> Cobb Tuning >
Cobb ATR Support
 Old 05-17-2012, 07:07 PM   #1
mysleeper6's Avatar
Posts: 204   (View Stats)
mysleeper6 is the leader of the worldmysleeper6 is the leader of the worldmysleeper6 is the leader of the worldmysleeper6 is the leader of the worldmysleeper6 is the leader of the worldmysleeper6 is the leader of the worldmysleeper6 is the leader of the worldmysleeper6 is the leader of the worldmysleeper6 is the leader of the worldmysleeper6 is the leader of the worldmysleeper6 is the leader of the world
Default AP Manager stuck after update
I was going to head to the track tomorrow, so I wanted to do two things: look at the logs from the last time I was at the track, and set up LC based on that info. So, I plugged in my AP and it prompted me to update to new soft- or firm-ware, whatever. I went through the upload process and tried to connect my AP, but it won't get past the 'Export ECU Data' screen.
I had a previous problem with the AP that required sending it in to Cobb. Ever since I got it back, I've had to click past that screen, which tells me there is no stock data saved. I should have already contacted Cobb about that, but I still had full functionality, and I wasn't going stock out anytime soon. So now the same thing happens, but instead of just letting me click past it, now it gets stuck.
I e-mailed Cobb, and tried to get on their forums, but apparently they are having server issues. Anyone else having similar issues/problems with the update?
mysleeper6 is offline   Reply With Quote
 Old 05-17-2012, 07:27 PM   #2
radbrad's Avatar
Posts: 538   (View Stats)
I never do the updates until other users have confirmed that their not buggy.
I am not an early adapter. More of a follower.
GL
07Speed3
radbrad is offline   Reply With Quote
 Old 05-17-2012, 07:37 PM   #3
mysleeper6's Avatar
Lol, thanks. I figure I'll hear from Cobb as soon as they get their issues straight.
 Old 05-17-2012, 08:03 PM   #4
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Mine updated fine about an hour ago. Took about 15 minutes though.
 Old 05-17-2012, 08:05 PM   #5
Dmurray06's Avatar
Posts: 3,279   (View Stats)
Yea mine worked aswell...like above stated...takes awhile.
 Old 05-17-2012, 08:16 PM   #6
mysleeper6's Avatar
Just to clarify, mine did update. I figured it out because it displays the new version number. So, my problem is a functionality issue. I have no stock data because there was none on the AP when it came back from warranty service.
But, thanks for looking, lol.
 Old 05-21-2012, 08:38 AM   #7
mysleeper6's Avatar
UPDATE: Talked to Aaron at Cobb. He informed me that even if there is no stock tune listed among your maps, that Cobb places a stock tune kind of in the background. If you uninstall the AP, it will re-install their stock map. Then you can re-install the AP, with the map of your choice. I did this and have had no problems since. Thanks, Cobb! Great customer service!
Firmware update gets stuck mysleeper6
Cobb Access Port/Maps
10 03-29-2012 04:37 PM
AP manager USB 3.0 Jonny Quest MazdaSpeed 3/6 - ECU Computer Tuning 0 01-24-2012 08:58 PM
new AP manager 2.0 problems with x64 bit superskaterxes MazdaSpeed 3/6 - ECU Computer Tuning 1 12-02-2010 06:21 AM
AP Manager help seanmiller09 MazdaSpeed 3/6 - ECU Computer Tuning 4 07-07-2010 08:31 PM
AP manager help boyer MazdaSpeed 3/6 - ECU Computer Tuning 5 01-20-2010 09:33 AM
Page generated in 0.27754 seconds with 23 queries
