> Cobb Tuning >
Cobb ATR Support
 Old 04-29-2009, 08:09 PM   #1
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
Default Closed Loop, Open Loop
I remember reading how this ECU was harder to deal with because of the closed loop.
I dont know much so educate me.
I see plenty of tables in here that according to the Cobb documentation can turn off closed loop.
Closed Loop-Exit delay
Closed Loop-Max load
Closed Loop Max throttle.
So if the closed loop is a problem...... why not turn it off??
Im half a bottle of wine in, so forgive me if I am over looking something simple??
Suspension:
 Old 04-29-2009, 08:28 PM   #2
dread's Avatar
Posts: 1,223   (View Stats)
dread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the world
for one your gas mileage will suck if you are always in open loop. I don't know why people hate closed loop so much. The car is adapting to the conditions.
[SIGPIC]http://i163.photobucket.com/albums/t318/dreadedhero/DSCN2058-2.jpg[/SIGPIC]
2007 ms3 sport black mica completely stock
dread is offline   Reply With Quote
 Old 04-30-2009, 07:58 AM   #3
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
ok...here's what I've gathered about closed/open loop:
1. It's there for emmissions/gas mileage.
2. Australians don't have the closed/open loop logic in the ECU (?)
3. One of our guys in Toronto prodded Christian to tune out his "phantom knock", and Christian replied that he can do so at the expense of perhaps 2mpg or something...I suspect it has to do with this.
It'd be cool to have a "hot" map that eliminates the closed/open loop transition, but without live map switching capabilities, I don't know how safe or a good idea it is.
-- Mario Andretti --
 Old 04-30-2009, 08:04 AM   #4
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
u cant just turn it off. you can only change the time it takes to transfer between O/CL
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
 Old 04-30-2009, 08:28 AM   #5
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
yesterday i messed with that and changed it from 30ms to 15ms and well that just got me a whole bunch of partial throttle knock as soon as my foot hit the gas pedal. changed it back and it went away.
 Old 04-30-2009, 10:24 PM   #6
The Kamikaze King!
Groans: 754
Not according to the cobb notes:
Closed Loop – Max Load A
Closed Loop – Max Load B
Closed Loop – Max Load C
Closed Loop – Max Load D
Closed Loop – Max Load E
Table Description – These tables are used to adjust if the ECU stays in closed-loop based on calculated
engine load values. A lower value in these tables will cause the ECU to enter into open-loop at lower
engine loads. A higher value will create a delay and will force the car to stay in closed-loop until higher
calculated engine load values are achieved. When calculated engine loads are above these values the car
MAY run in closed loop if other conditional parameters are met.
Closed Loop – Max Throttle A
Closed Loop – Max Throttle B
Closed Loop – Max Throttle C
Closed Loop – Max Throttle D
Closed Loop – Max Throttle E
Table Description – These tables are used to adjust if the ECU stays in closed-loop based on throttle
position values. A lower value in these tables will cause the ECU to enter into open-loop at lower throttle
values. A higher value will create a delay and will force the car to stay in closed-loop until higher throttle
position values are achieved. When throttle position values are above these values the car MAY run in
Suspension:
 Old 04-30-2009, 11:22 PM   #7
samsel450r's Avatar
Posts: 350   (View Stats)
samsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the world
so how do you turn off that thing that makes ur car cut out... like what cpe did with the fuel cut fix flash... sorry i forgot the actual term for it...
1999 Formula WS6 1 of 175 Made
Built 347 - Built 347, ARP everything, milled AFR 205's, PatG cam, ls6 Intake, MTI TB, Jethot LT's, True duals, 9inch rear 3.73's, built t56, NX kit W/NANO and more!
samsel450r is offline   Reply With Quote
 Old 05-17-2009, 08:59 AM   #8
Strizzo's Avatar
Posts: 148   (View Stats)
Strizzo is a glorious beacon of lightStrizzo is a glorious beacon of lightStrizzo is a glorious beacon of lightStrizzo is a glorious beacon of lightStrizzo is a glorious beacon of lightStrizzo is a glorious beacon of light
you'd have to adjust all of the boost and load limits above where they could expect to get to. for example, you could make the boost limits - fuel cut and boost limits - throttle close all above the range of the stock MAP sensor. the reason that cobb didn't want to do this was because its pretty dangerous on a car that doesn't have a boost gauge from the factory.
Strizzo is offline   Reply With Quote
 Old 05-19-2009, 11:28 PM   #9
Nuliaj's Avatar
Posts: 10   (View Stats)
Nuliaj is an unknown quantity at this point
I'm pretty sure we do, unless my Dashhawk is telling me something else?
3.25" ETS TMIC, Cobb Intake, Cobb TIP, HKS SSQ, BC Coilovers, CP-e Rear Engine Mount, CP-e Rear Diff Mount, CP-e Catted DP, Custom Catback, Denso ITV22
Nuliaj is offline   Reply With Quote
How ECUs Use Closed-Loop Controls to Make Fueling Corrections v1.02 94jedi MazdaSpeed 3/6 - ECU Computer Tuning 22 05-13-2014 08:45 PM
Closed Loop Tables SLS MS3
Cobb ATR Support
29 05-09-2011 10:06 AM
open and closed loop Doc MazdaSpeed 3/6 - ECU Computer Tuning 4 11-14-2008 03:04 PM
Closed and open loop booya620 MazdaSpeed 3/6 - ECU Computer Tuning 39 09-23-2008 03:06 PM
Open/Closed Loop Transition, Some New Observations superskaterxes MazdaSpeed 3/6 - ECU Computer Tuning 1 07-18-2008 11:35 AM
Page generated in 0.42597 seconds with 27 queries
