 | ![]() |
![]() Join Date: Mar 2013 Location: Honolulu, HI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 147
| Not Ranked : 0 score paiiiiidddddd
__________________ Installed: JBR SSP/RMM/RSB Cobb APv3/EBCS AT Internals Bilstein Coilovers SPC arms UR TP/DP BNR S4, JBR Undermount w/TR8, 3.5" intake OBX CBE For dat racecar: Gold Caliper Paint |
![]() | | #197 | ![]() |
| Not Ranked : 0 score What are you guys gonna run for camber arms? I'm up in the air about either spc or corksport |
![]() | | #198 | ![]() |
| Raider's Ohio Bottom Bitch ![]() Join Date: Oct 2012 Location: Cincinnati, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 106
![]() | | #199 | ![]() |
![]() | | #200 | ![]() |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f408/gb-ground-control-koni-sport-coilovers-mazdaspeed-167667/ | ||||
| Konisport + ground control setup | This thread | Refback | 04-25-2014 12:49 PM | |
| Konisport + ground control setup | This thread | Refback | 04-20-2014 03:35 AM | |
| Ground control and koni yellows | Bap | 2010 MS3 - Suspension & Brakes | 212 | 10-20-2016 11:43 AM |
| Koni Yellows | martin_nj | MazdaSpeed 3/6 - Suspension & Brakes | 50 | 05-09-2012 10:27 AM |
