> Cobb Tuning >
Cobb ATR Support
 Old 05-22-2009, 09:28 AM   #1
dread's Avatar
Posts: 1,223   (View Stats)
dread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the worlddread is the leader of the world
Default Using the App translation tables for smooth powerful results
I posted these results in the jerky throttle thread, but decided to make a new thread at the requests of other members. I used the app translation in combination with the throttle req. load tables to get a smooth and powerful map. The results are awesome. Very responsive and linear thottle, while not being too sensitive. I think the lag problem caused by linear load tables is best fixed with the app tables. The stock app tables are set up to work with the stock throttle req load tables that ramp up load quickly. That being said the app table I posted above is made to work with the load table I posted below. I used the same app table for all gears.
App translation to be put in all gear app tables other than neutral.
Code:
0.00	0.32	1.28	2.85	4.52	6.18	7.85	9.51	11.37	13.04	14.83	16.63	18.42	20.22	22.01	23.81	28.30	32.78	37.27	41.76	46.25	50.74	55.22	59.71	65.69	72.41	79.12	82.48	85.83	92.55	100.00
Throttle req. load data for tables a and c.
Code:
0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00
0.64	0.46	0.34	0.21	0.21	0.21	0.21	0.21	0.21	0.21	0.21	0.21	0.21	0.21	0.21
0.67	0.68	0.61	0.43	0.43	0.43	0.43	0.43	0.43	0.43	0.43	0.43	0.43	0.43	0.43
0.68	0.77	0.80	0.65	0.65	0.65	0.65	0.65	0.65	0.65	0.65	0.65	0.65	0.65	0.65
0.69	0.80	0.90	0.87	0.87	0.87	0.87	0.87	0.87	0.87	0.87	0.87	0.87	0.87	0.87
0.69	0.81	0.94	1.09	1.09	1.09	1.09	1.09	1.09	1.09	1.09	1.09	1.09	1.09	1.09
0.70	0.82	0.95	1.31	1.31	1.31	1.31	1.31	1.31	1.31	1.31	1.31	1.31	1.31	1.31
0.70	0.83	0.96	1.52	1.52	1.52	1.52	1.52	1.52	1.52	1.52	1.52	1.52	1.52	1.52
0.70	0.82	0.97	1.70	1.70	1.70	1.70	1.70	1.70	1.70	1.70	1.70	1.70	1.70	1.70
0.70	0.83	0.97	1.88	1.88	1.88	1.88	1.88	1.88	1.88	1.88	1.88	1.88	1.88	1.88
0.70	0.83	0.97	2.06	2.06	2.06	2.06	2.06	2.06	2.06	2.06	2.06	2.06	2.06	2.06
0.70	0.83	0.97	2.20	2.20	2.20	2.20	2.20	2.20	2.20	2.20	2.20	2.20	2.20	2.20
[SIGPIC]http://i163.photobucket.com/albums/t318/dreadedhero/DSCN2058-2.jpg[/SIGPIC]
2007 ms3 sport black mica completely stock
dread is offline   Reply With Quote
The Following 10 Users Say Thank You to dread For This Useful Post:
94jedi (05-29-2009), Arrowpoint (05-24-2009), bioevolve (05-22-2009), Fobio (05-22-2009), jahman (05-22-2009), justint5387 (01-27-2011), kgb (05-22-2009), Nliiitend1 (07-15-2009), RichB (10-14-2009), Smoker6 (05-22-2009)
 Old 05-22-2009, 09:36 AM   #2
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
I will give this a go this wknd.
-- Mario Andretti --
 Old 05-22-2009, 02:08 PM   #3
smakdown61's Avatar
Posts: 1,069   (View Stats)
smakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the world
Groaned at 37 Times in 23 Posts
Just tried it out. Feels great so far. Very good throttle response like the ots maps but much much more linear.
smakdown61 is offline   Reply With Quote
 Old 05-22-2009, 02:19 PM   #4
jahman's Avatar
Posts: 903   (View Stats)
jahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the world
Groaned at 9 Times in 7 Posts
I knew you'd like the app tables. I havent messed around with them too much but it looks like you have.
I'll be trying this on my next map.
07 Mazdaspeed3
jahman is offline   Reply With Quote
 Old 05-22-2009, 06:35 PM   #5
dread's Avatar
nice glad you like it smak. I love the way the car drives. Now I'll be done once I finish tuning out my high rpm knock
 Old 05-22-2009, 06:37 PM   #6
kgb
kgb's Avatar
Posts: 808   (View Stats)
kgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the world
Groans: 88
I'll try this too tonight and see how if works....must say your tweaks have really helped.
FAST & FURIOUS... MazdaSpeed CBE - CNT Downpipe (diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK 1-Step Colder Plugs
WHEEL HOP...........Cp-e RMM (75) - Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - CS Pads (Rear) - JBR Rear Cambers - JBR 5mm Wheel Spacers - JBR Rear Sway Bar - NATOR Clutch By-Pass - Nitto NT05s
AL GORE...............EGR Block, Valve Delete - JBR TB Coolant Bypass - NATOR Air Reroute to SRI
MMMM BRAINS.....Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated[SIGPIC][/SIGPIC] - DSC LED Reroute
JAM SESSION........US Amps (in Series w/ Stock Amp) using
OEM Speakers for Mids & Highs Only - Bazooka 8" Amplified (Got my trunk back)
RICE.................. NATOR Interior Red LEDs - NATOR Engine Blue LEDs - Advanced Film Solutions Tint - NATOR Gun Metal Stock Wheels - Ventshade Deflectors
- Acne Rear Bumper LED Reflectors
kgb is offline   Reply With Quote
 Old 05-22-2009, 06:38 PM   #7
GQ_WhiteMS3's Avatar
Posts: 658   (View Stats)
GQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the world
Applied these to my map to be flashed tonite, and then after some more logs I'll have to tune out my WOT knock.
GQ_WhiteMS3 is offline   Reply With Quote
 Old 05-22-2009, 06:50 PM   #8
dread's Avatar
I already cut my knock in half by adding fuel, and lowering load. The problem I am having is my boost is too high above 5k rpm and my turbo is probably a flame thrower. My next map is using the boost throttle close tables to limit boost up top. I am just hoping the throttle only closes slightly and doesn't slam shut.
 Old 05-22-2009, 09:32 PM   #9
Driver
Fobio's Avatar
Groans: 44
definitely brings the wild child back...just enough that I'll keep these changes for the dyno and track map for the next 2 wknds...for the commute, I may go back to your original throttle fixes, so I have a little bit more pedal play to vent frustration on the commute...thanks!
 Old 05-23-2009, 07:26 AM   #10
Arrowpoint's Avatar
Posts: 364   (View Stats)
Arrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the world
Dread, thanks for all the info you are generously sharing with the forum. You've always impressed me with the amount of time and effort you put in not just for yourself but for the others on this forum. I just wanted to point that out.
I'd like so see a complete map with all your changes. According to what I've read and from my testing it seems to hold true that whichever values in the Throttle req load tables and the gear specific load tables is lower are the values that get used. Are the values in your gear specific tables set high to force the ecu to use the throttle req a and c tables. I am begining to think that posting the values in one of these tables without the values in the other is useless since depending on what those values are the ecu may be switching back and forth between these three tables.
I know it's a pain in the ass but if you could post the map or better still the values in all your tables? It would be extremely helpfull.
I can see dissadvantages to the pieces parts method of info exchange we are useing now. This full disclosure is going to become more inportant as we learn more widely how all the tables relate to each other.
Arrowpoint is offline   Reply With Quote
The Following User Says Thank You to Arrowpoint For This Useful Post:
94jedi (05-29-2009)
 Old 05-23-2009, 07:45 AM   #11
dread's Avatar
I still use the gear based load tables but those don't come into affect until higher throttle requests. I like the gear based tuning. I am not sure how to upload maps I keep getting errors. I will post them up if someone tells me how.
 Old 05-23-2009, 07:58 AM   #12
dread's Avatar
Ok I figured it out. here is the map stage 1+93 octane cali spec with dread's special sauce. Nevermind the forum won't let me attach the same map in two places. It is 107h in the tuning out knock thread.
The Following User Says Thank You to dread For This Useful Post:
 Old 05-24-2009, 08:28 AM   #13
fostersafb's Avatar
Posts: 38   (View Stats)
fostersafb has a spectacular aura aboutfostersafb has a spectacular aura aboutfostersafb has a spectacular aura about
dread, can you post your full map in the same format (code) you posted the TRL and APP translation tables at the beginning of this thread? Unless we have the same year, etc as your car ATR wont open the file.
Interested to try the APP translation changes you made.
Thanks.
fostersafb is offline   Reply With Quote
 Old 05-24-2009, 08:51 AM   #14
Arrowpoint's Avatar
+1^^^ I know it's a pain but if you can spare the time it would be great. I haven't tried yet but I don't think my ATR Fed will load the Cali maps.
 Old 05-23-2009, 12:27 PM   #15
jahman's Avatar
If you use dreads map, be very careful and watch your logs closely.
Its not that dreads a bad guy...its just his load values are close to 2.00 in some places. His car and mine have the same exact mods, yet, I'm making the same boost as he is with values in the 1.75 range. If I used 2.00...i'd boost 27 psi and knock the hubble telescope out of orbit with one (or more) of my rods.
My point being...all of our cars act differently. This is why the OTS maps were so unsuccessful.
Be careful with this software, itd be very easy to start getting careless as some of us become more confident with its use.
07 Mazdaspeed3
 Old 05-23-2009, 12:49 PM   #16
dread's Avatar
Yes I do not recommend copying my maps onto your ecu. My load values are pretty high for some reason. I actually lowered them from the custom map christian gave me. I think my car is a freak, I out dyno'd stage 2+ guys on the 102 maps.
 Old 05-24-2009, 08:10 AM   #17
Arrowpoint's Avatar
I've been slowly increasing the gear load tables and am peakiing in the 190's. The car is pulling harder than it ever has. Boost is peaking at 20psi and tapering nicely to 17psi.
I don't want to use the map. I'm in a Fed model. I want to load the map into ATR and compare it to stock and the map I'm running now.
I was running peakes in the 180's and getting LTFT's of -2,0,1,2 but when I got into the 190's LTFT's went to 2,4,8,10 so now I guess I'll either reduce load values or go back to the MAF.
 Old 05-24-2009, 08:54 AM   #18
dread's Avatar
arrow, load doesn't affect ltft's, give them more time to settle
foster, I am not sure what you are looking for, everything you need is in the first post. All the other changes I have made were to tune out the knock. Just copy the app trans data into the table for each gear.
 Old 05-24-2009, 11:23 AM   #19
Driver
Fobio's Avatar
Groans: 44
there may be some confusion is terminology here...
dread posted values for a few tables. A collection of all the tables makes a map. You should just apply dread's values/tables to your corresponding tables in your own map.
My car spikes to 22 psi...holds mid 18's...it's been this way whether I was running dread's values or not.
 Old 05-27-2009, 10:03 PM   #20
Speedn3's Avatar
Posts: 642   (View Stats)
Speedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond repute
Code:
Code:
Thanks for sharing dread.
Have you or anyone else datalogged any WOT runs with these changes?
If so, did you notice any changes with WOT KR?
Speedn3 is offline   Reply With Quote
 Old 05-27-2009, 10:08 PM   #21
jahman's Avatar
This doesnt affect WOT KR. Infact at WOT the ECU ignores the req load tables and goes by load by gear.
APP tables really only have to do with the throttle response.
07 Mazdaspeed3
The Following User Says Thank You to jahman For This Useful Post:
Speedn3 (05-27-2009)
 Old 05-27-2009, 10:09 PM   #22
dread's Avatar
ha beat me to it.
 Old 06-02-2009, 07:01 PM   #23
Trader's Avatar
Posts: 90   (View Stats)
Trader is a splendid one to beholdTrader is a splendid one to beholdTrader is a splendid one to beholdTrader is a splendid one to beholdTrader is a splendid one to beholdTrader is a splendid one to beholdTrader is a splendid one to behold
Groaned at 5 Times in 1 Post
These changes feel great. I did notice that they changed my LTFT though the high LTFT went from +3 to +8.
Trader is offline   Reply With Quote
 Old 06-02-2009, 10:46 PM   #24
dread's Avatar
These changes have no effect on ltft's. Something else is affecting them or your map needs more time to settle.
 Old 05-27-2009, 10:08 PM   #25
dread's Avatar
I have done a ton of logs, this doesn't affect WOT load and does not change KR.
 Old 06-02-2009, 08:35 PM   #26
Speedn3's Avatar
Since I've did the throttle smoothing I have not seen much if any part throttle kr.
 Old 07-20-2009, 02:22 PM   #27
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Has anyone done any dyno testing to see if/how this might affect the torque/horsepower curves?
 Old 10-14-2009, 07:12 PM   #28
RichB's Avatar
Posts: 510   (View Stats)
RichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the world
I just made these changes and went out for a quick spin and love it. My WOT power feels about the same but the part throttle drivability is so predictable now. I love It! Thanks for all of your research Dread. I can't wait to see how my drive in to work feels tomorrow. Once I get my MAF cal where I want it, my req load tables per gear are next.
2007 Cosmic Blue Mazdaspeed 3 GT
RichB is offline   Reply With Quote
 Old 08-12-2013, 10:00 PM   #29
Mini Franki's Avatar
Posts: 37   (View Stats)
Mini Franki will become famous soon enough
Its supposed to work on 2e gen?
Because my APP table have only 20 values but the fix here have 31 values
Im using the 1st dread's fix(without app mod) but if he said, linear throttle reponse make lag, i really want to try this one. But if i change APP, that will affect something else?
I try to get back my pedal feeling when i had hypertech! A linear aggressive pedal response
Mini Franki is offline   Reply With Quote
 Old 08-16-2013, 07:34 AM   #30
bump
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f418/using-app-translation-tables-smooth-powerful-results-28444/
MS3/ATR: Smooth Throttle Fixes (May 23, 2009) - TorontoMazda3 This thread Refback 05-23-2009 07:56 AM
Boost Control for Smooth Response fjames
Cobb ATR Support
51 10-28-2011 05:00 AM
Smooth throttle test thejake
Cobb ATR Support
15 05-17-2009 01:08 PM
Smooth out driving / shifting KayWhy MazdaSpeed 3 - Engine, Transmission & Driveline 24 04-15-2009 01:18 PM
Pontiac G8 GT: No longer most powerful car under $30K Haltech Automotive News 0 06-18-2008 02:20 PM
Rumormill: Audi considering more powerful RS6 Avant Haltech Automotive News 0 05-15-2008 01:50 PM
Page generated in 0.48667 seconds with 32 queries
