> 2010 MS3 - Turbo Induction
Like Tree6Likes
  • 1 Post By whatsabrooklyn
  • 2 Post By Vansquish
  • 1 Post By Bertospeed3
  • 1 Post By Jeff23spl
 Old 08-03-2019, 11:23 AM   #1
Noah99's Avatar
Posts: 32   (View Stats)
Noah99 will become famous soon enoughNoah99 will become famous soon enough
Groaned at 8 Times in 4 Posts
Default Is 18.1 psi boost, stock?
Just used Versa Tuner for the first time and with a couple hard pulls I got 18.1 psi boost with 1748 fuel rail pressure. Just bought the car and I want to make sure that 18.1 psi is okay. Looking forward to your replies.
PS- I'm looking to change the intake to corksport and also a corksport HPFP. I just want to make sure everything's fine and dandy before hand.
Noah99 is offline   Reply With Quote
 Old 08-03-2019, 02:37 PM   #2
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
18 stock isn't a disaster outside of low RPM under heavy load, bad AFR, high BAT, knock, etc. a datalog would tell a better story.
94 M
MS6
IS350
The Following User Says Thank You to Pu Manchu For This Useful Post:
Noah99 (08-04-2019)
 Old 08-03-2019, 06:19 PM   #3
MSMS3's Avatar
Posts: 2,830   (View Stats)
If AFR is not lean, pump pressure stays no lower than 1600, and the boost tapers to 15+/- at Redline, I’d not go crazy. But stock boost should be 15.5 or thereabouts max.
This makes me suspect the car has previously been modified. An aftermarket downpipe will raise boost to 18 psi even on stock tune. And, it is not safe without a compatible tune.
Noah99 (08-04-2019)
 Old 08-03-2019, 06:52 PM   #4
Noah99's Avatar
Thank you for the respectful replies.
To my knowledge the car has zero modifications, the 2nd owner gladly boasted about that before I purchased the car.
Also I stupidly didn't monitor the air/fuel ratio.
I'll do another run soon and I'll post the log here, since I have no idea what these numbers mean.
Also, What does BAT mean?
 Old 08-04-2019, 06:24 AM   #5
Noah99's Avatar
Attached is a csv. with a couple hard pulls. Looking forward to reading your replies!
Min/Max Boost (PSI) = -12.4/17.5
Min/Max Actual equivalence AFR= 0.629/2.000
Min/Max Fuel Rail Pressure= 403/1736
Min/Max Engine RPM= 701/6250
Min/Max Desired fuel rail pressure= 292/1669
Min/Max Desired equivalence AFR= 0.631/1.009
 Old 08-04-2019, 06:26 AM   #6
Noah99's Avatar
Also here's a csv. of my car idling afterwards.
 Old 08-04-2019, 12:16 PM   #7
whatsabrooklyn's Avatar
Posts: 147   (View Stats)
whatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud of
hey, this may help a bit
Ultimate Guide to Parameter Monitoring?
BAT mean boost air temperature.
this could be a decent reference for ya
A Noob's Guide to Tuning Acronyms
also try to do pulls over 3k rpm for engine safety (didn't read log so maybe you did)
Noah99 likes this.
Last edited by whatsabrooklyn; 08-04-2019 at 12:18 PM. Reason: typed boosted when i should have typed boost, i wrote an incorrect definition
whatsabrooklyn is offline   Reply With Quote
 Old 08-04-2019, 01:04 PM   #8
Police - Grammarhead
Vansquish's Avatar
OK. Let's chat about datalogs. Imagine that you're where we are. You've been asked to remotely help figure out things that might be going on with someone's car. Datalogs are obviously going to help. The question is: what kind of datalogs?
Well, we need logs that show whatever problem that you're trying to have us diagnose. That means, if you're having problems under boost, we need datalogs showing behavior of the car under boost. If you're having problems under idle conditions, then we need to see idle behavior of your car.
We all have limited time though, and asking someone to sift through data from a log that is more than 2400 lines long is...unrealistic and difficult. It's also frustrating for those of us inclined to help you out.
Here's what I would recommend:
1. If you're having problems or concerns with your car's behavior under boost, take a standard WOT log. That means, put your car in either third or fourth gear, start datalogging slightly below 3000rpm, push the pedal to the floor and log all the way past at least 6000rpm. Then stop the log.
2. If you're having problems or concerns with your car's behavior at idle, take an idle log that replicates whatever issue that you're concerned about. It doesn't need to be thousands of lines long.
In short, hone the logs so that they show what you want to show us, not everything under the sun and then some.
Furthermore, when you datalog, you should make sure to capture at least the following parameters, but DO NOT include desired fuel pressure and desired AFR.
Accel. Pedal Pos. (%)
Actual AFR (AFR)
Boost (PSI)
Boost Air Temp. (° F)
Calculated Load (Load)
Coolant Temp. (° F)
HPFP Act. Press. (PSI)
Inj. Duty Cycle (%)
Intake Temp. (° F)
Intake Valve Adv. (°)
Knock Retard (°)
Long Term FT (%)
MAF Voltage (V)
Mass Airflow (g/s)
RPM (RPM)
Short Term FT (%)
Spark Adv. (°)
Throttle Position (%)
Vehicle Speed (mph)
Wastegate Duty (%)
Jeff23spl and Noah99 like this.
MSMS3 (08-04-2019)
 Old 08-05-2019, 06:17 PM   #9
Noah99's Avatar
Thank you for the correction Vanquish and whatsabrooklyn. Here's a new log, recorded from 3rd gear at about 2800rpm to 6300rpm. I tried to add everything I could from your list Vanquish, but VersaTuner wouldn't allow me to add more than 16 data points.
I'm looking forward to your replies and criticisms!
P.S. My primary interest is the AFR. I suspect my car is running lean. (Spark plugs had a white haze)
 Old 08-08-2019, 12:54 PM   #10
Noah99's Avatar
I'm sort of lost here. Does anyone know how to read the air fuel ratio? If not, who should I send this file to?
 Old 08-08-2019, 01:39 PM   #11
Bertospeed3's Avatar
Posts: 149   (View Stats)
Bertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant future
the way your afr is being logged requires a little math for me to be familiar with. Take your afr values and multiply it by stoich afr (14.8?).
So in line 30 of your log, your afr is showing 0.865
0.865 x 14.8 = 12.80 AFR - this is leaner than i would be comfortable with. You would like something starting with 11.xx
It starts to get more rich as your boost tapers down but i'm not seeing any red flags tho.
Granted, i'd wait for people who know more than me to chime in lol just figured id give me two cents
Noah99 likes this.
2010 MS3 - Tuned By Nishan
Autotech Fuel Pump Internals
OBX R Custom Exhaust
Cobb SF Intake & TIH w. Blitz Filter
CP-e TMIC
Corksport Dual VTA BPV
JBR 88 Duro RMM
Bertospeed3 is offline   Reply With Quote
 Old 08-08-2019, 02:39 PM   #12
Jeff23spl's Avatar
Posts: 2,237   (View Stats)
isn't there a place to switch units from metric to imperial. Yours is in lamba.
If you are limited to 16, i would pic those:
Actual AFR (AFR)
Boost (PSI)
Coolant Temp. (° F)
Inj. Duty Cycle (%)
Knock Retard (°)
Mass Airflow (g/s)
RPM (RPM)
Short Term FT (%)
Long Term FT (%)
Spark Adv. (°)
Wastegate Duty (%)
Discarded ones:
Vehicle Speed (mph) (Probably needed for virtual dyno but...)
Intake Temp. (° F) (you can just note the ambiant temp yourself)
Intake Valve Adv. (°) (higher level of tuning...)
MAF Voltage (V) (Needed with flow when you do a maf cal but flow is enough for diagnosis)
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 08-08-2019, 02:48 PM   #13
Jeff23spl's Avatar
here is it with correction, i used lambda 1=14.7
Noah99 likes this.
Wife drive 2010 CX7
The Following 2 Users Say Thank You to Jeff23spl For This Useful Post:
Bertospeed3 (08-08-2019), Vansquish (08-08-2019)
 Old 08-09-2019, 05:27 PM   #14
Noah99's Avatar
Thank you for the log correction Jeff! I'm mostly interested in the AFR since it seems my car is running on higher than stock boost. BTW, do you still want me to log another run with the 16 metrics you posted above?
Also, how can we tell what's a dangerous or inefficient AFR?
I know my car has an aftermarket hybrid TurboSmart BPV/BOV, (from the previous owner), but I doubt that effects the boost levels.
 Old 08-11-2019, 03:56 PM   #15
Jeff23spl's Avatar
from the log it isn't that much high but i don't know exactly what would it be stock reading.
when i look at your air flow isn't that high,,,
the 50/50 valve is just half bad but nothing to rise boost, it just make it rich between shifts.
Noah99 likes this.
Wife drive 2010 CX7
Stock boost? jeabou MazdaSpeed 3/6 - Troubleshoot/Diagnostics 19 09-09-2009 06:01 PM
Page generated in 0.35949 seconds with 27 queries
