  • 2 Post By Marcus
 Old 11-12-2014, 05:31 PM   #1
Marcus's Avatar
Posts: 777   (View Stats)
Marcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the world
Default Thanks to the RPM Store
You guys sorted me out on a faulty SPC balljoint and dealed me the CPe Safeseals at the same time!
Which is moar awesome since if RPM remembers, SPC backtracked on warrantying the less than 6 month old ball joint but you boys stepped up and offered me a discount. I do appreciate that and wanted to say thank you once again.
Both parts are installed and going great! No more squeak from the ball joint and seals are doing just what they should.
Thank you RPM!
smoogs12 and Mauro_Penguin like this.
2006 Moist Metallica Silver Speed6 GT #6557 @ 267,000km
Leakdown results was 50% or more across all four. slow rebuild in progress
Corksport: Turb.IM.DP.OCC.3.5MAP.IC.RMM.TIP.FSB.Tubes.Strut Tower. JBR: 70a Sides.SSP.51r SURE: Full3Aeros.Dreadnaught.Juggernaught.Anchors.FlowM6 .Rad Hoses.
Stratified Custome Tune/APv3.Turbosmart DS BOV.Cobb EBCS.AT HPFP.Deatchsworks.CPe SafeSeals.H&R Coils.Moog Camber Arms. SPC Ball Joints.Whiteline Adj RSB.
SU Rear Interior Brace.StopTech Perf Pads.Centric X-D Rotors.TechnaFit Braided Clutch-Brake Lines.Damond PS Cooler.EGR. PeRM PCV Plate.
Michelin Pilot Sport AS3+ 235/40/18.Drag DR-38 +47. Gloss Black Blue Undercut. Pirelli Sottozero s2 240 215/45/18. MS6 OEMs.
To order: Fullrace Exhaust Mani. FMIC. Damond side mounts. New built motor. Still thinking about Flowmasters
Marcus is offline   Reply With Quote
The Following 7 Users Say Thank You to Marcus For This Useful Post:
jack_hammer (11-12-2014), kbz0129 (11-13-2014), Mauro_Penguin (11-13-2014), motherfnmonsta (11-19-2014), RPM (11-12-2014), smoogs12 (11-14-2014), Zoom66 (11-13-2014)
Student? Try the Apple Store for Education at Apple Store for Education Haltech Hot Deals Section 0 04-11-2008 09:50 AM
$5 Off $20 In-Store Coupon Walgreens at Online Store Haltech Hot Deals Section 0 04-11-2008 07:11 AM
Page generated in 0.22705 seconds with 20 queries
