> Cobb Tuning >
Cobb ATR Support
 Old 02-09-2016, 12:00 PM   #1
NCspecV81's Avatar
Posts: 2,867   (View Stats)
Default Tables beyond 7000rpm
We ever going to have access to tables that read beyond 7000rpms?
2013 CWP and Stock
Easter Bunny (02-09-2016), Mauro_Penguin (02-10-2016)
 Old 02-09-2016, 12:04 PM   #2
Yup. Just have to make the switch over to VT
The Following 4 Users Say Thank You to Mazdazilla6 For This Useful Post:
Code Monkey (02-09-2016), Easter Bunny (02-09-2016), NCspecV81 (02-09-2016), SpeedRebirth (02-10-2016)
 Old 02-09-2016, 03:47 PM   #3
NCspecV81's Avatar
Figured that was going to be the end result
2013 CWP and Stock
 Old 02-09-2016, 03:57 PM   #4
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
@Cobb Tuning;
 Old 02-09-2016, 04:19 PM   #5
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
The 1 reason why this will never be assessed at cobb... because only a handful of people will or could actually use the extra rpm.
860whp/677wtq
2.7 V6 Ecoboost
 Old 02-09-2016, 06:41 PM   #6
Anyone with a big turbo could potentially use it.
 Old 02-09-2016, 06:47 PM   #7
PapaSmurf's Avatar
True, but I don't think anyone will or everyone would be screaming for it.
860whp/677wtq
2.7 V6 Ecoboost
 Old 02-09-2016, 06:52 PM   #8
Big turbo? I would rev the BNR to 8k if I could (and if I had a built block).
Easter Bunny (02-09-2016), Mauro_Penguin (02-10-2016), Mazdazilla6 (02-09-2016)
 Old 02-10-2016, 10:03 AM   #9
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
I don't know man... Unless you have a really big turbo and lots of aux fuelling the power kind of starts to drop around 6.5k rpm, give or take.
However, on stock block I strongly advise against revving more than 6700, simply because the factory pistons will not be able to take all that heat. It's possible that some meth spray to take away some of that heat and extend the life of the pistons, but they're on borrowed time really, and since on stock block probably the turbo is not that big either so not making enough power to justify that.
So i'm using VT, but I just outlined the logic behind Cobb not investing any R&D time into extending those tables given the situation if the majority of the modded 2.3DISI-fTw's (stock it small big turbo, flow mods and bolt-ons, eventually some shy aux fuelling implementation).
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
Code Monkey (02-10-2016)
 Old 02-10-2016, 10:17 AM   #10
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Sometimes it's not about the power up there, it's just to avoid the time wasted shifting. At the strip it might just be one shift, but autocross or road racing it's a shift AND downshift avoided, time and time again...it adds up quickly.
I've been turning 7500rpm with the k04 for two seasons because of that. The extra speed in gear is totally worth it.
I dumped Cobb for VT. No regrets here.
-06 MS6
-Corn fed 07 MS3 - Sold
The Following 11 Users Say Thank You to phate For This Useful Post:
Code Monkey (02-10-2016), DingoDave (02-13-2016), djern (06-23-2016), Easter Bunny (02-11-2016), g00s3y (02-11-2016), Mauro_Penguin (02-10-2016), Mazdazilla6 (02-10-2016), mituc (02-10-2016), NCspecV81 (02-10-2016), SpeedRebirth (02-10-2016), WetzMS3 (02-10-2016)
 Old 02-10-2016, 10:35 AM   #11
NCspecV81's Avatar
The extra speed is definitely worth it! A 25.71-26in tire with PU gearing has my 3rd gear at approximately 100mph.
2013 CWP and Stock
DBW Tables mrmonk7663 2010 MS3 - ECU Computer Tuning 25 07-14-2014 08:44 AM
Can we get tables? mdd5148 Website Help/Feedback 2 03-09-2012 02:28 PM
VVT Tables Caldazar
Cobb ATR Support
33 12-29-2010 08:23 PM
Any risk when setting throttle req load tables high to force boost by gear tables? 08Anamoly
Cobb ATR Support
5 03-29-2010 08:52 PM
APP Tables the Way They Should Be :D LBV
Cobb ATR Support
37 09-09-2009 08:57 AM
Page generated in 0.33655 seconds with 27 queries
