> Cobb Tuning >
Cobb ATR Support
  • 1 Post By jdub0802
  • 1 Post By TiGraySpeed6
 Old 11-29-2012, 07:34 PM   #1
jdub0802's Avatar
Posts: 125   (View Stats)
jdub0802 has a reputation beyond reputejdub0802 has a reputation beyond reputejdub0802 has a reputation beyond reputejdub0802 has a reputation beyond reputejdub0802 has a reputation beyond reputejdub0802 has a reputation beyond reputejdub0802 has a reputation beyond reputejdub0802 has a reputation beyond reputejdub0802 has a reputation beyond reputejdub0802 has a reputation beyond reputejdub0802 has a reputation beyond repute
Default ATR Win8 Problems
I just got a new laptop over the weekend, and it has Windows 8 on it. While I am not completely sold on Windows 8 yet, I figure I would give it a chance. But, I cannot for the life of me get ATR to install. It won't see the AP. I installed AP Manager first and it installed the drivers, and everything works. But, when I close out of AP manager and start the install of ATR the AP disconnects from the computer and the ATR installer doesn't try to reinstall the drivers and it won't continue the install process.
Has anybody had any luck getting ATR to install on Windows 8? If so how?
Thank you
2011 Speed 3 - Mica Black - Non Tech
Mods Installed: JBR SSR Level 2 with Big Knob/ JBR Motor Mounts / Cobb AP / Cobb TIP + SRI / GFB BPV / CS Race Pipe / Autotech Internals / Denso IVT-22 / JBR Throttle Body Gasket & Bypass / JBR EGR Block Off / JBR TIG / JBR RSB / GA
Apperance: DDM 6000k HID / JBR Mud Flaps / Windows Tinted
Tuning with Boost_Creep in Progress! Working towards Corn.
jdub0802 is offline   Reply With Quote
 Old 11-29-2012, 08:46 PM   #2
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
@Cobb Tuning; @Evan@COBB; @David@COBB;
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
jdub0802 (11-30-2012)
 Old 11-29-2012, 11:54 PM   #3
dantes5823's Avatar
Posts: 6,576   (View Stats)
Subbing. I upgraded to Windows 8 on my tablet that i use to tune and now my ap won't connect.
 Old 11-30-2012, 06:01 AM   #4
cshunter's Avatar
Posts: 1,312   (View Stats)
Same here, I believe it is just a driver issue for the AP.
Sent from StalknTalk
2013 CWP That's slow
Previous: MILTUNED E85 K04
 Old 11-30-2012, 06:17 AM   #5
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
Same here as well. Probably just a driver issue because as I understand it Win 8 isn't THAT much different from Win 7 underneath.
 Old 11-30-2012, 06:27 AM   #6
daafisch's Avatar
Groans: 58
Just found this on Cobb's forums. I'll give it a shot when I get home around 1.
https://forums.cobbtuning.com/forums...-x64-AP-Driver
The Following 2 Users Say Thank You to daafisch For This Useful Post:
dantes5823 (11-30-2012), Mase (11-30-2012)
 Old 11-30-2012, 06:31 AM   #7
jdub0802's Avatar
I tried this, and it does work for AP manager to install and the AP to be recognized as long as AP Manager is running. But when you close AP Manager the AP disconnects as well.
I am thinking that Cobb needs to update the Driver Install package in the ATR Install app the same way that they did for the AP Manager Install app.
cshunter likes this.
 Old 11-30-2012, 06:34 AM   #8
daafisch's Avatar
Groans: 58
So you're saying ATR works as long as APM is open? Good enough fix for me until Cobb releases a new version.
 Old 11-30-2012, 06:50 AM   #9
jdub0802's Avatar
No, even if APM is open ATR still won't see the AP as plugged in. I think what is happening is that the ATR installer is over writing the drivers that are installed by APM. Cause after you try to install ATR you have to go back and reinstall APM to get the drivers to work again.
 Old 11-30-2012, 06:51 AM   #10
daafisch's Avatar
Groans: 58
Makes sense
so wait, does this mean we can potentially use ATR on a tablet running Win8?
Don't see why not.
 Old 11-30-2012, 06:35 AM   #11
Must Have Teh 10's!
Downmented (12-03-2012)
 Old 11-30-2012, 09:46 AM   #12
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
FWIW-
I upgrade installed win8pro over win7, not as a new install.
-this was prior to any Cobb released win8 drivers being pushed, beta or otherwise
-both APM & ATR worked on first click with no changes
-the beta release of APM including the signed win8 driver installed & worked perfect
AFAIK, neither apm or atr will work on Win8 RT
I have an Asus Slate (Asus Eee Slate EP121) and touch as an interface is working well, selecting multiple cells & such is easy and works well. Also in Excel for logs.
340hp / 371tq
Pointless (11-30-2012), superskaterxes (11-30-2012)
 Old 11-30-2012, 09:48 AM   #13
Must Have Teh 10's!
FWIW-
SIIIIIIIICKKKKKKKKKKKK
can you post some screen shots? i would LOVE to see this in action haha
btw would a tablet be able to recognize a serial device with a USB>DB9 adapter?
Pointless (11-30-2012), rfinkle2 (12-03-2012)
 Old 11-30-2012, 09:59 AM   #14
Would you be bummed if I said it looks exactly the same as it does on Win7
cause, well, it does...
Mostly I like how easy it is to use in the car compared to a normal laptop, and the Dashboard functionality of ATR is total WIN. Enough so that I sold the DH
Edit to add- I'll start a new post on it with some screen shots such over the weekend. I've been meaning to do that just cause of the slate -vs- laptop thing.
340hp / 371tq
 Old 11-30-2012, 10:02 AM   #15
dantes5823's Avatar
I'm gonna give this driver thing a shot. Then go street tune my car lol.
The Following User Says Thank You to dantes5823 For This Useful Post:
 Old 11-30-2012, 10:14 AM   #16
metallemur's Avatar
Posts: 18   (View Stats)
metallemur has a brilliant futuremetallemur has a brilliant futuremetallemur has a brilliant futuremetallemur has a brilliant futuremetallemur has a brilliant futuremetallemur has a brilliant futuremetallemur has a brilliant futuremetallemur has a brilliant futuremetallemur has a brilliant futuremetallemur has a brilliant futuremetallemur has a brilliant future
I got it working with Access Port Manager 2.0.2.3 and Access Tuner Race 2442. I had to disable code signing for device drivers. If you remember when installing on Windows 7, Windows can't verify the publisher of this driver software and you had to click install this driver software anyways.
Try at your own discretion:
To get that prompt in Windows 8, I had to run these commands from an administrative command prompt (on the start screen type cmd, right click on it, and at the bottom of the screen select Run as administrator):
BCDEDIT /Set LoadOptions DDISABLE_INTEGRITY_CHECKS
BCDEDIT /Set TESTSIGNING ON
I also ran gpedit.msc (can type from start screen) and navigated to User Configuration | Administrative Templates | System | Driver Installation |
Double click on "Code signing for device drivers" and set it to Disabled.
Then I restarted my PC and was able to install Access Port manager and Access Race Tuner.
2011 black MS3 - Mods: Yes
metallemur is offline   Reply With Quote
The Following 8 Users Say Thank You to metallemur For This Useful Post:
alphasaur (11-30-2012), daafisch (11-30-2012), dantes5823 (11-30-2012), doubleflusher (11-30-2012), jdub0802 (11-30-2012), rfinkle2 (12-03-2012), superskaterxes (11-30-2012), TiGraySpeed6 (11-30-2012)
 Old 11-30-2012, 12:03 PM   #17
jdub0802's Avatar
I couldn't get this to work with Windows 8 Home. But it got me to thinking. After some serious google searching, there is a way to turn off Driver Signing checks temporarily in the home edition. It just only works until you restart the computer again. I just did this and was able to get ATR to install.
Here are the directions to temporarily disable the signed driver check.
To get started:
From the Metro Start Screen, open Settings (move your mouse to the bottom-right-corner of the screen and wait for the pop-out bar to appear, then click the Gear icon).
Click ‘More PC Settings’.
Click ‘General’.
Scroll down, and click ‘Restart now’ under ‘Advanced startup’.
Wait a bit.
Click ‘Troubleshoot’.
Click ‘Advanced Options’
Click ‘Windows Startup Settings’
Click Restart.
Profit!
When your computer restarts, select ‘Disable driver signature enforcement‘ from the list. (number 7) You can now load your modified driver.
Once you have done this you can click on the installer for ATR and it will proceed just like it did in Windows 7. A pop up box will ask you if you trust the driver and such, you will click install anyways. ATR will install just as planned.
Now restart you computer and everything should work. I now have ATR and APM working and my AP connecting to my laptop.
Thank you all for your help and ideas!
The Following 2 Users Say Thank You to jdub0802 For This Useful Post:
daafisch (12-03-2012), TiGraySpeed6 (11-30-2012)
 Old 11-30-2012, 10:25 AM   #18
dantes5823's Avatar
well ap connects now and i can use apm. Atr has been working since i upgraded and not clean installed it. Time to charge this bad boy and hit the streets.
 Old 12-03-2012, 08:35 AM   #19
Master of Hard Parts
Evan@COBB's Avatar
Posts: 240   (View Stats)
Evan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the world
Groaned at 8 Times in 2 Posts
So, from what I've been told, the current "solution" is to update APM to "Beta". This should allow you to connect the AP via ATR. You'll need to have APM and ATR open together.
Let me know if this fixes it.
Hard Parts Engineer - Mazda Expert Group
2009 MS3 Sport - Built Motor//Twinscroll 35R//Everything Else - SOLD!
2008 Toyota Tacoma TRD Sport 4x4 - Current Daily Until Next Turbo Car
Evan@COBB is offline   Reply With Quote
The Following User Says Thank You to Evan@COBB For This Useful Post:
 Old 12-03-2012, 08:49 AM   #20
With the Beta APM installed I'm able to use ATR in the car with full connectivity to the AP- dashboard gauges & logging, without APM open.
I've attached the only shot I've got just for giggles, I left it full res so you can see the APM icon at the bottom is not active, and the green connection box.
My car is going in today to see about getting the TC/VVT done before I cross 70K, so won't be able to get good screenshots of the working system till I get it back...
bheath3 likes this.
340hp / 371tq
 Old 12-03-2012, 11:46 AM   #21
Must Have Teh 10's!
what tablet is that?
 Old 12-03-2012, 12:18 PM   #22
That's the Asus Eee Slate EP121
340hp / 371tq
 Old 01-01-2013, 07:57 PM   #23
Amnesiac's Avatar
Posts: 315   (View Stats)
Amnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the world
Groaned at 6 Times in 4 Posts
I tried all the steps listed here and I still wasn't able to install ATR. I found this alternate method to install on the Cobb forums.
Reinstall the AP Manager and verify the AP can connect to it. Next, download 7zip and install it. Right click the ATR installer and open it with 7zip. Extract the license.ini and tunerRaceXXX.exe.
Create a directory C:\Program Files (x86)\AccessPORT\AccessTUNER Race
Put the license.ini file in C:\Program Files (x86)\AccessPORT\AccessTUNER Race.
Right click the tunerRaceXXXX.exe and open it with 7zip. Extract the contents to a temporary directory. Put the files not in any subdirectory in to C:\Program Files (x86)\AccessPORT\AccessTUNER Race.
Open the docs directory in the temp folder. Move the DLL files and DOCS directory in that docs directory to C:\Program Files (x86)\AccessPORT\AccessTUNER Race;
Open the plugins directory in the temp directory. You will find another plugins directory. Move it to C:\Program Files (x86)\AccessPORT\AccessTUNER Race.
Open the XML directory in the temp directory. You will find another XML directory. Move it to C:\Program Files (x86)\AccessPORT\AccessTUNER Race.
Create a shortcut on your desktop to the tunerRaceXX.exe file in C:\Program Files (x86)\AccessPORT\AccessTUNER Race.
After doing all that I was able to run ATR normally.
Amnesiac is offline   Reply With Quote
The Following User Says Thank You to Amnesiac For This Useful Post:
TiGraySpeed6 (01-01-2013)
 Old 01-01-2013, 08:04 PM   #24
so you essentially just extracted the program files to the needed locations and voila- instant ATR?
Handy. I had wondered if it wrote any files to the registry, but suspected not since it won't associate with PTM files, or open them without license errors.
340hp / 371tq
 Old 01-13-2013, 04:48 PM   #25
blackstar's Avatar
Posts: 523   (View Stats)
blackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the world
That is weird. I just bought my laptop with windows8 and I didn't have any problems. I hope you guys get it figured out!!
blackstar is offline   Reply With Quote
Official: Fisker Q&A sheds light, lots of light, on Karma problems, lots of Karma problems Haltech Automotive News 0 08-23-2012 02:50 PM
Help with problems from '10 MS3 yz007 2010 MS3 - Troubleshoot/Diagnostics 14 05-23-2012 06:20 PM
Problems Problems RUMBLEFISH MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 03-25-2012 02:12 PM
Problems with AC trdsw MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 07-03-2011 10:49 AM
Few problems need help MS6 KoleDeRacer MazdaSpeed 6 - Engine, Transmission & Driveline 8 01-03-2010 10:26 PM
Page generated in 0.46202 seconds with 30 queries
