> Cobb Tuning >
Cobb ATR Support
 Old 01-13-2010, 04:54 PM   #1
RJTSi's Avatar
Posts: 205   (View Stats)
RJTSi has a reputation beyond reputeRJTSi has a reputation beyond reputeRJTSi has a reputation beyond reputeRJTSi has a reputation beyond reputeRJTSi has a reputation beyond reputeRJTSi has a reputation beyond reputeRJTSi has a reputation beyond reputeRJTSi has a reputation beyond reputeRJTSi has a reputation beyond reputeRJTSi has a reputation beyond reputeRJTSi has a reputation beyond repute
Default 0 WGDC, High Load, Low Boost
i am having a strange issue. back in november i was slowly upping the TRL in each gear to achieve my boost targets and was getting pretty close. i started doing some logs the last few weeks and 2nd and 3rd gear seem normal. however in 4th and 5th gear my WGDC almost immediately goes to 0% at WOT. also im barely seeing 14 psi even though the calc. loads are in the 190's. i reflashed to an older map today and did a few pulls and im having the same issues. anyone ever had this type of situation?
True Red 2008.5 SPEED3 Sport...RIP
VRM 2006 Mazdaspeed6....Corksport TD05H-18g, Rambo 3.5" intake, Circuit Werks catless DP, AP E85 tuned, CX Racing FMIC piping w/ TR8, 3 port EBCS, 3-bar Map, heavy Shift weight, Shifter bushings, Autotech internals, RMM, Hawk Pads, SS clutch and brake lines
RJTSi is offline   Reply With Quote
 Old 01-13-2010, 08:59 PM   #2
fjames's Avatar
Posts: 1,058   (View Stats)
It's been cold.
The Following 3 Users Say Thank You to fjames For This Useful Post:
FreeFlyFreak (01-13-2010), ms3077 (01-13-2010), RJTSi (01-13-2010)
 Old 01-13-2010, 09:13 PM   #3
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
Originally Posted by fjames View Post
It's been cold.
Like fjames said.
You have the load.
Suspension:
The Following User Says Thank You to FreeFlyFreak For This Useful Post:
RJTSi (01-13-2010)
 Old 01-13-2010, 09:55 PM   #4
johnsin55's Avatar
Posts: 59   (View Stats)
johnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud of
Ive been having the same problem, im set to run 18 psi but I only get maybe 12-13 with 190-200 load and 0 wgdc... that and my MAF sensor is maxing out around 5500 rpms then the engine cuts and my afrs dip into the 9s, im switching my aem intake to a CPE in the next week or so hoping that might help but Im thinking I just need a larger MAF housing...
08 currently running AEM CAI, CPE TIP, GT2871, Forge BPV, COBB DP, Vibrant exhaust with ptp fp internals
johnsin55 is offline   Reply With Quote
 Old 01-13-2010, 09:56 PM   #5
RJTSi's Avatar
Fair enough. i just didn't know if this was normal or not.
Thanks
 Old 01-19-2010, 03:11 AM   #6
Meder's Avatar
Posts: 1,065   (View Stats)
Meder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the world
When do you guys feel you start seeing boost drop?
I have not noticed much difference in the 60's but am unsure.
60's is cold here.
Meder is offline   Reply With Quote
 Old 01-19-2010, 10:04 AM   #7
RJTSi's Avatar
i noticed it when it hit 40's and under.
max boost and load? superskaterxes
Cobb ATR Support
44 10-31-2009 01:33 PM
Vague Observations on Boost and Load Tables fjames
Cobb ATR Support
5 09-02-2009 08:48 AM
Upping the Boost Using Load Scatt Nasty
Cobb ATR Support
7 07-17-2009 07:32 PM
weird crackling noise only at boost, and when engline under load kachow22 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 13 06-29-2009 03:34 PM
Page generated in 0.26755 seconds with 24 queries
