> Cobb Tuning >
Cobb ATR Support
  • 1 Post By TWOptSL0W
 Old 07-02-2012, 06:30 PM   #1
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
Default Rad fan adjustment
Is the rad fan adjustment working yet ????
@David@COBB
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
Last edited by jracer; 07-02-2012 at 06:30 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-03-2012, 08:03 AM   #2
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
it's hot out, & getting hotter. I don't really want to slice up the wires to install an aux switch if I don't have to....
340hp / 371tq
jracer (07-03-2012)
 Old 04-27-2013, 06:24 AM   #3
Mfinlay04's Avatar
Posts: 827   (View Stats)
@David@COBB
Bump for this request as well. Would love this feature as im having to run my ac/heater for 5-10 mins after parking my car to get the fan to kick on despite my coolant temps >210 degrees. If Cobb doesn't update this ill have to figure out a aux setup
2006 MS6 Titanium Grey
Tuned with
 Old 04-27-2013, 06:44 AM   #4
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
Better work on the aux controller then. Last time I checked, Cobb said the fan isn't cot rolled by the ecu, there is a separate controller
Mfinlay04 likes this.
The Following User Says Thank You to TWOptSL0W For This Useful Post:
Mfinlay04 (04-27-2013)
 Old 04-27-2013, 06:59 AM   #5
Mfinlay04's Avatar
FML this man. I lull probably just tap into the power wire and hook up a switch in the cabin to remotely turn it on. The coolant temps are normally good when I'm driving but once i park it forget about it...
Tuned with
 Old 04-27-2013, 09:14 PM   #6
TWOptSL0W's Avatar
Groans: 125
HOW-TO: Auxiliary Fan controller
read this good sir
 Old 04-27-2013, 10:57 PM   #7
Mfinlay04's Avatar
Yeah plan on doing this as well as my brakes this summer when i get a little extra money saved up. Just paid off my move and working on a few other things so extras are on back order right now. Running the heater and revving my car @1.5k when i stop for about 2-5 mins depending on how hard I've ran it works pretty well right now. Inconvenient but works
Tuned with
Rad fan adjustment in ATR ?? jracer Cobb Tuning 23 11-06-2011 09:29 AM
Brake adjustment mazdaspeeding MazdaSpeed 3/6 - Suspension & Brakes 48 10-20-2011 02:28 PM
Clutch adjustment LiEast MazdaSpeed 3 - Engine, Transmission & Driveline 7 04-29-2011 11:42 AM
Window adjustment turboneil MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 07-12-2010 12:53 AM
BOV adjustment help Nazarite Mazdaspeed3/6 General Discussion 10 03-23-2009 08:32 AM
Page generated in 0.29172 seconds with 23 queries
