> Cobb Tuning >
Cobb ATR Support
 Old 07-25-2009, 07:37 PM   #1
senor blanco ms3's Avatar
Posts: 1,353   (View Stats)
senor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the world
Default Mysterious Cut
What's this and how can I fix it?
This is in 5th gear. I'm on the Stg 1+ SF 93 v104 map with SLS closed loop delay changes only.
At 18.3s, it feels like I hit a wall then power comes right back. Help!!
Added another log...4th gear 7-25-09. Cuts are in red.
2008.5 Crystal White Pearl MS3
A lot of mods
Check out my big turbo build!
senor blanco ms3 is offline   Reply With Quote
 Old 07-25-2009, 07:41 PM   #2
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
post an excel file thats hard to read lol
 Old 07-25-2009, 07:53 PM   #3
nevermind...stupid excel 2007
A lot of mods
 Old 07-25-2009, 08:13 PM   #4
SLS MS3's Avatar
Posts: 1,254   (View Stats)
SLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the world
Looks like boost cut, your WGDC drops to 0%. Do you normally knock like that? And damn your BATs are high.
2007 Sunlight Silver MS3
Graphite RX8 Rims · 235/40R18 Kumho SPTs
BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM
Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust
mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle
Stock is just plain, gay.
SLS MS3 is offline   Reply With Quote
 Old 07-25-2009, 08:24 PM   #5
I hardly watch KR. At this point, if it blows, I'll make an appointment with Mike.
A lot of mods
 Old 07-25-2009, 08:33 PM   #6
aaronc7's Avatar
Groans: 370
you both need meth
 Old 07-25-2009, 09:29 PM   #7
I don't do drugs sir
A lot of mods
 Old 07-25-2009, 10:23 PM   #8
evo2ms3's Avatar
Posts: 287   (View Stats)
evo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the world
That happened to me too during my etune. I thought it was boost cut, b/c it felt like it, but Christian said it was load cut. Not fun when going WOT in 5th.
//Cobb AccessPORT//Cobb E-Tune@20psi//SU TMIC//Mazdaspeed CAI//HKS SSQV//RPMC Turbo Inlet//CP-E HPFP//Corksport Race Pipe//Resonator Delete//Corksport MM Inserts//TWM STS//TWM Bushings//Denso ITV22//Prosport Premium Boost//RX-8 Wheels//Kumho Ecsta XS's 235-40//Valentine One//35% Tint//TRADED IN
WW EVO X GSR//SSS//Navi//Advan Racing RS 19x10//BC Racing Coilovers//Cobb AccessPORT//Perrin 3-port/AMS FMIC//UR UICP//Works Air Filter//UR Test Pipe//Trust PE II Exhaust//Defi Boost Gauge//APR Vortex Generator//Ralliart Tails//20% Tint//Valentine One//
evo2ms3 is offline   Reply With Quote
 Old 07-26-2009, 08:16 AM   #9
aaronc7's Avatar
Groans: 370
I used to get one short cut at 4500rpm in 5th gear, then it was totally fine after that all the way to 6000+. was load cut
 Old 07-26-2009, 01:19 PM   #10
Speedn3's Avatar
Posts: 642   (View Stats)
Speedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond repute
isn't there a table to address "load cut" in ATR?
Speedn3 is offline   Reply With Quote
 Old 07-29-2009, 06:36 PM   #11
speedo's Avatar
Posts: 37   (View Stats)
speedo has a spectacular aura aboutspeedo has a spectacular aura aboutspeedo has a spectacular aura about
The same thing happen to me, it's very wierd.
I have the Stg 1 + SF 91 v103 + FMIC with the map mods form Dread
Anyone know what happen
speedo is offline   Reply With Quote
 Old 07-29-2009, 06:48 PM   #12
aaronc7's Avatar
Groans: 370
i think he fixed this
 Old 07-29-2009, 11:07 PM   #13
JMEngineer's Avatar
Posts: 2,122   (View Stats)
Oops... For some reason I thought this thread was titled 'mysterious cat'
I'm way too tired to think about anything, so this is me subscribing so I can read this later.
-GTX2867R Coming Soon
 Old 08-01-2009, 01:34 AM   #14
Wenis Prinkle's Avatar
Posts: 176   (View Stats)
Wenis Prinkle has much to be proud ofWenis Prinkle has much to be proud ofWenis Prinkle has much to be proud ofWenis Prinkle has much to be proud ofWenis Prinkle has much to be proud ofWenis Prinkle has much to be proud ofWenis Prinkle has much to be proud ofWenis Prinkle has much to be proud ofWenis Prinkle has much to be proud of
Groaned at 143 Times in 33 Posts
first i would try changing the plugs to one step colder and closing the gap to half of what mazda recommends, all the extra cylinder pressures and fuel are causing what they call spark blow out. by running a tighter gap on the plugs the spark is more stable/powerful and consistent under heavy loads. try it, it works. it totally fixed my sputtering up top issues.
Wenis Prinkle is offline   Reply With Quote
 Old 08-01-2009, 08:30 AM   #15
speedo's Avatar
I already have the ITV22S denso plug and it make the same problem
i'm not sure it solved the problem
Spy Shots: Mysterious Chevy small car spied testing Haltech Automotive News 0 03-05-2009 04:50 PM
Spy Shots: Mysterious Hyundai sedan spotted undisguised Haltech Automotive News 0 02-16-2009 06:50 PM
Mansory builds mysterious Bugatti Veyron Vincero Haltech Automotive News 0 12-19-2008 06:10 PM
The mysterious FUEL CUT... right, not the ordinary one! Silo MazdaSpeed 3/6 - ECU Computer Tuning 22 12-07-2008 02:05 PM
Mysterious Forces Hack Pro-Tibet, Save Darfur, Falun Gong Sites Haltech Computers & Technology News 0 03-26-2008 08:30 AM
Page generated in 0.34318 seconds with 28 queries
