 Old 04-22-2015, 02:43 AM   #1
Kor3y101's Avatar
Posts: 193   (View Stats)
Kor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond reputeKor3y101 has a reputation beyond repute
Default HTP>JBR?
Why you no stock HTP anymooarr?
But seriously, found out today that HTP intakes are no longer stocked. Being that I had ordered the BNRS3, the HTP 3" was one of the supporting mods. RPM did the right thing and have offered me an equivalent (JBR 3") at no extra price, which is fantastic!
Only thing I'm concerned about is fitment with the battery box and ECU. I didn't really want to do a relocate or anything, but if it's neccasary I guess I'll need to make the plunge. Can anyone chime in on this?
I should note that it is the full aluminium widepath 3" intake being offered instead of HTP
'12 Black Speed 3
CS RMM -~- CS SSP & Gearbox Bushings -~- CS OCC -~- CS LED light kit -~- CS Front and Rear Sway Bar -~- UnPlugged EGR Delete -~- CS Hood Struts -~- DVC30 WMI -~- JBR 3" Widepath -~- CS HPFP -~- GrimmSpeed 3 Port -~- HKS SSQV -~- CS TMIC -~- 500W Memphis Sub/Custom Wheel Well Box -~- 3" Xforce TBE -~- RayD Tuned
Kor3y101 is offline   Reply With Quote
 Old 04-22-2015, 03:06 AM   #2
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
Relocation is not necessary with a 3".
John@RPM (04-22-2015), Kor3y101 (04-22-2015)
 Old 04-22-2015, 03:18 AM   #3
Kor3y101's Avatar
Fair enough. I've read/seen that the ecu lower needs to be removed, does this cause excessive rubbing on the cables? Would hate to destroy a wire on that sucker
'12 Black Speed 3
 Old 04-22-2015, 03:36 AM   #4
Ksky90's Avatar
Posts: 1,026   (View Stats)
Ksky90 is the leader of the worldKsky90 is the leader of the worldKsky90 is the leader of the worldKsky90 is the leader of the worldKsky90 is the leader of the worldKsky90 is the leader of the worldKsky90 is the leader of the worldKsky90 is the leader of the worldKsky90 is the leader of the worldKsky90 is the leader of the worldKsky90 is the leader of the world
3.5" needs relocation. Believe 3" just needs the ecu cover removed.
Had a Big Turbo '13 Speed3 WMI and 400 ponies.
Now I have a '13 WRX and zero ponies
Ksky90 is offline   Reply With Quote
 Old 04-22-2015, 07:40 AM   #5
WAMBUSHHHH!'s Avatar
Posts: 1,599   (View Stats)
also keep in mind BPV placement (i.e. location of the BPV for the TMIC vs FMIC). We just did a BNR install over last weekend and I can't remember if it was JBR or CS but there was some issues in fitment with the filter rubbing on the BPV with a TMIC application.
 Old 04-22-2015, 07:51 AM   #6
John@RPM's Avatar
Posts: 24   (View Stats)
John@RPM has much to be proud ofJohn@RPM has much to be proud ofJohn@RPM has much to be proud ofJohn@RPM has much to be proud ofJohn@RPM has much to be proud ofJohn@RPM has much to be proud ofJohn@RPM has much to be proud ofJohn@RPM has much to be proud ofJohn@RPM has much to be proud of
some trimming may be required of the bpv hose. I do belive you will need to move the ecm for clearance of the intake. But that is no big deal just unmount from your battery box and move it to the front of the battery box or mount it to your fuse block cover.
John@RPM is offline   Reply With Quote
 Old 04-22-2015, 08:06 AM   #7
AnubisFSU's Avatar
Posts: 117   (View Stats)
AnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond repute
This is taken right from jbr's website.
Fitment:
Simple bolt on application.
Compatible with the stock battery box (May require the removal of the outer ECU cover)
Uses stock mounting location for OEM Turbo. (May not use OEM mounting location with all GT Turbos)
Fits with the OEM and all aftermarket top mount intercoolers.
Fits with all front mount intercoolers that a conventional SRI will work with.
(NOTE: When run with a BNR turbo, ECU relocation is required for proper fitment of this intake.)
2010 Mazdaspeed3 Tech
JBR Power Path Stage II / Double Adjustable Short Shifter / Solid Shifter Bushings
Cobb Accessport v3 / XLE BPV / Cobb Knob
Damond Motorsports License Plate Tow Mount / EGR Delete
Ultimate Racing Test Pipe
Autotech Fuel Pump Internals
CP-E XFlex Stage2 RMM
Stratified Stage 3 93oct OTS+
AnubisFSU is offline   Reply With Quote
 Old 04-22-2015, 01:00 PM   #8
Kor3y101's Avatar
Fitment:
Yeah I've read that, but that's not always 100% accurate. Sales pitches stretch the truth to make $$$ occasionally. But I'm sure it'll be fine. I've seen quite a few people install it without much drama, so I'm happy.
'12 Black Speed 3
 Old 04-22-2015, 12:59 PM   #9
Kor3y101's Avatar
I don't mind if I have to move the ECU, but I didn't wanna go around having to extend the cables as if rather not learn to solder on my ecu haha. But if it's truly as simple as just moving it without having to worry about that, no dramas here then.
'12 Black Speed 3
The Following User Says Thank You to Kor3y101 For This Useful Post:
John@RPM (04-23-2015)
 Old 04-22-2015, 02:19 PM   #10
brandonnicholson's Avatar
Posts: 1,699   (View Stats)
brandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the world
Pull battery and box, theres a little bracket held on by 2 nuts i think that holds the ecu down. unscrew that and take it out of the white plastic piece on the ecu wires then you can move it freely to the fuse box or infront of the battery box. no need to cut and solder, that would be a nightmare haha.
brandonnicholson is offline   Reply With Quote
 Old 04-22-2015, 02:42 PM   #11
Kor3y101's Avatar
Oh cool, I mean I've pulled it off before when I installed my corksport intake, but couldn't remember if there was a lot of play in where the cables would extend to. So it's good to know. I'll just mount it on the front of the battery box more then likely then.
Thanks for all the help people!
'12 Black Speed 3
 Old 04-22-2015, 12:59 PM   #12
Ksky90's Avatar
Typically most people just stick it on the fuse box. Doesn't look clean but its secure.
 Old 05-05-2015, 08:31 PM   #13
Kor3y101's Avatar
So update, got it all installed last weekend. I removed the bottom ecu cover and have put a bit of foam to it so I don't destroy it. It fits without too much of a hassle, which is good
'12 Black Speed 3
The Following 2 Users Say Thank You to Kor3y101 For This Useful Post:
Pat@RPM (05-06-2015), RPM (05-05-2015)
 Old 05-05-2015, 08:35 PM   #14
skoski17's Avatar
Posts: 1,235   (View Stats)
I have the bnrs3 with the htp 3.5" no issues with the stock battery box just an fyi for anybody looking the only thing is I moved the ecu with was no bid deal was told that I would need a smaller batter tray but I said bs here is a pic after the install
Too much for you
skoski17 is offline   Reply With Quote
The Following User Says Thank You to skoski17 For This Useful Post:
Agent_Orange (05-05-2015)
 Old 05-05-2015, 08:36 PM   #15
skoski17's Avatar
the top cover of the battery box does go on just fine by the way
Too much for you
Page generated in 0.34789 seconds with 27 queries
