 Old 02-14-2015, 01:25 AM   #1
license2ill's Avatar
Posts: 313   (View Stats)
license2ill is infamous around these partslicense2ill is infamous around these parts
Groans: 30
Groaned at 132 Times in 57 Posts
Default Ground Control Bump Stops
I see the set of 4 progressive set for shocks listed, but do you have any that work for a pair of struts and pair of shocks, or a way to mix and match stiff/linear from GC? I'd buy them from you instead of them if you can mix and match pairs for front and back. Thanks!
license2ill is offline   Reply With Quote
 Old 02-14-2015, 08:48 AM   #2
RPM
RPM's Avatar
Posts: 1,149   (View Stats)
The bump stops listed on our site are the ones recommended for the GC set up for the MS3. That said, we can get anything they offer as long as you let us know what you need.
license2ill (02-14-2015)
 Old 02-14-2015, 09:16 AM   #3
Groans: 30
Cool, I'll figure it out for sure and let you know when I'm ready to pick up some more stackable sale items.
The Following User Says Thank You to license2ill For This Useful Post:
Pat@RPM (02-14-2015)
MS3 rear suspension 0.5" from the rear bump stops before you even get in the car. Fronts only have 1" till bump stop. FreeFlyFreak MazdaSpeed 3/6 - Suspension & Brakes 223 09-07-2015 12:47 PM
Fatcat Vs Ground Control bump stops ak_spray MazdaSpeed 3/6 - Suspension & Brakes 26 08-21-2014 01:29 PM
Bump stops=gone at 44,000 bigmike MazdaSpeed 3/6 - Suspension & Brakes 18 11-19-2013 09:14 PM
question about ground control bump stop boostedms3 MazdaSpeed 3/6 - Suspension & Brakes 6 05-23-2012 11:29 PM
Page generated in 0.25318 seconds with 21 queries
