| Revolution Performance Motorsports Revolution Performance Manufacturing (RPM) was started by three Mazda 6 enthusiasts in early 2004 under a simple premise: to develop and manufacture new products for the Mazda 6 at an affordable price. We began to realize our purpose with the short throw shifter and gas hood lifter kits for that vehicle. Since then, we have added many new aftermarket products from well-known manufacturers and continue to expand to offer products for other vehicles with the goal of having the best prices and customer service on the 'net. |
![]() | | #41 | ![]() |
![]() Join Date: Feb 2015 Location: Arizona
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 56
| The Following User Says Thank You to ELKhunter For This Useful Post: | RPM (04-06-2015) |
![]() | | #42 | ![]() |
![]() Join Date: Sep 2014 Location: SoCal from NC and NYC
| Not Ranked : 0 score I didn't want to do this but I needed a replacement k04 because mines is going bad. It didn't make sense to replace it with the same product because I would be spending especially for a new one because you can't trust a used one and a predicted mileage usage. I decided to purchase the GTX3076R IWG package which was outside my budget for a final replacement especially since in the near future, I plan to do a rebuild. I used Affirm and the interest and monthly payment for 12 months was not that bad. RPM. You Guys are great. I should of more to the order but I can be greedy because I am low of funds.
__________________ __________________ 2012 Black MazdaSpeed3 Power: GTX3076R IWG / COBB EBCS / Bosch MAP Sensor Adapter Harness / Bosch 3 Bar T-MAP MAP Sensor with IAT / JBR TRU-3.5 / DM EGR Delete Kit / FORGE V1 BPV / AUTOTECH HPFP INTERNALS / UR TBE / UR DP / UR SP / NGK IRIDIUM IX / COBB SW / UR FMIC / MD OCC V1 & V2 / BrassCraft Coolant Bypass / RC IM Mani / cp-e Exi Mani / ZZB REPLACEMENT / Handling: DM TMM / DM RMM / DM PMM / JBR FSB / JBR RSB / JBR RTA / CS FEL / SPC CAMBER ARMS / BCRacing COILOVERS / GTSPEC STB /FRONT EBC YELLOWS / FRONT EBC SLOTTED ROTORS / GOODRIDGE SSL / TWM STS /RPF1 17x9 Wheels / 225/45-17 Toyo Proxes S4 / ACT ZX4-HDG6 / Extra Safety: COBB AP V3 / AEM WIDEBAND FAILSAFE (AFR) / V1 / AEM TRU BOOST / CS Skidplate / Innovate Motorsports MTX-D: Oil Pressure & Temperature / Fuel: 91 & 93 Octane / Looks: VENTPOD / JTMS3 DUAL POD / RB MUD FLAPS / Black Glossified Dipped Stock Wheels / GV OPEN MOUTH GRILL / JBR SHIFT KNOB / Black Powder Coated Front Calipers with Green MazdaSpeed Decals / Green Cabin and Trunk 8K Lights / Green Demon Headlights with black painted housing and RBG halo rings / RC signature VC / JTMS3 Stealth Sub Enclosure with a 10" JL Swallow Sub / baysonR MS-Style Lip Kit / COMING SOON AEM METH KIT / Anti Laser Priority /CS Radiator Panel / CS Rear Chassis Brace / CS Mid-Chassis Brace / CS Hood Scoop / DYNO TUNED by HYPNOTIC 93 and STREET TUNED on 91 soon e85 mix |
![]() | | #43 | ![]() |
| Approved MSF Vendor ![]() Join Date: Nov 2008 Location: Euless, TX
Rep Power: 975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 850
(Thread Starter) | Not Ranked : 0 score Keep these options in mind when you need some high-dollar parts or are looking to do a big build. We now have had a ton of experience with both options and not a single complaint! |
| The Following User Says Thank You to RPM For This Useful Post: | littleloogy (08-18-2015) |
![]() | | #44 | ![]() |
__________________ __________________ 2012 Black MazdaSpeed3 Power: GTX3076R IWG / COBB EBCS / Bosch MAP Sensor Adapter Harness / Bosch 3 Bar T-MAP MAP Sensor with IAT / JBR TRU-3.5 / DM EGR Delete Kit / FORGE V1 BPV / AUTOTECH HPFP INTERNALS / UR TBE / UR DP / UR SP / NGK IRIDIUM IX / COBB SW / UR FMIC / MD OCC V1 & V2 / BrassCraft Coolant Bypass / RC IM Mani / cp-e Exi Mani / ZZB REPLACEMENT / Handling: DM TMM / DM RMM / DM PMM / JBR FSB / JBR RSB / JBR RTA / CS FEL / SPC CAMBER ARMS / BCRacing COILOVERS / GTSPEC STB /FRONT EBC YELLOWS / FRONT EBC SLOTTED ROTORS / GOODRIDGE SSL / TWM STS /RPF1 17x9 Wheels / 225/45-17 Toyo Proxes S4 / ACT ZX4-HDG6 / Extra Safety: COBB AP V3 / AEM WIDEBAND FAILSAFE (AFR) / V1 / AEM TRU BOOST / CS Skidplate / Innovate Motorsports MTX-D: Oil Pressure & Temperature / Fuel: 91 & 93 Octane / Looks: VENTPOD / JTMS3 DUAL POD / RB MUD FLAPS / Black Glossified Dipped Stock Wheels / GV OPEN MOUTH GRILL / JBR SHIFT KNOB / Black Powder Coated Front Calipers with Green MazdaSpeed Decals / Green Cabin and Trunk 8K Lights / Green Demon Headlights with black painted housing and RBG halo rings / RC signature VC / JTMS3 Stealth Sub Enclosure with a 10" JL Swallow Sub / baysonR MS-Style Lip Kit / COMING SOON AEM METH KIT / Anti Laser Priority /CS Radiator Panel / CS Rear Chassis Brace / CS Mid-Chassis Brace / CS Hood Scoop / DYNO TUNED by HYPNOTIC 93 and STREET TUNED on 91 soon e85 mix | |
| The Following User Says Thank You to GCPhotographers For This Useful Post: | RPM (08-18-2015) |
![]() | | #45 | ![]() |
![]() Join Date: Oct 2012 Location: Summit Hill, PA
| Not Ranked : 0 score I have seen this option before but didn't know much about it till I checked this thread out. Looks like I will be having a BT in my life sooner than later!
__________________ Adapted Performance - (Gold engine covers and Shift hammer waiting for install) Blox - Gold type R shift knob Cobb - AP V3 Corksport - HPFP, 3.5 Bar MAP, TMIC, 3.5 inch intake, Battry box, Boost tubes, Recirc hose (Injector seals waiting for install) Cp-e - Catted DP, Stage 2 RMM Damond - PMM, TMM, (OCC and Full EGR delete waiting for install) DDM - High, Low, Fog 6k hids Grimmspeed - (EBCS waiting for install) JBR - RSB, Solid shifter bushings, Mud flaps (Crash bar and FMIC piping waiting for install) OBX - Catback with res delete Turbosmart - 50/50 BOV Treadstone - TR8 |
| The Following User Says Thank You to Nevershallifall For This Useful Post: | RPM (08-27-2015) |
![]() | | #46 | ![]() |
| Not Ranked : 0 score So far, everyone gets approved. I have a Buddy with bad credit and he got approved and yeah it's a one time agreement with no late fees etc but don't take advantage....they will deny you if you try to work with them again.
![]() | | #47 | ![]() |
![]() Join Date: Mar 2011 Location: Newport News/Yorktown, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 83
| Not Ranked : 0 score So you can only use AFFIRM once??? I was going to look into this and if it is only a one time thing then i guess my cart is going to be huge!!!
__________________ 2006 Whitewater Pearl Mazdaspeed 6 GT #355 FJ BUILT LONG BLOCK BNR S4 JBR TRU 3" SURE BOOST TUBES JBR SSP JBR CHROME MOLLY RMM COBB AP AUTOTECH HPFP INTERNALS EBAY DP 3.5 BAR PURPLE DRANK TUNED![]() WAITING TO BE INSTALLED PROSPORT EVO BOOST GAUGE TR1035 w/ CXRACING PIPING JMF INTAKE AWR PASSENGER MOTOR MOUNT AWR TRANSMISSION MOUNT |
![]() | | #48 | ![]() |
(Thread Starter) | Not Ranked : 0 score You can definitely use it more than once. We have some customers who have used it 3 or more times. It just depends on your credit. |
| The Following User Says Thank You to RPM For This Useful Post: | Bleupit80 (09-12-2015) |
![]() | | #49 | ![]() |
| Not Ranked : 0 score @Bleupit80; I am using Affirm (8 times with no problem). I think over a certain amount, they ask for banking info as a back up just in case you can't pay I guess but if you can keep up with your payments, you are good.
![]() | | #50 | ![]() |
__________________ 2006 Whitewater Pearl Mazdaspeed 6 GT #355 FJ BUILT LONG BLOCK BNR S4 JBR TRU 3" SURE BOOST TUBES JBR SSP JBR CHROME MOLLY RMM COBB AP AUTOTECH HPFP INTERNALS EBAY DP 3.5 BAR PURPLE DRANK TUNED![]() WAITING TO BE INSTALLED PROSPORT EVO BOOST GAUGE TR1035 w/ CXRACING PIPING JMF INTAKE AWR PASSENGER MOTOR MOUNT AWR TRANSMISSION MOUNT | |
| The Following User Says Thank You to Bleupit80 For This Useful Post: | RPM (09-12-2015) |
![]() | | #51 | ![]() |
but I am happy with my purchases so far.
![]() | | #52 | ![]() |
![]() | | #53 | ![]() |
(Thread Starter) | Not Ranked : 0 score If you know what you want, we can probably get it for you. We did get a Precision for a customer in the past. Once you know for sure, just shoot us a PM. |
| The Following User Says Thank You to RPM For This Useful Post: | Bleupit80 (09-13-2015) |
![]() | | #54 | ![]() |
| Not Ranked : 0 score Like they said, they will take care of you. They were able to get many products not listed on their website.
![]() | | #55 | ![]() |
| Yeah, they can get anything you want, if you ask them. Parts-wise. sent from my HTC One M9
![]() | | #56 | ![]() |
![]() Join Date: Apr 2013 Location: Atlanta, Georgia
Rep Power: 1578 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,584
| Not Ranked : 0 score I just paid my last payment to Affirm and wanted to wrap up my experience. It started as me just fucking around, seeing how much a BNRs3v2 would cost. Everything included, sub $1200. "What a deal" I thought. But being the broke SOB I was I didn't have the cash at the time. I had seen this thread and decided to apply for shits and giggles. It was like a <2 minute process and I came back approved. Cost would be $1300 after all paid up. I didn't feel too bad paying $150 for someone to finance my beaner, so i was good. Clicky clicky and here comes the beaner. Unbeknownst to me, I was the first person on a 3 month back order lol. Payments were extremely easy. Easier than my credit cards, IMO. They are very flexible as well. I ran into some difficult times and I was hit with no penalties for paying a month late. Hands down without a doubt next parts that need to be financed will be through Affirm and RPM. Thanks for having this option guys!
__________________ '06 Mazdaspeed 6 GT Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth - Miltuned On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.![]() |
| The Following User Says Thank You to ItsNox For This Useful Post: | RPM (03-17-2016) |
![]() | | #57 | ![]() |
| Not Ranked : 0 score ^ Agreed but in my case I am a few months behind but I will catch up. They are flexible. I am still making payments because I did any custom orders with RPM.
| The Following User Says Thank You to GCPhotographers For This Useful Post: | ItsNox (03-19-2016) |
![]() | | #58 | ![]() |
![]() Join Date: Sep 2013 Location: Winnipeg, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31
| Not Ranked : 0 score anyway to use affirm as a Canadian? or any financing through you guys at all as a Canadian? @RPM;
__________________ 2007 CWP MS3 Powered by Purple Drank @ 22psi // ATP GT2871r // J2 Engineering catless downpipe // Continental Extreme Contact DW 245/40/17 // Rays Gram Lights 57DR 17x9 // // CP-e Nexus catback // resonator delete // Damond Motorsports rmm // GoFastBits bov // Maisonvi piston style shift knob // Cobb shift weight // Street Unit testpipe // Cobb Accessport V3 // JBR shifter bushings // Treadstone TR8L // JBR intercooler piping // Damond Motorsports power steering cooler // Denso 1-step colder plugs // Ramfab 4" intake // coolant bypass // Damond Motorsports egr block-off // Rally Armor mudflaps // Defi boost gauge // 3 bar MAP sensor // 3 port ebcs // Stratified Guardian Angel // JBR short shifter // Hotchkis rear sway bar // Stoptech ss brake lines // Centric premium brake rotors // Powerstop Z23 brake pads // Koni yellow shocks // Corksport springs // MOOG front and rear endlinks |
![]() | | #59 | ![]() |
![]() | | #60 | ![]() |
| Not Ranked : 0 score damn, was ready to get some shocks and springs but as usual Canada doesn't exist
| BNR S3 Turbos @ therpmstore.com | smoogs12 | Revolution Performance Motorsports | 129 | 08-28-2017 07:22 PM |
| GM to promote dealer financing options | Haltech | Automotive News | 0 | 10-15-2008 06:10 AM |
| GM to promote dealer financing options | Haltech | Automotive News | 0 | 10-14-2008 08:50 PM |
