> Cobb Tuning >
Cobb ATR Support
 Old 12-28-2010, 11:00 PM   #1
Caldazar's Avatar
Posts: 293   (View Stats)
Caldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond repute
Default calculated load oddness
Ok, now that we have the new ATR and the new firmware for the AP, I tried monitoring calculated load so as to more easily understand where and when things are happening.
However, when I was doing so, I noticed my calculated loads were alot higher than any numbers I have in my load tables.
I was hitting 1.7+ with half throttle at 2500rpm, whereas all my tables in that area are 1.4-1.7 under full throttle. I know, this could be normal as the ECU could be maxing out due to other factors. Still seems odd tho.
but when at WOT at higher rpms I was seeing over 2.2 and NONE of my tables are higher than 1.8-1.9, except for throttle cut and fuel cut. And most of the tables(gear based, TRL etc) are all in the 1.80-1.84 ranges max. 2.2-2.3 is quite a bit more.
Anyone else seeing this?
Bug with the AP?
or what do I need to do differently?
Also, my LTFT is usually between -1 and +3 tops, so I know the maf is at least decently calibrated.
06 Speed6, camber balljoints and alignment, HankookV12 Evos, Konigs, Corksport full intake system, PTP pump internals, Cobb Ap, Forge BPV. Daily driver
91 Talon TSi, 5spd AWD, GT3076R, fmic, 3" exhaust, Jackal EMS, methanol injection, JIC C/O and more. Looking at 10's
Caldazar is offline   Reply With Quote
 Old 05-16-2012, 07:29 AM   #2
Snotrocket's Avatar
Posts: 900   (View Stats)
bump... Trying to understand more about these tables.
2010 MS3 Black
395whp/386wtq
ATR AP load change? LiEast MazdaSpeed 3/6 - ECU Computer Tuning 6 10-17-2009 03:10 PM
Max Load C djuosnteisn
Cobb ATR Support
5 07-11-2009 10:57 PM
What is this load cut? gsrtype1 MazdaSpeed 3/6 - ECU Computer Tuning 90 06-23-2009 09:36 AM
Site won't load on my Mac MS6_Auburn_Fan Website Help/Feedback 7 06-21-2009 05:06 PM
LOAD!!! superskaterxes MazdaSpeed 3/6 - ECU Computer Tuning 12 01-14-2009 03:59 PM
Page generated in 0.24421 seconds with 21 queries
